查看: 424|回复: 1
16*64点阵程序
发表于 2019-1-16 14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
16*64点阵程序
# {  k2 O) N. F1 P7 B2 _: Q+ J# P
+ n: y4 X$ G' c' X
//帮忙修改点阵条屏16*16程序,此为静态显示程序范例,功能:key2 key3 key4 key5,其中任意两个为ON,锁定切换显示四个字.$ u1 N* f( k% J3 s
//key2 key3 key4 key5都为off按key1切换显示四个字。
0 _! A( o/ A' c//现要求改成从右往左滚动显示字条,字条滚动播完一遍后,静止显示任意四个字5秒(可定义),接着播放。
) \2 K7 E2 @2 X6 Q" M //key2 key3 key4 key5,其中任意两个为ON,锁定显示一条滚动字条。都为off时,按key1切换显示滚动字条内容。
9 t  ]0 C8 _4 _//字条任意,但关键地方要做好说明,方便后续修改字体内容·滚动速度
& [8 P" e8 M" |1 y$ A$ W* L7 i, _# j+ y( D: E. V
#include<reg51.h>
4 ]) ~+ o$ i" L5 e* O& \#define ROW_address                P2
  A+ t0 ?' }! ^- g8 k, Ysbit R1=P1^0;
0 e1 R3 E6 \, x) C8 M  Fsbit G1=P1^1;2 w* k* c! b6 w' T- `; r7 C' q
sbit SK=P1^2;9 e; S  I( @) h" i
sbit LT=P1^3;& a7 Y8 s( l% X+ n' O* \% E
sbit EN=P1^4;
3 ~4 V4 Y- N8 ~- W3 o+ n4 w' T& g$ T& H
sbit key1=P0^6;- b6 d4 S+ B" B  F( @; x1 ?
sbit key2=P0^0;0 T8 O8 I4 l- @1 |' Q" L
sbit key3=P0^1;
8 z& V( X1 h$ qsbit key4=P0^2;
+ U' s2 k9 |" ?; c! [$ F: Osbit key5=P0^3;
# o+ ]/ n4 U3 i, V( l9 B% P
0 U# a# R' Q4 s7 M& `9 ovoid debouncer(void);# d4 F6 s6 G/ `6 v- U) _( R) L
unsigned char code GB_16[] =          // 数据表
' S( \% t$ U7 W) f( X8 t{
+ R/ l* d' \. _/ G1 A' u4 V, v$ r0x08,0x10,0x3F,0xF8,0x08,0x80,0x04,0x40,0x06,0x18,0x24,0x48,0x0C,0x80,0x04,0x40,
% I7 A2 X/ P3 d) A! g3 T( z0x04,0x20,0x24,0x48,0x09,0x00,0x04,0x40,0xFF,0xFE,0x3F,0xF8,0x13,0xFE,0x04,0x44,
% H; B+ B: h! _: h+ X0x00,0x00,0x01,0x00,0x12,0x80,0x44,0x46,0x3E,0x08,0x7F,0xFC,0x34,0x88,0x24,0x4C,5 J' V! B/ x% J9 u- n
0x22,0x48,0x02,0x00,0x50,0xFC,0x24,0x48,0x3E,0x48,0x1F,0xF0,0x90,0x80,0x14,0x50,
3 ?7 P& e4 f! q$ X; L4 x! D9 u0x22,0x48,0x10,0x10,0x10,0x80,0x1C,0x50,0x22,0x48,0x1F,0xF0,0x10,0x84,0x14,0x60,
2 ?9 q; F# V' e! o6 g0x3E,0x48,0x10,0x10,0x10,0xFE,0x04,0x40,0x22,0x48,0x1F,0xF0,0x10,0x80,0x04,0x40,) U9 a: _: p" a+ _. U
0x22,0x48,0x10,0x10,0x10,0x80,0x04,0x44,0x2A,0x08,0x1F,0xF0,0x10,0x80,0xFF,0xFE,, X3 ^9 f; I8 g/ T9 S% }  d# s( L
0x24,0x28,0x10,0x10,0x10,0x80,0x00,0x00,0x00,0x10,0xFF,0xFE,0x10,0x80,0x00,0x00, //one  前置作业' y6 m4 T* _! R* j
4 E) x4 K+ b& C+ l( {& p. ?0x08,0x10,0x3F,0xF8,0x40,0x02,0x00,0x20,0x06,0x18,0x24,0x48,0x27,0xC2,0x40,0x28,
