本帖最后由 Taio 于 2019-4-12 10:56 编辑 2 |( g! `( G7 F7 x3 Z$ T8 r1 V; W
1 j, j1 u( x- E) {基于SOPC的单通道TDC设计(3) ) R" j' ]$ H* i( z
2 软件系统. X ~0 a6 s$ K
% U- M9 W. V/ o5 R/ L: V9 I7 a4 I1 ~" N3 G/ m3 A- O, M
! H# y2 K2 r9 R0 `3 f4 N3 z
2.1 System.h/* * system.h - SOPC Builder system and BSP software package information * * Machine generated for CPU 'cpu' in SOPC Builder design 'audio_nios' * SOPC Builder design path: E:/eeworld_soc/eeworld3/tdc1000_SoC/audio_nios.sopcinfo * * Generated: Tue Jun 02 11:18:56 CST 2015 */ / ^2 E1 d$ l8 e a
/* * DO NOT MODIFY THIS FILE * * Changing this file will have subtle consequences * which will almost certainly lead to a nonfunctioning * system. If you do modify this file, be aware that your * changes will be overwritten and lost when this file * is generated again. * * DO NOT MODIFY THIS FILE */ ; v1 z1 E1 w) k
/* * License Agreement * * Copyright (c) 2008 * Altera Corporation, San Jose, California, USA. * All rights reserved. * * Permission is hereby granted, free of charge, to any person obtaining a * copy of this software and associated documentation files (the "Software"), * to deal in the Software without restriction, including without limitation * the rights to use, copy, modify, merge, publish, distribute, sublicense, * and/or sell copies of the Software, and to permit persons to whom the * Software is furnished to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER * DEALINGS IN THE SOFTWARE. * * This agreement shall be governed in all respects by the laws of the State * of California and by the laws of the United States of America. */
M/ p }8 E7 E4 K$ l9 z#ifndef __SYSTEM_H_ #define __SYSTEM_H_ 0 t, `# u7 {, [) p
/* Include definitions from linker script generator */ #include "linker.h" 2 |( \/ S0 ~# C* r
$ e5 w3 o* b: [8 Q% n2 m" p5 r h
/* * CPU configuration * */
6 a0 T$ A" _7 ^' k$ X1 a#define ALT_CPU_ARCHITECTURE "altera_nios2_gen2" #define ALT_CPU_BIG_ENDIAN 0 #define ALT_CPU_BREAK_ADDR 0x05100820 #define ALT_CPU_CPU_ARCH_NIOS2_R1 #define ALT_CPU_CPU_FREQ 100000000u #define ALT_CPU_CPU_ID_SIZE 1 #define ALT_CPU_CPU_ID_VALUE 0x00000000 #define ALT_CPU_CPU_IMPLEMENTATION "fast" #define ALT_CPU_DATA_ADDR_WIDTH 0x1b #define ALT_CPU_DCACHE_BYPASS_MASK 0x80000000 #define ALT_CPU_DCACHE_LINE_SIZE 32 #define ALT_CPU_DCACHE_LINE_SIZE_LOG2 5 #define ALT_CPU_DCACHE_SIZE 2048 #define ALT_CPU_EXCEPTION_ADDR 0x05080020 #define ALT_CPU_FLASH_ACCELERATOR_LINES 0 #define