查看: 286|回复: 6
基于SOPC的单通道TDC设计(2)
发表于 2019-4-12 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于SOPC的单通道TDC设计(2)
/ K7 Y2 Y  W5 l' h
6 m( s4 j6 o9 c' S3 r  s
1.4 Nios II顶层源程序
`timescale 1 ps / 1 ps
module audio_nios (
                input  wire        clk_clk,                            //                         clk.clk
                input  wire [31:0] din32_external_connection_export,   //   din32_external_connection.export
                input  wire [3:0]  key_external_connection_export,     //     key_external_connection.export
                output wire [9:0]  pio_0_external_connection_export,   //   pio_0_external_connection.export
                output wire        pll_locked_export,                  //                  pll_locked.export
                output wire        pll_outclk3_clk,                    //                 pll_outclk3.clk
                output wire        pll_sdam_clk,                       //                    pll_sdam.clk
                input  wire        rd_empt_external_connection_export, // rd_empt_external_connection.export
                output wire        rd_rqt_external_connection_export,  //  rd_rqt_external_connection.export
                input  wire        reset_reset_n,                      //                       reset.reset_n
                output wire [12:0] sdram_wire_addr,                    //                  sdram_wire.addr
                output wire [1:0]  sdram_wire_ba,                      //                            .ba
                output wire        sdram_wire_cas_n,                   //                            .cas_n
                output wire        sdram_wire_cke,                     //                            .cke
                output wire        sdram_wire_cs_n,                    //                            .cs_n
                inout  wire [15:0] sdram_wire_dq,                      //                            .dq
                output wire [1:0]  sdram_wire_dqm,                     //                            .dqm
                output wire        sdram_wire_ras_n,                   //                            .ras_n
                output wire        sdram_wire_we_n,                    //                            .we_n
                output wire [47:0] seg7_conduit_end_export,            //            seg7_conduit_end.export
                input  wire [9:0]  sw_external_connection_export,      //      sw_external_connection.export
                input  wire        wr_full_external_connection_export  // wr_full_external_connection.export
. A( n# s# X2 ~3 A3 n* j
        wire         pll_outclk0_clk;                                           // pllutclk_0 -> [cpu:clk, cpu_peripheral_bridge:s0_clk, irq_mapper:clk, irq_synchronizer:sender_clk, irq_synchronizer_001:sender_clk, irq_synchronizer_002:sender_clk, jtag_uart:clk, mm_interconnect_0:pll_outclk0_clk, onchip_memory2:clk, rst_controller:clk, rst_controller_002:clk, sdram:clk, sysid_qsys:clock, timer:clk]
        wire         pll_outclk2_clk;                                           // pllutclk_2 -> [cpu_peripheral_bridge:m0_clk, din32:clk, irq_synchronizer:receiver_clk, irq_synchronizer_001:receiver_clk, irq_synchronizer_002:receiver_clk, key:clk, mm_interconnect_1:pll_outclk2_clk, pio_led:clk, rd_empt:clk, rd_rqt:clk, rst_controller_001:clk, seg7:s_clk, sw:clk, wr_full:clk]
        wire  [31:0] cpu_data_master_readdata;                                  // mm_interconnect_0:cpu_data_master_readdata -> cpu:d_readdata
        wire         cpu_data_master_waitrequest;                               // mm_interconnect_0:cpu_data_master_waitrequest -> cpu:d_waitrequest
        wire         cpu_data_master_debugaccess;                               // cpu:debug_mem_slave_debugaccess_to_roms -> mm_interconnect_0:cpu_data_master_debugaccess
        wire  [26:0] cpu_data_master_address;                                   // cpu:d_address -> mm_interconnect_0:cpu_data_master_address
        wire   [3:0] cpu_data_master_byteenable;                                // cpu:d_byteenable -> mm_interconnect_0:cpu_data_master_byteenable
        wire         cpu_data_master_read;                                      // cpu:d_read -> mm_interconnect_0:cpu_data_master_read
        wire         cpu_data_master_readdatavalid;                             // mm_interconnect_0:cpu_data_master_readdatavalid -> cpu:d_readdatavalid
        wire         cpu_data_master_write;                                     // cpu:d_write -> mm_interconnect_0:cpu_data_master_write
        wire  [31:0] cpu_data_master_writedata;                                 // cpu:d_writedata -> mm_interconnect_0:cpu_data_master_writedata
        wire  [31:0] cpu_instruction_master_readdata;                           // mm_interconnect_0:cpu_instruction_master_readdata -> cpu:i_readdata
        wire         cpu_instruction_master_waitrequest;                        // mm_interconnect_0:cpu_instruction_master_waitrequest -> cpu:i_waitrequest
        wire  [26:0] cpu_instruction_master_address;                            // cpu:i_address -> mm_interconnect_0:cpu_instruction_master_address
        wire         cpu_instruction_master_read;                               // cpu:i_read -> mm_interconnect_0:cpu_instruction_master_read
        wire         cpu_instruction_master_readdatavalid;                      // mm_interconnect_0:cpu_instruction_master_readdatavalid -> cpu:i_readdatavalid
        wire         mm_interconnect_0_jtag_uart_avalon_jtag_slave_chipselect;  // mm_interconnect_0:jtag_uart_avalon_jtag_slave_chipselect -> jtag_uart:av_chipselect
        wire  [31:0] mm_interconnect_0_jtag_uart_avalon_jtag_slave_readdata;    // jtag_uart:av_readdata -> mm_interconnect_0:jtag_uart_avalon_jtag_slave_readdata
        wire         mm_interconnect_0_jtag_uart_avalon_jtag_slave_waitrequest; // jtag_uart:av_waitrequest -> mm_interconnect_0:jtag_uart_avalon_jtag_slave_waitrequest
        wire   [0:0] mm_interconnect_0_jtag_uart_avalon_jtag_slave_address;     // mm_interconnect_0:jtag_uart_avalon_jtag_slave_address -> jtag_uart:av_address
        wire         mm_interconnect_0_jtag_uart_avalon_jtag_slave_read;        // mm_interconnect_0:jtag_uart_avalon_jtag_slave_read -> jtag_uart:av_read_n
        wire         mm_interconnect_0_jtag_uart_avalon_jtag_slave_write;       // mm_interconnect_0:jtag_uart_avalon_jtag_slave_write -> jtag_uart:av_write_n
        wire  [31:0] mm_interconnect_0_jtag_uart_avalon_jtag_slave_writedata;   // mm_interconnect_0:jtag_uart_avalon_jtag_slave_writedata -> jtag_uart:av_writedata
        wire  [31:0] mm_interconnect_0_sysid_qsys_control_slave_readdata;       // sysid_qsys:readdata -> mm_interconnect_0:sysid_qsys_control_slave_readdata
        wire   [0:0] mm_interconnect_0_sysid_qsys_control_slave_address;        // mm_interconnect_0:sysid_qsys_control_slave_address -> sysid_qsys:address
        wire  [31:0] mm_interconnect_0_cpu_debug_mem_slave_readdata;            // cpu:debug_mem_slave_readdata -> mm_interconnect_0:cpu_debug_mem_slave_readdata
        wire         mm_interconnect_0_cpu_debug_mem_slave_waitrequest;         // cpu:debug_mem_slave_waitrequest -> mm_interconnect_0:cpu_debug_mem_slave_waitrequest
        wire         mm_interconnect_0_cpu_debug_mem_slave_debugaccess;         // mm_interconnect_0:cpu_debug_mem_slave_debugaccess -> cpu:debug_mem_slave_debugaccess
        wire   [8:0] mm_interconnect_0_cpu_debug_mem_slave_address;             // mm_interconnect_0:cpu_debug_mem_slave_address -> cpu:debug_mem_slave_address
        wire         mm_interconnect_0_cpu_debug_mem_slave_read;                // mm_interconnect_0:cpu_debug_mem_slave_read -> cpu:debug_mem_slave_read
        wire   [3:0] mm_interconnect_0_cpu_debug_mem_slave_byteenable;          // mm_interconnect_0:cpu_debug_mem_slave_byteenable -> cpu:debug_mem_slave_byteenable
        wire         mm_interconnect_0_cpu_debug_mem_slave_write;               // mm_interconnect_0:cpu_debug_mem_slave_write -> cpu:debug_mem_slave_write
        wire  [31:0] mm_interconnect_0_cpu_debug_mem_slave_writedata;           // mm_interconnect_0:cpu_debug_mem_slave_writedata -> cpu:debug_mem_slave_writedata
        wire  [31:0] mm_interconnect_0_cpu_peripheral_bridge_s0_readdata;       // cpu_peripheral_bridge:s0_readdata -> mm_interconnect_0:cpu_peripheral_bridge_s0_readdata
        wire         mm_interconnect_0_cpu_peripheral_bridge_s0_waitrequest;    // cpu_peripheral_bridge:s0_waitrequest -> mm_interconnect_0:cpu_peripheral_bridge_s0_waitrequest
