查看: 566|回复: 1
 mfrc522与MSP430开发板及51单片机连接(含上位机测试软件)
发表于 2018-11-13 10:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4 ^  `9 |# n4 j) h, u4 W1 G3 @
% c# ^* l+ n+ _# C# H/ a# z. I
) x9 {/ B8 a0 R( O. h
! G" o1 k, X+ C# I: i# r  D5 ~51单片机源程序如下:. W0 P6 o/ M: \: U( `+ ~  N" k
5 N5 o8 A8 I. |5 M  z
#include "reg52.h"! m3 n: v* d, Q$ B" h
#include "main.h"( f1 F. q- e3 o; s
#include "mfrc522.h"
3 K7 Q+ ^9 @- ]2 m1 _#include <string.h>
% }5 }; w, p1 e//M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令6 t/ V! ]) `0 U2 \' V9 |" p8 @
//4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反 2 R8 N/ \8 O. n& a3 K5 B/ M: Q* q' C
unsigned char code data2[4]  = {0x12,0,0,0};
! J9 a1 L3 \% Q! K( X1 H) H. Ounsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
' f3 n( a1 k; l+ }: ?1 ]" Zunsigned char g_ucTempbuf[20];
* f+ t  ^( L2 d+ F: [3 @  V; w& M. ]unsigned char idata MLastSelectedSnr[4];- ]5 K+ N' y/ F9 P/ S8 K
unsigned char idata RevBuffer[30];
: t/ ]! o4 E6 C; o% Ounsigned char data SerBuffer[20]; 3 D3 B1 g/ @4 [0 \: @
bit CmdValid;
% ~2 }/ T2 t  w7 ~9 P" G: t* u- d8 I/ d  h( T9 b1 m" v0 y7 g" h3 D
void iccardcode()# Q' v  a- B) n. I, z$ K6 I
$ s3 m6 s$ h: @/ t6 P. t5 M- r          unsigned char cmd;9 O' P+ D, }# i5 c4 f/ O
        unsigned char status;
5 ^# W, r( ?$ r5 O
2 @- s/ o1 h( j7 i        cmd = RevBuffer[0];
9 k2 \0 n& Z% F  O) p1 v8 Z8 J. d        switch(cmd)+ Y7 ?: p! o$ o3 Z( c2 X3 Q
         {. J' d1 ^9 h: N- [7 {& v  M
                case 1:     // Halt the card     //终止卡的操作
$ y: Y, m' p$ K& Z# M! F5 v% W                        status= PcdHalt();;
# d2 b( t$ L5 C+ m                        RevBuffer[0]=1;
, l  a* {1 l( f# n# U  U) @! e6 J                        RevBuffer[1]=status;, N3 U( D$ |: R
                        break;
; C9 [3 \1 g; z  g                case 2:     // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
# ?. l/ i7 O& {  k' ^0 m9 p* l2 N                                // 寻卡,防冲突,选择卡    返回卡类型(2 bytes)+ 卡系列号(4 bytes)
( G3 ^8 U3 k# Z+ }" i$ W                        status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
" K% z' T5 `" @: @9 @: r  F                        if(status!=0)! h4 C5 [; d! p+ t" |
  s6 v& F8 F- L0 I                                status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
2 u# u* f9 d' }0 o- u                                if(status!=0)
" s7 L  G3 D% y% ]* M! W                                {( }; }: Q. Q. `6 e1 w
                                        RevBuffer[0]=1;
* W3 G# j; ^/ @# T: h8 q. s) l                                        RevBuffer[1]=status;/ F$ z4 Y& o: T' N( r+ ?* ]
                                        break;0 J  M* m: B) v9 a  H