ALT_CPU_FLASH_ACCELERATOR_LINE_SIZE 0 #define ALT_CPU_FLUSHDA_SUPPORTED #define ALT_CPU_FREQ 100000000 #define ALT_CPU_HARDWARE_DIVIDE_PRESENT 0 #define ALT_CPU_HARDWARE_MULTIPLY_PRESENT 1 #define ALT_CPU_HARDWARE_MULX_PRESENT 0 #define ALT_CPU_HAS_DEBUG_CORE 1 #define ALT_CPU_HAS_DEBUG_STUB #define ALT_CPU_HAS_EXTRA_EXCEPTION_INFO #define ALT_CPU_HAS_ILLEGAL_INSTRUCTION_EXCEPTION #define ALT_CPU_HAS_JMPI_INSTRUCTION #define ALT_CPU_ICACHE_LINE_SIZE 32 #define ALT_CPU_ICACHE_LINE_SIZE_LOG2 5 #define ALT_CPU_ICACHE_SIZE 4096 #define ALT_CPU_INITDA_SUPPORTED #define ALT_CPU_INST_ADDR_WIDTH 0x1b #define ALT_CPU_NAME "cpu" #define ALT_CPU_NUM_OF_SHADOW_REG_SETS 0 #define ALT_CPU_OCI_VERSION 1 #define ALT_CPU_RESET_ADDR 0x05080000 . J8 D0 O$ I$ ]* \" [+ Z" Y
/ B( l) ^9 [5 \/ f% @/* * CPU configuration (with legacy prefix - don't use these anymore) * */ . ~3 S* c2 n4 Y0 | c2 z7 b" ?( F* O
#define NIOS2_BIG_ENDIAN 0 #define NIOS2_BREAK_ADDR 0x05100820 #define NIOS2_CPU_ARCH_NIOS2_R1 #define NIOS2_CPU_FREQ 100000000u #define NIOS2_CPU_ID_SIZE 1 #define NIOS2_CPU_ID_VALUE 0x00000000 #define NIOS2_CPU_IMPLEMENTATION "fast" #define NIOS2_DATA_ADDR_WIDTH 0x1b #define NIOS2_DCACHE_BYPASS_MASK 0x80000000 #define NIOS2_DCACHE_LINE_SIZE 32 #define NIOS2_DCACHE_LINE_SIZE_LOG2 5 #define NIOS2_DCACHE_SIZE 2048 #define NIOS2_EXCEPTION_ADDR 0x05080020 #define NIOS2_FLASH_ACCELERATOR_LINES 0 #define NIOS2_FLASH_ACCELERATOR_LINE_SIZE 0 #define NIOS2_FLUSHDA_SUPPORTED #define NIOS2_HARDWARE_DIVIDE_PRESENT 0 #define NIOS2_HARDWARE_MULTIPLY_PRESENT 1 #define NIOS2_HARDWARE_MULX_PRESENT 0 #define NIOS2_HAS_DEBUG_CORE 1 #define NIOS2_HAS_DEBUG_STUB #define NIOS2_HAS_EXTRA_EXCEPTION_INFO #define NIOS2_HAS_ILLEGAL_INSTRUCTION_EXCEPTION #define NIOS2_HAS_JMPI_INSTRUCTION #define NIOS2_ICACHE_LINE_SIZE 32 #define NIOS2_ICACHE_LINE_SIZE_LOG2 5 #define NIOS2_ICACHE_SIZE 4096 #define NIOS2_INITDA_SUPPORTED #define NIOS2_INST_ADDR_WIDTH 0x1b #define NIOS2_NUM_OF_SHADOW_REG_SETS 0 #define NIOS2_OCI_VERSION 1 #define NIOS2_RESET_ADDR 0x05080000
" k+ k4 W3 b3 n* b& O q+ A$ ]3 M" d! L4 \3 N
/* * Define for each module class mastered by the CPU * */
- A! l# P6 [) d9 s#define __ALTERA_AVALON_JTAG_UART #define __ALTERA_AVALON_NEW_SDRAM_CONTROLLER #define __ALTERA_AVALON_ONCHIP_MEMORY2 #define __ALTERA_AVALON_PIO #define __ALTERA_AVALON_SYSID_QSYS #define __ALTERA_AVALON_TIMER #define __ALTERA_NIOS2_GEN2 #define __SEG7_IF 3 |& \* y. C3 v7 S3 z; c' g1 J
