Fixed CCRs: SPB 17.2 HF050; d6 Z+ g; u' r2 b0 k
12-23-2018- o( A$ q! F' s( ~+ f
' L) H" I2 a) K4 ]$ o. }$ d. z/ Q5 k8 aCCRID Product ProductLevel2 Title( _1 }1 }1 N: h0 c$ D( G
========================================================================================================================================================, d$ c1 b9 j" c7 i n$ I
2012119 ADW ADWSERVER Cannot connect Component Browser to server
! v6 d- |" S4 m3 @7 J# ~5 q8 [; _* w7 K1 t1998856 ADW ADW_UPREV adw_uprev fails and a typo in rule name, z1 y$ [. U; u0 b" Y w) q# M
1673333 ADW CONF Configuration Manager stops working and gives Java Timer-1 Error
( k/ L) k2 L$ o$ y. g3 e! Z( k ^1900342 ADW DBEDITOR 'Link To' on a schematic classification attribute does not work with linked attributes containing parenthesis/ F! C7 y) k v4 g
1997516 ADW DBEDITOR DBEditor stops responding on changing attributes
5 T& F% Q! k# m. | h; T1986292 ADW LIBDISTRIBUTI Some parts are not updated in the part table in all_noauto and ini_noauto (restricted_sites).' x0 K9 s" d6 y
2010460 ADW PART_BROWSER PKG-1002 error when opening a DE-HDL design9 X0 D' h; b- E- X
2013430 ADW PART_BROWSER Add component is inactive if WB_SHARED_RESOURCES is not pointing to the installation directory
4 @9 L" w3 r) Y5 g3 l0 Q2022806 ADW PART_BROWSER PKG-10005: Cannot package the following primitive instance in any section of the physical part& I+ I/ i4 ]; _3 _! a( a0 z
2006528 ADW PART_MANAGER Part Manager does not update parts when Key PTF property value changes1 Y* D3 W4 E* z2 G' |7 s# ?
1980397 ALLEGRO_EDITOR DATABASE Mechanical pins with route keepouts (RKO) not updated6 q# D: i8 M" k8 P
1988171 ALLEGRO_EDITOR DATABASE Backdrill clearance Keepout is not applied consistently& y, H7 @: [2 }8 R8 B. J5 x6 V; b
1994280 ALLEGRO_EDITOR DFM PCB Editor crashes during Unplace component& q5 u$ b" C0 e/ k; p
2012742 ALLEGRO_EDITOR DFM DFT for testpoint to outline not showing DRC# e. y9 d4 }5 {. T3 S
2002680 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes on choosing Add Connect for two selected nets& R9 D; ~' c) {2 R: U e+ t! g6 j
2004597 ALLEGRO_EDITOR EDIT_ETCH Illegal BMS Identifier error when copying multiple via structures
1 W" B: z. D' m* ]' }+ [2004929 ALLEGRO_EDITOR EDIT_ETCH Net with physical pin pair constraints is using incorrect line width when routed9 o+ c: R4 ?' P5 w2 Q0 k/ Z- [2 D
2008314 ALLEGRO_EDITOR EDIT_ETCH Adding nets in tabbed routing crashes PCB Editor
' y( A" n1 U+ l7 }. V2018710 ALLEGRO_EDITOR GRAPHICS Using the mouse to zoom by scrolling stops working randomly
0 i d, K9 t/ p4 R" M2018841 ALLEGRO_EDITOR GRAPHICS Canvas does not regain mouse focus after working in the Options pane in hotfix 0491 ?1 O# C1 R* r& _$ l3 }) O, O
2019482 ALLEGRO_EDITOR GRAPHICS Canvas does not regain mouse focus after working with the Options pane in hotfix 049 on Windows 7
