使用DS1302的时钟单片机程序 Lcd1602液晶显示6 k' F5 [% N! y" R5 |
3 P( @, @8 |+ t Q! d
7 F/ y* d% q) W7 M) |! T: B
附件和图发:
5 U3 b4 F% j3 h ~* \
$ C8 y/ h$ { }+ ]* m+ Z' j( X6 B. O9 r7 q
51单片机源程序:
( D: z% m1 f* u8 v#include<reg52.h># F: h, d J" k4 z1 [1 F
# P8 b/ _( H* E& D l2 r
5 L0 H) S4 Y8 G$ i) s) [struct sTime{ //日期时间结构体申明
, w1 H" l1 U; K, j unsigned int year;
H5 g0 Q' H; ]3 k; I3 m" n unsigned char mon;8 i5 F$ ?" o- j* x; H6 u
unsigned char day;, U0 h _: M! c( _ C& \+ ^+ N
unsigned char hour;
" ^" G1 [* T8 N$ Z5 o2 M& ` unsigned char min;- T9 i& J. u& y2 Z* H( S# H
unsigned char sec;0 K' j7 i- p2 t+ Q
unsigned char week;0 Q% y! H2 P% d, K- F6 F
6 n% b O* V3 _, F2 g5 q- ` W. e4 l/ _+ n% ]8 x2 J
x( p( U; e2 I9 t' y c7 u, b
bit flag200ms = 1; //200ms 定时标志
! Q7 r9 z t+ d8 c9 V; Q! f5 ~) [( pstruct sTime bufTime; //日期时间缓冲区
* y" R6 B& x+ K q9 }9 P% o& o2 punsigned char setIndex = 0; //时间设置索引 0 0 就表示正常运行,( e4 {) X ^0 c* L8 `* ]
unsigned char T0RH, T0RL;9 c3 m" Q2 a o8 K# X
- Q6 s9 \8 n$ [1 u: P
9 i5 m5 D( o1 W- R+ Pvoid RefreshTimeShow();! r ?! K" y% N# ~+ m" v
void ConfigTimer0(unsigned int ms);& [) O; Y' A: \- @; \) J
extern void KeyScan();0 ~& I8 o2 T7 c# Z
extern void KeyDriver();
3 i. w3 p6 |/ _$ S8 cextern void InitLcd1602();' g/ G$ g2 L$ {5 C6 L
extern void LcdOpenCursor();! ~$ C2 {9 N& F; I4 ~
extern void LcdCloseCursor();1 E# B, ^. I4 K
extern void LcdSetCursor(unsigned char x, unsigned char y);0 p) @: U1 s7 b3 v2 }
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
# Y2 b$ |3 K9 O1 |, v1 t1 @& [extern void InitDS1302();
$ }, D2 m6 A+ u# }6 z9 Vextern void SetRealTime(struct sTime *time);
0 q/ [3 F7 [$ I7 T4 kextern void GetRealTime(struct sTime *time); - X* U/ r/ S6 `4 [$ @& C/ ~; h7 m# Z$ ]
! V4 F% [ t: i2 O7 [
4 I4 j! Z0 r( q# o# lvoid main()
' C& K( E8 A! X$ |2 |" \% f+ ^) _{
9 p# Q0 G2 e8 X: v& K. m, h unsigned char psec = 0xaa; //秒备份,初值 AA 确保首次读取时间后刷新显示, V9 _6 `% i, C6 @7 U! e
2 D4 S, N( P" l( x4 k9 _& j
+ e% ^$ m$ F$ v. S EA = 1;
( ^5 \$ Y. n0 \, @ ConfigTimer0(1);
$ x6 {. @" u/ H. p InitLcd1602();
4 n! r6 {: Q0 k f# m" ^! U: Z InitDS1302();
& O0 C* P. ^9 l; n) ?6 F0 z LcdShowStr(0, 0, "20 - - Week "); //初始化屏幕上固定不变的内容% B5 \; w9 E2 @' v
LcdShowStr(4, 1, " : : ");