6 j6 z1 [6 h- Q. J* K
/* * System configuration * */
, z+ S9 L) m% U% H; d) q#define ALT_DEVICE_FAMILY "Cyclone V" #define ALT_ENHANCED_INTERRUPT_API_PRESENT #define ALT_IRQ_BASE NULL #define ALT_LOG_PORT "/dev/null" #define ALT_LOG_PORT_BASE 0x0 #define ALT_LOG_PORT_DEV null #define ALT_LOG_PORT_TYPE "" #define ALT_NUM_EXTERNAL_INTERRUPT_CONTROLLERS 0 #define ALT_NUM_INTERNAL_INTERRUPT_CONTROLLERS 1 #define ALT_NUM_INTERRUPT_CONTROLLERS 1 #define ALT_STDERR "/dev/jtag_uart" #define ALT_STDERR_BASE 0x5101028 #define ALT_STDERR_DEV jtag_uart #define ALT_STDERR_IS_JTAG_UART #define ALT_STDERR_PRESENT #define ALT_STDERR_TYPE "altera_avalon_jtag_uart" #define ALT_STDIN "/dev/jtag_uart" #define ALT_STDIN_BASE 0x5101028 #define ALT_STDIN_DEV jtag_uart #define ALT_STDIN_IS_JTAG_UART #define ALT_STDIN_PRESENT #define ALT_STDIN_TYPE "altera_avalon_jtag_uart" #define ALT_STDOUT "/dev/jtag_uart" #define ALT_STDOUT_BASE 0x5101028 #define ALT_STDOUT_DEV jtag_uart #define ALT_STDOUT_IS_JTAG_UART #define ALT_STDOUT_PRESENT #define ALT_STDOUT_TYPE "altera_avalon_jtag_uart" #define ALT_SYSTEM_NAME "audio_nios"
/ g: r* C! T- m0 H) W2 I) n8 _5 n- N
/* * altera_hostfs configuration * */ 5 T5 M* |7 O7 Z Y) E' t
#define ALTERA_HOSTFS_NAME "/mnt/host"
3 [" c- s2 |5 X g8 _* H% B& }) u. ^" _& P
/* * altera_ro_zipfs configuration * */
$ i1 F) B5 x5 V0 m0 A9 E#define ALTERA_RO_ZIPFS_BASE 0x0 #define ALTERA_RO_ZIPFS_NAME "/mnt/rozipfs" #define ALTERA_RO_ZIPFS_OFFSET 0x100000
U C' ?1 i6 J- r# \: j7 c4 O* X( y; j. E( Z. g& s
/* * din32 configuration * */ # n7 ?; P- Z1 l, O/ y; S& \# a; E
#define ALT_MODULE_CLASS_din32 altera_avalon_pio #define DIN32_BASE 0x4000050 #define DIN32_BIT_CLEARING_EDGE_REGISTER 0 #define DIN32_BIT_MODIFYING_OUTPUT_REGISTER 0 #define DIN32_CAPTURE 0 #define DIN32_DATA_WIDTH 32 #define DIN32_DO_TEST_BENCH_WIRING 0 #define DIN32_DRIVEN_SIM_VALUE 0 #define DIN32_EDGE_TYPE "NONE" #define DIN32_FREQ 10000000 #define DIN32_HAS_IN 1 #define DIN32_HAS_OUT 0 #define DIN32_HAS_TRI 0 #define DIN32_IRQ -1 #define DIN32_IRQ_INTERRUPT_CONTROLLER_ID -1 #define DIN32_IRQ_TYPE "NONE" #define DIN32_NAME "/dev/din32" #define DIN32_RESET_VALUE 0 #define DIN32_SPAN 16 #define DIN32_TYPE "altera_avalon_pio" + y0 x' _. w* ?9 ~
' X/ ]0 D7 b' @& p, Y. |
/* * hal configuration * */
: F3 W. V' o' M- L#define ALT_MAX_FD 32 #define ALT_SYS_CLK TIMER #define ALT_TIMESTAMP_CLK TIMER
) j! l E2 b" K' j& X, g5 k* W6 }1 ?
