在protel里画的PCB图转到allegro里面是出现如下问题Layout To PCBEditor Version 15.7.0
) J1 c" z3 j6 a. X* f Copyright 1985-2006 cadence Design Systems, Inc.9 Y! K8 X4 Z: ?1 z$ r
WARNING (Layout To PCBEditor), Duplicate pin names were renamed in footprint 'BUTTON148'
4 n; w4 g' h; F; r! m; x- W' QWARNING (Layout To PCBEditor), Duplicate pin names were renamed in footprint 'TS5169'
8 E6 G/ B! ]0 u9 h* V6 ?WARNING (Layout To PCBEditor), Duplicate pin names were renamed in footprint 'BUTTON148_S1'
/ {. L) [& X8 M" c* PWARNING (Layout To PCBEditor), Duplicate pin names were renamed in footprint 'TS5169_U22'
+ ]5 `1 B0 U0 u, {+ M9 XWARNING (Layout To PCBEditor), Netname 'SPI2_MOSI' was discarded because it is not used by any component pad
7 S' d0 @9 _4 d$ F6 P% p+ MWARNING (Layout To PCBEditor), Netname 'SPI1_MISO' was discarded because it is not used by any component pad9 d6 `; i5 p7 _0 M1 T( W
WARNING (Layout To PCBEditor), Netname 'I2C1_SCL' was discarded because it is by any component pad& y* T/ B0 V6 [4 J" m
WARNING (Layout To PCBEditor), Netname 'SPI1_NSS' was discarded because it is not used bynot used by any component pad6 q! J k4 B( Z) T6 V2 W; _- a4 U
WARNING (Layout To PCBEditor), Netname 'I2C1_SDA' was discarded because it is not used by any component pad
7 s4 Y7 Z+ N2 m7 qWARNING (Layout To PCBEditor), Netname 'I2C1_SMBAI' was discarded because it is not used by any component pad
! d. s8 O1 j# S: c! k2 pWARNING (Layout To PCBEditor), Netname 'I2C2_SCL' was discarded because it is not used by any component pad9 _* }0 S. p! M4 p& E& Y
WARNING (Layout To PCBEditor), Netname 'I2C2_SDA' was discarded because it is not used any component pad
7 a6 T+ `) X* qWARNING (Layout To PCBEditor), Netname 'SPI2_NSS' was discarded because it is not used by any component pad! j( y, a0 h/ v" `2 o; `- S$ a
WARNING (Layout To PCBEditor), Netname 'USART1_RX' was discarded because it is not used by any component pad
i" ], l8 b; h& ?& S% D" fWARNING (Layout To PCBEditor), Netname 'USART1_TX' was discarded because it is not used by any component pad
' G% M% _+ X+ }/ p1 @* ]4 mERROR (Layout To PCBEditor), padstack '56' is malformed on layer 1* s$ g: R7 ~" L* c, m3 K. C
Netlist Warnings and Errors recorded in 'E:\TEST\netin.log':: T% @" J2 }& \1 X% y/ T! n
7 M( {: V4 o0 O; \$ C( {" ITranslate time 1 seconds3 n+ `* b+ v5 g: n5 W. K6 y
- s+ c% p, N, z" H4 j
' u1 w; F) x( M6 ]5 p请高手解答一下是怎么回事呢? |
