1 Topology and placement of DDR3 memory chips
' A) ?. h5 D/ A' ~ DDR3 chips should put at the suitable place for fly-by topology layout and close to the7 `5 \* L& \2 o; o) `) e5 s
controller chips.
, H& j! F6 V$ S5 |0 W 2 Trace routing guide – Clock4 w0 b4 l( p% ]# W$ G
Route the CLK/CLK# signals as a differential pair. Use 5/5/5mil to control the
8 X# p4 e. x4 y9 q" r) ?, k: { differential impedance to 100ohm.2 P) g( W* g- N6 {4 Q' D' Y
Route the CLK/CLK# pair as “Fly-by” type to make the traces symmetrical.
8 Z! o+ d7 A1 V/ K | Place the CLK/CLK# termination at the end of Fly-by type connect point.- d7 Y$ X y# o. B6 o% r" f
The two branches of Fly-by topology should be controlled as balance as6 A9 W; T. t& A% \* c" |
possible and the mismatch should be less than 5ps.# h' I& n$ Z3 n, H
3 Trace routing guide --DQS/DQSN/DQ/DQM& U+ K: e3 H! s+ v3 B
DQS, DQSN,$ M5 D7 V7 R9 k, z2 r" m
DQ & DQM, A6 i! ]* i6 `& [
The delay mismatch of intra groups should be less than 5 ps.0 c' E- U/ q$ e
The delay mismatch of inter groups should be less than 15 ps.2 _" K: I" K- X3 m4 w" T- D: ^# G8 W' p
The same group should have equal numbers and either “NO” or “two” via
5 [) V& O" S* }' n6 u& ^ DQS/DQSN Rout the DQS/DQSN as differential pair(5/5/5) and as short as possible
+ |: z0 j" { |9 u) y DQ/DQM Rout the DQ/DQM traces in 5mil wide and as short as possible.2 I4 t5 N- d5 L
4 Trace routing guide --Command/Address
& e4 `2 o+ m/ y) O+ }; ]5 ~ Route the CMD&ADDR signals in 5mil width to control impedance.) ^0 T% [- U+ s# p2 \" m' m# `
Route the CMD&ADDR signals as similar “Fly-by” topology to make the trace) F% U- P& |5 W7 i- d
symmetrical.
' A3 x3 U9 v B5 W' I' W The termination resistor should be placed ½” to 1” beyond the primary split in a% m+ v1 i M7 O& ?1 E7 A' r
tee configuration or beyond the final DRAM in a daisy chain configuration.6 o) D3 D+ Y8 |3 @* z0 S, S) x
100ohm pull up and pull down.) L8 y, A7 v5 |( W
Route serpentine traces to control the CMD&ADDR group mismatch within
/ }/ J0 e' o i% h4 e r9 l 70ps.(include substrate delay data)% u: x, k) {" M0 [# f3 P7 q
To control data crosstalk, the gap between traces should be at least 15mil! E, z: k. Q. z; e* Z) q
Each via delay is 10.5ps for the 2-layer stack up board.
2 Y9 A; f& ^% M 3 / 5( F6 \/ H: e( \
5 Layout guide --Power/GND Plane and decoupling cap
; o6 N& L3 g3 s& l For power, ground and decoupling capacitors, several issues need special attention/ f8 f8 K0 g* U% f3 O1 r
during the placement and layout. To make power of both SOC and memory chips stable,
/ e- m# X; H7 p q% y3 A0 | many capacitors need be placed under the SOC and memory chips. Capacitors should) Q0 m+ g$ u1 {0 }7 _$ o
be included 10uF, 0.1uF and 0.01uF to lower the noises of various band of frequency.3 Y |) j. D5 g6 {. ~* k3 T% Q
The location of decoupling capacitors for several power and ground balls need be as9 i* W: y r, N4 {+ f: f# r
near to the balls as possible.
( T) k6 I7 L6 F. w& p6 k9 d, D The ground is used as a signal return path for DDR trace line. As the stack of the
0 {! D2 R0 e% E6 w 2 layer board, the each signal should have a 5 mil ground line close to it. And make- f1 ]# M% ?) {. i$ A
sure the GND connection is solid enough. And add some via one the memory ground
9 r9 P; I' D6 O0 d line connect the top and bottom ground.
; h" S7 e) K9 S1 W8 y% ~( g 6 Trace routing guide –MVREF+ w9 t5 c: b# U( a6 p
Add 0.1uF decoupling cap at every VREF Pin as near as possible.+ z& i) y1 @4 a) J r
Make the VREF trace as wide as possible and at least 10mil.5 U0 w9 B6 w1 _! L" x
Use precise divider resistors (1%) to make sure the VREF voltage is stable.3 u$ f- {3 W: A! o \( a
7 Flash Memory InteRFace
0 @- o. Q9 H8 ^$ Y( P Since the flash memory speed is higher and higher, we need to take more care
5 E" A( n9 P$ }6 t about flash interface layout. It is better to make the traces as short as possible and
/ W+ k; N, O; e: O. b make sure they have the great possible complete reference plane on GND and VCC+ v( {! z# i' U% D0 z
layer. So we do not suggest to layout flash trace on PCB inner layer for 2-layer PCB.0 u8 t7 g2 ?9 N
8 HDMI Interface
- R+ G3 l+ K& k# A- G7 v- D Differential pair of signals# Z# |1 W L; } G/ A: A4 u7 l
The High Definition Multimedia Interface (HDMI) video signals should be
' T+ X3 U: s$ W7 f8 |, K+ }' A transmitted on high speed differential pairs.5 x( A' Z- l6 Z% C9 A
To get continued impedance and control differential impedance within
& U% O' @1 p9 w. v 100ohm+-15%, integrated reference plane must be provided.4 F2 i3 A$ d4 o r3 E% E$ ]
Differential pair routing rule---5/5/5/5/5mil GND/line/air gap/line/GND4 v7 S, S \2 Q9 R
with recommended stack up to get 100ohm differential impedance.