& D* p# Z' D; g5 l+ Z! }( V2019864 ALLEGRO_EDITOR GRAPHICS Using the mouse scroll button to scroll the canvas: focus is in the Options pane" C1 P# j7 r, l1 n' v
2020750 ALLEGRO_EDITOR GRAPHICS Zoom in/Zoom out scroll does not work+ A8 ?/ b- j* Q7 |
2020847 ALLEGRO_EDITOR GRAPHICS Scroll up/down key focus remains in command screen even when canvas is selected) r: i4 s2 O- O9 m5 Q% U
1908812 ALLEGRO_EDITOR INTERACTIV Tools > Design Compare command does not work on Windows
$ D8 \) ~% f0 `5 h% \0 H* d1995846 ALLEGRO_EDITOR INTERACTIV When there is an embedded component, the result of Metal Usage report is incorrect.. }/ a: g' \( ]& S4 G- X" \3 \3 ]1 E
2011449 ALLEGRO_EDITOR INTERACTIV Command not found error (_impvision) for Impedance and Return Path DRC visions
. n* n2 M" x& h( J+ w+ Q. H) i( R1982867 ALLEGRO_EDITOR INTERFACES DBDoctor displays error for objects outside extent that cannot be fixed because the extents cannot be increased8 ?7 ?0 S5 [8 |
1983177 ALLEGRO_EDITOR INTERFACES PCB Editor crashes when reading IDX file \( C! ^7 D9 ]
1985623 ALLEGRO_EDITOR INTERFACES STEP model not exported from PCB Editor) Y; \7 I6 J4 U7 {8 R
1994855 ALLEGRO_EDITOR MANUFACT Drill legend with counter-bore: legend size not uniform when database set to inches- u' e9 I- t# {, B: k8 ^: \
2001355 ALLEGRO_EDITOR NC PCB Editor crashes with NC route parameter
" @! `2 ]" n( A1753414 ALLEGRO_EDITOR OTHER Ability to add Rigid Flex class in a format symbol6 W- o0 }5 C; C. S: Z) k
2004786 ALLEGRO_EDITOR OTHER Legacy menu option missing in OrCAD Professional/ A9 [/ \0 f7 s1 y
1949695 ALLEGRO_EDITOR PADS_IN Third-party to PCB Editor translation does not make a clean conversion; T; x/ X; ^/ i6 p+ b. f
1949658 ALLEGRO_EDITOR PLACEMENT SKILL module creation issue: subsequent runs rotate module incorrectly
( H9 Q+ L9 y" r# H" R7 d; i2001496 ALLEGRO_EDITOR PLACEMENT Constraint Region not replicated as part of the Place replicate apply command
, [% U8 } B: I2 e8 q* F$ Y7 m2002989 ALLEGRO_EDITOR PLACEMENT Default rotation point is set to 'User Pick'
2 ?3 p# ~+ K; h2007301 ALLEGRO_EDITOR PLACEMENT DFA boundary is shifted when moving components with User Pick
. l" D, ]5 }4 L9 l2007312 ALLEGRO_EDITOR PLACEMENT DFA boundary is shifted when moving components with User Pick
+ l8 B5 T. ?3 [* i* `/ M% B* r2008098 ALLEGRO_EDITOR PLACEMENT DFA boundary shows a shift if anchor point is set to 'User pick'
, N3 b0 r2 X( L2009085 ALLEGRO_EDITOR PLACEMENT DFA boundary is shifted when moving components with User Pick% u7 r, p5 y+ X- }4 I5 [+ m9 B' i
2009090 ALLEGRO_EDITOR PLACEMENT DFA boundary is being offset when moving components with User Pick
, r) f& ^' p& m; F8 Q2009580 ALLEGRO_EDITOR PLACEMENT Component outline offsets during move process
( R* i& A1 Y. |- E1 j2010726 ALLEGRO_EDITOR PLACEMENT Two images appear when moving component in release 17.2-2016, hotfix 048$ o: d# p. K9 }
2010819 ALLEGRO_EDITOR PLACEMENT A separate outline appears when moving components using User Pick1 }; m( f# e# i3 {9 S: s0 l8 I