& T$ W! }: i1 j2 Q3 w( ~' u' ]; Y) x: K) }: }! N7 e2 {
! ]) t5 N, j, [8 W! h
while(1)4 \) K. z" @/ @' F8 c# c/ c# N4 Z
{2 _9 p0 Z& K7 j$ N8 M' E* |
KeyDriver(); //调用按键驱动
3 |. g/ i+ U% w; y if(flag200ms && (setIndex == 0))* @- p7 b! o/ x; I
: F: U7 S( `4 s' h) k flag200ms = 0; //每隔200ms且未处于设置状态时,' x& N3 p6 ]' ? T7 r4 V
GetRealTime(&bufTime); //获取当前时间
$ J: ~4 p5 v# [: _6 v( O3 x if(psec != bufTime.sec) //检测到时间有变化时刷新显示1 a" ]. g% q. O
& `) k& d3 R/ X" t: b1 C4 U- {0 i RefreshTimeShow();
) T7 U" x; B- Z psec = bufTime.sec; //用当前值更新上次秒数
l3 p7 _8 [7 q4 l& j } 1 T5 D4 i5 V6 `$ t; F
}* i7 U4 f& O8 v1 b
6 E' I& W/ C& q! R5 H}
' J1 J5 ^# U/ b7 }$ I$ D/* 将一个BCD码字节显示到屏幕上,(x,y)-屏幕起始坐标,bcd-待显示BCD码 */: p3 R r. [/ L' }3 ~
void ShowBCDByte(unsigned char x, unsigned char y, unsigned char bcd)
7 U) v' I& r. _. N) _{
% C% k% F) s" a unsigned char str[4];2 R0 j. X7 B9 C0 U0 I& f
- }: Q) E" ~% p2 r; _- c( i5 ^5 Y, w1 i6 w; O/ A7 h
str[0] = (bcd >> 4) + '0';" @5 U5 }+ G, f) Q; Q3 q# N! Q
str[1] = (bcd & 0x0f) + '0';# \& Z: M$ p- [+ I: G
str[2] = '\0';1 ?7 {+ {8 [% v5 i
LcdShowStr(x, y, str);% h/ x9 a* e2 L; O: b+ `/ a. @
! ]) N9 Z! B: ]/ K* _0 b" h! Z/ |; `7 d
& A- w' ^: {0 m7 N t$ _3 M
void ShowBCDWeek(unsigned char x, unsigned char y, unsigned char bcd)2 L5 H r# a: I6 h% e( a% J
' f0 c$ n! ?7 `8 ~' J+ [ unsigned char str[3];, C; y) K& b7 {. Z7 x5 G+ Y$ Q" f
0 `9 P; J7 q. K. M
# y9 B$ Y' Z: K- [ str[0] = (bcd & 0x0f) + '0';$ d0 K/ K( w9 @6 @/ @
str[1] = '\0';) x( Z" ~2 Y ]& E
, ~6 ?0 s ^; y K}
* e5 F. A2 A% R% e/ G# v, t7 @/* 刷新日期时间的显示 */
0 m& K- v3 P; B* z4 qvoid RefreshTimeShow()
9 t2 p! \& K% j5 `' M{
/ s) Z5 A0 o e ShowBCDByte(2, 0, bufTime.year);
$ f3 U% Q$ E/ x( I8 i. b, l ShowBCDByte(5, 0, bufTime.mon);
" s& ?% z! g! Y3 I$ |; k ShowBCDByte(8, 0, bufTime.day);
7 f) |* b* @6 i) t7 D ShowBCDByte(4, 1, bufTime.hour);; J- C# o; ?( w$ ^: Q
ShowBCDByte(7, 1, bufTime.min);, ?* {- T# }1 }( C$ u8 o
ShowBCDByte(10, 1, bufTime.sec);
+ ?1 r; t$ V5 }9 T- e ShowBCDWeek(15, 0, bufTime.week); 3 J! K+ n6 S7 @: u
} / G' t, i! _2 Y" A
/* 刷新当前设置位的光标指示 */
/ l# j! v" L- vvoid RefreshSetCursorShow()
6 n! b; t* S- z0 M8 N. h{" V; c" m$ n- Y) b; s) j, L" |" U
switch(setIndex): p; `/ f8 C) F/ m) k