                                }3 s# O7 Q7 A9 ]8 v4 d! p
                        }  : e9 k* B' s. M( X, L4 @
                        RevBuffer[0]=3;
' O" a  [# d$ T# \: u$ r! l" S                        RevBuffer[1]=status;
8 ?, Y% Z1 P. s6 S. g. F0 F                        break;  @# B# W7 @) V2 C
) B. V8 V0 A4 d- l3 i                case 3:                         // 防冲突 读卡的系列号 MLastSelectedSnr
1 w; ~# [8 f& D9 M6 R                        status = PcdAnticoll(&RevBuffer[2]);- C# L/ ~! q0 U8 Q( q& t3 f8 |
                        if(status!=0)
. w  t8 d! f) U9 l                        {1 w" S7 e3 u- j; Y) }4 _
                                RevBuffer[0]=1;
4 N1 u, l# I# q# r* s                                RevBuffer[1]=status;
2 C% b: l, [/ ]9 H# I' ]+ o  b                                break;
5 @/ h+ A! m+ r5 D                        }
: t( @' C( V" Q" G, ~# c7 b                        mEMCpy(MLastSelectedSnr,&RevBuffer[2],4);
5 P* n: ?9 i/ ]) ?( l1 M- f- J- f                        RevBuffer[0]=5;& Y9 ]4 f" U- o0 W5 k" f
; v4 l" D/ @) A8 l8 f                        break;        % s9 P# r/ u; j, \$ |; a
                case 4:                                    // 选择卡 Select Card
  l5 _+ z% ?9 p5 g8 Z- a/ q5 Y                        status=PcdSelect(MLastSelectedSnr);
3 L2 }# G& z4 z; y) [                        if(status!=MI_OK)7 V# p6 b* r) W/ {6 f
+ r$ \/ A) B# y( U7 D                                RevBuffer[0]=1;        $ ^; N0 f6 J1 y
                                RevBuffer[1]=status;' t1 [. p6 ~8 B; n
                                break;
, C: k+ d& v/ Q/ }3 u                        }
6 X* k/ q. [" ?5 D: b                        RevBuffer[0]=3;5 c; S& }1 U! }# I. T3 w0 V
) n8 w5 k0 d0 b1 [' n0 j2 K                        break;
, ?( D$ ?8 B5 J* U5 o. f$ Q                case 5:            // Key loading into the MF RC500's EEPROM
, _- U, g- p9 D            status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校验卡密码  O# M* r8 ?, W9 `; l% M% ~
                        RevBuffer[0]=1;
' U! J6 i" o( Y  L# w                        RevBuffer[1]=status;
( ^1 i# G6 ^, o% R2 V1 }6 B                        break;
) l# V5 P( g/ z$ y                case 6: - j' d# k# w7 _% _& u1 q' u
                        RevBuffer[0]=1;! `. \) l" ~) M  m4 a
/ f# Y- \0 `+ ~: y, D3 L8 L8 C. \                        break;
9 P) n7 h0 C4 @$ G6 Y                case 7:
4 O: p2 ~& H, N$ T) @; Y+ Q                    RevBuffer[0]=1;6 ]" o! s! ^: _" Q- J0 b3 g
                        RevBuffer[1]=status;                        3 b9 D2 I+ D/ i3 q
                        break;
/ y& \' v/ n2 I# f' m- G( e                case 8:     // Read the mifare card, f8 C2 @5 _: [9 V7 A" n$ @