* j6 z# M& s: B  }4 f0x04,0x20,0x24,0x48,0x24,0x42,0x20,0x24,0xFF,0xFE,0x3F,0xF8,0x84,0x52,0x30,0x24,# v: b- R- w! R
0x00,0x00,0x01,0x00,0x45,0x52,0x27,0xFE,0x3E,0x08,0x7F,0xFC,0x55,0x52,0x00,0x20,
: g- D2 h7 i+ w5 m5 t& N0x22,0x48,0x02,0x00,0x15,0x52,0xE0,0x20,0x3E,0x48,0x1F,0xF0,0x25,0x52,0x27,0xE0,
( i! P) ]/ g4 s  L0 `9 U0x22,0x48,0x10,0x10,0x25,0x52,0x21,0x20,0x22,0x48,0x1F,0xF0,0x25,0x52,0x21,0x10,
3 \( s6 P* J% h2 ^' s7 K2 |! @0x3E,0x48,0x10,0x10,0xC5,0x52,0x21,0x10,0x22,0x48,0x1F,0xF0,0x41,0x02,0x21,0x0A,! P+ q+ w) U# B- v/ B
0x22,0x48,0x10,0x10,0x42,0x82,0x29,0xCA,0x2A,0x08,0x1F,0xF0,0x42,0x42,0x36,0x06,
8 \. y, e: s: c( P; p. f2 t0x24,0x28,0x10,0x10,0x44,0x4A,0x20,0x02,0x00,0x10,0xFF,0xFE,0x48,0x04,0x00,0x00,  //two 无载跑合9 L5 Z' G6 i( P) R1 y0 m, P, y+ s: `1 V
( l; X, q& B% F0x00,0x7C,0x10,0x40,0x40,0x02,0x00,0x20,0x3F,0x80,0x10,0x20,0x27,0xC2,0x40,0x28,
$ |8 g/ p8 E2 \( }. i0x02,0x20,0x23,0xFE,0x24,0x42,0x20,0x24,0x04,0x20,0x20,0x40,0x84,0x52,0x30,0x24,
7 ?3 x# u, @* l$ M2 s6 N. m+ c, A2 H0x08,0x40,0x44,0x40,0x45,0x52,0x27,0xFE,0x1F,0x80,0xF8,0x88,0x55,0x52,0x00,0x20,- ^; A0 r' Y% y. ~0 j! h  H$ D
0x03,0x20,0x09,0x04,0x15,0x52,0xE0,0x20,0x0C,0x10,0x13,0xFE,0x25,0x52,0x27,0xE0,
' E, G$ p9 q" K. Z) {, E% a5 ~0 u0x3F,0xF8,0x20,0x94,0x25,0x52,0x21,0x20,0x10,0x8C,0x7C,0x90,0x25,0x52,0x21,0x10,
- g" g4 K$ i! W/ r( t% G0x04,0xA0,0x00,0x90,0xC5,0x52,0x21,0x10,0x08,0x90,0x00,0x90,0x41,0x02,0x21,0x0A,
5 d$ ~$ b% |8 o6 X3 U: `0x10,0x88,0x1D,0x12,0x42,0x82,0x29,0xCA,0x20,0x84,0xE1,0x12,0x42,0x42,0x36,0x06,/ z7 @* e- x9 b; I& _
0x42,0x84,0x02,0x0E,0x44,0x4A,0x20,0x02,0x01,0x00,0x04,0x00,0x48,0x04,0x00,0x00,  //three$ K+ Z/ w" ^& y8 Y* d2 l
0x00,0x00,0x08,0x00,0x10,0x40,0x00,0x00,0x00,0x00,0x0F,0xFC,0x10,0x40,0x00,0x00,, U) j" z: w# P) G, ~  U
0x00,0x00,0x10,0x00,0x10,0xA0,0x00,0x00,0x00,0x00,0x2F,0xF8,0xFD,0x10,0x00,0x00,  c2 X, S8 w9 a2 C
0x00,0x00,0x48,0x08,0x12,0x0E,0x00,0x00,0x00,0x00,0x0F,0xF8,0x38,0x00,0x00,0x00,+ J2 i2 w9 k  h# l0 f9 Q
0x00,0x00,0x08,0x08,0x35,0xF8,0x00,0x00,0x00,0x00,0x0F,0xF8,0x50,0x00,0x00,0x00,