2 q9 F: q9 G7 p4 V/* * jtag_uart configuration * */ - c+ }* Z) f: P2 T# x! ~
#define ALT_MODULE_CLASS_jtag_uart altera_avalon_jtag_uart #define JTAG_UART_BASE 0x5101028 #define JTAG_UART_IRQ 0 #define JTAG_UART_IRQ_INTERRUPT_CONTROLLER_ID 0 #define JTAG_UART_NAME "/dev/jtag_uart" #define JTAG_UART_READ_DEPTH 64 #define JTAG_UART_READ_THRESHOLD 8 #define JTAG_UART_SPAN 8 #define JTAG_UART_TYPE "altera_avalon_jtag_uart" #define JTAG_UART_WRITE_DEPTH 64 #define JTAG_UART_WRITE_THRESHOLD 8 , c+ ~! x1 S* {' _# q
# w. \; Y, L1 S) q/* * key configuration * */ ! D* V+ t; p' h$ ~; C1 A3 ]) _; l
#define ALT_MODULE_CLASS_key altera_avalon_pio #define KEY_BASE 0x4000080 #define KEY_BIT_CLEARING_EDGE_REGISTER 0 #define KEY_BIT_MODIFYING_OUTPUT_REGISTER 0 #define KEY_CAPTURE 1 #define KEY_DATA_WIDTH 4 #define KEY_DO_TEST_BENCH_WIRING 0 #define KEY_DRIVEN_SIM_VALUE 0 #define KEY_EDGE_TYPE "FALLING" #define KEY_FREQ 10000000 #define KEY_HAS_IN 1 #define KEY_HAS_OUT 0 #define KEY_HAS_TRI 0 #define KEY_IRQ 1 #define KEY_IRQ_INTERRUPT_CONTROLLER_ID 0 #define KEY_IRQ_TYPE "EDGE" #define KEY_NAME "/dev/key" #define KEY_RESET_VALUE 0 #define KEY_SPAN 16 #define KEY_TYPE "altera_avalon_pio" 0 M6 |5 A* [6 V4 C9 {( k& Z
Z/ K3 ~ G7 ^9 l3 D/* * onchip_memory2 configuration * */
; X) q" u( l+ A" E#define ALT_MODULE_CLASS_onchip_memory2 altera_avalon_onchip_memory2 #define ONCHIP_MEMORY2_ALLOW_IN_SYSTEM_MEMORY_CONTENT_EDITOR 0 #define ONCHIP_MEMORY2_ALLOW_MRAM_SIM_CONTENTS_ONLY_FILE 0 #define ONCHIP_MEMORY2_BASE 0x5080000 #define ONCHIP_MEMORY2_CONTENTS_INFO "" #define ONCHIP_MEMORY2_DUAL_PORT 0 #define ONCHIP_MEMORY2_GUI_RAM_BLOCK_TYPE "AUTO" #define ONCHIP_MEMORY2_INIT_CONTENTS_FILE "audio_nios_onchip_memory2" #define ONCHIP_MEMORY2_INIT_MEM_CONTENT 1 #define ONCHIP_MEMORY2_INSTANCE_ID "NONE" #define ONCHIP_MEMORY2_IRQ -1 #define ONCHIP_MEMORY2_IRQ_INTERRUPT_CONTROLLER_ID -1 #define ONCHIP_MEMORY2_NAME "/dev/onchip_memory2" #define ONCHIP_MEMORY2_NON_DEFAULT_INIT_FILE_ENABLED 0 #define ONCHIP_MEMORY2_RAM_BLOCK_TYPE "AUTO" #define ONCHIP_MEMORY2_READ_DURING_WRITE_MODE "DONT_CARE" #define ONCHIP_MEMORY2_SINGLE_CLOCK_OP 0 #define ONCHIP_MEMORY2_SIZE_MULTIPLE 1 #define ONCHIP_MEMORY2_SIZE_VALUE 320000 #define ONCHIP_MEMORY2_SPAN 320000 #define ONCHIP_MEMORY2_TYPE "altera_avalon_onchip_memory2" #define ONCHIP_MEMORY2_WRITABLE 1
. K0 A' o4 t" W+ a; p% {
* k+ [7 s& ]! q+ d) i- Z/* * pio_led configuration * */