        wire         mm_interconnect_0_cpu_peripheral_bridge_s0_debugaccess;    // mm_interconnect_0:cpu_peripheral_bridge_s0_debugaccess -> cpu_peripheral_bridge:s0_debugaccess
        wire   [8:0] mm_interconnect_0_cpu_peripheral_bridge_s0_address;        // mm_interconnect_0:cpu_peripheral_bridge_s0_address -> cpu_peripheral_bridge:s0_address
        wire         mm_interconnect_0_cpu_peripheral_bridge_s0_read;           // mm_interconnect_0:cpu_peripheral_bridge_s0_read -> cpu_peripheral_bridge:s0_read
        wire   [3:0] mm_interconnect_0_cpu_peripheral_bridge_s0_byteenable;     // mm_interconnect_0:cpu_peripheral_bridge_s0_byteenable -> cpu_peripheral_bridge:s0_byteenable
        wire         mm_interconnect_0_cpu_peripheral_bridge_s0_readdatavalid;  // cpu_peripheral_bridge:s0_readdatavalid -> mm_interconnect_0:cpu_peripheral_bridge_s0_readdatavalid
' X. @8 i4 }2 \; Q& J& l/ b+ O$ v! ~
 楼主| 发表于 2019-4-12 10:46 | 只看该作者
wire         mm_interconnect_0_cpu_peripheral_bridge_s0_write;          // mm_interconnect_0:cpu_peripheral_bridge_s0_write -> cpu_peripheral_bridge:s0_write
        wire  [31:0] mm_interconnect_0_cpu_peripheral_bridge_s0_writedata;      // mm_interconnect_0:cpu_peripheral_bridge_s0_writedata -> cpu_peripheral_bridge:s0_writedata
        wire   [0:0] mm_interconnect_0_cpu_peripheral_bridge_s0_burstcount;     // mm_interconnect_0:cpu_peripheral_bridge_s0_burstcount -> cpu_peripheral_bridge:s0_burstcount
        wire         mm_interconnect_0_sdram_s1_chipselect;                     // mm_interconnect_0:sdram_s1_chipselect -> sdram:az_cs
        wire  [15:0] mm_interconnect_0_sdram_s1_readdata;                       // sdram:za_data -> mm_interconnect_0:sdram_s1_readdata
        wire         mm_interconnect_0_sdram_s1_waitrequest;                    // sdram:za_waitrequest -> mm_interconnect_0:sdram_s1_waitrequest
        wire  [24:0] mm_interconnect_0_sdram_s1_address;                        // mm_interconnect_0:sdram_s1_address -> sdram:az_addr
        wire         mm_interconnect_0_sdram_s1_read;                           // mm_interconnect_0:sdram_s1_read -> sdram:az_rd_n
        wire   [1:0] mm_interconnect_0_sdram_s1_byteenable;                     // mm_interconnect_0:sdram_s1_byteenable -> sdram:az_be_n
        wire         mm_interconnect_0_sdram_s1_readdatavalid;                  // sdram:za_valid -> mm_interconnect_0:sdram_s1_readdatavalid
        wire         mm_interconnect_0_sdram_s1_write;                          // mm_interconnect_0:sdram_s1_write -> sdram:az_wr_n
        wire  [15:0] mm_interconnect_0_sdram_s1_writedata;                      // mm_interconnect_0:sdram_s1_writedata -> sdram:az_data
        wire         mm_interconnect_0_onchip_memory2_s1_chipselect;            // mm_interconnect_0nchip_memory2_s1_chipselect -> onchip_memory2:chipselect
        wire  [31:0] mm_interconnect_0_onchip_memory2_s1_readdata;              // onchip_memory2:readdata -> mm_interconnect_0nchip_memory2_s1_readdata
        wire  [16:0] mm_interconnect_0_onchip_memory2_s1_address;               // mm_interconnect_0nchip_memory2_s1_address -> onchip_memory2:address
        wire   [3:0] mm_interconnect_0_onchip_memory2_s1_byteenable;            // mm_interconnect_0:onchip_memory2_s1_byteenable -> onchip_memory2:byteenable
        wire         mm_interconnect_0_onchip_memory2_s1_write;                 // mm_interconnect_0:onchip_memory2_s1_write -> onchip_memory2:write
        wire  [31:0] mm_interconnect_0_onchip_memory2_s1_writedata;             // mm_interconnect_0:onchip_memory2_s1_writedata -> onchip_memory2:writedata
        wire         mm_interconnect_0_onchip_memory2_s1_clken;                 // mm_interconnect_0:onchip_memory2_s1_clken -> onchip_memory2:clken
        wire         mm_interconnect_0_timer_s1_chipselect;                     // mm_interconnect_0:timer_s1_chipselect -> timer:chipselect
        wire  [15:0] mm_interconnect_0_timer_s1_readdata;                       // timer:readdata -> mm_interconnect_0:timer_s1_readdata
        wire   [2:0] mm_interconnect_0_timer_s1_address;                        // mm_interconnect_0:timer_s1_address -> timer:address
        wire         mm_interconnect_0_timer_s1_write;                          // mm_interconnect_0:timer_s1_write -> timer:write_n
        wire  [15:0] mm_interconnect_0_timer_s1_writedata;                      // mm_interconnect_0:timer_s1_writedata -> timer:writedata
        wire         cpu_peripheral_bridge_m0_waitrequest;                      // mm_interconnect_1:cpu_peripheral_bridge_m0_waitrequest -> cpu_peripheral_bridge:m0_waitrequest
        wire  [31:0] cpu_peripheral_bridge_m0_readdata;                         // mm_interconnect_1:cpu_peripheral_bridge_m0_readdata -> cpu_peripheral_bridge:m0_readdata
        wire         cpu_peripheral_bridge_m0_debugaccess;                      // cpu_peripheral_bridge:m0_debugaccess -> mm_interconnect_1:cpu_peripheral_bridge_m0_debugaccess
        wire   [8:0] cpu_peripheral_bridge_m0_address;                          // cpu_peripheral_bridge:m0_address -> mm_interconnect_1:cpu_peripheral_bridge_m0_address
        wire         cpu_peripheral_bridge_m0_read;                             // cpu_peripheral_bridge:m0_read -> mm_interconnect_1:cpu_peripheral_bridge_m0_read
        wire   [3:0] cpu_peripheral_bridge_m0_byteenable;                       // cpu_peripheral_bridge:m0_byteenable -> mm_interconnect_1:cpu_peripheral_bridge_m0_byteenable
        wire         cpu_peripheral_bridge_m0_readdatavalid;                    // mm_interconnect_1:cpu_peripheral_bridge_m0_readdatavalid -> cpu_peripheral_bridge:m0_readdatavalid
        wire  [31:0] cpu_peripheral_bridge_m0_writedata;                        // cpu_peripheral_bridge:m0_writedata -> mm_interconnect_1:cpu_peripheral_bridge_m0_writedata
        wire         cpu_peripheral_bridge_m0_write;                            // cpu_peripheral_bridge:m0_write -> mm_interconnect_1:cpu_peripheral_bridge_m0_write
        wire   [0:0] cpu_peripheral_bridge_m0_burstcount;                       // cpu_peripheral_bridge:m0_burstcount -> mm_interconnect_1:cpu_peripheral_bridge_m0_burstcount
        wire   [7:0] mm_interconnect_1_seg7_avalon_slave_readdata;              // seg7:s_readdata -> mm_interconnect_1:seg7_avalon_slave_readdata
        wire   [2:0] mm_interconnect_1_seg7_avalon_slave_address;               // mm_interconnect_1:seg7_avalon_slave_address -> seg7:s_address
        wire         mm_interconnect_1_seg7_avalon_slave_read;                  // mm_interconnect_1:seg7_avalon_slave_read -> seg7:s_read
        wire         mm_interconnect_1_seg7_avalon_slave_write;                 // mm_interconnect_1:seg7_avalon_slave_write -> seg7:s_write
        wire   [7:0] mm_interconnect_1_seg7_avalon_slave_writedata;             // mm_interconnect_1:seg7_avalon_slave_writedata -> seg7:s_writedata
        wire         mm_interconnect_1_key_s1_chipselect;                       // mm_interconnect_1:key_s1_chipselect -> key:chipselect
        wire  [31:0] mm_interconnect_1_key_s1_readdata;                         // key:readdata -> mm_interconnect_1:key_s1_readdata
        wire   [1:0] mm_interconnect_1_key_s1_address;                          // mm_interconnect_1:key_s1_address -> key:address
        wire         mm_interconnect_1_key_s1_write;                            // mm_interconnect_1:key_s1_write -> key:write_n
        wire  [31:0] mm_interconnect_1_key_s1_writedata;                        // mm_interconnect_1:key_s1_writedata -> key:writedata
        wire         mm_interconnect_1_pio_led_s1_chipselect;                   // mm_interconnect_1:pio_led_s1_chipselect -> pio_led:chipselect
        wire  [31:0] mm_interconnect_1_pio_led_s1_readdata;                     // pio_led:readdata -> mm_interconnect_1:pio_led_s1_readdata
        wire   [1:0] mm_interconnect_1_pio_led_s1_address;                      // mm_interconnect_1:pio_led_s1_address -> pio_led:address
        wire         mm_interconnect_1_pio_led_s1_write;                        // mm_interconnect_1:pio_led_s1_write -> pio_led:write_n
        wire  [31:0] mm_interconnect_1_pio_led_s1_writedata;                    // mm_interconnect_1:pio_led_s1_writedata -> pio_led:writedata
        wire         mm_interconnect_1_sw_s1_chipselect;                        // mm_interconnect_1:sw_s1_chipselect -> sw:chipselect
        wire  [31:0] mm_interconnect_1_sw_s1_readdata;                          // sw:readdata -> mm_interconnect_1:sw_s1_readdata