, z$ b( d+ z+ G; J! }0x00,0x00,0x04,0x00,0x50,0x88,0x00,0x00,0x00,0x00,0x07,0xF8,0x92,0x4C,0x00,0x00,
  I8 h3 b! e& I( r: T2 x0x00,0x00,0x0C,0x10,0x11,0x48,0x00,0x00,0x00,0x00,0x12,0x60,0x11,0x50,0x00,0x00,7 U  x  {. Q) X! }6 v  i
0x00,0x00,0x21,0x80,0x10,0x20,0x00,0x00,0x00,0x00,0x06,0x60,0x17,0xFE,0x00,0x00,
! w3 E& \) I2 y7 c0 [0x00,0x00,0x18,0x1E,0x10,0x00,0x00,0x00,0x00,0x00,0x60,0x04,0x00,0x00,0x00,0x00,  //four
# d( S4 _0 a# W; E8 k& y& z0x00,0x00,0x00,0x00,0x10,0x40,0x00,0x00,0x00,0x00,0x0F,0xF0,0x10,0x40,0x00,0x00,
. c" w, ^7 _7 e9 v# N' g; ?7 M0x00,0x00,0x08,0x10,0x10,0xA0,0x00,0x00,0x00,0x00,0x08,0x10,0xFD,0x10,0x00,0x00,- `; I, M6 t* L: i# e  k% J0 P
0x00,0x00,0x08,0x10,0x12,0x0E,0x00,0x00,0x00,0x00,0x0F,0xF0,0x38,0x00,0x00,0x00,
& p4 W6 L2 A1 i( D7 Y: q# D1 j0x00,0x00,0x08,0x10,0x35,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x00,0x00,0x00,; ]% G7 T$ v$ V2 y  ~1 ?# g/ i: [
0x00,0x00,0x7E,0xFC,0x50,0x88,0x00,0x00,0x00,0x00,0x42,0x84,0x92,0x4C,0x00,0x00,
/ b- C( {" V! p* ?% ^, f0x00,0x00,0x42,0x84,0x11,0x48,0x00,0x00,0x00,0x00,0x42,0x84,0x11,0x50,0x00,0x00,) X. q3 z7 O# Q' i
0x00,0x00,0x42,0x84,0x10,0x20,0x00,0x00,0x00,0x00,0x7E,0xFC,0x17,0xFE,0x00,0x00,* ?# R9 \% B% L+ ~8 q! K/ K' U
0x00,0x00,0x42,0x84,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,   //five0 w8 g( A9 Z: ~8 U, a: n3 F
0x00,0x10,0x40,0x0C,0x00,0x01,0x00,0x00,0x00,0x18,0x40,0x06,0x00,0x00,0x80,0x00,# Q# c! ?% }  V
0x00,0x13,0xFC,0x02,0x00,0x3F,0xFE,0x00,0x00,0x28,0x40,0x01,0x00,0x21,0x00,0x00,; {0 ^3 T3 S" M
0x00,0x4C,0x40,0x03,0x00,0x21,0x00,0x00,0x00,0x88,0x40,0x02,0x80,0x3F,0xFC,0x00,# Y" F8 y% w6 B, T8 _
0x00,0x17,0xFE,0x02,0x80,0x22,0x40,0x00,0x00,0x10,0x10,0x04,0x40,0x24,0x40,0x00,! x9 q+ l. ]) Y+ [% q6 j
0x00,0x30,0x10,0x04,0x20,0x2F,0xFC,0x00,0x00,0x57,0xFE,0x08,0x20,0x24,0x40,0x00,) {! G& Y6 E8 x/ u% T
0x00,0x10,0x10,0x08,0x10,0x20,0x40,0x00,0x00,0x11,0x10,0x10,0x08,0x3F,0xFE,0x00,1 L7 k+ O) j) {9 k2 P+ r, g! M" d
0x00,0x11,0x10,0x20,0x0E,0x20,0x40,0x00,0x00,0x10,0x10,0x40,0x04,0x40,0x40,0x00,- x  S; Z# S/ `! M
0x00,0x10,0x50,0x80,0x00,0x40,0x40,0x00,0x00,0x10,0x20,0x00,0x00,0x80,0x40,0x00,  //six