- A% Z& {7 I- H+ }9 ~#define ALT_MODULE_CLASS_pio_led altera_avalon_pio #define PIO_LED_BASE 0x4000070 #define PIO_LED_BIT_CLEARING_EDGE_REGISTER 0 #define PIO_LED_BIT_MODIFYING_OUTPUT_REGISTER 0 #define PIO_LED_CAPTURE 0 #define PIO_LED_DATA_WIDTH 10 #define PIO_LED_DO_TEST_BENCH_WIRING 0 #define PIO_LED_DRIVEN_SIM_VALUE 0 #define PIO_LED_EDGE_TYPE "NONE" #define PIO_LED_FREQ 10000000 #define PIO_LED_HAS_IN 0 #define PIO_LED_HAS_OUT 1 #define PIO_LED_HAS_TRI 0 #define PIO_LED_IRQ -1 #define PIO_LED_IRQ_INTERRUPT_CONTROLLER_ID -1 #define PIO_LED_IRQ_TYPE "NONE" #define PIO_LED_NAME "/dev/pio_led" #define PIO_LED_RESET_VALUE 0 #define PIO_LED_SPAN 16 #define PIO_LED_TYPE "altera_avalon_pio"
0 y2 c" H8 _- r/ N& @3 {
- y/ ^ Y1 I5 g9 B, F8 o/* * rd_empt configuration * */
2 ]. d9 s+ c! y, A U3 W, h Q4 U" P#define ALT_MODULE_CLASS_rd_empt altera_avalon_pio #define RD_EMPT_BASE 0x4000020 #define RD_EMPT_BIT_CLEARING_EDGE_REGISTER 0 #define RD_EMPT_BIT_MODIFYING_OUTPUT_REGISTER 0 #define RD_EMPT_CAPTURE 0 #define RD_EMPT_DATA_WIDTH 1 #define RD_EMPT_DO_TEST_BENCH_WIRING 0 #define RD_EMPT_DRIVEN_SIM_VALUE 0 #define RD_EMPT_EDGE_TYPE "NONE" #define RD_EMPT_FREQ 10000000 #define RD_EMPT_HAS_IN 1 #define RD_EMPT_HAS_OUT 0 #define RD_EMPT_HAS_TRI 0 #define RD_EMPT_IRQ -1 #define RD_EMPT_IRQ_INTERRUPT_CONTROLLER_ID -1 #define RD_EMPT_IRQ_TYPE "NONE" #define RD_EMPT_NAME "/dev/rd_empt" #define RD_EMPT_RESET_VALUE 0 #define RD_EMPT_SPAN 16 #define RD_EMPT_TYPE "altera_avalon_pio"
8 ?* Y3 R6 C+ P) q
a: n' _2 i) _) B: r4 Y$ u/* * rd_rqt configuration * */
7 e- [) V4 `$ P2 N* G#define ALT_MODULE_CLASS_rd_rqt altera_avalon_pio #define RD_RQT_BASE 0x4000030 #define RD_RQT_BIT_CLEARING_EDGE_REGISTER 0 #define RD_RQT_BIT_MODIFYING_OUTPUT_REGISTER 0 #define RD_RQT_CAPTURE 0 #define RD_RQT_DATA_WIDTH 1 #define RD_RQT_DO_TEST_BENCH_WIRING 0 #define RD_RQT_DRIVEN_SIM_VALUE 0 #define RD_RQT_EDGE_TYPE "NONE" #define RD_RQT_FREQ 10000000 #define RD_RQT_HAS_IN 0 #define RD_RQT_HAS_OUT 1 #define RD_RQT_HAS_TRI 0 #define RD_RQT_IRQ -1 #define RD_RQT_IRQ_INTERRUPT_CONTROLLER_ID -1 #define RD_RQT_IRQ_TYPE "NONE" #define RD_RQT_NAME "/dev/rd_rqt" #define RD_RQT_RESET_VALUE 0 #define RD_RQT_SPAN 16 #define RD_RQT_TYPE "altera_avalon_pio" 6 G. j" k0 B. [+ W9 F
4 Z; @) Y! x4 o2 m$ m
/* * sdram configuration * */ 2 Y# j' D! f! m+ s# I. N
#define ALT_MODULE_CLASS_sdram altera_avalon_new_sdram_controller #define SDRAM_BASE 0x0 #define SDRAM_CAS_LATENCY 3 #define SDRAM_CONTENTS_INFO #define SDRAM_INIT_NOP_DELAY 0.0 #define SDRAM_INIT_REFRESH_COMMANDS 2 #define SDRAM_IRQ -1 #define SDRAM_IRQ_INTERRUPT_CONTROLLER_ID -1 #define SDRAM_IS_INITIALIZED 1 #define SDRAM_NAME "/dev/sdram" #define SDRAM_POWERUP_DELAY 100.0 #define SDRAM_REFRESH_PERIOD 15.625 #define SDRAM_REGISTER_DATA_IN 1 #define SDRAM_SDRAM_ADDR_WIDTH 0x19 #define SDRAM_SDRAM_BANK_WIDTH 2 #define