        wire   [1:0] mm_interconnect_1_sw_s1_address;                           // mm_interconnect_1:sw_s1_address -> sw:address
        wire         mm_interconnect_1_sw_s1_write;                             // mm_interconnect_1:sw_s1_write -> sw:write_n
        wire  [31:0] mm_interconnect_1_sw_s1_writedata;                         // mm_interconnect_1:sw_s1_writedata -> sw:writedata
        wire  [31:0] mm_interconnect_1_din32_s1_readdata;                       // din32:readdata -> mm_interconnect_1:din32_s1_readdata
        wire   [1:0] mm_interconnect_1_din32_s1_address;                        // mm_interconnect_1:din32_s1_address -> din32:address
        wire         mm_interconnect_1_wr_full_s1_chipselect;                   // mm_interconnect_1:wr_full_s1_chipselect -> wr_full:chipselect
        wire  [31:0] mm_interconnect_1_wr_full_s1_readdata;                     // wr_full:readdata -> mm_interconnect_1:wr_full_s1_readdata
        wire   [1:0] mm_interconnect_1_wr_full_s1_address;                      // mm_interconnect_1:wr_full_s1_address -> wr_full:address
        wire         mm_interconnect_1_wr_full_s1_write;                        // mm_interconnect_1:wr_full_s1_write -> wr_full:write_n
        wire  [31:0] mm_interconnect_1_wr_full_s1_writedata;                    // mm_interconnect_1:wr_full_s1_writedata -> wr_full:writedata
        wire         mm_interconnect_1_rd_rqt_s1_chipselect;                    // mm_interconnect_1:rd_rqt_s1_chipselect -> rd_rqt:chipselect
        wire  [31:0] mm_interconnect_1_rd_rqt_s1_readdata;                      // rd_rqt:readdata -> mm_interconnect_1:rd_rqt_s1_readdata
        wire   [1:0] mm_interconnect_1_rd_rqt_s1_address;                       // mm_interconnect_1:rd_rqt_s1_address -> rd_rqt:address
        wire         mm_interconnect_1_rd_rqt_s1_write;                         // mm_interconnect_1:rd_rqt_s1_write -> rd_rqt:write_n
        wire  [31:0] mm_interconnect_1_rd_rqt_s1_writedata;                     // mm_interconnect_1:rd_rqt_s1_writedata -> rd_rqt:writedata
        wire  [31:0] mm_interconnect_1_rd_empt_s1_readdata;                     // rd_empt:readdata -> mm_interconnect_1:rd_empt_s1_readdata
        wire   [1:0] mm_interconnect_1_rd_empt_s1_address;                      // mm_interconnect_1:rd_empt_s1_address -> rd_empt:address
        wire         irq_mapper_receiver0_irq;                                  // jtag_uart:av_irq -> irq_mapper:receiver0_irq
        wire         irq_mapper_receiver3_irq;                                  // timer:irq -> irq_mapper:receiver3_irq
        wire  [31:0] cpu_irq_irq;                                               // irq_mapper:sender_irq -> cpu:irq
        wire         irq_mapper_receiver1_irq;                                  // irq_synchronizer:sender_irq -> irq_mapper:receiver1_irq
        wire   [0:0] irq_synchronizer_receiver_irq;                             // key:irq -> irq_synchronizer:receiver_irq
        wire         irq_mapper_receiver2_irq;                                  // irq_synchronizer_001:sender_irq -> irq_mapper:receiver2_irq
        wire   [0:0] irq_synchronizer_001_receiver_irq;                         // sw:irq -> irq_synchronizer_001:receiver_irq
        wire         irq_mapper_receiver4_irq;                                  // irq_synchronizer_002:sender_irq -> irq_mapper:receiver4_irq
        wire   [0:0] irq_synchronizer_002_receiver_irq;                         // wr_full:irq -> irq_synchronizer_002:receiver_irq
        wire         rst_controller_reset_out_reset;                            // rst_controller:reset_out -> [cpu:reset_n, irq_mapper:reset, irq_synchronizer:sender_reset, irq_synchronizer_001:sender_reset, irq_synchronizer_002:sender_reset, mm_interconnect_0:cpu_reset_reset_bridge_in_reset_reset, rst_translator:in_reset]
        wire         rst_controller_reset_out_reset_req;                        // rst_controller:reset_req -> [cpu:reset_req, rst_translator:reset_req_in]
        wire         cpu_debug_reset_request_reset;                             // cpu:debug_reset_request -> rst_controller:reset_in1
        wire         rst_controller_001_reset_out_reset;                        // rst_controller_001:reset_out -> [cpu_peripheral_bridge:m0_reset, din32:reset_n, irq_synchronizer:receiver_reset, irq_synchronizer_001:receiver_reset, irq_synchronizer_002:receiver_reset, key:reset_n, mm_interconnect_1:cpu_peripheral_bridge_m0_reset_reset_bridge_in_reset_reset, pio_led:reset_n, rd_empt:reset_n, rd_rqt:reset_n, seg7:s_reset, sw:reset_n, wr_full:reset_n]
        wire         rst_controller_002_reset_out_reset;                        // rst_controller_002:reset_out -> [cpu_peripheral_bridge:s0_reset, jtag_uart:rst_n, mm_interconnect_0:jtag_uart_reset_reset_bridge_in_reset_reset, onchip_memory2:reset, rst_translator_001:in_reset, sdram:reset_n, sysid_qsys:reset_n, timer:reset_n]
        wire         rst_controller_002_reset_out_reset_req;                    // rst_controller_002:reset_req -> [onchip_memory2:reset_req, rst_translator_001:reset_req_in]
* j6 N0 {2 C: v5 E
        audio_nios_cpu cpu (
                .clk                                 (pll_outclk0_clk),                                   //                       clk.clk
                .reset_n                             (~rst_controller_reset_out_reset),                   //                     reset.reset_n
                .reset_req                           (rst_controller_reset_out_reset_req),                //                          .reset_req
                .d_address                           (cpu_data_master_address),                           //               data_master.address
                .d_byteenable                        (cpu_data_master_byteenable),                        //                          .byteenable
                .d_read                              (cpu_data_master_read),                              //                          .read
                .d_readdata                          (cpu_data_master_readdata),                          //                          .readdata
                .d_waitrequest                       (cpu_data_master_waitrequest),                       //                          .waitrequest
                .d_write                             (cpu_data_master_write),                             //                          .write
                .d_writedata                         (cpu_data_master_writedata),                         //                          .writedata
                .d_readdatavalid                     (cpu_data_master_readdatavalid),                     //                          .readdatavalid
                .debug_mem_slave_debugaccess_to_roms (cpu_data_master_debugaccess),                       //                          .debugaccess
                .i_address                           (cpu_instruction_master_address),                    //        instruction_master.address
                .i_read                              (cpu_instruction_master_read),                       //                          .read
                .i_readdata                          (cpu_instruction_master_readdata),                   //                          .readdata
                .i_waitrequest                       (cpu_instruction_master_waitrequest),                //                          .waitrequest
                .i_readdatavalid                     (cpu_instruction_master_readdatavalid),              //                          .readdatavalid
                .irq                                 (cpu_irq_irq),                                       //                       irq.irq
7 _& a) z2 @2 x2 ]3 C
.debug_reset_request (cpu_debug_reset_request_reset), // debug_reset_request.reset .debug_mem_slave_address (mm_interconnect_0_c  详情 回复 发表于 2019-4-12 10:46
1 v1 H) H8 c7 Y$ w7 f. \# h
                .debug_mem_slave_address             (mm_interconnect_0_cpu_debug_mem_slave_address),     //           debug_mem_slave.address
                .debug_mem_slave_byteenable          (mm_interconnect_0_cpu_debug_mem_slave_byteenable),  //                          .byteenable
                .debug_mem_slave_debugaccess         (mm_interconnect_0_cpu_debug_mem_slave_debugaccess), //                          .debugaccess
                .debug_mem_slave_read                (mm_interconnect_0_cpu_debug_mem_slave_read),        //                          .read