/ ^; m' ?$ |+ [9 e  b4 L0x00,0x00,0x10,0x40,0x00,0x40,0x00,0x00,0x00,0x00,0x10,0x60,0x7B,0xFC,0x00,0x00,
( x' @0 m( f% w; }0x00,0x00,0x10,0x40,0x49,0x08,0x00,0x00,0x00,0x00,0x10,0x40,0x50,0x90,0x00,0x00,
. T" m: K/ T$ u% {0x00,0x00,0xFE,0xFE,0x57,0xFE,0x00,0x00,0x00,0x00,0x10,0x88,0x60,0x00,0x00,0x00,  G& l/ {" j! ~( L
0x00,0x00,0x10,0x88,0x53,0xF8,0x00,0x00,0x00,0x00,0x7D,0x88,0x4A,0x08,0x00,0x00," i2 R+ w; U+ c* q0 G
0x00,0x00,0x46,0x50,0x4B,0xF8,0x00,0x00,0x00,0x00,0x44,0x50,0x6A,0x08,0x00,0x00,
  f. L6 e( `" Y% [) A: F3 K0x00,0x00,0x44,0x20,0x53,0xF8,0x00,0x00,0x00,0x00,0x44,0x20,0x40,0x40,0x00,0x00,
4 z7 o' c, L, h, {& e9 M5 b0x00,0x00,0x7C,0x50,0x4F,0xFE,0x00,0x00,0x00,0x00,0x41,0x8E,0x40,0x40,0x00,0x00,6 D7 N$ y- P& H3 g
0x00,0x00,0x06,0x04,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x00,0x00,  //seven
6 F( [+ i, Q# ]' P6 H: L0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x40,0x40,0x00,0x00,0x00,- o7 I! h! t1 p# {
0x00,0x00,0x08,0x40,0x27,0xFE,0x00,0x00,0x00,0x00,0x48,0xA0,0x30,0x20,0x00,0x00,  k. e; U6 u* u7 k. a3 Z
0x00,0x00,0x48,0x90,0x20,0x20,0x00,0x00,0x00,0x00,0x49,0x0E,0x00,0x20,0x00,0x00,
* X- B: L# |. w1 c0x00,0x00,0x4B,0xF0,0xE2,0x20,0x00,0x00,0x00,0x00,0x7C,0x00,0x22,0x20,0x00,0x00,7 D2 S+ b- [8 e: a1 N* L" g
0x00,0x00,0x04,0x84,0x22,0x3C,0x00,0x00,0x00,0x00,0x06,0x44,0x22,0x20,0x00,0x00,
) Y' ?; Z9 @6 h+ d' w0x00,0x00,0x35,0x48,0x22,0x20,0x00,0x00,0x00,0x00,0xC5,0x48,0x22,0x20,0x00,0x00," r7 l$ [9 R% a3 M% U  P
0x00,0x00,0x04,0x10,0x2A,0x20,0x00,0x00,0x00,0x00,0x17,0xFE,0x32,0x20,0x00,0x00,
) K( V: P" {0 T; @0x00,0x00,0x08,0x00,0x2F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,   //eight, K& M% R1 g) r1 A; e, k% u! B$ y
0x00,0x00,0x04,0x40,0x00,0x80,0x01,0x00,0x3F,0xFC,0x04,0x50,0x7C,0xC0,0x02,0x80,
7 S4 [, H4 t/ P' Q2 k" k( Y/ z0x01,0x00,0x3F,0x48,0x44,0x80,0x04,0x40,0x01,0x00,0x04,0x40,0x44,0xFC,0x08,0x20,
- X' f' s, U/ `. M" s0x01,0x00,0xFF,0xFE,0x45,0x04,0x10,0x18,0x01,0x00,0x08,0x40,0x7D,0xF4,0x20,0x2E,
0 ?# I" K, r8 _8 [0x7F,0xFE,0x7F,0x44,0x52,0x94,0xDF,0xF4,0x01,0x80,0x10,0x44,0x10,0x94,0x00,0x00,
( b. f! G% _! b! s0x02,0x80,0x24,0x28,0x5E,0x94,0x00,0x00,0x02,0x80,0x7F,0x28,0x50,0xF4,0x1F,0xF0,7 G1 I7 ^; o# T# N" P