SDRAM_SDRAM_COL_WIDTH 10 #define SDRAM_SDRAM_DATA_WIDTH 16 #define SDRAM_SDRAM_NUM_BANKS 4 #define SDRAM_SDRAM_NUM_CHIPSELECTS 1 #define SDRAM_SDRAM_ROW_WIDTH 13 #define SDRAM_SHARED_DATA 0 #define SDRAM_SIM_MODEL_BASE 1 #define SDRAM_SPAN 67108864 #define SDRAM_STARVATION_INDICATOR 0 #define SDRAM_TRISTATE_BRIDGE_SLAVE "" #define SDRAM_TYPE "altera_avalon_new_sdram_controller" #define SDRAM_T_AC 6.0 #define SDRAM_T_MRD 3 #define SDRAM_T_RCD 20.0 #define SDRAM_T_RP 20.0 #define SDRAM_T_WR 14.0 /* * seg7 configuration * */ + {8 s+ @/ \$ q" b4 b+ f9 O
#define ALT_MODULE_CLASS_seg7 SEG7_IF #define SEG7_BASE 0x4000000 #define SEG7_IRQ -1 #define SEG7_IRQ_INTERRUPT_CONTROLLER_ID -1 #define SEG7_NAME "/dev/seg7" #define SEG7_SPAN 32 #define SEG7_TYPE "SEG7_IF" ; W0 A( D0 I6 w7 G/ Q
8 q& U: ~6 O( F4 [
/* * sw configuration * */
T% y9 h4 ]4 Q& A( n. a#define ALT_MODULE_CLASS_sw altera_avalon_pio #define SW_BASE 0x4000060 #define SW_BIT_CLEARING_EDGE_REGISTER 0 #define SW_BIT_MODIFYING_OUTPUT_REGISTER 0 #define SW_CAPTURE 1 #define SW_DATA_WIDTH 10 #define SW_DO_TEST_BENCH_WIRING 0 #define SW_DRIVEN_SIM_VALUE 0 #define SW_EDGE_TYPE "FALLING" #define SW_FREQ 10000000 #define SW_HAS_IN 1 #define SW_HAS_OUT 0 #define SW_HAS_TRI 0 #define SW_IRQ 2 #define SW_IRQ_INTERRUPT_CONTROLLER_ID 0 #define SW_IRQ_TYPE "EDGE" #define SW_NAME "/dev/sw" #define SW_RESET_VALUE 0 #define SW_SPAN 16 #define SW_TYPE "altera_avalon_pio"
2 R) j' B# i4 ]& P! o- j% i9 O9 o7 e Z) r) u
/* * sysid_qsys configuration * */ . w" t$ x& o6 H3 D4 W. f
#define ALT_MODULE_CLASS_sysid_qsys altera_avalon_sysid_qsys #define SYSID_QSYS_BASE 0x5101020 #define SYSID_QSYS_ID 0 #define SYSID_QSYS_IRQ -1 #define SYSID_QSYS_IRQ_INTERRUPT_CONTROLLER_ID -1 #define SYSID_QSYS_NAME "/dev/sysid_qsys" #define SYSID_QSYS_SPAN 8 #define SYSID_QSYS_TIMESTAMP 1433211715 #define SYSID_QSYS_TYPE "altera_avalon_sysid_qsys"
W3 }3 z% s0 o6 v7 m
6 M, ]; W7 u* l/* * timer configuration * */
: ^' z( D! f( i! A# c6 B#define ALT_MODULE_CLASS_timer altera_avalon_timer #define TIMER_ALWAYS_RUN 0 #define TIMER_BASE 0x5101000 #define TIMER_COUNTER_SIZE 32 #define TIMER_FIXED_PERIOD 0 #define TIMER_FREQ 100000000 #define TIMER_IRQ 3 #define TIMER_IRQ_INTERRUPT_CONTROLLER_ID 0 #define TIMER_LOAD_VALUE 99999 #define TIMER_MULT 0.001 #define TIMER_NAME "/dev/timer" #define TIMER_PERIOD 1 #define TIMER_PERIOD_UNITS "ms" #define TIMER_RESET_OUTPUT 0 #define TIMER_SNAPSHOT 1 #define TIMER_SPAN 32 #define TIMER_TICKS_PER_SEC 1000 #define TIMER_TIMEOUT_PULSE_OUTPUT 0 #define TIMER_TYPE "altera_avalon_timer" 3 x" q9 n; k" y1 \+ L7 B
$ [! ] f' i( P
/* * wr_full configuration * */