                            // 读卡& x. |' P* b6 e1 _
                        status=PcdRead(RevBuffer[1],&RevBuffer[2]);
- Z; N2 K, b, ?! }: b                        if(status==0)+ ]' R3 b& P6 M& \
                        {RevBuffer[0]=17;}
9 y6 u$ B1 L7 k) l                        else
  _' D; Z, K# G2 q+ u                        {RevBuffer[0]=1;}
) m4 K* z: b6 k' q% M) W                        RevBuffer[1]=status;
; e1 ~$ F4 T. |  F7 Y: i7 t" }                        break;0 i3 `$ d& _/ M' z
                case 9:     // Write the mifare card
' C" n& {7 S+ y0 x" {                            // 写卡  下载密码1 ?. {9 ]9 o! \& K& h% v# Z
                        status=PcdWrite(RevBuffer[1],&RevBuffer[2]);9 w/ i2 e  ]1 v2 U( f  s
                        RevBuffer[0]=1;9 s- {" c& |9 C+ X! W; W
$ S6 Y7 ]5 i1 }! T& ~                        break;# m; H* \4 x- n4 r& E5 K& {, b. D
                case 10:' g7 @% u- R4 W+ I% B' [
            PcdValue(RevBuffer[1],RevBuffer[2],&RevBuffer[3]);
3 u4 B' }2 D; t( R/ q! Q4 ]                        RevBuffer[0]=1;        6 u$ U3 n! O: u8 H
5 O  t& I! k! A3 R3 H                        break;
# U/ l/ E6 k& p, i* F, J                case 12:    // 参数设置
# v' r/ }7 Z) i+ U0 G- s1 ?  `                    PcdBakValue(RevBuffer[1], RevBuffer[2]);) _8 s  Y4 R$ n
                        RevBuffer[0]=1;        //contact
1 X& ?* T+ i& t; T                        RevBuffer[1]=0;4 p9 c7 n) w3 F( q/ T5 r2 \
                        break;
8 \$ U; C; R  R" ~6 b        }
* ?$ n+ ^8 O2 |; @) Y# e9 M+ `# M
* q: w  }) C4 l  @0 g
+ S1 ~2 _+ ~) ?$ {: M7 @
# G* F  D% y+ a/ z* U( g& Y
/ |: x) O, O; n  T# ^8 R' P1 Q  m% k4 I0 s. i" @* ]+ e
# n9 S6 a8 h6 d) E  d8 q
        }# k, h' c6 r3 M( a4 J9 _* x) a0 K
/////////////////////////////////////////////////////////////////////6 k: A/ v0 K6 Q0 l# v
//系统初始化
5 d; d- i% o, {+ c, i' M/////////////////////////////////////////////////////////////////////
# v& w  L7 {! Q; u, T4 J2 Gvoid InitializeSystem()8 M) ]% ~. [* Y0 K
{" N# y) e3 X. \: i1 e+ q! a0 H
    P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;# h) a  S$ k8 h0 a+ o  }% M
, B+ D9 b9 h8 d. o8 @% s) Q" ?7 T0 z, m" x/ {4 j5 M+ @
6 A5 P+ {0 |4 Q" a; q- |% y8 P
         ET2 = 0;           S# A& e' E* T3 R0 x+ D
        T2CON = 0x04;
% c9 N5 [* v. G' n) D) V    PCON = 0x80;
) ^$ j& n/ }, g% N( f    SCON = 0x70;
4 O( d4 S4 n0 E+ w4 u    TMOD = 0x21;        //TMOD = 0x22;' [8 {: t  w+ h7 n
" t1 N6 J' N0 z3 `/ i        TH1   = BAUD_9600;
' |4 c  d2 g8 n5 b- i        TL1   = TH1;
% o8 r% f. f  W$ o( d3 _        TR1   = 1;             // 波特率发生器! I; M4 y: i) ^7 R. m
# v, r2 n" s* b. a        TH0 = 0x60;
7 g1 J% u9 V' r    TL0 = 0x60;