2011454 ALLEGRO_EDITOR PLACEMENT DFA boundary is not centered correctly on moving components
/ C7 k/ s$ V3 {) T. B* u, W2 e- `2011497 ALLEGRO_EDITOR PLACEMENT DFA boundary shifted from the part when moved, E! g" O7 F9 o9 p% t* l- `
2014250 ALLEGRO_EDITOR PLACEMENT Moving a symbol using the 'User Pick' causing an offset image of the symbol outline getting attached to cursor: r. c; Q( J3 ~( o& J* _1 i
2015676 ALLEGRO_EDITOR PLACEMENT Strange end-to-end DFA checking: offset of DFA from component when in user pick. i5 ^5 J- o3 a/ K# m
2016421 ALLEGRO_EDITOR PLACEMENT Fail to place symbols because definition is incompatible for attribute 'PW_GENERATED'
% J; `* X2 Q5 E4 x2016452 ALLEGRO_EDITOR PLACEMENT Some symbols cannot be placed due to property definition differences
* {& l3 m# X' X2 w: w2016527 ALLEGRO_EDITOR PLACEMENT PCB Editor crashes on moving all components on board
# g3 v1 l& |9 J; V2017364 ALLEGRO_EDITOR PLACEMENT Strange behavior when moving component: DFA or place bound area is centered around the User Pick position
0 T3 A/ c. b. [/ i. P; o+ Q: P% @2018859 ALLEGRO_EDITOR PLACEMENT Moving parts by 'User Pick' or 'Sym Pin #' shows two component placement boundary outlines
, }1 S/ w% @4 f) E, _0 n" _! [" z2019364 ALLEGRO_EDITOR PLACEMENT PCB Editor stops responding when moving components' } h: q1 A q6 _6 \3 S: ^
2019478 ALLEGRO_EDITOR PLACEMENT PCB Editor crashes when moving more than one component across the design* o, X) k j9 `) h$ t3 Y* M
2019624 ALLEGRO_EDITOR PLACEMENT DFA Boundary is offset from definition when moving symbols with user pick' t- j6 J' g. H- [' g8 p9 K/ Z2 s
2021625 ALLEGRO_EDITOR PLACEMENT Graphical Issue with Edit - Move and User Pick: additional outline image shown
% s/ i* U$ B- ~' W% W' K2022203 ALLEGRO_EDITOR PLACEMENT Place bound outline is shown at the center of the pick when moving a part by User Pick
+ |9 P' M- T! r0 d$ D2024655 ALLEGRO_EDITOR PLACEMENT Moving multiple components causes PCB Editor to crash9 ~! E/ Q! N p- e; _3 j5 ^' U7 |
2025895 ALLEGRO_EDITOR PLACEMENT PCB Editor stops responding when multiple symbols are moved and on getting too close to another symbol) V6 H/ y% I; A
2004497 ALLEGRO_EDITOR SHAPE Automatically deleting antenna shape is not deleting thermal reliefs associated with those shapes( u( D( o) w- ?
2007832 ALLEGRO_EDITOR SHAPE Cannot void shape properly after rotating symbol
4 j9 F; ` H: I/ t: {7 Z) F2009601 ALLEGRO_EDITOR SHAPE Error for shape created using third-party SKILL utility
4 Z+ T5 x2 b! ?2 I; z2010924 ALLEGRO_EDITOR SHAPE Dynamic shape does not void in route keepout areas
; k' d4 Y: v1 c* A' [2011176 ALLEGRO_EDITOR SHAPE Nothing happens on choosing 'Shape- - Change Shape Type' in Allegro Sigrity SI# s5 O0 h8 Z& c. t6 o
2015446 ALLEGRO_EDITOR SHAPE Thermal relief connection created for static shape covering pin when inside a void in a dynamic shape.3 C+ g. B" j% _- P3 m- }5 |