0x04,0x80,0x04,0x30,0x50,0x94,0x10,0x10,0x08,0x80,0x07,0x30,0x50,0x88,0x10,0x10,
$ V" N- ?" J0 l. g2 w9 q3 w) h0x10,0x82,0x7C,0x52,0x50,0x82,0x10,0x10,0x20,0x82,0x04,0x8A,0x5E,0x82,0x1F,0xF0,
/ I3 z) v0 b. A* c0xC0,0x7E,0x05,0x04,0xE0,0x7E,0x10,0x10,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00, //nine
3 C- q8 X4 }+ O. z; @0x20,0x00,0x04,0x40,0x00,0x80,0x01,0x00,0x21,0xFC,0x04,0x50,0x7C,0xC0,0x02,0x80,
) L! X! T" n. f4 p& e8 W. p0xFE,0x08,0x3F,0x48,0x44,0x80,0x04,0x40,0x20,0x10,0x04,0x40,0x44,0xFC,0x08,0x20,+ ^; z6 x& d  Q; p* T) @
0x50,0x20,0xFF,0xFE,0x45,0x04,0x10,0x18,0x50,0x50,0x08,0x40,0x7D,0xF4,0x20,0x2E,
7 c8 b8 \, c6 \) S0x90,0x8C,0x7F,0x44,0x52,0x94,0xDF,0xF4,0xFD,0x04,0x10,0x44,0x10,0x94,0x00,0x00,
3 z9 P+ @4 f4 b, z0 t* P0x13,0xFE,0x24,0x28,0x5E,0x94,0x00,0x00,0x10,0x20,0x7F,0x28,0x50,0xF4,0x1F,0xF0,
/ r6 e! f4 A$ ]0x1C,0x20,0x04,0x30,0x50,0x94,0x10,0x10,0xF0,0x20,0x07,0x30,0x50,0x88,0x10,0x10,  j$ R; S& i: k. K# `* X
0x10,0x20,0x7C,0x52,0x50,0x82,0x10,0x10,0x10,0x20,0x04,0x8A,0x5E,0x82,0x1F,0xF0,; M0 p$ V* p8 `
0x17,0xFE,0x05,0x04,0xE0,0x7E,0x10,0x10,0x10,0x00,0x04,0x00,0x00,0x00,0x00,0x00, //ten
; j2 C' T/ S7 L. i8 k2 K0x41,0x10,0x04,0x40,0x00,0x80,0x01,0x00,0x21,0x10,0x04,0x50,0x7C,0xC0,0x02,0x80,
- C% Q' C# V- P6 c" E0x2F,0xFE,0x3F,0x48,0x44,0x80,0x04,0x40,0x01,0x10,0x04,0x40,0x44,0xFC,0x08,0x20,
. N4 Y6 ]% r7 x/ C5 p% j0x80,0x00,0xFF,0xFE,0x45,0x04,0x10,0x18,0x57,0xFE,0x08,0x40,0x7D,0xF4,0x20,0x2E,6 ]8 K# Y  a) b6 a. K* B' S
0x51,0x20,0x7F,0x44,0x52,0x94,0xDF,0xF4,0x17,0xFC,0x10,0x44,0x10,0x94,0x00,0x00,
* l1 R/ v+ A; G$ O! P5 O0x25,0x24,0x24,0x28,0x5E,0x94,0x00,0x00,0x25,0x24,0x7F,0x28,0x50,0xF4,0x1F,0xF0,( ?! B8 o, M, F0 V+ V+ Q6 T
0x25,0xB4,0x04,0x30,0x50,0x94,0x10,0x10,0xC6,0x4C,0x07,0x30,0x50,0x88,0x10,0x10,: [+ T9 P2 A, o  d3 F% h! D* |
0x44,0x84,0x7C,0x52,0x50,0x82,0x10,0x10,0x44,0x04,0x04,0x8A,0x5E,0x82,0x1F,0xF0,' y7 j2 }9 n8 T( s
0x44,0x14,0x05,0x04,0xE0,0x7E,0x10,0x10,0x44,0x08,0x04,0x00,0x00,0x00,0x00,0x00, //eleven
# \: t1 U) t: r7 l( l7 ~/ Z
+ r( o6 B/ [8 [( f, }0x01,0x00,0x10,0x40,0x40,0x02,0x00,0x20,0x01,0x00,0x18,0x50,0x27,0xC2,0x40,0x28,+ g1 j% i  j& ?