, k8 h* {' S& T4 l. j    TR0 = 0;
7 p% y$ W( D* G1 v. H) v: t6 p3 \1 q. F* p0 e, i
    ET0=0;# U* ~9 i% {6 X
        ET1=0;
1 [- T/ e9 W+ k# o2 z( B. ]        EA=1;' _/ Y% e8 a/ G/ v; B
        EX0=1;& x7 V8 k# J) N5 C7 A
        IT0 = 1;
* R- @! |( w+ {" P5 G( c/ b2 ~        TR2=0;
/ K3 ~2 a. f0 l- u         ES = 1;    + Q7 A4 J# ]: V) o$ L; C
        CmdValid=0; ; f9 {. v1 a- o
$ p" A$ {  u# y$ g$ l     LED_GREEN = 1;. x% a: o" u% D& @) b: S9 b
     PcdReset();  a/ `, A7 \9 V& W- ^
     PcdAntennaOff();
3 A" Z% _, {. H% Q     PcdAntennaOn();  8 a- T- \3 g! c8 M
         M500PcdConfigISOType( 'A' );0 Q5 J+ M/ v0 H$ D
     LED_GREEN = 0;9 J0 h$ w! L5 i: G
          delay_10ms(10);        7 m8 ]. Y7 B8 o
     LED_GREEN = 1;
( a# N' i# m' m/ u/ p0 Z2 |  Q          delay_10ms(10);
/ T0 q7 m8 U/ f     LED_GREEN = 0;
+ G) V  x/ t4 }/ v, G* ~4 t7 @/ r! c" ^" S! o}1 K  n3 t' s8 \; ^  ^) u
2 l/ n( a. F% s( w/ ~- d
/////////////////////////////////////////////////////////////////////# \6 c1 ~) z* q' i5 J7 u9 U
//用T2做延时子程序
6 O& S( L  p6 S8 o% F3 w////////////////////////////////////////////////////////////////////// `( b( ^2 Y* e2 \; ~& C
; X$ S! k6 ]0 s5 K" Y% K) o
* ]0 b: _/ t: `/ c! q9 O- G///////////////////////////////////////////////////////////////////////
; x! C7 `7 F, K% S// 接收和发送中断9 r+ L& ]- H% L9 [* w2 {. Y
///////////////////////////////////////////////////////////////////////1 W5 M8 X7 I7 R  Q
void isr_UART(void) interrupt 4 using 1# o4 ~9 i% W$ y+ s- ^7 M
{4 m7 t" _4 e% L9 R
    unsigned char len, i;
. Z; g- A: b& p# H( `          unsigned int j=0;: U) n8 t: U- G0 j6 \
1 _. {5 @% q% ?, A. A
          if(RI)
, k3 ?+ y9 ~" w& |$ s        {
# K: l' o& T" K1 I' u; z- d8 z1 C                len=SBUF;+ P9 o* D4 X; G% W' o( L! M
                RI=0;
. M. _/ ]& |9 O. ^$ s                for(i=0;i<len;i++)
' Y& C. l) N% ~/ e3 d- _. l                {+ s6 F9 P* p, T# f! a
                        while(!RI)
6 r& C9 N: k/ n7 E$ K& q                        {' l) D; J/ n/ y. j
                                j++;
( p' k! `+ I* W, h  Q; e                                if(j>1000)$ u7 E1 U1 X" [2 q, k3 |
                                {9 o  N: _+ s3 T
                                    break;4 b" B* x$ |6 u) D# a
4 }1 ?! c$ n+ Y9 v  Y                        }1 l" m) X2 C6 B
                        if(j<1000)0 W# V) P# l' b! w, H
                        {- j, s4 ]4 q) r
                                RevBuffer=SBUF;
/ Q3 A% V( e- {& p+ Y; h" m5 j                                RI=0;! n0 o' `3 v. O. _4 U
                                j=0;9 @9 c7 o/ h5 F3 U2 o
0 n$ |- ~3 B9 u4 a                        else
2 Z2 r! p7 e: x+ a: `0 H1 H1 r' \$ @                        {