! Q4 S( ?# G/ Q5 d3 s0 a A case 1: LcdSetCursor(2, 0); break;! k/ d6 B8 i. }& |1 c# s
case 2: LcdSetCursor(3, 0); break;
) K0 M |8 |/ r; m+ f case 3: LcdSetCursor(5, 0); break;7 T* G: {0 p/ o& n
case 4: LcdSetCursor(6, 0); break;
$ Q& ]( H( z& Y3 o z# \. h( o" s- y case 5: LcdSetCursor(8, 0); break;1 o# w4 ]4 A, j2 B
case 6: LcdSetCursor(9, 0); break;
5 l+ j$ S- N. j9 ^) Y- t! x case 7: LcdSetCursor(4, 1); break;
; M# D% Q# T( Z case 8: LcdSetCursor(5, 1); break;# \* P2 T/ r/ A7 ?- L
case 9: LcdSetCursor(7, 1); break;# C5 M! x! E+ c" v
case 10: LcdSetCursor(8, 1); break;
" C/ z& a# P9 U; e4 n0 S9 `8 O* f3 J case 11: LcdSetCursor(15, 0); break;9 m4 V% z u$ H% S+ `& p
default: break;
0 q& {8 F/ b3 f2 G }
7 `1 t4 @3 z; z( ?5 m. P4 M+ \}
% \/ `9 m/ s) A7 ]
) q/ z& i. h p7 ?( `; D- y& i' i. U2 t) |+ y
unsigned char DecrBCDHight(unsigned char bcd)& u6 ^7 o8 k- T1 @! ?% q
9 R- a9 z/ G! ^5 m' U0 Q$ i6 g/ M1 R
( V8 | Y! d- s8 J( F4 z/ ^6 x0 ]" a) b# c5 v
0 g/ p1 l$ L( i% o! V! s
, p& x6 ]7 [2 ~1 F6 s if((bcd & 0xf0) > 0x00)
5 k7 q- L) a1 y$ w/ G% P! j {
; q: n0 s- s$ h: Z bcd -= 0x10;
" V4 U) y: w( Z4 B) c }
8 a \: @4 m% p- R3 U$ [, o else$ F! E" R- ~! z4 u- t" r2 {
{5 E( N3 t3 u6 v8 k& Y
if(setIndex == 1)
1 n" @+ _+ e, E+ W5 D bcd |= 0x90;; D7 I: ~# J* }
else if(setIndex == 3)- R* V0 y4 u6 I' C2 O8 S% Z
bcd |= 0x10;
+ |* N, L. K) L7 n( i) b8 U/ |) k9 D else if(setIndex == 5)5 f6 B- z/ X. p' j7 [/ u9 t
bcd |= 0x30;
/ o$ m$ `( b* M7 k$ T+ M else if(setIndex == 7)$ {1 \7 x/ G8 T5 @( B3 }0 b5 ?" | v
bcd |= 0x20;
v# b1 }5 g' X' V7 P" Z0 U else if((setIndex == 9))# W. d! B' m" a8 ?0 [% j: i
bcd |= 0x60;
6 |+ P2 Q1 d5 U6 _. P: m }
2 r u) V3 D6 Z' ]7 F1 G! b/ _" ~
8 m7 q, @( @3 j( Q% s( L8 ~0 w return bcd;
" E& R, Q6 j1 A5 W0 r* b}
4 _( F3 C8 \ j8 ]3 p
( z$ b$ y0 p4 e6 D
0 k# b6 X9 ? d' C6 O. punsigned char DecrBCDLow(unsigned char bcd)" P+ I8 W, V5 P% \0 f
{3 I; Z s. O- O3 f4 T* {8 j
6 G9 b% o5 D: S# R/ j8 [ q7 H3 _ |) s$ S# @6 a
! [" o6 ?0 R+ ?. m1 P3 c% s$ t9 t) a x7 g% w
if((bcd & 0x0f) > 0x00)
4 _) ^0 v- p3 G) B* F5 c+ Q1 Y {; q( J$ X+ o, _0 y
bcd -= 0x01;9 s* U! h( C# b/ V
}, w, x2 K1 H* f! ^% J1 A
else if(setIndex == 11)
5 q1 B2 n* V# S4 s {
$ P3 s* O2 r' O! @0 b) q1 S$ ^ bcd |= 0x07;; g1 E( _8 I s6 v) ~
}8 s/ C6 W/ i$ f* F