                .debug_mem_slave_readdata            (mm_interconnect_0_cpu_debug_mem_slave_readdata),    //                          .readdata
                .debug_mem_slave_waitrequest         (mm_interconnect_0_cpu_debug_mem_slave_waitrequest), //                          .waitrequest
                .debug_mem_slave_write               (mm_interconnect_0_cpu_debug_mem_slave_write),       //                          .write
                .debug_mem_slave_writedata           (mm_interconnect_0_cpu_debug_mem_slave_writedata),   //                          .writedata
                .dummy_ci_port                       ()                                                   // custom_instruction_master.readra
+ E9 \3 l3 X7 P+ I# [& f4 i; E
        altera_avalon_mm_clock_crossing_bridge #(
                .DATA_WIDTH          (32),
                .SYMBOL_WIDTH        (8),
                .HDL_ADDR_WIDTH      (9),
                .BURSTCOUNT_WIDTH    (1),
                .COMMAND_FIFO_DEPTH  (32),
                .RESPONSE_FIFO_DEPTH (64),
                .MASTER_SYNC_DEPTH   (3),
                .SLAVE_SYNC_DEPTH    (3)
        ) cpu_peripheral_bridge (
                .m0_clk           (pll_outclk2_clk),                                          //   m0_clk.clk
                .m0_reset         (rst_controller_001_reset_out_reset),                       // m0_reset.reset
                .s0_clk           (pll_outclk0_clk),                                          //   s0_clk.clk
                .s0_reset         (rst_controller_002_reset_out_reset),                       // s0_reset.reset
                .s0_waitrequest   (mm_interconnect_0_cpu_peripheral_bridge_s0_waitrequest),   //       s0.waitrequest
                .s0_readdata      (mm_interconnect_0_cpu_peripheral_bridge_s0_readdata),      //         .readdata
                .s0_readdatavalid (mm_interconnect_0_cpu_peripheral_bridge_s0_readdatavalid), //         .readdatavalid
                .s0_burstcount    (mm_interconnect_0_cpu_peripheral_bridge_s0_burstcount),    //         .burstcount
                .s0_writedata     (mm_interconnect_0_cpu_peripheral_bridge_s0_writedata),     //         .writedata
                .s0_address       (mm_interconnect_0_cpu_peripheral_bridge_s0_address),       //         .address
                .s0_write         (mm_interconnect_0_cpu_peripheral_bridge_s0_write),         //         .write
                .s0_read          (mm_interconnect_0_cpu_peripheral_bridge_s0_read),          //         .read
                .s0_byteenable    (mm_interconnect_0_cpu_peripheral_bridge_s0_byteenable),    //         .byteenable
                .s0_debugaccess   (mm_interconnect_0_cpu_peripheral_bridge_s0_debugaccess),   //         .debugaccess
                .m0_waitrequest   (cpu_peripheral_bridge_m0_waitrequest),                     //       m0.waitrequest
                .m0_readdata      (cpu_peripheral_bridge_m0_readdata),                        //         .readdata
                .m0_readdatavalid (cpu_peripheral_bridge_m0_readdatavalid),                   //         .readdatavalid
                .m0_burstcount    (cpu_peripheral_bridge_m0_burstcount),                      //         .burstcount
                .m0_writedata     (cpu_peripheral_bridge_m0_writedata),                       //         .writedata
                .m0_address       (cpu_peripheral_bridge_m0_address),                         //         .address
                .m0_write         (cpu_peripheral_bridge_m0_write),                           //         .write
                .m0_read          (cpu_peripheral_bridge_m0_read),                            //         .read
                .m0_byteenable    (cpu_peripheral_bridge_m0_byteenable),                      //         .byteenable
                .m0_debugaccess   (cpu_peripheral_bridge_m0_debugaccess)                      //         .debugaccess
  a% b8 w( `. S; D* A+ a/ h
        audio_nios_din32 din32 (
                .clk      (pll_outclk2_clk),                     //                 clk.clk
                .reset_n  (~rst_controller_001_reset_out_reset), //               reset.reset_n
                .address  (mm_interconnect_1_din32_s1_address),  //                  s1.address
                .readdata (mm_interconnect_1_din32_s1_readdata), //                    .readdata
                .in_port  (din32_external_connection_export)     // external_connection.export
3 O3 G) ~. o% t& w
        audio_nios_jtag_uart jtag_uart (
                .rst_n          (~rst_controller_002_reset_out_reset),                       //             reset.reset_n
                .av_chipselect  (mm_interconnect_0_jtag_uart_avalon_jtag_slave_chipselect),  // avalon_jtag_slave.chipselect
                .av_address     (mm_interconnect_0_jtag_uart_avalon_jtag_slave_address),     //                  .address
                .av_read_n      (~mm_interconnect_0_jtag_uart_avalon_jtag_slave_read),       //                  .read_n
                .av_readdata    (mm_interconnect_0_jtag_uart_avalon_jtag_slave_readdata),    //                  .readdata
                .av_write_n     (~mm_interconnect_0_jtag_uart_avalon_jtag_slave_write),      //                  .write_n
                .av_writedata   (mm_interconnect_0_jtag_uart_avalon_jtag_slave_writedata),   //                  .writedata
                .av_waitrequest (mm_interconnect_0_jtag_uart_avalon_jtag_slave_waitrequest), //                  .waitrequest
                .av_irq         (irq_mapper_receiver0_irq)                                   //               irq.irq
; H0 e' |- m7 B# A
        audio_nios_key key (
                .address    (mm_interconnect_1_key_s1_address),    //                  s1.address
                .write_n    (~mm_interconnect_1_key_s1_write),     //                    .write_n
                .writedata  (mm_interconnect_1_key_s1_writedata),  //                    .writedata
                .chipselect (mm_interconnect_1_key_s1_chipselect), //                    .chipselect
                .readdata   (mm_interconnect_1_key_s1_readdata),   //                    .readdata
                .in_port    (key_external_connection_export),      // external_connection.export
                .irq        (irq_synchronizer_receiver_irq)        //                 irq.irq
9 _( j+ s% W3 A6 c4 v& l6 J" N
        audio_nios_onchip_memory2 onchip_memory2 (
                .clk        (pll_outclk0_clk),                                //   clk1.clk
                .address    (mm_interconnect_0_onchip_memory2_s1_address),    //     s1.address
                .clken      (mm_interconnect_0_onchip_memory2_s1_clken),      //       .clken
                .chipselect (mm_interconnect_0_onchip_memory2_s1_chipselect), //       .chipselect
                .write      (mm_interconnect_0_onchip_memory2_s1_write),      //       .write
                .readdata   (mm_interconnect_0_onchip_memory2_s1_readdata),   //       .readdata
                .writedata  (mm_interconnect_0_onchip_memory2_s1_writedata),  //       .writedata
                .byteenable (mm_interconnect_0_onchip_memory2_s1_byteenable), //       .byteenable
                .reset      (rst_controller_002_reset_out_reset),             // reset1.reset
                .reset_req  (rst_controller_002_reset_out_reset_req)          //       .reset_req
8 s# L0 c. z0 j" E0 [1 _" |' d
        audio_nios_pio_led pio_led (
                .address    (mm_interconnect_1_pio_led_s1_address),    //                  s1.address
                .write_n    (~mm_interconnect_1_pio_led_s1_write),     //                    .write_n
                .writedata  (mm_interconnect_1_pio_led_s1_writedata),  //                    .writedata
                .chipselect (mm_interconnect_1_pio_led_s1_chipselect), //                    .chipselect
                .readdata   (mm_interconnect_1_pio_led_s1_readdata),   //                    .readdata
                .out_port   (pio_0_external_connection_export)         // external_connection.export
0 G2 `* R+ p% \* T' n- J
        audio_nios_pll pll (
                .refclk   (clk_clk),           //  refclk.clk
                .rst      (~reset_reset_n),    //   reset.reset
                .outclk_0 (pll_outclk0_clk),   // outclk0.clk
                .outclk_1 (pll_sdam_clk),      // outclk1.clk
                .outclk_2 (pll_outclk2_clk),   // outclk2.clk