6 O0 U6 G" b& A0 r- l# Z                            break;
% S( }; y3 o' n' Z7 P# Q                        }$ \: c% {$ c0 ~, T2 e& a+ ~, R
                }& Q/ l- L% B% B" s
                if(i==len): }: R' D6 \* c2 B4 U
6 b( E% ~. e/ _4 F1 U% x                        REN=0;, H) f) U: D" ^6 A  X/ \  T
                        CmdValid=1;6 n: q3 k1 y' w' m0 @( ]& q
                }) B$ g- u$ ~* B8 \$ G9 s) s
4 P( w: y) F6 a. A        else if(!RI && TI)
# c4 S8 x  L! G: n9 c        {( L& W$ V. w8 h& W0 s
                TI=0;) n; B* j" I3 i9 d' U/ c9 w
                len=RevBuffer[0];
/ W; N- M0 Q& N  n" `                for(i=0;i<len+1;i++)& D4 \" \  O0 d) K# T' F, B
% m- A& q$ N: a$ L% ]: I7 a- x3 a                        SBUF=RevBuffer;2 l3 Z" u/ w6 H& @& Q3 v, ], I
                        while(!TI);" ?' K' i4 E2 q4 _$ {& R+ e
                        TI=0;                        0 s6 v+ C7 t3 w/ W
                }' {5 P$ R% [5 u
                REN=1;
" \* `1 d& P5 p* K( x% f        }
7 r7 T0 n4 J. v) f% P}
$ w/ O* p# o# y1 z4 _# G# d5 p  q2 X
+ u% D) h9 y* k- c3 t" `4 P
) x& h+ c7 V& {$ w& W  void main( )  B" s0 }) w' E' c. G
4 a  x8 c0 P8 q: i/ o5 `: P; V    unsigned char baud;* E$ S) s! Y1 I! b8 N; x/ _( l
     InitializeSystem( );
& c) x2 O& s' n$ ?& ~; h5 E    while (1)
, t7 }* ~$ _9 d* k- A2 y4 I    {        - Q% m' t2 {& Y) h
             if (CmdValid)
7 S6 c( ~6 n8 u! p" B) [            {3 {8 J3 P' A1 w
                    CmdValid = FALSE;- V: m  x. O( Y+ h4 U6 N
                    if(RevBuffer[0]==11)            //为了加快相应速度 测试风鸣器
% K9 j% j" O( P% D" H7 L                    {
: X% N, Z0 Y# `! K* x# T0 Z                            RevBuffer[2]=RevBuffer[1];
9 O( x9 Y9 Q$ i                              RevBuffer[0]=1;         //contact
6 x! N' E1 l  r4 e9 L                            RevBuffer[1]=0;
5 n! f2 `/ K% L4 ?) f4 s                            CALL_isr_UART();                9 G/ m& l: e" O. q& a- z; q8 C
                LED_GREEN = 1;9 Z3 |5 t  j. p5 y3 |0 F
                            delay_10ms(RevBuffer[2]);
; ^, O0 e, ]2 h( @! w                LED_GREEN = 0;6 X7 S: B# {/ R, v- d9 M3 ?" P
4 m8 ?9 z* o2 O3 o                    else if(RevBuffer[0]==13)   //设置通讯波特率' U. T( Y: a* Q) q6 A( f
+ m( d) ^) E) Y3 G' S& H. S                            switch(RevBuffer[1])
) \; u: n2 q- J% v' X" S$ u                            {
  d, h4 Z' g/ d' `4 O0 Z3 J                                    case 0:
; D+ d6 I8 h% ^  Q* J                                            baud=BAUD_9600;. f3 c1 I# f9 M: ]& `; j
                                            break;3 l: t( d0 d+ H) L' O
                                    case 1:
