查看: 3743|回复: 2
在导ipc网表时出错,请教各位,先谢谢了!
发表于 2009-3-20 17:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(------------------------------------------------------------)2 {& ?' R; P4 p, k3 S" I
(                                                            )  P1 r' ]' c  X8 A" P
(        IPC-D-356                                           )
4 d( k2 W- E* ]) J(                                                            )
2 I- f+ P! U! ]% r4 j4 {. \(        Software Version : 16.1p001                         )
: p& a# e: q! O3 l% L(        Date/Time        : Fri Mar 20 17:09:09 2009         )3 v4 L+ w# |0 P9 p2 i8 B5 n
(                                                            )$ z; W6 E6 W- z; `& Y+ Y  g# y
(------------------------------------------------------------)/ L1 D& F, F/ L* K
2 J4 t% E) R" vWarning: Found a mechanical pin at location (15994.80 17583.74) with no drill - skipping.
% v5 e6 ?6 y$ t8 {4 o) F! rWarning: Found a mechanical pin at location (14845.20 16418.39) with no drill - skipping.
4 Z; C* u! _7 pWarning: Found a mechanical pin at location (10725.00 16850.00) with no drill - skipping.
& r3 T4 E8 d( kWarning: Found a mechanical pin at location (12535.00 18520.00) with no drill - skipping.
/ A  w+ D; E1 b8 t, `Warning: Found a mechanical pin at location (16269.33 12660.67) with no drill - skipping.% t9 R. X% k; i
Warning: Found a mechanical pin at location (15560.67 13369.33) with no drill - skipping.& `: ^. b% P, v% t! _/ W
Warning: Found a mechanical pin at location (8020.87 10375.20) with no drill - skipping.0 N* p7 @( g; l8 v/ J, u) P
Warning: Found a mechanical pin at location (7812.21 10375.20) with no drill - skipping.! q7 j5 g% a& h
Warning: String TX_DISABLE0 exceeds record length on line 375 at column 20% i( l5 I7 h% s4 h5 s# g
Warning: String LA_RST3 exceeds record length on line 525 at column 20+ g1 Z9 D2 E9 M! l& G
Warning: String TX_FAULT2 exceeds record length on line 708 at column 20, C( ^' b' W, E
Warning: String DATABUS_EN exceeds record length on line 2806 at column 20. H- b/ \0 z3 r4 G
Warning: String cpld_RST exceeds record length on line 3138 at column 20
% N- k# _8 g- ?( |1 P3 {Warning: String AC101_2CLK exceeds record length on line 3161 at column 20* A5 _5 u# S. D5 o; ~4 \
Warning: String AC101_1CLK exceeds record length on line 3179 at column 20
4 N: `3 N6 l- w5 i, B1 Y) qWarning: String PHY1_RST exceeds record length on line 3201 at column 20
& Y+ F2 ^$ |- c* z8 |Warning: String CPU_CLKIN exceeds record length on line 3266 at column 20
2 X9 `2 L, ~: \4 kWarning: String CPLD_CLK exceeds record length on line 3324 at column 20
" ?9 J7 U' |9 X+ C5 \Warning: String PHY2_RST exceeds record length on line 3339 at column 20
# a, ^, i% Q) _) p1 W+ T# UWarning: String CPU_RST exceeds record length on line 3349 at column 20
/ b8 z( ?* O0 F+ DWarning: String FLASH_RST exceeds record length on line 3376 at column 208 f8 \5 R( n3 [6 ?
Warning: String mcu_RXD2 exceeds record length on line 3690 at column 20) l, w! j& H& P" x$ y0 G
Warning: String MCU_TXD2 exceeds record length on line 3718 at column 20
$ v5 D" r5 W5 ?$ d7 _' ~Error: Integer value 42520 can not be written in columns 59-62  on line 3829.- @5 E7 z. x4 H+ e+ J
Error: Integer value 42520 can not be written in columns 59-62  on line 3830.
2 f; g* [$ f# k2 Z) j: DWarning: String PON_F_RST exceeds record length on line 4120 at column 20
0 i" x  o& ]( KWarning: String 9545_RST exceeds record length on line 4145 at column 201 x8 [" \$ ]/ h% ^, F8 D" M
Warning: String PON_RST exceeds record length on line 4167 at column 20. n2 w. Z  W* ?+ ?
Warning: String IPMC_3.3V exceeds record length on line 5077 at column 20
' ], g& d1 F, M! }. i9 \1 q' Y4 BWarning: String TX_DISABLE3 exceeds record length on line 10104 at column 20
2 K# @8 k) D8 s/ b5 WWarning: String TX_DISABLE2 exceeds record length on line 10369 at column 20
7 |) Y& j3 V' C; Q# l0 VWarning: String TX_DISABLE1 exceeds record length on line 10405 at column 20: X" @, ^& l1 E; n0 Q5 _- u) h/ }2 x( e
Warning: String 7.3728M exceeds record length on line 10534 at column 20
* G! D8 d$ _: }Warning: String TX_FAULT1 exceeds record length on line 10641 at column 20
6 y, @" z  L9 r- g# e2 x, S$ LWarning: String TX_FAULT3 exceeds record length on line 10684 at column 201 L! L0 N2 H1 L3 a- u1 w4 @
Warning: String TX_FAULT0 exceeds record length on line 10727 at column 20- c: A# w5 L, ?2 T  `0 a6 R
Warning: String LA_RST2 exceeds record length on line 10752 at column 20
2 `  y6 t3 J, }. |! f, i0 PWarning: String RSSI_ACQ0 exceeds record length on line 10882 at column 20' W: S6 h8 z- n/ ?# L7 V; k8 i: h
Warning: String LA_RST1 exceeds record length on line 11043 at column 20  }5 O6 o' U$ f5 Q: @
Warning: String RSSI_ACQ2 exceeds record length on line 11070 at column 20
+ X) A7 j( n+ e# J4 }. w# _Error: Integer value 50400 can not be written in columns 59-62  on line 11161.- O( ~0 w2 R8 x6 i
Error: Integer value 50400 can not be written in columns 59-62  on line 11162.
( h! I/ A7 L; N4 p; XWarning: String RSSI_ACQ1 exceeds record length on line 12179 at column 20
4 y# c/ h4 W) |0 _) eWarning: String RSSI_ACQ3 exceeds record length on line 12309 at column 20
  e9 R4 z0 B* e1 Z  O3 IWarning: String LA_RST0 exceeds record length on line 12336 at column 20
1 v& U* _/ v9 x( P4 ^! k! \. y% j4 @2 j5 g
------------------------------------------6 H2 f% l1 O6 B8 D2 o) T0 f+ L$ B
SUMMARY:
  m% Y/ p* K/ F  Errors:       4
% q/ f* K/ {; [; ?8 b  Warnings:    41
7 \8 i( _/ U  l- g/ ^Info: Most likely cause of "Integer value" errors are:
' ]+ ?8 t. c. w$ `      - (Most likely) Coordinates in the database exceed IPC's coordinate system.
$ ?( l: ?6 a: l6 R4 J. ~        Try setting the database origin to center the design to reduce the large
5 B( E/ m. O  ~: w        coordinate values.
) j0 p' U3 a, u      - Large pad sizes. Reduce any large pad sizes.
 楼主| 发表于 2009-3-20 17:14 | 只看该作者
只要找出错误的地方,警告的可以不用,再顶一下先谢谢了
发表于 2009-3-20 21:17 | 只看该作者
我还没碰到这种情况,可能你的原点离pcb太远了,导致数字太大。
GMT+8, 2025-7-27 06:42 , Processed in 0.109375 second(s), 24 queries , Gzip On.