2017273 ALLEGRO_EDITOR SHAPE Same net spacing does not void properly for shape to hole.
6 e2 a3 U+ a6 t4 V# C2012878 ALLEGRO_EDITOR UI_FORMS Custom toolbars cannot be loaded as size differs for customState and customExteded in registry; m8 ~3 }) L5 Y: R3 M7 B
2018177 ALLEGRO_EDITOR UI_FORMS Custom toolbars cannot be loaded as size differs for customState and customExteded in registry% c7 x, F* O9 w+ Y
2019437 ALLEGRO_EDITOR UI_FORMS Custom toolbars cannot be loaded as size differs for customState and customExteded in registry
$ h- l: J2 U% ~! P" f1 u2020491 ALLEGRO_EDITOR UI_FORMS Cannot load custom toolbars because the customState and customExtended Windows Registry entries are incorrect
7 n9 z4 {. [9 J1897843 ALLEGRO_EDITOR UI_GENERAL Function Keys, such as F3, F6, and F7, are not working if tool is idle for some time
% I) ^2 U ]) e/ E8 N! d2000445 ALLEGRO_EDITOR UI_GENERAL Funckeys not working in hotfix 048 with the new Command Pane as default
) w7 G1 D4 ^1 a6 F2001847 ALLEGRO_EDITOR UI_GENERAL Ctrl related funckeys not working in hotfix 048: Q* M" S# v$ O1 v& s
2008112 ALLEGRO_EDITOR UI_GENERAL Funckeys using Ctrl and Shift do not work in hotfix 048 (QIR 7)
0 `/ t m! H0 G7 L. Z1 D2010370 ALLEGRO_EDITOR UI_GENERAL Shift + arrow key does not move component in release 17.2-2016, hotfix 048# _; W, T. O1 `% d* K5 i) s
2015418 ALLEGRO_EDITOR UI_GENERAL Funckey not working: ?( q8 t2 P' Z8 y1 a5 [/ T' J) G
2015443 ALLEGRO_EDITOR UI_GENERAL Text does not regain focus even on clicking after using a drop-down menu
* L) ~, @5 y* w/ p8 l' n2016899 ALLEGRO_EDITOR UI_GENERAL Dynamic zoom and funckeys are disabled after clicking a combo box in the Options pane" X& h2 {2 y3 q- S+ k
2019753 ALLEGRO_EDITOR UI_GENERAL Infinite Cursor disappears regularly in hotfix 049 when infinite_cursor_bug_nt is set
3 h; S% i: ?2 m2019990 ALLEGRO_EDITOR UI_GENERAL Mouse over does not highlight pin, need to click
1 [% i% F1 t5 }2 T2020162 ALLEGRO_EDITOR UI_GENERAL Funckeys not working in hotfix 049: pressing F4 not running Show Element1 R" d5 C6 l4 Z. R
2020168 ALLEGRO_EDITOR UI_GENERAL Data tips not shown on mouse hover
8 }( Q. r+ P: Q% V; g! P" i* ]2020840 ALLEGRO_EDITOR UI_GENERAL Page-up/Page-down (remapped to zoom-in/zoom-out) stop working until mouse scroll button is pressed# R8 S" d! v: |; i' a! x
2021416 ALLEGRO_EDITOR UI_GENERAL New user interface does not shift input focus and zoom in/out does no longer work in layout window
% A: ^3 {; v" d( N2022185 ALLEGRO_EDITOR UI_GENERAL Ctrl related funckeys are not working" H7 W9 J, s$ j