' h% H( G4 L4 H8 a! e" x/ Q6 H                                            baud=BAUD_14400;  {+ C+ |' m& O6 u2 G- J- l
                                            break;* }' U) s  ]9 ~) p
                                    case 2:
, n" X0 ^2 G# w5 L                                            baud=BAUD_19200;9 i/ n2 e$ R7 A4 m( u
                                            break;
, {+ k+ S: O' {! ]. B                                    case 3:% N0 _( P3 N4 e* @/ O  [
                                            baud=BAUD_28800;$ e) @& u$ p: f5 p* |/ T' s
                                            break;
1 }2 r+ `9 e0 C9 l( T3 g# u                                    case 4:& b; u; ?8 R- a9 K& m+ {, \6 f
                                            baud=BAUD_38400;
) k& W1 I1 C$ P0 w$ m  L                                            break;& q' I2 R5 Q7 `
                                    case 5:
8 X" {. X) s, J& U; [                                            baud=BAUD_57600;
0 @! o) v  |1 u7 Z2 A) T                                            break;
* c4 q# _# l+ _& E; P! `……………………1 I$ N" F! P; {
, S- _0 \3 g. V* p+ O: j7 i2 j
…………限于本文篇幅 余下代码请从论坛下载附件…………
* }3 M& `8 L5 [3 m0 u1 X# B* X" |  W, l4 c( _) N
msp430单片机源程序:
% X& `5 k) Z* G! i# z( M        //) P1 G) p8 ?; S3 N; [
- b. m' {- l6 s
5 Z, {0 }$ M4 m( }5 R
3 v- Y3 c9 ^& M" ^9 f& I4 X$ E
#include "msp430x14x.h"
" `/ s/ ^0 `+ V- C#include "PIN_DEF.H"' w4 X$ j2 u7 S4 @+ _* X8 I
#include "RC522.H"( |! O; d  ?- N  M% M& k5 y
#include "UART0_Func.c"
% q% Z  V  Z0 M5 r- ]#include "ctype.h" # `: t  S8 x0 R6 r1 Z" [- I" u
#include "BoardConfig.h", s: G; p0 S  I# W- J, w
6 A" B2 H( @: I$ G8 o
$ i' t9 ]$ ^+ v
unsigned char UID[5],Temp[4]                                       ;
& u/ i; _9 a& h$ m4 tunsigned char RF_Buffer[18]                                        ;, N, P0 V8 S5 M) R2 O/ \0 C" I
unsigned char Password_Buffer[6]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF}   ; // Mifare One 缺省密码1 U. g0 D7 h9 i8 g6 _
7 ~) u) T% c" F' t
( b) R5 s( K+ B4 Achar          MBRX[30]                                             ;
/ ^1 T. m  a5 Z' C& d$ tchar          MBKeyTP[30]                                          ;
: K  C) ?  [+ [1 w. Dchar          Event                                                ;& i5 `1 o. l: B$ P( r5 q3 D
unsigned char DISP_MODE,i                                            ; // 编辑控件显示模式
, U9 X; ?, a/ E8 c! funsigned char des_on       = 0                                     ; // DES加密标志2 b/ G, C5 d" e2 f
void Key_TP_Task(void)                                             ;; m# ~( D6 R3 N9 m* ]  G
' ~" `, s6 {* a4 K+ \3 X+ ]& @
! J! u- |( D' K: U2 ^//***************************************************************************//