                .outclk_3 (pll_outclk3_clk),   // outclk3.clk
                .locked   (pll_locked_export)  //  locked.export
& O* W' w' F1 G# C& y1 O/ j
        audio_nios_rd_empt rd_empt (
                .address  (mm_interconnect_1_rd_empt_s1_address),  //                  s1.address
                .readdata (mm_interconnect_1_rd_empt_s1_readdata), //                    .readdata
                .in_port  (rd_empt_external_connection_export)     // external_connection.export
* r% i/ p' h: W6 a7 z# [# y( J
        audio_nios_rd_rqt rd_rqt (
                .address    (mm_interconnect_1_rd_rqt_s1_address),    //                  s1.address
                .write_n    (~mm_interconnect_1_rd_rqt_s1_write),     //                    .write_n
                .writedata  (mm_interconnect_1_rd_rqt_s1_writedata),  //                    .writedata
                .chipselect (mm_interconnect_1_rd_rqt_s1_chipselect), //                    .chipselect
                .readdata   (mm_interconnect_1_rd_rqt_s1_readdata),   //                    .readdata
                .out_port   (rd_rqt_external_connection_export)       // external_connection.export
2 J3 r* a8 L) p) B4 S' i0 L
 楼主| 发表于 2019-4-12 10:47 | 只看该作者
Taio 发表于 2019-4-12 10:46' m2 @4 h/ ]. w6 N; f5 w* a
.debug_reset_request                 (cpu_debug_reset_request_reset),                     //    ...
  d" t9 D1 v0 T" ~$ J4 p6 V
audio_nios_sdram sdram (
                .reset_n        (~rst_controller_002_reset_out_reset),      // reset.reset_n
                .az_addr        (mm_interconnect_0_sdram_s1_address),       //    s1.address
                .az_be_n        (~mm_interconnect_0_sdram_s1_byteenable),   //      .byteenable_n
                .az_cs          (mm_interconnect_0_sdram_s1_chipselect),    //      .chipselect
                .az_data        (mm_interconnect_0_sdram_s1_writedata),     //      .writedata
                .az_rd_n        (~mm_interconnect_0_sdram_s1_read),         //      .read_n
                .az_wr_n        (~mm_interconnect_0_sdram_s1_write),        //      .write_n
                .za_data        (mm_interconnect_0_sdram_s1_readdata),      //      .readdata
                .za_valid       (mm_interconnect_0_sdram_s1_readdatavalid), //      .readdatavalid
                .za_waitrequest (mm_interconnect_0_sdram_s1_waitrequest),   //      .waitrequest
                .zs_addr        (sdram_wire_addr),                          //  wire.export
                .zs_ba          (sdram_wire_ba),                            //      .export
                .zs_cas_n       (sdram_wire_cas_n),                         //      .export
                .zs_cke         (sdram_wire_cke),                           //      .export
                .zs_cs_n        (sdram_wire_cs_n),                          //      .export
                .zs_dq          (sdram_wire_dq),                            //      .export
                .zs_dqm         (sdram_wire_dqm),                           //      .export
                .zs_ras_n       (sdram_wire_ras_n),                         //      .export
                .zs_we_n        (sdram_wire_we_n)                           //      .export
' O1 B3 H6 }/ `8 l% z
        SEG7_IF #(
                .SEG7_NUM       (6),
                .ADDR_WIDTH     (3),
                .DEFAULT_ACTIVE (1),
                .LOW_ACTIVE     (1)
        ) seg7 (
                .s_address   (mm_interconnect_1_seg7_avalon_slave_address),   //     avalon_slave.address
                .s_read      (mm_interconnect_1_seg7_avalon_slave_read),      //                 .read
                .s_readdata  (mm_interconnect_1_seg7_avalon_slave_readdata),  //                 .readdata
                .s_write     (mm_interconnect_1_seg7_avalon_slave_write),     //                 .write
                .s_writedata (mm_interconnect_1_seg7_avalon_slave_writedata), //                 .writedata
                .SEG7        (seg7_conduit_end_export),                       //      conduit_end.export
                .s_clk       (pll_outclk2_clk),                               //       clock_sink.clk
                .s_reset     (rst_controller_001_reset_out_reset)             // clock_sink_reset.reset
- i2 N* X" l7 @/ {( R+ F
        audio_nios_sw sw (
                .address    (mm_interconnect_1_sw_s1_address),     //                  s1.address
                .write_n    (~mm_interconnect_1_sw_s1_write),      //                    .write_n
                .writedata  (mm_interconnect_1_sw_s1_writedata),   //                    .writedata
                .chipselect (mm_interconnect_1_sw_s1_chipselect),  //                    .chipselect
                .readdata   (mm_interconnect_1_sw_s1_readdata),    //                    .readdata
                .in_port    (sw_external_connection_export),       // external_connection.export
                .irq        (irq_synchronizer_001_receiver_irq)    //                 irq.irq
) D3 @! m: O- Z9 M4 K$ L7 D
        audio_nios_sysid_qsys sysid_qsys (
                .clock    (pll_outclk0_clk),                                     //           clk.clk
                .readdata (mm_interconnect_0_sysid_qsys_control_slave_readdata), // control_slave.readdata
                .address  (mm_interconnect_0_sysid_qsys_control_slave_address)   //              .address
$ z8 x+ P: |8 I- p% i* C7 ~7 \5 g' R6 p* |
9 i  D/ f! E! y7 p
% t$ @  v) e: o! H& u, C
" K0 E, ^# i8 e2 o; C3 I
audio_nios_timer timer (
                .address    (mm_interconnect_0_timer_s1_address),    //    s1.address
                .writedata  (mm_interconnect_0_timer_s1_writedata),  //      .writedata
                .readdata   (mm_interconnect_0_timer_s1_readdata),   //      .readdata
                .chipselect (mm_interconnect_0_timer_s1_chipselect), //      .chipselect
                .write_n    (~mm_interconnect_0_timer_s1_write),     //      .write_n
                .irq        (irq_mapper_receiver3_irq)               //   irq.irq
4 U# y) f; L; J
        audio_nios_wr_full wr_full (
                .address    (mm_interconnect_1_wr_full_s1_address),    //                  s1.address
                .write_n    (~mm_interconnect_1_wr_full_s1_write),     //                    .write_n
                .writedata  (mm_interconnect_1_wr_full_s1_writedata),  //                    .writedata
                .chipselect (mm_interconnect_1_wr_full_s1_chipselect), //                    .chipselect
                .readdata   (mm_interconnect_1_wr_full_s1_readdata),   //                    .readdata
                .in_port    (wr_full_external_connection_export),      // external_connection.export
                .irq        (irq_synchronizer_002_receiver_irq)        //                 irq.irq
& n. p# T1 V, c& q
        audio_nios_mm_interconnect_0 mm_interconnect_0 (
                .pll_outclk0_clk                             (pll_outclk0_clk),                                           //                           pll_outclk0.clk
                .cpu_reset_reset_bridge_in_reset_reset       (rst_controller_reset_out_reset),                            //       cpu_reset_reset_bridge_in_reset.reset
                .jtag_uart_reset_reset_bridge_in_reset_reset (rst_controller_002_reset_out_reset),                        // jtag_uart_reset_reset_bridge_in_reset.reset
                .cpu_data_master_address                     (cpu_data_master_address),                                   //                       cpu_data_master.address
                .cpu_data_master_waitrequest                 (cpu_data_master_waitrequest),                               //                                      .waitrequest
                .cpu_data_master_byteenable                  (cpu_data_master_byteenable),                                //                                      .byteenable
                .cpu_data_master_read                        (cpu_data_master_read),                                      //                                      .read
                .cpu_data_master_readdata                    (cpu_data_master_readdata),                                  //                                      .readdata
                .cpu_data_master_readdatavalid               (cpu_data_master_readdatavalid),                             //                                      .readdatavalid
                .cpu_data_master_write                       (cpu_data_master_write),                                     //                                      .write