0 v4 T' m: B) x3 `( V `! b#define ALT_MODULE_CLASS_wr_full altera_avalon_pio #define WR_FULL_BASE 0x4000040 #define WR_FULL_BIT_CLEARING_EDGE_REGISTER 0 #define WR_FULL_BIT_MODIFYING_OUTPUT_REGISTER 0 #define WR_FULL_CAPTURE 1 #define WR_FULL_DATA_WIDTH 1 #define WR_FULL_DO_TEST_BENCH_WIRING 0 #define WR_FULL_DRIVEN_SIM_VALUE 0 #define WR_FULL_EDGE_TYPE "RISING" #define WR_FULL_FREQ 10000000 #define WR_FULL_HAS_IN 1 #define WR_FULL_HAS_OUT 0 #define WR_FULL_HAS_TRI 0 #define WR_FULL_IRQ 4 #define WR_FULL_IRQ_INTERRUPT_CONTROLLER_ID 0 #define WR_FULL_IRQ_TYPE "EDGE" #define WR_FULL_NAME "/dev/wr_full" #define WR_FULL_RESET_VALUE 0 #define WR_FULL_SPAN 16 #define WR_FULL_TYPE "altera_avalon_pio"
4 L$ y4 K" `% h#endif /* __SYSTEM_H_ */ / e9 c7 u! @3 p) A
2.2 Main.c #include "my_includes.h" #include "LED.h" #include "SEG7.h" #include <math.h> #ifdef DEBUG_APP #define APP_DEBUG(x) DEBUG(x) #else #define APP_DEBUG(x) #endif /////////////////////////////////////////////////////////////////////////////// //////////// Internal function prototype & data structure ///////////////////// /////////////////////////////////////////////////////////////////////////////// //================= internal function prototype & data structure definit ===== #define MAX_TRY_CNT 1024 #define USE_SDRAM_FOR_DATA #ifndef USE_SDRAM_FOR_DATA #define BUF_SAMPLE_NUM (96000*5) // 5 second @ 96K #endif void button_monitor_isr(void* context, alt_u32 id); bool button_monitor_start(volatile alt_u32 *pPressedMask); void TDC_monitor_isr(void* context, alt_u32 id); bool TDC_monitor_start(volatile alt_u32 *pPressedMask); void TEST_monitor_isr(void* context, alt_u32 id); bool TEST_monitor_start(volatile alt_u32 *pPressedMask); void display_time_elapsed(alt_u32 sample_num); void button_monitor_isr(void* context, alt_u32 id) { volatile alt_u32* pPressedMask = (volatile alt_u32*) context; *pPressedMask |= IORD_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE) & 0x0F; // 4-button IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE, 0); printf("in ISR\r\n"); printf("wr = %d rd = %d \r\n", IORD_ALTERA_AVALON_PIO_DATA(WR_FULL_BASE) & 0x01, IORD_ALTERA_AVALON_PIO_DATA(RD_EMPT_BASE) & 0x01); } bool button_monitor_start(volatile alt_u32 *pPressedMask) { bool bSuccess = TRUE; // enable interrupt IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_BASE, 0x0F); // 4-button // Reset the edge catpure register IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE, 0); printf("in start\r\n"); // register IRQ if (bSuccess && (alt_irq_register(KEY_IRQ, (void *) pPressedMask, button_monitor_isr) != 0)) { printf("[SW-MONITOR]register button IRQ fail\r\n"); bSuccess = FALSE; } return bSuccess; } void TDC_monitor_isr(void* context, alt_u32 id) { volatile alt_u32* pPressedMask = (volatile alt_u32*) context; *pPressedMask |= IORD_ALTERA_AVALON_PIO_EDGE_CAP(WR_FULL_BASE) & 0x01; // 1-line in IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WR_FULL_BASE, 0); printf("in fifo-ISR\r\n"); } bool TDC_monitor_start(volatile alt_u32 *pPressedMask) { bool bSuccess = TRUE; // enable interrupt IOWR_ALTERA_AVALON_PIO_IRQ_MASK(WR_FULL_BASE, 0x01); // 4-button // Reset the edge catpure register IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WR_FULL_BASE, 0); printf("in fifo-start\r\n"); // register IRQ if (bSuccess && (alt_irq_register(WR_FULL_IRQ, (void *) pPressedMask, TDC_monitor_isr) != 0)) { printf("Fifo IRQ fail\r\n"); bSuccess = FALSE; } return bSuccess; } void TEST_monitor_isr(void* context, alt_u32 id) { volatile alt_u32* pPressedMask = (volatile alt_u32*) context; *pPressedMask |= IORD_ALTERA_AVALON_PIO_EDGE_CAP(TEST_SIG_BASE) & 0x01; // 1-line in IOWR_ALTERA_AVALON_PIO_EDGE_CAP(TEST_SIG_BASE, 0); printf("in test-ISR\r\n"); } bool TEST_monitor_start(volatile alt_u32 *pPressedMask) { bool bSuccess = TRUE; // enable interrupt IOWR_ALTERA_AVALON_PIO_IRQ_MASK(TEST_SIG_BASE, 0x01); // 4-button // Reset the edge catpure register IOWR_ALTERA_AVALON_PIO_EDGE_CAP(TEST_SIG_BASE, 0); printf("in test-start\r\n"); // register IRQ if (bSuccess && (alt_irq_register(TEST_SIG_IRQ, (void *) pPressedMask, TEST_monitor_isr) != 0)) { printf("TEST IRQ fail\r\n"); bSuccess = FALSE; } return bSuccess; } void display_time_elapsed(alt_u32 sample_num) { // assume sample rate is 48K alt_u32 time; SEG7_Decimal(123456, 0x04); } bool init(void) { bool bSuccess = TRUE; SEG7_Clear(); SEG7_Decimal(0x00000000, 0x00); return bSuccess; } 7 @* K* m% U+ j% F- y" ~1 L9 A
7 ^! k! n J5 F4 p/ l: m* D" U
* f7 Z+ U; x) N0 Y6 H: D) Y- \ int main() { volatile alt_u32 button_mask = 0; volatile alt_u32 tdc_mask = 0; volatile alt_u32 test_mask = 0; alt_u32 *pBuf, *pPlaying, *pRecording, RecordLen, PlayLen, data, try_cnt, buf_sample_size; printf("\nHello World\n"); if (!init()) return 0; #ifdef USE_SDRAM_FOR_DATA pBuf = (alt_u32 *) SDRAM_BASE; buf_sample_size = SDRAM_SPAN / sizeof(alt_u32); #else // alloc memory to stroe PCM data buf_sample_size = BUF_SAMPLE_NUM; pBuf = malloc(buf_sample_size * sizeof(alt_u32)); if (!pBuf) { LCD_TextOut("malloc fail\n\n"); printf("malloc fail\r\n"); return 0; } #endif button_monitor_start(&button_mask); // button IRQ TDC_monitor_start(&tdc_mask); // TDC IRQ TEST_monitor_start(&test_mask); // TDC IRQ printf("ready\n"); 0 f4 h& ~7 T/ Y4 J
// infinite loop while (1) { // } } |