4 k% k! t! O- ~  i# T//        //
9 J3 s% _4 q: c. x3 [1 p//                 初始化主时钟: MCLK = XT1×(FLL_FACTOR+1)                  //6 s8 ?6 ]4 H, k* h
//        //$ p6 }% q) u* c/ a9 k
$ j5 s; M( Z" j6 f2 Q3 Fvoid Init_CLK(void)1 G8 q' d: ?: K+ u$ K
; v( U2 G- ~% b' X+ v+ X1 a% c  unsigned int qq;& X- `! S  b8 r5 K2 d$ [8 t; m
  WDTCTL     = WDTPW + WDTHOLD                                     ; // 关看门狗3 `' K& c- p0 w# I2 N
  BCSCTL1 &= ~XT2OFF;           //打开XT2高速晶体振荡器
7 K, S/ A, L6 i" H+ e  do4 h/ g7 I: Y) ]( a) ^4 D! G
  {2 A3 ^9 I! m, K4 K% Q  [0 g
    IFG1 &= ~OFIFG;           //Clear oscFault flag清除振荡器失效标志
7 `( @! Z) a4 A2 S    for(qq=0xff;qq>0;qq--);% H; K- X' D) x. H6 \
  }while((IFG1&OFIFG));       //oscFault flag still set4 C2 Y: f; ^2 q2 a+ a$ b9 k
- k0 i9 z% L% B% D3 ~# u4 ^7 j% O  BCSCTL2 |= SELM_2;          //MCLK=XT2- A0 p6 E# x$ X- C6 @8 U
  //BCSCTL2 |= DIVM_0;        //控制MCLK不分频,默认7 o  ^: k6 E7 P8 f9 {9 [
  ! Y' C) q3 Y  F0 f! a3 E
  BCSCTL2 |= SELS;            //SMCLK=XT2
& I3 e6 Z; T8 s* R1 M  //BCSCTL2 |= DIVS_0;        //控制SMCLK不分频,默认/ b/ t" N$ ?! @2 D) u# a2 w
}5 z' d' U) @& c, e) }7 @9 F9 x
" }6 e# ~! a& l  [7 z3 r+ J
+ [  n- @* G5 Kvoid Delay(unsigned int time)  Y" p8 ~, @6 q6 T
{$ P- a" N6 E3 z6 f% v  l  b% Y
  unsigned int i,k                             ;
% Z( v# a' ^0 g8 b  for(i=0;i<255;i++)# D7 I( M/ d7 C0 j# v
    for(k=0;k<time;k++)' L  y% Z5 J) l( f
      _NOP()                                   ;
. Q$ O# |! x/ Z2 l0 k; i}
, [$ ~+ y9 M/ {# A$ W3 i' c/ _
9 M  V6 \4 U4 v6 t3 z$ M
. l- x+ K  ^; vvoid Auto_Reader(void)- U* C: b8 @$ b3 H
; [, Q0 d# l9 V* f) T  while(1), K; T+ S2 E" p% ]4 [5 i
- _% w, j4 W2 u    if(PcdRequest(0x52,Temp)==MI_OK)% |6 K+ u/ z, F! }  B
    {# R& W( Y" o( n5 u+ v& I
      if(Temp[0]==0x04&&Temp[1]==0x00)    B) G: A2 R: ?
          PutString("MFOne-S50");  m, M4 B- @# M0 @6 D' m
        else if(Temp[0]==0x02&&Temp[1]==0x00)' n9 B  R- P$ c; v: O% u  O$ [
          PutString("MFOne-S70");
0 g+ j. {% b; L: `9 \        else if(Temp[0]==0x44&&Temp[1]==0x00)( }2 N) k- ]0 Z6 q9 ?3 `
          PutString("MF-UltraLight");9 `: R* a9 O) A/ m& S  ~
        else if(Temp[0]==0x08&&Temp[1]==0x00)
6 t/ A1 G. d- _! h* n: W          PutString("MF-Pro");7 x. u; Z; m" z8 J
        else if(Temp[0]==0x44&&Temp[1]==0x03)" [4 l4 {1 Z* \! U4 N
          PutString("MF Desire");) |2 d- V1 c- W: M$ L, b: p
        else
( d: h, _; U. w1 ]7 A+ y6 g          PutString("Unknown");
+ s3 u2 [; b7 K& d- t0 v      if(PcdAnticoll(UID)==MI_OK)8 h7 u7 n5 p& ]/ ]1 R
      { $ m" X+ k9 R  D
        PutString0("Card Id is:");  D9 M5 p5 u6 K% `( K4 t
        tochar(UID[0]);
7 _/ r6 _/ z; }4 [  Z7 j        tochar(UID[1]);
