查看: 297|回复: 1
VGA Timings
发表于 2019-3-13 10:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VGA Timings
9 F5 W+ P! W; R6 l) Q! `% H6 s
5 v. X, z# r& B$ C$ b: F3 M+ X: o$ m
VGA Timings6 L% V8 [9 v3 V* Z# r
The following table lists timing values for several popular resolutions.
& ?8 ~3 q% l. ]# x- u" D. f2 X' {  Z7 y4 F+ f3 U* r4 z
Format        Pixel Clock5 S5 e* H/ J7 a2 e+ ?7 |4 \% @
(MHz)        Horizontal (in Pixels)        Vertical (in Lines)/ l: J" a  X7 @2 {
Active1 Y% u$ `. [; o- ^0 a9 O
Video        Front# W; \3 L9 o9 J8 Y- y  P
Porch        Sync( |& D3 T* C$ f
Pulse        Back6 [5 |0 M1 T3 t6 b/ U
Porch        Active
1 q: p" Q8 h, G& }' @8 RVideo        Front
% Z9 ^* R. m. A+ G2 w- R4 MPorch        Sync
4 a* V4 I: s! M$ n2 |" ?$ HPulse        Back
5 _* Z  _3 O/ Y; C& IPorch' O  n/ c' A; u9 m4 w0 S& x+ A' c5 p+ F
640x480, 60Hz        25.175        640        16        96        48        480        11        2        31" m8 R4 _  S( }! C; q7 [
640x480, 72Hz        31.500        640        24        40        128        480        9        3        28; f0 ~/ W8 e) a0 @  E( W: N
640x480, 75Hz        31.500        640        16        96        48        480        11        2        32
( {& e' B" p2 T, L6 P8 h$ P- `640x480, 85Hz        36.000        640        32        48        112        480        1        3        25
% ?7 D3 @6 _. _7 X* ]# J9 u800x600, 56Hz        38.100        800        32        128        128        600        1        4        144 q; ^( S3 J5 g& R1 [% y
800x600, 60Hz        40.000        800        40        128        88        600        1        4        23
% |4 \  U4 i- r' R/ V' G800x600, 72Hz        50.000        800        56        120        64        600        37        6        23
; G$ o' D  `7 g% V800x600, 75Hz        49.500        800        16        80        160        600        1        2        21
4 G. i3 p+ r/ V- ~" z: N. I7 G# V800x600, 85Hz        56.250        800        32        64        152        600        1        3        27
: B' o) f5 e/ O0 X1024x768, 60Hz        65.000        1024        24        136        160        768        3        6        29. e2 I& H1 l5 t6 D' p, J
1024x768, 70Hz        75.000        1024        24        136        144        768        3        6        29
* [  {+ h) @  r( b1 |; p$ n1024x768, 75Hz        78.750        1024        16        96        176        768        1        3        28
* Z! D$ {0 E; ], J( p! Y! n4 Y% ~1024x768, 85Hz        94.500        1024        48        96        208        768        1        3        36
0 ?; t+ L* A0 s
发表于 2019-3-13 14:38 | 只看该作者
thanks for sharing
GMT+8, 2025-10-8 12:04 , Processed in 0.125000 second(s), 23 queries , Gzip On.
