单片机三层电梯控制proteus仿真设计 带源码
! X0 f9 y# Z" E8 W$ w4 q" B5 r" c; I/ ]+ r+ V' Z
% j3 _6 K9 D' H
单片机三层电梯控制,使用数电和带单片机,适合新手。2 W) T8 Z) `" K* d
9 m3 L: x9 d& F- H- N
' G( e+ `0 O8 O6 r/ d单片机三层电梯的源程序:+ u" P a) Y4 V: N
/******************************************************************- }' A6 I9 ~ \; X( O. P& Q6 n
AT89S51的T0,T1计数器对输入的信号进行频率计数,测量结果用五位数码管5 }$ `9 O# g9 Z
动态显示,要求对0~65KHZ的信号频率进行准确测量,误差不超过5HZ
6 t* B6 L' g8 _! I8 g9 Y. {& T*****************************************************************/
5 D+ k5 S6 R( s" a5 N#include ( o9 n4 Z- F. \
#define uint unsigned int
/ \- O0 l4 O& R; m( a3 W5 E3 q7 A4 Gsbit KEY_1=P2^0;: z: j, U$ d' A
sbit KEY_2=P2^1;
2 b. t) Q- o Ysbit KEY_3=P2^2; A) @$ A5 H9 _, ?! U
sbit KEY_4=P3^3;
, Y7 ?" X* m- ^- csbit LED1=P3^0;
: s c& _6 G* \% Z msbit LED2=P3^1;$ C; R% t0 p0 R* A. R' `3 d
sbit LED3=P3^2;
; g2 a5 R1 ^# X! n4 d1 Iunsigned int num=0;
) V8 ~: y. ^% \1 ]. T% m2 j# gcode unsigned char TAB[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0X77};
- p& A! t; s( d$ P/ P1 ?9 \- d /*显示变量对应的数值*/
& g# K5 m+ l: I# m# P/***************定时器0中断服务函数************************/9 e* l( }/ s8 Z' [
void timer0()interrupt 1{; w6 P/ S! N8 m0 `
TH0 = (65536 - 10000) / 256;, A! a, `/ N- T) w" t8 o5 M
TL0 = (65536 - 10000) % 256;
% m3 g. P! ] {; @9 W9 G num++;//记到20就直接停止) E' s. F- Z( o1 x& \, w/ c
//if(num>=50)* h9 Z O4 |$ X2 H7 ]
" g. K' W' G. h0 K. o& b+ a/**************************延时函数************************************/
# r& k: k4 x! l5 K3 d V# J+ ~, Ovoid delay(unsigned char t){
* \' Q% M5 g8 Z; y C9 f unsigned char i,j;- ?6 {7 q( T9 G! m
for(i=0;i<t;i++)
" e+ r# C% ~ m: w/ L for(j=0;j<125;j++);4 Q+ Y. R6 e) @ X6 ^
}. x4 \+ g( K2 ^$ z7 x0 s
void delayms(unsigned int xms) 3 m* D: b9 K$ a' n" L
{5 }* e" g E' g! M$ b- ~' e
unsigned int x;
/ Y4 G; y2 {- T% t. q5 u unsigned char y;
+ \. s9 i. Y/ ]8 x+ g2 s2 D for(x = xms; x > 0; x--)
5 D* W6 v# ?% F0 y" M' n4 O for(y = 124; y>0; y--);//11.0592MHz: 114 //12MHz: 124
, u c. z6 D% \4 B1 p" o) ?4 l}
1 e3 p" n$ W5 m" C/ @void delayus( int xus) - |; Z5 u! P: b0 j7 D- V4 O
{9 U) ]3 N: o( x( a2 v
while(--xus>0);
t8 A! I# ~. ] K}
$ ]2 [0 q8 }: s( L$ @' t/*************************显示函数**************************************/
' `1 I z! P4 h# f- L/ G& Q [1 p
6 j/ D) [2 `8 dvoid main(){
" ]8 I1 d! V; I# ]2 T) S: W1 T
# j! t: U: `# Z TMOD=0x01;//T0 记时 T1计数2 T6 O. R, G8 T# C' u. K
TH0 = (65536 - 10000) / 256;1 K. j- x, w; E( A/ f6 u, f
- O) u: V" \/ N, q' C2 Y0 c
3 [0 t5 p/ M% h. F TR0=1; //开T0 // IT1=1;
3 O4 p- {7 A; P7 Q/ m1 @5 S' N# G ET0=1;//开中断4 s/ `+ F% h1 {) ^ o/ r
EA=1;//打开总中断 0x86 0xdb 0xcf
6 ?8 u$ I& ~( P% v LED1=1;
& _% N$ k' J0 w3 \* t( o2 j, U: U2 g LED2=1;
9 L: h; m- N' r) ^- S1 e1 m5 W LED3=1;
0 W' T T! P/ i) l# q; S0 \ num=0; //1 1000 0110 2 1101 1011 3 1100 11112 V0 d0 W+ F3 k4 J- D9 F; w
while(1)
/ R( u- Y" X, ]8 j+ e) f {
/ k; b! t$ W% q% W% b, [) g; @- k* ~ if(KEY_1==0){ LED1=1; LED2=1; LED3=1;while(P1!=0X86);num=0; LED1=0; while(num<500){if(KEY_2==0||KEY_3==0)break;} if(P1==0X86)LED1=1; }+ k9 A9 o% ]9 Z: n# S3 H
else if(KEY_2==0) {LED1=1; LED2=1; LED3=1;while(P1!=0Xdb);num=0; LED2=0; while(num<500){if(KEY_1==0||KEY_3==0)break;} if(P1==0Xdb)LED2=1;}
( h# F; l& S- L. X0 ] else if(KEY_3==0) {LED1=1; LED2=1; LED3=1;while(P1!=0Xcf);num=0; LED3=0; while(num<500){if(KEY_1==0||KEY_2==0)break;} if(P1==0Xcf)LED3=1;}
c8 f: E+ V$ T$ d}+ A1 d, O7 B2 H+ i: ^. W
+ A) Y9 O0 R2 ^+ k1 M' A E // % h1 i. D5 h# p* X2 K# V+ ^, R
% N6 N6 A; a7 Y4 Q& V l- k7 P
3 v, v; q; E0 s0 S' c; c单片机三层电梯控制系统的所有资料下载:' c7 }6 y3 C% H. a
: @8 ~9 I Q( z# V: M
* z8 Q+ J# O: z8 ^0 t) O, J5 G