2023402 ALLEGRO_EDITOR UI_GENERAL During Add text, focus does not move from the subclass dropdown to the canvas.# u3 e, b0 @8 Q6 {+ P) S
2025806 ALLEGRO_EDITOR UI_GENERAL Function keys and shortcuts not detected
* m# h, r; ^, i n2027581 ALLEGRO_EDITOR UI_GENERAL Funckey problem: focus lost from canvas on using another window
/ f$ R7 p, h9 z: {- b! j$ H2009382 ALLEGRO_EDITOR ZONES When deleting zone by Zones - Manage, the shape in zone is out-of-date
8 c* R5 m5 T$ [9 y& {) `4 u1977211 APD DXF_IF APD: die pads shift after export DXF6 @, x% o, b$ W4 ?* r7 x
2018483 CAPTURE NETLISTS Error when extracting netlist from schematic (ORNET-1193)3 ] S$ i0 `3 \, W
2022764 CAPTURE NETLISTS Schematic will not generate pstchip.dat file0 T( a1 |5 d+ o- E
1921557 CAPTURE NEW_SYM_EDITO Zoom to region option grayed out/ }" k( Y4 u4 M1 N2 ~" d. ^: V3 [
1945203 CAPTURE NEW_SYM_EDITO Symbol Editor: No Zoom to Region and cannot edit Pin Type and User Pin Properties for multiple pins
: O% ?$ R( v2 U$ t' c5 E: j1950178 CAPTURE NEW_SYM_EDITO Ability to remove convert view of a component
& t- r- G- P, c( Y2 d1966792 CAPTURE NEW_SYM_EDITO JavaScript error on trying to edit pin name for GP0
/ A$ [) z5 \. h' P/ \1969099 CAPTURE NEW_SYM_EDITO Cannot add convert view after creating a part
2 J- N, n9 C. B% L1969834 CAPTURE NEW_SYM_EDITO Shapes not mirrored around center if more than one shape selected in Symbol Editor
_; n: _! b. {" B" ~- M' x# t- z1970984 CAPTURE NEW_SYM_EDITO New part is getting Numeric Numbering automatically
% A) |$ m) e' z R. C* Z% S1972607 CAPTURE NEW_SYM_EDITO New Symbol Editor: name cannot be edited unless value is entered for a new property' U, J+ X9 `2 b5 Y0 d
1972635 CAPTURE NEW_SYM_EDITO New Symbol Editor: wrong listing of Symbol Properties in right pane
: r& f/ C( g) [9 Q1974296 CAPTURE NEW_SYM_EDITO Design Template font settings are not being honored for new library/part creation9 J+ p3 D+ g5 k7 P8 V6 R- H
1982783 CAPTURE NEW_SYM_EDITO Part Editor is blurry when zoomed out.5 o1 @6 U! I1 ^, l. `* o
1993361 CAPTURE NEW_SYM_EDITO Cannot change part numbering, set to Numeric by default
# E" l0 |9 F. k: A( I% f& u2003749 CAPTURE NEW_SYM_EDITO Cannot save edits to hierarchical blocks in new Symbol Editor in hotfix 048
5 g* ]3 @( j* L2004395 CAPTURE NEW_SYM_EDITO 'Pin ignore' modifications not saved in new Symbol Editor 'Edit Pins' after hotfix 0481 q9 u" B" l8 F7 a* [) [1 U
2007747 CAPTURE NEW_SYM_EDITO Cannot add Convert View after creating a part
0 T( s8 g4 w- f2011321 CAPTURE NEW_SYM_EDITO 'Place - Picture' is not working for blocks in hotfix 0489 y8 f1 d3 k( x" `6 _0 r9 ?