else0 S+ U/ X5 q4 }1 a
5 i# o$ Z' O4 e bcd |= 0x09;
6 A( D( m. A7 c8 `( g3 @1 s }# }9 L& K( U3 b) K+ X- u
7 i& a2 Q$ v* s$ E
return bcd;. L4 \5 f H1 L% u
7 [8 S# f, @7 L0 L2 u3 f# O4 t+ u* T+ |, N
$ m6 S* f1 q: J1 b' Y: munsigned char IncrBCDHight(unsigned char bcd)' U! _8 I% \" G
{3 ~$ \; l" U6 k9 q$ J2 Y o# n [
if((setIndex == 1)&&((bcd & 0xf0)< 0x90))
/ f% O. q5 I. W6 c {9 N( F! Q2 W% a' H
bcd += 0x10;7 p" z7 k8 r* m& C. Z
}! m- ^5 ^1 A @; A z. K
else if((setIndex == 3)&&(bcd < 0x10))
, g" ]" [8 p0 o5 A6 W {
4 ~3 |' N% ~! {2 o3 J$ S3 c% o bcd +=0x10;4 T* _; i K# y/ D
}8 I2 ~- |' k5 l! e2 B
else if((setIndex == 5)&&(bcd < 0x30))
; o0 h Y) j }+ o {
+ y% [/ w1 ?2 H% d( z8 q% f bcd += 0x10;
" d8 {4 e% f7 |4 j, @ }. ~7 x6 s' S9 }; [3 C/ t
else if((setIndex == 7)&&(bcd < 0x20))3 t, O2 X- n/ E. F
* p6 z% R7 [; S" x6 U% Q) p/ F" a! E" U bcd += 0x10;! B! k8 i/ v4 \5 X8 @- y5 o- p
1 x f* S. V, M* f9 d9 i! @, o& L8 b else if(setIndex == 9)
" ?" \/ s9 T+ D. E6 B, f8 g( E9 e {. b4 r- r% N* O* X2 P7 k
bcd += 0x10;
7 o& q, i m; ]. G7 A* Y }
% n: }" A) C% \0 t else if(setIndex == 11)! |3 G- h6 r8 o0 D0 t! G0 |: J1 n
{& R& U! k- ]+ q( M7 R+ f
if(bcd < 0x07)! F9 j, P1 q) D3 m
1 ^. ^3 l5 x2 i bcd++;
& ?, E; @, o" k& Y1 b' T1 C }4 H" d5 {4 U r0 I8 g+ j
else7 m% v: [ @, b* C+ ^
- _- b% N2 B/ M6 r bcd = 0x01;
# z1 s5 o7 R7 D9 _! \5 I }
( U4 a: m4 T- G; ` }+ `& j8 n6 |8 V! p& g# W N
else
1 ~, r; X& z$ g$ o0 b! l {
/ X: ~$ z2 @" N0 Q bcd &= 0x0f;3 j. ] g3 y6 E# l
# c+ Q% ]1 h5 _/ M
m2 Q o$ J/ I" b return bcd;
: `1 q" z7 G% i6 U9 J}
, C( y" t3 e2 ~0 [
A/ e, g( w% \& v+ l3 L3 u6 a$ q9 k' }) d' v$ Q6 h" h
unsigned char IncrBCDLow(unsigned char bcd)
]& B4 b; Y$ l$ v: P" q" Z{$ i& k) k8 D2 M. R
if(setIndex != 11)
0 \, R4 N( z3 o {0 O. g. [ i% }3 }5 T2 o( m
if ((bcd&0x0F) < 0x09)$ U+ {( M% }* J4 E; n) c3 h
bcd += 0x01;
; a- L1 t4 i0 b8 K else
5 m9 Q+ W1 G" F3 b" o+ C bcd &= 0xF0;: G# z5 k" F) t3 H( U
1 Q' D/ p8 j' D. s6 D3 ^1 C else |- J9 a/ x1 I2 y$ a: Q
/ \3 c' X3 O% @ if ((bcd&0x0F) < 0x07)6 F' A! m6 d) L# b
bcd += 0x01;" r# @0 r# ~! p: L8 U5 W, e
else$ |8 q* R6 d0 }: H" o3 x
bcd &= 0x01;
$ L* Q; t8 |+ l, U) U9 ` }1 ?% Q- F3 {4 R q* o$ d6 h8 ]
5 _8 c9 m3 R) N, t
return bcd;
' w c; a2 J0 `' f}* s3 P5 d) b: Y ?
