C语言可变参数函数使用总结
2 N0 J A' U+ v1 C2 y( O5 x9 U* r
! q3 [) t3 n2 s: e% w
//ADS1.2下编译使用 void TestFun(char* fmt,...) { int ch; char selch = 0; va_list ap = NULL; va_start(ap, fmt); do { selch = *fmt; if (selch!='%') { putchar(*fmt); } else { selch = *++fmt; switch(selch) { case 'c': ch = va_arg(ap, int); printf("%c",ch); break; case 'd': ch = va_arg(ap,int); printf("%d",ch); break; case 'x': ch = va_arg(ap, int); printf("%#x",ch); break; } } ++fmt; }while(*fmt!=''); va_end(ap); } //调用 TestFun((char*)"this is %d,%c,%x",1234,'6',0x12345); //WIN-TC编译通过 #i nclude /************************************************************ typedef void *va_list; #define va_start(ap, pARMN) (ap = ...) #define va_arg(ap, type) (*((type *)(ap))++) #define va_end(ap) ********************************************************************/ void TestFun(cosnt char* fmt,...) { int ch; long i32value = 0; char selch = 0; va_list ap = 0; va_start(ap, fmt); do { selch = *fmt; if (selch!='%') { putch(*fmt); } else { selch = *++fmt; switch(selch) { case 'c': ch = va_arg(ap, int); printf("%c",ch); break; case 'd': ch = va_arg(ap,int); printf("%d",ch); break; case 'x': ch = va_arg(ap, int); printf("%#x",ch); break; case 'l': if(*++fmt== 'd') { i32value = va_arg(ap, long); printf("%ld",i32value); } else { putch('l'); if(*fmt!=0) { putch(*fmt); } } break; default: break; } } ++fmt; }while(*fmt!=''); va_end(ap); } void main(void) { TestFun("this is %d,%c,%x,%ld",1234,'6',0x2345,(long)12345678); getch(); } void main(void) { TestFun("this is %d,%c,%x,%ld",1234,(char)'6',0x2345,(long)12345678); getch(); } 上述的example使用宏定义, var_start(ap, pareN),var_arg(ap,type),var_end(ap). var_start(ap, pareN) //是ap指向第一个变参. var_arg(ap,type),//返回变参的实际值. var_end(ap).//是ap指向空指针. 具体的实现,在不同的编译环境下有所不同. 1 ]+ g) L7 S+ P8 I0 z" O$ U4 `
