Processing NC Parameters file ...
7 O+ t3 \5 b! O8 ~# T# W8 \* o/ r" p
NC PARAMETERS
9 S& ]6 H8 R: o' j" d -------------! v- |/ z$ K; n5 M% ~
l8 p4 x, _8 A" L: l+ X, B; _ FORMAT 2.3% V6 y) _% W$ Z3 e' n
MACHINE-OFFSET x:0.000000 y:0.000000
% C5 p3 z ?, d5 j; m+ ]: S FEEDRATE 1
* W$ t1 G. i% |" ]+ ? COORDINATES ABSOLUTE) a8 `* \* n5 c" Q' f2 d* N& E
OUTPUT-UNITS ENGLISH
" x9 E- S" H3 J/ u& H/ e- T TOOL-ORDER INCREASING
2 b: R1 b( q# i, u8 F- u ]0 c REPEAT-CODES YES: S# z* B% J- ~: f" C8 k
SUPPRESS-LEAD-ZEROES NO
8 i/ k& {/ w* F% t4 ] SUPPRESS-TRAIL-ZEROES NO: H7 ]/ |7 x9 }8 d$ A- H. W8 c+ Z- }
SUPPRESS-EQUAL NO9 n2 g5 a6 i$ b7 D
TOOL-SELECT NO
+ i( ?1 y& X) j/ U& n* v HEADER none
* v* Z9 w3 j* E" w# L; F4 X LEADER 123 @( `3 v0 [: _* d
CODE ASCII+ g {2 ?1 J; Y7 q
SEPARATE NO* q& i7 M8 W- ~2 o: r. v
OPTIMIZE_DRILLING NO
! a- `% ?& A% `% M* \0 ~ ENHANCED_EXCELLON NO
- _/ d. Q2 z5 P& H SCALE 1.000000- n) N0 w1 f: l9 w
% K; Q- [+ w7 d5 ?2 ?1 z# f- b-------------------------------------------------------------
$ Z. d5 p7 H2 k
3 n) U. C9 x5 B f+ T8 @4 S& x& T Processing route path data ...* n& z4 L0 p# `* Z3 ^' m+ C2 F
& b# p+ E# p, f" {" L WARNING: No route path data was found for processing.
9 X6 k# n5 b" F4 \, i2 N( t7 l! Q9 a
1 G- X. j/ n& j; p-------------------------------------------------------------0 A3 y @: U: c
+ t# U) T7 H% Z1 p8 ^
Processing slot hole data ...
, ^! Q. ~' j! Y/ h* B
3 ~2 B: M. x7 t/ h WARNING: Can't find NC Route bit file (ncroutebits.txt)!
- s4 L6 E$ ?. l3 D Using T01 to route ALL route cuts.
: p0 V" A" A0 ]/ [& O# K( q! ]4 j* T
WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!3 }; p, H/ D S/ n( ~
Defaulting to T01 as toolname.0 T; {/ |( _( I% L; L0 v
) t. h# p' n! T+ Z, \) y: A WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!
. N: R- {7 z1 H4 B Defaulting to T01 as toolname.
; ~: h% ?$ g/ M: ]4 u! r% }- e" j1 c
9 Z! {9 _" D7 s6 q- l Defaulting to T01 as toolname.
7 F9 o2 \* D; W7 I5 R. Q
$ A7 u0 l. F5 r' v WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!
$ `) C; ~. d6 f o Defaulting to T01 as toolname.7 u+ E; y' ?2 O# S
, f4 `4 R/ j: s+ u/ w$ m$ d% y WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!0 z2 ~% b( T- n9 c
! u$ V6 {$ T0 }% M( M2 V; Q3 M; h) c
WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!$ ]% z+ r! g! b
Defaulting to T01 as toolname.+ O' T( i% @7 Y" E
' _0 b9 S4 V% a) G4 i& r WARNING: No toolcode of a size the same as or smaller than 20 found for an OVAL slot!0 ]. ~2 v6 O) r; R5 `' W
Defaulting to T01 as toolname.. E7 d: S" A% \5 N0 ` c* l; T
, v$ s* C3 r6 _& X OVAL slots routed: 7
9 F- T: O0 b9 a: @ RECTANGLE slots routed: 05 n/ U4 ~3 h- _- _7 f% s- z; C
! \& V' U6 {. M' y7 P5 D m3 ]