; A+ M* B: Q) c9 C7 d3 {8 A0 @ j2 W% X HDMI ESD/EMI Protection0 T# W" M7 t; B4 w3 t
HDMI receivers must have ESD protection components.
8 G/ m! w' Q9 D Common mode choke always be added to have better EMI result+ O: F* M" [5 j, Q$ Z; r" D
Recommend SEMTECH’s ESD suppresser RClamp0524 ,Parasitical
6 j. ~: E' _4 [" ~; l. T' i" M capacitance < 0.3Pf
h/ S9 M0 t8 e$ j& g 4 / 5
0 t, B3 g5 w7 ` b/ }) U2 }+ U. z 9 LVDS/VBO/IDP interface" n9 `& i# [7 \1 f1 x1 v
Make sure LVDS trace as short as possible- i% M+ }, V' c7 m
Make sure LVDS trace differential impedance about 100 ohms.1 o) S2 m6 z% K
If needed, add common mode choke to improve LVDS bus EMI/ESD
6 f9 Z9 q6 ]' l performance.5 V3 L& ?& i/ @+ [
Differential pair routing rule---5/5/5mil, h: |+ p. p) _" B- c3 }
" k, e6 w! \. z" `* m/ V0 y% n; q9 A7 q The air gap between LVDS differential pairs should more than 25mil
6 z6 y# ]0 G6 y 10 USB interface
8 s5 x0 l# ~2 |# k3 z- E. M a" G Differential Pair Signals
: E4 ^6 U; q' W- q1 L: v0 r6 }. @ Make sure USB differential pair as short as possible/ l8 `5 _* P$ W% b* H @& V5 d
Make sure USB trace differential impedance is about 90 ohm& f0 V' `2 u r" w5 U
Differential pair routing rule---5/6/5/6/5mil
. o/ a5 W# I: v0 A s with recommended stack up to get 90ohm differential impedance
( v. V9 ^- E+ x5 f) Y' [4 U4 H! u, L! | Supply integrated reference plane for differential pair to have continue impedance
0 ?. ]6 w' W4 c# ^" m* a In order to minimize effect of crosstalk, signal traces should have at least 25mil
+ s! G2 t$ L- ^ air gap to other signals.2 N, T2 I7 k5 d; K0 a
ESD
) W4 ?2 `4 v2 \2 _9 v% r6 b( |1 T ESD protection parts should be added near the USB connector
6 E u* `8 p* }4 j" z; p0 K CM1214-02MS is used for ESD protection in Fusion EP board.9 d# s& I5 i% D2 `
To make differential impedance meet USB specification, special routing around
. C! n4 V8 d8 | CM1214-02MS should be implemented to compensate the differential impedance d+ [( }" S! V# g
skew brought by these parts, refer to layout file for details.
) _9 Z* @' w `8 M; P 11 Analog Video input
+ E1 Z ^- j$ H5 A" M+ t7 d: d Analog inputs should stay away from digital signal and be at least 8mil width.- {+ i% K/ \) v3 c0 d
INN nets capacitors should be placed near to chip as closer as possible.* t$ G/ w. n! `" ]) W0 h
ESD protection parts should be added at analog input connectors.
# U# l3 Z/ k0 |* ?6 Q4 `+ J PC input should add 100ohm resistor as filter to make RGB input has better* Z7 x/ I* p. @# \' Q# H6 c
phase.
# `# Z1 p- z3 w The power of analog block should be as cleaner as possible. It is better to" e$ D9 x7 e2 K* ~5 ?. U
separate analog power from digital power with ferrate beads or inductors.
. M9 z7 E3 x2 Z% H% k0 }6 g- B 5 / 5
* g9 ~" x+ m9 m/ k+ E 12 Ethernet interface
/ k$ q( G9 W0 d6 R Route RX(TX) +/- as differential pair, using 5/5/5/5/5 4/6/4 rule to control the3 X& P. y2 F- Y6 \6 n* r2 ?
2 z; J9 n& h u$ s PHY should close to UXL chip if it is possible.
; y' | k) m( k# X Separate RJ45 connector’s ground from system ground
7 d0 Z, U% F6 l( J$ Q Make sure Inner Layer copper being kept away under transformer area to
- V1 T: T( m% Q: j; o avoid the noise from LAN bus.
8 R0 h: Y# I) ?, C 13 Tuner IF signal( V, G6 c1 l; U) I1 M
Route IF differential input on the top layer, shield with GND and make it as( r; p9 Z: H, x3 [0 k: z! @+ `8 p$ t
short as possible.
8 x m2 D R9 o$ X* I. ] |
