查看: 597|回复: 0
ARM Cortex™-A7四核CPU--A31S
发表于 2019-4-13 14:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1MB 二级缓存SGX544MP2 GPU使用少量外围器件即可实现3G, 2G, LTE, WiFi, Bluetooth, FM, GPS等无线数据传输技术2160P视频解码H.264 HP 1080P@30fps视频编码HDMI 1080P@30fps输出内置ISP32位 DDR3/DDR3L/LPDDR2
& x  E) j) a2 k. R
CPU
  • ARM® Cortex™-A7 Quad-Core
  • 256KB L1 Cache
  • 1MB L2 Cache9 K  l  L" e3 t6 |9 w
GPU
  • PowerVR™ SGX544MP2
  • Complies with OpenGL ES 2.0, OpenCL 1.x, DX 9_3
    , W+ }! Y* J* V9 [8 u5 r' y# R
Audio
  • Two sets of I2S/PCM inteRFaces for Baseband and Bluetooth
  • Two integrated differential analog MIC for headset and phone
  • Integrated digital MIC interface
  • Dedicated headphone/speaker/receiver outputs
  • Two-channel audio ADC with 96dBA SNR
  • Two-channel audio DAC with 100dBA SNR/ F: x+ {3 c$ @! d& O
Video
  • UHD H.264 2160p video decoding
  • Multi-format FHD video decoding, including Mpeg1/2, Mpeg4 SP/ASP GMC, H.263, H.264,etc.
  • H.264 High Profile 1080p@30fps or 720p@60fps encoding
  • 3840x1080@30fps 3D decoding, BD/SBS/TAB/FP supported
  • 3840x1080@30fps 3D encoding
  • Complies with RTSP, HTTP, HLS, RTMP, MMS streaming media protocols* J: W( C' ~/ J: t: L. q
Display
  • Integrated LVDS/RGB/CPU LCD interface 1280x800 resolution
  • Integrated HDMI1.4 1920x1080@60fps
    " `" @: I+ ]; w1 R: o
Camera
  • Supports 0.3M/1.3M/2M/5M CMOS sensor
  • Supports 8/10/12-bit YUV/Bayer sensor" j# ^. T3 ~; _
HawkView™
6 Y5 K" H" G0 Q: P8 J9 d# \            ISP
  • Static and dynamic defect pixel correction, and lens shading correction
  • Anisotropic non-linear Bayer interpolation with false color suppression
  • Programmable color correction, dynamic range compression and contrast enhancement
  • Advanced spatial de-noise filter
  • AE/AF/AWB
  • Anti-flick detection
    & x5 s5 D/ _. t3 _2 S* Q  A8 c
Memory
  • 32-bit DDR3/DDR3L/LPDDR2 controller
  • 8-bit NAND Flash controller with 64-bit ECC
    % x! `8 E( c# r
PMIC
  • PMIC AXP221s
  • 21-CH power output and 2.2A Flash charging
  • Comply with USB 3.0 power supply standard% h: N  M# C# E, r
OS
  • Supports Android 4.1/4.2 and above
  • Compatible with Microsoft Windows 8' B. @% z! Y! j
( q# R; ?; z, A
GMT+8, 2025-11-5 21:24 , Processed in 0.140625 second(s), 24 queries , Gzip On.