/* 递增当前设置位的值 */
+ h4 x4 {5 y5 Z& Yvoid IncrSetTime()
/ t: S9 b1 L0 w% J# A9 Z{
r" T8 ]# C* \: ^# v, o8 ^ M switch(setIndex)* V. {" J, B2 r& P$ J# D8 u4 G
{# X+ A; n5 _7 O
case 1: bufTime.year = IncrBCDHight(bufTime.year); break;
. C& A# v2 U. ~8 H6 c case 2: bufTime.year = IncrBCDLow(bufTime.year); break;
Z! B' P- J! b6 y% K8 k9 K case 3: bufTime.mon = IncrBCDHight(bufTime.mon); break;
1 M# ?4 t( O: {0 p; s case 4: bufTime.mon = IncrBCDLow(bufTime.mon); break;
7 L! d2 D) v- `! m6 [- _" d case 5: bufTime.day = IncrBCDHight(bufTime.day); break;$ q. G. d, c f/ P9 w p2 @, c
case 6: bufTime.day = IncrBCDLow(bufTime.day); break;
5 r# i8 I8 d8 M- |" H0 f case 7: bufTime.hour = IncrBCDHight(bufTime.hour); break;
1 s3 D& T7 _+ b$ ^6 X# u% U case 8: bufTime.hour = IncrBCDLow(bufTime.hour); break;$ w$ v( m5 l. V
case 9: bufTime.min = IncrBCDHight(bufTime.min); break;6 U0 I' {0 V" X8 j( [( s) M
case 10: bufTime.min = IncrBCDLow(bufTime.min); break;# Y5 V4 Y5 a$ a
case 11: bufTime.week = IncrBCDLow(bufTime.week); break;6 L1 E3 ^$ z" ^& I9 @3 t6 s4 }
default: break; u6 p2 h( E% P2 p. d5 l9 d
}3 c- Q3 c, D8 m5 S8 W) x
RefreshTimeShow();
2 w/ n' D; z/ Q3 K RefreshSetCursorShow();8 g4 Z" ] X$ o9 z
( s. |, }( i( Z7 U# G" c: [/* 递减当前设置位的值 */
3 b# G$ t1 J( K7 k- @( svoid DecrSetTime()
% s* O0 |5 _+ P. A# K5 ?{
; j' ~& m4 U/ Z7 N! F2 i switch(setIndex)
0 M l, ? C6 } {4 D1 B2 F0 b1 u6 S$ v2 X
case 1: bufTime.year = DecrBCDHight(bufTime.year); break;
( `+ Z* { v: s/ `4 d2 S h case 2: bufTime.year = DecrBCDLow(bufTime.year); break;
1 `1 z( R) ?9 k7 L( y) E: b case 3: bufTime.mon = DecrBCDHight(bufTime.mon); break;$ ]0 X% f9 M+ A T& U/ [. v
case 4: bufTime.mon = DecrBCDLow(bufTime.mon); break;
/ M- n3 T9 ?0 G, C$ I case 5: bufTime.day = DecrBCDHight(bufTime.day); break;4 g3 m9 i( e6 n9 z
case 6: bufTime.day = DecrBCDLow(bufTime.day); break;% m V7 I0 p, w7 I3 T8 R/ H* _
case 7: bufTime.hour = DecrBCDHight(bufTime.hour); break;. \, n- h. f" k" n4 m$ W C- G+ g
case 8: bufTime.hour = DecrBCDLow(bufTime.hour); break;# O, F- N5 g$ J' [& o. e# q
case 9: bufTime.min = DecrBCDHight(bufTime.min); break;
: E2 C5 ^8 _5 P case 10: bufTime.min = DecrBCDLow(bufTime.min); break;
0 C/ B5 L7 D: [5 k% k case 11: bufTime.week = DecrBCDLow(bufTime.week); break;, k4 w! W P0 g, }9 ]5 b
default: break;( p0 L; {% P% W% K, Y5 G0 q# o9 v