0x7F,0xFC,0x10,0x4C,0x24,0x42,0x20,0x24,0x02,0x00,0x20,0x48,0x84,0x52,0x30,0x24,
  }+ ^" ]5 g9 }9 }- i9 C0x1F,0xF0,0x23,0xFC,0x45,0x52,0x27,0xFE,0x10,0x10,0x48,0x40,0x55,0x52,0x00,0x20,0 c8 V/ \# c4 f8 u1 q
0x10,0x10,0xF8,0x40,0x15,0x52,0xE0,0x20,0x1F,0xF0,0x13,0xFE,0x25,0x52,0x27,0xE0," ]$ V) ]5 S0 }9 }4 c% T7 H! r
0x10,0x10,0x20,0x40,0x25,0x52,0x21,0x20,0x1F,0xF0,0x7C,0x48,0x25,0x52,0x21,0x10,& d% t- s1 Q6 F/ g; t+ t0 O. T
0x10,0x10,0x00,0x30,0xC5,0x52,0x21,0x10,0x1F,0xF0,0x00,0x22,0x41,0x02,0x21,0x0A,
/ O* r7 K. Q! \' \) i0x10,0x10,0x1C,0xD2,0x42,0x82,0x29,0xCA,0x10,0x10,0xE3,0x0A,0x42,0x42,0x36,0x06,2 G% S$ V: ^+ R+ n
0xFF,0xFE,0x00,0x06,0x44,0x4A,0x20,0x02,0x00,0x00,0x00,0x02,0x48,0x04,0x00,0x00, //twelve
- |6 T. \, a& h! ~/ v3 D1 b0x00,0x00,0x01,0x00,0x40,0x02,0x00,0x20,0x3F,0xFE,0x01,0x00,0x27,0xC2,0x40,0x28,
* {5 }' u3 k: {- b# B  ^0x20,0x00,0x01,0x00,0x24,0x42,0x20,0x24,0x20,0x80,0x01,0x00,0x84,0x52,0x30,0x24,
; E: ?. M, m( Z0x20,0x80,0x7F,0xFC,0x45,0x52,0x27,0xFE,0x20,0x88,0x01,0x04,0x55,0x52,0x00,0x20,
! D) P3 A( Q0 e" _+ \3 ?' L0x2F,0xFC,0x01,0x04,0x15,0x52,0xE0,0x20,0x20,0x80,0x01,0x04,0x25,0x52,0x27,0xE0,1 h3 z5 B9 u7 N, T3 V* f
0x20,0xA0,0x01,0x04,0x25,0x52,0x21,0x20,0x20,0x90,0x02,0x04,0x25,0x52,0x21,0x10,- W! z2 @1 t! K/ m4 V; e% O; f
0x20,0x98,0x02,0x04,0xC5,0x52,0x21,0x10,0x40,0x90,0x04,0x04,0x41,0x02,0x21,0x0A,
) [6 s$ z2 i, [( z/ M0x40,0x80,0x04,0x04,0x42,0x82,0x29,0xCA,0xBF,0xFE,0x08,0x04,0x42,0x42,0x36,0x06,9 o- t  |5 ?7 S& o; l2 Q
0x00,0x00,0x10,0x28,0x44,0x4A,0x20,0x02,0x00,0x00,0x20,0x10,0x48,0x04,0x00,0x00, //thirteen! E  q' u6 W$ Z2 {/ J3 _: D. m1 s
0x00,0x00,0x10,0x40,0x40,0x02,0x00,0x00,0x00,0x00,0x18,0x40,0x27,0xC2,0x00,0x00,0 m, M0 r/ m  h9 b
0x00,0x00,0x13,0xFC,0x24,0x42,0x00,0x00,0x00,0x00,0x28,0x40,0x84,0x52,0x00,0x00,0 @  h# w4 `$ D9 y! P# U" b- G" Y
0x00,0x00,0x4C,0x40,0x45,0x52,0x00,0x00,0x00,0x00,0x88,0x40,0x55,0x52,0x00,0x00,
' N8 Y2 C$ o) y' B0x00,0x00,0x17,0xFE,0x15,0x52,0x00,0x00,0x00,0x00,0x10,0x10,0x25,0x52,0x00,0x00,# x( ]3 X& A6 [! c
0x00,0x00,0x30,0x10,0x25,0x52,0x00,0x00,0x00,0x00,0x57,0xFE,0x25,0x52,0x00,0x00,2 I: c! Q, z4 U" s) d: @( p0 e
0x00,0x00,0x10,0x10,0xC5,0x52,0x00,0x00,0x00,0x00,0x11,0x10,0x41,0x02,0x00,0x00,
; f8 i2 j( y7 D( {2 z* u0x00,0x00,0x11,0x10,0x42,0x82,0x00,0x00,0x00,0x00,0x10,0x10,0x42,0x42,0x00,0x00,
& l8 W9 S5 i* G/ b/ p0x00,0x00,0x10,0x50,0x44,0x4A,0x00,0x00,0x00,0x00,0x10,0x20,0x48,0x04,0x00,0x00,  //fourteen
. C# N3 ^2 W4 {, A0 G; u! o; P};