                .cpu_data_master_writedata                   (cpu_data_master_writedata),                                 //                                      .writedata
                .cpu_data_master_debugaccess                 (cpu_data_master_debugaccess),                               //                                      .debugaccess
                .cpu_instruction_master_address              (cpu_instruction_master_address),                            //                cpu_instruction_master.address
                .cpu_instruction_master_waitrequest          (cpu_instruction_master_waitrequest),                        //                                      .waitrequest
                .cpu_instruction_master_read                 (cpu_instruction_master_read),                               //                                      .read
                .cpu_instruction_master_readdata             (cpu_instruction_master_readdata),                           //                                      .readdata
                .cpu_instruction_master_readdatavalid        (cpu_instruction_master_readdatavalid),                      //                                      .readdatavalid
                .cpu_debug_mem_slave_address                 (mm_interconnect_0_cpu_debug_mem_slave_address),             //                   cpu_debug_mem_slave.address
                .cpu_debug_mem_slave_write                   (mm_interconnect_0_cpu_debug_mem_slave_write),               //                                      .write
                .cpu_debug_mem_slave_read                    (mm_interconnect_0_cpu_debug_mem_slave_read),                //                                      .read
                .cpu_debug_mem_slave_readdata                (mm_interconnect_0_cpu_debug_mem_slave_readdata),            //                                      .readdata
                .cpu_debug_mem_slave_writedata               (mm_interconnect_0_cpu_debug_mem_slave_writedata),           //                                      .writedata
                .cpu_debug_mem_slave_byteenable              (mm_interconnect_0_cpu_debug_mem_slave_byteenable),          //                                      .byteenable
                .cpu_debug_mem_slave_waitrequest             (mm_interconnect_0_cpu_debug_mem_slave_waitrequest),         //                                      .waitrequest
                .cpu_debug_mem_slave_debugaccess             (mm_interconnect_0_cpu_debug_mem_slave_debugaccess),         //                                      .debugaccess
                .cpu_peripheral_bridge_s0_address            (mm_interconnect_0_cpu_peripheral_bridge_s0_address),        //              cpu_peripheral_bridge_s0.address
                .cpu_peripheral_bridge_s0_write              (mm_interconnect_0_cpu_peripheral_bridge_s0_write),          //                                      .write
                .cpu_peripheral_bridge_s0_read               (mm_interconnect_0_cpu_peripheral_bridge_s0_read),           //                                      .read
                .cpu_peripheral_bridge_s0_readdata           (mm_interconnect_0_cpu_peripheral_bridge_s0_readdata),       //                                      .readdata
                .cpu_peripheral_bridge_s0_writedata          (mm_interconnect_0_cpu_peripheral_bridge_s0_writedata),      //                                      .writedata
                .cpu_peripheral_bridge_s0_burstcount         (mm_interconnect_0_cpu_peripheral_bridge_s0_burstcount),     //                                      .burstcount
                .cpu_peripheral_bridge_s0_byteenable         (mm_interconnect_0_cpu_peripheral_bridge_s0_byteenable),     //                                      .byteenable
                .cpu_peripheral_bridge_s0_readdatavalid      (mm_interconnect_0_cpu_peripheral_bridge_s0_readdatavalid),  //                                      .readdatavalid
                .cpu_peripheral_bridge_s0_waitrequest        (mm_interconnect_0_cpu_peripheral_bridge_s0_waitrequest),    //                                      .waitrequest
                .cpu_peripheral_bridge_s0_debugaccess        (mm_interconnect_0_cpu_peripheral_bridge_s0_debugaccess),    //                                      .debugaccess
                .jtag_uart_avalon_jtag_slave_address         (mm_interconnect_0_jtag_uart_avalon_jtag_slave_address),     //           jtag_uart_avalon_jtag_slave.address
                .jtag_uart_avalon_jtag_slave_write           (mm_interconnect_0_jtag_uart_avalon_jtag_slave_write),       //                                      .write
                .jtag_uart_avalon_jtag_slave_read            (mm_interconnect_0_jtag_uart_avalon_jtag_slave_read),        //                                      .read
                .jtag_uart_avalon_jtag_slave_readdata        (mm_interconnect_0_jtag_uart_avalon_jtag_slave_readdata),    //                                      .readdata
                .jtag_uart_avalon_jtag_slave_writedata       (mm_interconnect_0_jtag_uart_avalon_jtag_slave_writedata),   //                                      .writedata
                .jtag_uart_avalon_jtag_slave_waitrequest     (mm_interconnect_0_jtag_uart_avalon_jtag_slave_waitrequest), //                                      .waitrequest
                .jtag_uart_avalon_jtag_slave_chipselect      (mm_interconnect_0_jtag_uart_avalon_jtag_slave_chipselect),  //                                      .chipselect
                .onchip_memory2_s1_address                   (mm_interconnect_0_onchip_memory2_s1_address),               //                     onchip_memory2_s1.address
                .onchip_memory2_s1_write                     (mm_interconnect_0_onchip_memory2_s1_write),                 //                                      .write
                .onchip_memory2_s1_readdata                  (mm_interconnect_0_onchip_memory2_s1_readdata),              //                                      .readdata
                .onchip_memory2_s1_writedata                 (mm_interconnect_0_onchip_memory2_s1_writedata),             //                                      .writedata
                .onchip_memory2_s1_byteenable                (mm_interconnect_0_onchip_memory2_s1_byteenable),            //                                      .byteenable
                .onchip_memory2_s1_chipselect                (mm_interconnect_0_onchip_memory2_s1_chipselect),            //                                      .chipselect
                .onchip_memory2_s1_clken                     (mm_interconnect_0_onchip_memory2_s1_clken),                 //                                      .clken
                .sdram_s1_address                            (mm_interconnect_0_sdram_s1_address),                        //                              sdram_s1.address
                .sdram_s1_write                              (mm_interconnect_0_sdram_s1_write),                          //                                      .write
                .sdram_s1_read                               (mm_interconnect_0_sdram_s1_read),                           //                                      .read
                .sdram_s1_readdata                           (mm_interconnect_0_sdram_s1_readdata),                       //                                      .readdata
                .sdram_s1_writedata                          (mm_interconnect_0_sdram_s1_writedata),                      //                                      .writedata
                .sdram_s1_byteenable                         (mm_interconnect_0_sdram_s1_byteenable),                     //                                      .byteenable
                .sdram_s1_readdatavalid                      (mm_interconnect_0_sdram_s1_readdatavalid),                  //                                      .readdatavalid
                .sdram_s1_waitrequest                        (mm_interconnect_0_sdram_s1_waitrequest),                    //                                      .waitrequest
                .sdram_s1_chipselect                         (mm_interconnect_0_sdram_s1_chipselect),                     //                                      .chipselect
                .sysid_qsys_control_slave_address            (mm_interconnect_0_sysid_qsys_control_slave_address),        //              sysid_qsys_control_slave.address