}) w! k5 I2 L4 @6 [. O. K1 N3 M
RefreshTimeShow();* A8 c8 z/ k7 [" i; f
9 X9 l1 l" D, @- }3 ~6 d; M}
8 J" J6 n; x" J: z2 v/* 左移设置位 */
& S1 k6 \3 e0 m" Ovoid LeftShiftTimeSet()9 A: j- G, a! U0 Z
{, e7 _3 z! L1 N8 ]
if(setIndex != 0)( w( I8 d- i4 b$ o% S! [5 n# c
- {# W; |0 s4 ^+ a. ?" ~ if(setIndex > 1) n. E# H T1 h% f, c. H/ U
setIndex--;; |! M2 c! I( s* M
else
A/ R; O3 q& e* }7 c. V6 k setIndex = 11;
$ T8 l: p" x+ V+ S! b3 v! ? RefreshSetCursorShow();
: k8 t. r' M2 ]- s" q5 A& a: ]* ~# L }
# Q# V3 a2 z2 A8 d}
, Q7 Y; D" a& N! }7 |# C% q0 n/* 右移设置位 */
6 F- k9 Z0 K% k) `' L# F) {, wvoid RightShifTimeSet()
0 D! F( V, U; H6 T{* b! u) Y3 N# Y* X
if(setIndex != 0)* T# s! ~6 z0 S* ~: ~5 q8 E& u8 E
{0 d3 k" c& N: D; r3 l, L
if(setIndex < 11)
4 [; a# U. v; @( M, i7 P setIndex++;
" b2 K/ r' w/ N+ C else
, L! R s) k/ U8 R$ ~6 U) C setIndex = 1;" x- N+ f0 Q s0 m
8 N' r8 L/ f6 ^- L8 ]- E }
# C2 Q+ W5 `$ b/ z. Y. r+ }}
; V; z" y3 {0 u4 A. [/* 进入设置状态 */& z* i+ m( X3 ^5 O4 [, D
void EnterTimeSet()5 I4 y g/ n9 D' G; ~0 K. D. E
{% Z5 Y! P$ ]/ n' g* z+ U& f
setIndex = 2; //把设置索引设置为2,即可进入设置状态
) W+ S/ W4 S% s& a1 c6 Y9 j3 m. P. [# B LeftShiftTimeSet(); //再利用现成的左移操作移到位置1并完成显示刷新
) @" q; a2 }+ T# _' L$ s4 c LcdOpenCursor(); //打开光标闪烁效果
8 }. H! T7 y0 J/ n* }}
6 `2 o u+ Q3 k B1 P v/* 退出设置状态,save-是否保存当前设置的时间值 */
# |% U* ]* b4 d6 m- Xvoid ExitTimeSet(bit save) //save = 1 保存,save = 0 不保存9 b' n4 o; |) ] o0 C
{( w& ^$ N V* G5 b$ `; |. ^
setIndex = 0; //把设置索引设置为0,即可退出设置状态
$ ^$ ~5 k; T0 D V. g! ] @ if(save) //需保存时即把当前设置时间写入DS1302! r- l- x) U0 C0 ^. p: e
SetRealTime(&bufTime);
7 N3 M8 U- `% {- Z3 S! J9 Q8 u% w! V LcdCloseCursor(); //关闭光标显示
8 r! U2 Q- E% H1 @+ ~}
. ]2 ^8 k$ F0 q& d" @; L4 R/* 按键动作函数,根据键码执行相应的操作,keycode-按键键码 */
# P5 {9 J& M. Q v& E5 Y; Zvoid KeyAction(unsigned char keycode)# r) f- q( H: U& C2 G3 q
{6 n1 M4 h" N0 e( y# D0 o
if((keycode >= '0')&&(keycode <= '9'))//不响应字符键
' f& l$ \/ u, o% s& s) X' _6 N3 ]3 h {}: b( Y: d( B- [! e! ^
else if((keycode == 0x26)) //向上键,递增当前设置位的值
' d# F. r, H3 P6 V6 l6 D {
* `& n$ `( I/ P5 X/ B9 L IncrSetTime();
5 f/ ]2 h2 K Z. r- y; F }4 g5 |# M, I. f7 C, Z
else if(keycode == 0x28) //向下键,递减当前设置位的值
" G1 t1 f* I/ ] {
4 M7 ? F8 ?& r DecrSetTime();
; j8 K2 ^! F1 ~3 f1 i$ B# G7 ?) y }
h. Y: d; m3 t$ Q5 J4 R else if(keycode == 0x25) //向左键,向左切换设置位. k0 q/ w1 `/ G