! j2 o; h4 F9 b4 b2 D5 {# @4 w9 Z  Y4 ?/ C3 ]
unsigned int x=0;
8 d! F8 V, |& `9 g5 B7 Dunsigned long cnt=0;
( p6 z, z! b: v% Nunsigned int Row=0;
* B3 [* Q4 {0 f2 `8 vunsigned int m=0;/ g* W* t- B' G
void delay(unsigned int i)5 S$ Z. J+ @" ?# v  B0 U
6 m, n! I& |9 P0 D/ W* K        unsigned int j,k;
5 u. s7 s# h1 t& h        for(i;i>0;i--)
9 ~$ Y3 o7 D/ V  E: t6 ]+ t& S# I# C        for(j=10;j>0;j--)# k' J" @$ g4 E% l
        for(k=200;k>0;k--);
) ?$ @8 I1 c4 E7 b: Z( y9 \6 x2 N. B}. s3 Z) |. G8 q  v9 i; Y; O/ H0 j
void display(unsigned int C_num)
% a: B: s! L- R5 y( r{
! P4 D5 _: V" O8 m8 ~# o        unsigned char k,n,num;2 w0 W1 s* S( R( H1 u1 J
, \6 j' I9 Y& P1 z3 V1 s
                for(k=0;k<2*C_num;k++)$ r( K. k# L! ^7 F- E6 _1 y; c
8 H. I. b9 T. P3 \5 }$ V* b                        num=GB_16[8*Row+k+128*x];
$ u3 k% s& A6 r, I                        for(n=0;n<8;n++): \% A- A" D6 J4 u
                        {- H1 m: h5 V& s: j. |0 N
                                SK=0;
/ y" n4 Q, W) \) ^                                R1=~num&0x80;0 ?! V8 A. r, E
                                G1=~num&0x80;/ R" w( r: y# b
                                SK=1;! J$ a3 O7 ^$ a, ?5 }0 F
                                num<<=1;
& }# }1 q0 t$ W                        }
7 o* B9 j" `+ k- X  s& f& _9 V                }
' A: {1 X) v' j" U% e                EN=1;5 l9 s- S) i4 e0 B# ^) K
                LT=1;2 A$ Y0 ~3 b4 P! W
                LT=0;% ]( \6 T7 }$ _" z0 [' O
, J0 ~4 ~8 W- n/ z  S
                ROW_address=Row;! |4 |* u5 B/ n2 f2 V; F
                EN=0;
) S  o/ m! q  G& I% \/ m9 F}5 }" g# S0 [3 m- _& t- A
/************interrupt T0****************/
' @# j4 ^' n- g+ r. ^# Gvoid time0() interrupt 1
8 V! q% b; j1 }% }, m( I2 T8 x. ?$ S{, f8 T# ?4 X: _. [, z" H" P; C
        TH0=0x1ff;7 ?4 Y9 w- M8 Q! K
        TL0=0x00;+ U5 P+ h5 v9 I- D8 Q
        Row++;
: n1 E0 s3 K2 {; L- @' |        if(Row==16)4 J0 K6 O+ |- d6 n2 D5 h
                Row=0;# ^0 k+ M3 `* v# s; t, s) }1 S* _9 X
        display(4);6 V* v# C! e6 w7 |* T: J
        cnt++;
- A# r3 b$ {# _; I) B' o}
- h! O8 Y$ N. d7 s' A9 S
7 B! e" S) _. E9 G/***********init ************************/
* M6 {1 O6 ]& Q. K; Bvoid init()
5 [6 v$ w$ B6 c( |{
1 m5 B) H4 x( Q. W: d; q6 |; ^' p        TMOD=0x01;  y: Q0 Y; F/ t6 }, E. h* Z
        TH0=0x1ff;
/ F6 y' ]; s. k. n0 V6 [5 G/ G        TL0=0x00;$ c4 ~  f* p3 u# j( P' j
        ET0=1;6 x9 t: ?& I; t4 _& f