                .sysid_qsys_control_slave_readdata           (mm_interconnect_0_sysid_qsys_control_slave_readdata),       //                                      .readdata
                .timer_s1_address                            (mm_interconnect_0_timer_s1_address),                        //                              timer_s1.address
                .timer_s1_write                              (mm_interconnect_0_timer_s1_write),                          //                                      .write
                .timer_s1_readdata                           (mm_interconnect_0_timer_s1_readdata),                       //                                      .readdata
                .timer_s1_writedata                          (mm_interconnect_0_timer_s1_writedata),                      //                                      .writedata
                .timer_s1_chipselect                         (mm_interconnect_0_timer_s1_chipselect)                      //                                      .chipselect
- Q* I. R0 `' Q8 B6 b& E5 Y5 U
7 z$ M& H. B& b, y$ A- w
5 s. e# @0 R4 V& g! A, F
audio_nios_mm_interconnect_1 mm_interconnect_1 ( .pll_outclk2_clk (pll_outclk2_clk), //  详情 回复 发表于 2019-4-12 10:48
 楼主| 发表于 2019-4-12 10:48 | 只看该作者
. Z, R+ B$ ~) }" \( B
                .pll_outclk2_clk                                            (pll_outclk2_clk),                               //                                          pll_outclk2.clk
                .cpu_peripheral_bridge_m0_reset_reset_bridge_in_reset_reset (rst_controller_001_reset_out_reset),            // cpu_peripheral_bridge_m0_reset_reset_bridge_in_reset.reset
                .cpu_peripheral_bridge_m0_address                           (cpu_peripheral_bridge_m0_address),              //                             cpu_peripheral_bridge_m0.address
                .cpu_peripheral_bridge_m0_waitrequest                       (cpu_peripheral_bridge_m0_waitrequest),          //                                                     .waitrequest
                .cpu_peripheral_bridge_m0_burstcount                        (cpu_peripheral_bridge_m0_burstcount),           //                                                     .burstcount
                .cpu_peripheral_bridge_m0_byteenable                        (cpu_peripheral_bridge_m0_byteenable),           //                                                     .byteenable
                .cpu_peripheral_bridge_m0_read                              (cpu_peripheral_bridge_m0_read),                 //                                                     .read
                .cpu_peripheral_bridge_m0_readdata                          (cpu_peripheral_bridge_m0_readdata),             //                                                     .readdata
                .cpu_peripheral_bridge_m0_readdatavalid                     (cpu_peripheral_bridge_m0_readdatavalid),        //                                                     .readdatavalid
                .cpu_peripheral_bridge_m0_write                             (cpu_peripheral_bridge_m0_write),                //                                                     .write
                .cpu_peripheral_bridge_m0_writedata                         (cpu_peripheral_bridge_m0_writedata),            //                                                     .writedata
                .cpu_peripheral_bridge_m0_debugaccess                       (cpu_peripheral_bridge_m0_debugaccess),          //                                                     .debugaccess
                .din32_s1_address                                           (mm_interconnect_1_din32_s1_address),            //                                             din32_s1.address
                .din32_s1_readdata                                          (mm_interconnect_1_din32_s1_readdata),           //                                                     .readdata
                .key_s1_address                                             (mm_interconnect_1_key_s1_address),              //                                               key_s1.address
                .key_s1_write                                               (mm_interconnect_1_key_s1_write),                //                                                     .write
                .key_s1_readdata                                            (mm_interconnect_1_key_s1_readdata),             //                                                     .readdata
                .key_s1_writedata                                           (mm_interconnect_1_key_s1_writedata),            //                                                     .writedata
                .key_s1_chipselect                                          (mm_interconnect_1_key_s1_chipselect),           //                                                     .chipselect
                .pio_led_s1_address                                         (mm_interconnect_1_pio_led_s1_address),          //                                           pio_led_s1.address
                .pio_led_s1_write                                           (mm_interconnect_1_pio_led_s1_write),            //                                                     .write
                .pio_led_s1_readdata                                        (mm_interconnect_1_pio_led_s1_readdata),         //                                                     .readdata
                .pio_led_s1_writedata                                       (mm_interconnect_1_pio_led_s1_writedata),        //                                                     .writedata
                .pio_led_s1_chipselect                                      (mm_interconnect_1_pio_led_s1_chipselect),       //                                                     .chipselect
                .rd_empt_s1_address                                         (mm_interconnect_1_rd_empt_s1_address),          //                                           rd_empt_s1.address
                .rd_empt_s1_readdata                                        (mm_interconnect_1_rd_empt_s1_readdata),         //                                                     .readdata
                .rd_rqt_s1_address                                          (mm_interconnect_1_rd_rqt_s1_address),           //                                            rd_rqt_s1.address
                .rd_rqt_s1_write                                            (mm_interconnect_1_rd_rqt_s1_write),             //                                                     .write
                .rd_rqt_s1_readdata                                         (mm_interconnect_1_rd_rqt_s1_readdata),          //                                                     .readdata
                .rd_rqt_s1_writedata                                        (mm_interconnect_1_rd_rqt_s1_writedata),         //                                                     .writedata
                .rd_rqt_s1_chipselect                                       (mm_interconnect_1_rd_rqt_s1_chipselect),        //                                                     .chipselect
                .seg7_avalon_slave_address                                  (mm_interconnect_1_seg7_avalon_slave_address),   //                                    seg7_avalon_slave.address
                .seg7_avalon_slave_write                                    (mm_interconnect_1_seg7_avalon_slave_write),     //                                                     .write
                .seg7_avalon_slave_read                                     (mm_interconnect_1_seg7_avalon_slave_read),      //                                                     .read
                .seg7_avalon_slave_readdata                                 (mm_interconnect_1_seg7_avalon_slave_readdata),  //                                                     .readdata
                .seg7_avalon_slave_writedata                                (mm_interconnect_1_seg7_avalon_slave_writedata), //                                                     .writedata
                .sw_s1_address                                              (mm_interconnect_1_sw_s1_address),               //                                                sw_s1.address
                .sw_s1_write                                                (mm_interconnect_1_sw_s1_write),                 //                                                     .write
                .sw_s1_readdata                                             (mm_interconnect_1_sw_s1_readdata),              //                                                     .readdata
