查看: 12017|回复: 7
DRC时出现以下错误
发表于 2008-3-2 11:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Checking for Invalid References) `1 U  @* F6 T" `: Y  W7 K, G. y
ERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK1 AND BANK2  (4.00, 2.10)
9 `& ~$ `) E9 j% V0 Z" wERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK1 AND BANK2  (9.70, 2.00)
9 R- j) ]  s8 S! BERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK3 AND BANK4  (9.80, 2.10) 3 B8 D4 \& |6 h) Y
ERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK3 AND BANK4  (4.40, 2.10)
7 g$ l. d1 H7 \ERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK5 AND BANK6  (2.60, 2.30)
( t! o! B/ O( P9 Z& LERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 BANK5 AND BANK6  (8.00, 2.30)
2 r4 J' P" N7 s0 R3 hERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 POWER AND CONFIG  (2.30, 1.40) " P  @) Y1 E8 [8 }) }& l
ERROR [DRC0026]   This reference has already been assigned to a different package type. U2:  SCHEMATIC1, EP2C20 POWER AND CONFIG  (4.40, 6.40)
" [, Z  O' m: J" l) `, {我调用元件的时候操作方法一样,但只有BANK7 AND BANK8 没有报错,其余几个都报错了.
8 O% V' O/ d7 t6 {& x还有就是我在多页原理图中使用分层端口符号,结果报错:
1 r1 K) C" e; m: ~ERROR [DRC0003]   Port has a type which is inconsistent with other ports on the net DRAM_CKE:  SCHEMATIC1, EP2C20 BANK1 AND BANK2  (2.70, 4.80)
! C7 s( v1 L, V( P我是在一个电路图上设置端口为output,另一个图上则为input,结果就产生上面的错误,改成一致的就没问题了,但我不明白的是,从原理上说不是一个input,一个output才连接正常吗?为什么都是input或output才可以?我看网上下载的原理图也是一个input,一个output?
8 c8 Q; d& `: j- W1 w& I不知道怎么办了; A' A, m  `, a. L. b  I! S/ j
请教大家怎么修改啊.谢谢了7 R9 f; r: G# u* A# V/ H
1 }& K$ ~; p9 U+ U
[ 本帖最后由 elmma 于 2008-3-2 13:36 编辑 ]
发表于 2008-3-2 15:18 | 只看该作者
上传个原理图看一下!
 楼主| 发表于 2008-3-2 15:50 | 只看该作者
上传的原理图,.我现在把端口都改成一样的
DE2.rar
607.29 KB, 下载次数: 67, 下载积分: 威望 -5
 楼主| 发表于 2008-3-3 10:37 | 只看该作者
知道的麻烦给点意见,折腾好久了,一点头绪都没.
; q6 F2 @* G  s% k" }! g+ R谢谢啦
发表于 2008-3-3 13:00 | 只看该作者
原理图问题比较多,这里只回答有关DRC错误的原因2 r8 q( f7 w3 w# T
你自己把所有U2的part都看一下, 原理图中U2各个部分调用的source package不一样,有的是"EP2C20_31"有的是"EP2C20_29"等等,也就是说根本就不是同一个元件。再画一遍吧- ^" W4 U. Z3 o) i" p
# b3 @$ \$ N! h1 n' F另一个问题是关于Port, 请牢记:
7 t2 J2 z8 n8 y1 v/ N. Eport只针对层次式原理图才有意义,在平坦式原理图中出现port虽然不影响电气连接(事实上也没有错),但是DRC肯定有问题。像你说的两端口都改成input才能避免DRC标记,但是理论上又说不过去。& C5 B7 `8 r' T" J- n5 S5 `- `" g$ `
建议平坦式电路图都使用offpage connector作不同页面之间连接,这样才不会DRC出错,input/ouput类型也能匹配. f% d1 i' U$ ?% f; X
最后一句,尽管你图上port有问题,但是不影响电气连接,也就是不影响网表,不影响layout。所以,就睁一支眼、闭一只眼就当没看到吧5 L0 f* u0 N! \9 y* L$ L, C
# H) f8 n' Y' A6 {. D/ `. u* M) }[ 本帖最后由 numbdemon 于 2008-3-3 13:43 编辑 ]
 楼主| 发表于 2008-3-3 15:28 | 只看该作者
我之前也是一样调用的,奇怪啊.现在我重新画了一遍后就好了.
% j/ }" v  b" i6 C4 p. C8 v谢谢版主,原来看那个就知道是不是用的同一个元件.晕.我都不知道.
    2019-12-3 15:20
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2008-3-3 15:30 | 只看该作者
    还是numbdemon版主经验多啊。
    发表于 2008-9-1 17:31 | 只看该作者
    numbdemon版主请不吝赐教。
    我用capture cis 画的层次式原理图,结果也出现了上面的问题,可是我没有把元件分成多个部分,不存在调用的问题呀。请您帮我看看到底是怎么回事呀?这个图的DRC这么我好几天了。
    ' `  M, H) v* v1 Q7 \您有邮箱吗?我把设计发给您。多谢了。
    GMT+8, 2025-11-4 21:42 , Processed in 0.171875 second(s), 28 queries , Gzip On.