) L! ?: I/ d: K0 E4 X% q LeftShiftTimeSet();
- O/ a R9 Z+ c, i }
; R2 x4 W1 O' x* D7 I; g& L else if(keycode == 0x27) //向右键,向右切换设置位
o3 ?1 }$ P9 \4 t; h {9 |3 U( U* D- Z/ M Y
RightShifTimeSet();$ ?7 m, g4 R3 S: D" i% |
}2 s3 N; b" Z$ v' e4 k0 w
else if(keycode == 0x0d) //回车键,进入设置模式/启用当前设置值
7 w$ x2 H4 ]" \- W& m {: L0 h e G' V1 X3 k0 c: d5 k( v: b
if(setIndex == 0) //不处于设置状态时,进入设置状态
( u4 @$ O' l. B4 Q. r {
4 ^* n" S2 t2 E& h EnterTimeSet();) t1 E8 B6 j# P, A/ D1 V& \
} K; c, P3 ^" t) D1 n
else //已处于设置状态时,保存时间并退出设置状态
6 i" S, P. w& b# l {
' i; Q) r$ }1 Z$ k+ T2 m ExitTimeSet(1);0 V# S) l! p- p' D3 B/ Q
: U7 Z) m* `' s2 T% ^ }$ y, a- y" K; C
else if(keycode == 0x1b) //Esc键,取消当前设置) d2 X4 d2 ?: e+ n* t7 `0 K& m
' b$ R1 h0 N- o |1 x8 S ExitTimeSet(0);: Q" f6 N5 @. `' U7 C
& ~0 L; ~* D2 u/ s6 O8 k5 o} ) c7 s5 I, x# v3 ^8 c* v
3 l+ G+ i; I2 b$ |1 E5 P" S* j, w$ }
void ConfigTimer0(unsigned int ms)/ f) W/ e$ p5 V' C
{( W4 B! W4 h7 D- u5 `1 T
unsigned long tmp;, F: _( H# y5 T7 n( q# H" q
# k1 K/ w+ S: l+ w7 y
W- I- t- [, q/ G
tmp = 11059200 / 12;. B- J$ }$ W0 o, m5 @6 q* v
tmp = tmp * ms / 1000;
& G& O& u' A+ S) x6 g6 U/ {& [ tmp = 65536 - tmp;/ l5 ?# d5 r) }5 T0 \
tmp = tmp + 28;4 {% l g6 D: o$ }# [
T0RH = (unsigned char)(tmp >> 8);; }! |9 i( P! s6 ]* x7 j
T0RL = (unsigned char)tmp;% M& i# l8 v; R2 b& f E6 k
TMOD = (TMOD & 0xf0)|0x01;
% |! I4 }7 F$ X6 u9 ?/ x# R- z TH0 = T0RH;# \+ B9 D( w$ d5 i
TL0 = T0RL;/ w5 h* Z+ r0 Q) j$ F+ i& Q C8 i
ET0 = 1;
+ h6 V0 c, \; `) e TR0 = 1;: d6 W6 A" p! M: T8 c
/ |* y3 l* n% r' u/ ^8 z- q* _+ G( l. a7 }
( w& j4 s8 }: ^$ n* M$ R" n% ?
void IntTimer0() interrupt 1& x- }$ ~) S0 F0 Z! ]* O
{1 k8 H2 n3 S' w* U' X
static unsigned char tmr200ms = 0;
: N1 b9 O# p8 |4 A1 u( d. w) }% \; G
( o5 N" @# I7 ^" x9 u4 Q
# O/ h/ q' j, u4 T9 Y0 e TH0 = T0RH;
; o7 w$ c6 m u. Y TL0 = T0RL;
) W, {9 m0 q; v" K$ o$ S
; U" n5 P/ C6 w" _3 f) U( N ^; V. t! O8 }
KeyScan();7 G% n8 Y5 @" Q& I& h+ P
tmr200ms++;5 q3 B5 w5 |+ E3 j+ R1 P6 z
if(tmr200ms >= 200)1 j; P3 ]& x5 S5 h! R X7 N! J: u
7 O2 n3 f3 s- L3 O7 v# R* @7 J# ^6 Y tmr200ms = 0;
! R) _ z: R; o0 E$ F- T flag200ms = 1;# }! ~5 H& x. Y! n- W. h' B
1 t2 t& k; Q9 t# L) B J}6 L; M% |" Q- D- t! `' g
8 r- l# p* K( t' C. ~8 t8 J
9 ~# ^* u5 }% u; U6 ?下载:
6 ] Q" h/ x8 ~ g3 X
~- A. \# h9 }& N: C3 t \% A8 E- |! W5 d" W% r1 u# O