                .sw_s1_writedata                                            (mm_interconnect_1_sw_s1_writedata),             //                                                     .writedata
                .sw_s1_chipselect                                           (mm_interconnect_1_sw_s1_chipselect),            //                                                     .chipselect
                .wr_full_s1_address                                         (mm_interconnect_1_wr_full_s1_address),          //                                           wr_full_s1.address
                .wr_full_s1_write                                           (mm_interconnect_1_wr_full_s1_write),            //                                                     .write
                .wr_full_s1_readdata                                        (mm_interconnect_1_wr_full_s1_readdata),         //                                                     .readdata
                .wr_full_s1_writedata                                       (mm_interconnect_1_wr_full_s1_writedata),        //                                                     .writedata
                .wr_full_s1_chipselect                                      (mm_interconnect_1_wr_full_s1_chipselect)        //                                                     .chipselect
5 K0 L+ c7 _2 I- o
        audio_nios_irq_mapper irq_mapper (
                .reset         (rst_controller_reset_out_reset), // clk_reset.reset
                .receiver0_irq (irq_mapper_receiver0_irq),       // receiver0.irq
                .receiver1_irq (irq_mapper_receiver1_irq),       // receiver1.irq
                .receiver2_irq (irq_mapper_receiver2_irq),       // receiver2.irq
                .receiver3_irq (irq_mapper_receiver3_irq),       // receiver3.irq
                .receiver4_irq (irq_mapper_receiver4_irq),       // receiver4.irq
                .sender_irq    (cpu_irq_irq)                     //    sender.irq
  l$ m4 V; q! D" L" }
        altera_irq_clock_crosser #(
                .IRQ_WIDTH (1)
        ) irq_synchronizer (
                .receiver_clk   (pll_outclk2_clk),                    //       receiver_clk.clk
                .sender_clk     (pll_outclk0_clk),                    //         sender_clk.clk
                .receiver_reset (rst_controller_001_reset_out_reset), // receiver_clk_reset.reset
                .sender_reset   (rst_controller_reset_out_reset),     //   sender_clk_reset.reset
                .receiver_irq   (irq_synchronizer_receiver_irq),      //           receiver.irq
                .sender_irq     (irq_mapper_receiver1_irq)            //             sender.irq
- t. {1 {7 I8 y; X- ]$ P1 p2 ?
                .IRQ_WIDTH (1)
        ) irq_synchronizer_001 (
                .receiver_irq   (irq_synchronizer_001_receiver_irq),  //           receiver.irq
                .sender_irq     (irq_mapper_receiver2_irq)            //             sender.irq
' T& g* N% H& U) ]
3 M. A( z- ]/ V9 h' P
Taio 发表于 2019-4-12 10:489 @! N) _& q6 H' P# f! k
audio_nios_mm_interconnect_1 mm_interconnect_1 (                .pll_outclk2_clk                  ...
+ R2 d3 N* V& `+ _4 q
                .IRQ_WIDTH (1)
        ) irq_synchronizer_002 (
                .receiver_irq   (irq_synchronizer_002_receiver_irq),  //           receiver.irq
                .sender_irq     (irq_mapper_receiver4_irq)            //             sender.irq
# m$ F$ M0 M8 Q- u, P& ]
        altera_reset_controller #(
                .NUM_RESET_INPUTS          (2),
                .OUTPUT_RESET_SYNC_EDGES   ("deassert"),
                .SYNC_DEPTH                (2),
                .RESET_REQUEST_PRESENT     (1),
                .RESET_REQ_WAIT_TIME       (1),
                .MIN_RST_ASSERTION_TIME    (3),
                .RESET_REQ_EARLY_DSRT_TIME (1),
                .USE_RESET_REQUEST_IN0     (0),
                .USE_RESET_REQUEST_IN1     (0),
                .USE_RESET_REQUEST_IN2     (0),
                .USE_RESET_REQUEST_IN3     (0),
                .USE_RESET_REQUEST_IN4     (0),
                .USE_RESET_REQUEST_IN5     (0),
                .USE_RESET_REQUEST_IN6     (0),
                .USE_RESET_REQUEST_IN7     (0),
                .USE_RESET_REQUEST_IN8     (0),
                .USE_RESET_REQUEST_IN9     (0),
                .USE_RESET_REQUEST_IN10    (0),
                .USE_RESET_REQUEST_IN11    (0),
                .USE_RESET_REQUEST_IN12    (0),
                .USE_RESET_REQUEST_IN13    (0),
                .USE_RESET_REQUEST_IN14    (0),
                .USE_RESET_REQUEST_IN15    (0),
                .ADAPT_RESET_REQUEST       (0)
        ) rst_controller (
                .reset_in0      (~reset_reset_n),                     // reset_in0.reset
                .reset_in1      (cpu_debug_reset_request_reset),      // reset_in1.reset
                .reset_out      (rst_controller_reset_out_reset),     // reset_out.reset
                .reset_req_in0  (1'b0),                               // (terminated)
                .reset_req_in1  (1'b0),                               // (terminated)
                .reset_in2      (1'b0),                               // (terminated)
                .reset_req_in2  (1'b0),                               // (terminated)
                .reset_in3      (1'b0),                               // (terminated)
                .reset_req_in3  (1'b0),                               // (terminated)
                .reset_in4      (1'b0),                               // (terminated)
                .reset_req_in4  (1'b0),                               // (terminated)
                .reset_in5      (1'b0),                               // (terminated)
                .reset_req_in5  (1'b0),                               // (terminated)
                .reset_in6      (1'b0),                               // (terminated)
                .reset_req_in6  (1'b0),                               // (terminated)
                .reset_in7      (1'b0),                               // (terminated)
                .reset_req_in7  (1'b0),                               // (terminated)
                .reset_in8      (1'b0),                               // (terminated)
                .reset_req_in8  (1'b0),                               // (terminated)
                .reset_in9      (1'b0),                               // (terminated)
                .reset_req_in9  (1'b0),                               // (terminated)
                .reset_in10     (1'b0),                               // (terminated)
                .reset_req_in10 (1'b0),                               // (terminated)
                .reset_in11     (1'b0),                               // (terminated)
                .reset_req_in11 (1'b0),                               // (terminated)
                .reset_in12     (1'b0),                               // (terminated)
                .reset_req_in12 (1'b0),                               // (terminated)
                .reset_in13     (1'b0),                               // (terminated)
                .reset_req_in13 (1'b0),                               // (terminated)
                .reset_in14     (1'b0),                               // (terminated)
                .reset_req_in14 (1'b0),                               // (terminated)
                .reset_in15     (1'b0),                               // (terminated)
                .reset_req_in15 (1'b0)                                // (terminated)
0 @' g6 V) L& ~1 [$ j
                .NUM_RESET_INPUTS          (1),
                .SYNC_DEPTH                (2),
                .RESET_REQUEST_PRESENT     (0),
        ) rst_controller_001 (
                .reset_out      (rst_controller_001_reset_out_reset), // reset_out.reset
                .reset_req      (),                                   // (terminated)
                .reset_in1      (1'b0),                               // (terminated)
3 G6 M, m- U0 {- T5 t3 ?/ _
                .SYNC_DEPTH                (2),
        ) rst_controller_002 (
                .reset_out      (rst_controller_002_reset_out_reset),     // reset_out.reset
                .reset_req      (rst_controller_002_reset_out_reset_req), //          .reset_req
- l% Q7 o4 b: Y0 k3 I- R
Endmodule
, n/ t. j" A" T" c  \* v) b2 P
) w% ~3 ^* T6 Y/ R' Q( w
GMT+8, 2025-10-9 12:48 , Processed in 0.187500 second(s), 28 queries , Gzip On.