        TR0=1;
- k# g- f' L; X& F! l& @9 u6 W        EA=1;
3 [& D9 O( g6 v9 E8 t# i}7 s/ `% ?8 z# ~* |' C6 ^% k+ l
void main(void)
* R  S* v3 w  ?/ k9 |0 z/ ^$ P{' C$ P$ x5 e2 `! y3 @
        init();
! \7 U3 {! z! X% P8 T! v    key1=1;
# p+ U9 K  Q' l6 h) }7 w2 K, m    key2=1;
3 q& y* N/ a& ~% S; `    key3=1;
' f9 V: Y$ k& G- X    key4=1;% L4 f  q# o3 o
        while(1)9 a4 P5 B7 d& T2 k
        {! \% X' M/ A  K- X7 v- p
//                if(key1==0 && key2==1 && key3==1 && key4==1 && key5==1)
1 t, [' z- a; ?! u                if(key1==0)
/ V, G1 u% _/ v( q                {- P2 f& z  N' u8 L& v5 X
                 while(!key1);
( [/ d3 ~9 `: h1 E# j4 e+ l, ~                 x++;- ?6 V/ b2 D# a8 s' u0 J* q6 {; S2 ?: g
                 if(x>=8)
6 k! A4 A. K* m+ w: F7 ~                 x=0;* V9 }1 P% w* B
                }! C5 U3 I8 K5 d
                else if(key2==0 && key3==0)
/ g/ I* o/ N+ w: e; p* L( H+ l/ i  c                {- S" Z- z" \, I9 r
                 x=8;1 a6 B; j* A! h8 |. x* N' l# b
1 y2 v$ E% z2 J2 h/ J5 f& j) H
' ]$ p' [( I8 H+ \3 d                else if(key2==0 && key4==0)
3 U+ R4 Y3 h4 r0 D% z4 M- b. g. y/ W: U                {
9 }, l5 e, c+ d4 Y- c2 u3 t+ m                 x=9;
0 e% L# H& }$ H% b: D                }
5 d' d4 T4 `- q/ l. e
* h4 _% {  g/ a- J' ~3 f                else if(key2==0 && key5==0)
7 H8 g+ d/ }; U                {
2 N* d2 i! M( J                 x=10;8 q/ _8 p4 [8 n( v* K/ F; ~; k0 z
                }/ L* I& J% \  y- X
                else if(key3==0 && key4==0)
  A0 U2 H: T, g% W            {! H, @% ]& p8 {
                 x=11;
( N3 `# t2 b0 c- w9 n9 e' @                }2 q$ s0 U6 Q* s& s
0 f+ K; U3 ~3 N: R2 j                else if(key3==0 && key5==0)$ U" i1 R4 S: T: l4 G7 O
                {, M5 R' Z8 ^' U4 a6 Q& H
                 x=12;, [: N2 r9 }! j3 I7 ?2 E5 ^
                }( N4 ~6 z/ |& S' H
5 d  M$ B1 O9 Z7 r! F# U                else if(key4==0 && key5==0)
" {! `0 f; o! ?0 T: Y                {
( Q7 l$ U& y; C2 U                 x=13;
3 {5 C2 k: X) }" R6 ~: P                }1 f/ }1 Y  b9 J/ D8 R- z8 F( \3 n/ }
# y* j8 P1 u) w2 j+ k! `3 [" x}
. o5 Y5 Y: z" {( q
" I+ v# K0 N  z" _1 G) Y9 {5 p$ u/ V. d( P8 U! m4 i1 _' R
6 {5 S: I' A( K5 T' @2 s下载:
4 T! R) J) ?* }' ^; U2 P
游客,如果您要查看本帖隐藏内容请回复
8 p7 h4 Z  H0 d- A
/ o* J9 C( }4 L, G: l
发表于 2019-1-16 21:21 | 只看该作者
看看楼主的代码
GMT+8, 2025-10-9 00:03 , Processed in 0.140625 second(s), 26 queries , Gzip On.