2013146 CAPTURE NEW_SYM_EDITO 'Part Edit' not updating changes in hierarchical block
: u+ v m# X* L# Q1 ]# X2 H H2002904 CAPTURE OTHER Unable to check out Capture license in release 17.2-2016, HotFix 048- n# b- x3 C5 k4 }7 w
2002922 CAPTURE OTHER Unable to check out Capture license in release 17.2-2016, HotFix 048
9 E4 ~ M# V; W, S' w% j! v1988812 CAPTURE PART_EDITOR Parts created or edited with hotfix 038 Part editor do not use default font size6 S7 D% i* K. U Z5 i4 D5 l
2008912 CAPTURE SCHEMATIC_EDI Design Compare shows 'NaN' in the graphical output0 Q8 }" W( w: N8 x, @6 t
1985701 CONCEPT_HDL CHECKPLUS Library symbols are missing from the examples folder1 O: C9 R; _; `/ U- R5 [2 b
1933789 CONCEPT_HDL CORE honor_sch_custom_texts" c2 x' ^2 b5 X' U3 |" W8 ]- q% O
1933892 CONCEPT_HDL CORE HONOR_SCH_CUSTOM_TEXTS
: e4 i2 u- I& a" a3 E i2001737 CONCEPT_HDL PDF DE-HDL crashes on choosing File - Publish PDF
2 d# @+ H) x* R6 |: `7 Q6 Z2010508 CONSTRAINT_MGR CONCEPT_HDL Schematic data corrupted on reading the data from CM database using the CM SKILL APIs
+ t! j$ s: P9 u1997461 PSPICE AA_FLOW 'Edit PSpice Model' from 'Assign Tolerance' window does not work
' m! V/ D1 _5 E1 ]2005948 SIP_LAYOUT DIE_EDITOR CTE expansion tool shifts pins off the die
- r6 n7 O1 @& u" x4 U, R( Q1893045 SIP_LAYOUT INTERACTIVE Refreshing bond finger labels causes all the labels to shift location
7 i d3 @$ Q( n5 r* X; W K9 }3 e, \% g2006926 SIP_LAYOUT ORBITIO_IF Bundle translation from OrbitIO is incorrect
& C, } T/ o# P$ n4 b2006659 SIP_LAYOUT SHAPE Cannot form fillets inside a shape in hotfix 048% k8 C1 |, q+ b' I n5 S4 ]4 F
1969192 SYSTEM_CAPTURE CANVAS_EDIT Pin Numbers of Discrete Symbols visible- Y' j1 f1 Z- b n; D
1982368 SYSTEM_CAPTURE CANVAS_EDIT System Capture switches to Auto Pan, even if the option is disabled, in the Notes mode6 B# O$ j; k* f, M
1995012 SYSTEM_CAPTURE CANVAS_EDIT Connect lines do not move with components- _: ~7 r. n9 `1 \- c$ x+ `/ O$ V
1907992 SYSTEM_CAPTURE CONNECTIVITY_ Draw stubs is not respecting stub length setting.4 l) w# G: E d4 _1 H
1960100 SYSTEM_CAPTURE CONNECTIVITY_ Moving components after routing failure: connect lines do not move resulting in disconnected route
5 N/ `: G) w* O& A0 q: ]1988284 SYSTEM_CAPTURE CONSTRAINT_MA Log files and topology files are being stored at the top-level design (CPM) folder level3 G/ j" `8 |1 l9 }
1996039 SYSTEM_CAPTURE COPY_PASTE Cut and Paste change the pin numbers for connector after saving design.
# {& y/ Y0 }7 y% M; p1951700 SYSTEM_CAPTURE EXPORT_PCB System Capture: Export Physical - Change Directory UI entry block not displaying properly" g( F u/ u# Q
1970761 SYSTEM_CAPTURE EXPORT_PCB Cannot import System Capture netlist if PCB Editor is launched with -proj argument
' x+ _8 U, o1 T- K1997533 SYSTEM_CAPTURE IMPORT_PCB Pins do not swap in System Capture on backannotation
" J# M. e% R0 H! H% _' x; H! _" D6 e1910962 SYSTEM_CAPTURE MISCELLANEOUS Dragging GND symbol placed on a pin sometimes disconnects the GND symbol( Z/ @ I. [1 @* v. z
1962037 SYSTEM_CAPTURE TABLE_OF_CONT Table of content link number not same as page number in the title block
T/ c3 ~/ _/ K8 M1986317 TDA SHAREPOINT Cannot enable Design Management and SSO session expires |