" H6 g1 R1 r' J" x" f6 {5 W        tochar(UID[2]);* C3 j' \  d; |8 x1 w
        tochar(UID[3]);0 ^2 @  c: q; j" [" E' W1 ]
        while (!(IFG1 & UTXIFG0));+ Q% E. y3 Z  ~2 I+ @  l2 ~
        TXBUF0 = '\n';                              //发送换行指令
& }) W  j- v* M% f                        % o( k  P8 c. P! A) s* q
        RED_LED_ON                                            ;
) O! Z4 P- K5 Q( q3 R        Delay(200)                                           ;7 U! N+ ?7 X0 b, N  j
        RED_LED_OFF                                           ;
+ P6 m; m0 z3 s; p6 }0 S6 t7 d8 _% G        Delay(200)                                           ;
) d6 K, t0 w( B, A- x      }0 m/ c3 f0 u- J! ]  p
5 J8 `7 o8 i2 d  else GRE_LED_OFF                                            ;1 g# O  N+ v9 K( F9 l, [
  } - W+ A8 R+ w0 x' s6 v6 w% o* g6 q' \; k
! G1 P( J* q3 N" I7 r& R2 ~. I
  m2 ], B8 i3 c" e& d1 A! ^
7 T6 g+ o: q% m$ hvoid Find_Card(void)8 Y+ [0 `1 @+ ]4 s+ f" E* f1 w
{8 O' U* x9 S5 n" P' P0 g
    if(PcdRequest(0x52,Temp)==MI_OK)1 g# Y  }1 J: V( d
    {5 }- K, S* x8 y' e! K+ V
      if(Temp[0]==0x04&&Temp[1]==0x00)  7 q' @/ [# W+ n. g
          PutString("MFOne-S50");0 T4 O; Y; H- \) G" J
        else if(Temp[0]==0x02&&Temp[1]==0x00): t% m  O5 \; \/ i; Y
) b  F% Y( N" g        else if(Temp[0]==0x44&&Temp[1]==0x00)5 C1 u. B: |0 L( y3 \$ D
          PutString("MF-UltraLight");6 S4 @; |! R7 m1 W2 t+ F
        else if(Temp[0]==0x08&&Temp[1]==0x00)* ^8 W" }2 M8 G
          PutString("MF-Pro");9 B0 `8 j( _" `$ K
        else if(Temp[0]==0x44&&Temp[1]==0x03)# I: x& I) i! `! I* ]& Y, X
          PutString("MF Desire");3 A9 I  S5 n; q5 Q3 z0 d3 q
        else
% \; Z! X7 o# Z; D3 S9 s1 \, P8 P          PutString("Unknown");% h) Q  p5 Y" }7 y" Z; Z% H7 s1 H
        PutString("SUCCESS!");
3 ^: {  `- u5 N$ N( `6 g) W& H    }
6 S/ Z/ |) O3 r9 x2 K    else PutString("Faile!");                                             ' D: O$ p$ e3 P2 m2 |- G- d
! i( Z' G, V* p% e  y9 @
( B" s2 q8 m4 k; B' M- G: \6 l7 h
) r4 w( d' B/ t, t) H  evoid Init_Port(void)2 E7 h3 k+ m; b; ?2 j
{" s0 N( V) B( V& A
  P4DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;: u& G; f8 y! j4 E' k4 h
  P2DIR |= BIT0+RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT;
% W) u0 w) F0 D+ \! W$ A0 d  P1DIR   =   RF_LPCTL + RF_SS   + RF_SCLK  + RF_DATA_OUT                     ;
& q6 w& l# j. N8 i6 @: A/ M+ ~0 f}1 ~! A( v. C# B5 A0 i4 H0 k; o8 C
# O) z' e7 a) H# J函数名称:HandleConfigMenu
' l* Z$ Z! o+ n9 T9 g功    能:处理PC的配置函数) z9 v1 Y" n+ Y5 w3 }3 _/ Y* s3 X
参    数:inputvalue--接收到的来自PC机的字符& N" Q, N9 D, b' `/ C$ b
返回值  :无% P5 l2 ^# n( x
' i7 G6 [+ I9 j" P5 n6 s& ?3 Pvoid HandleConfigMenu(uchar inputvalue)
4 G, F0 _+ K/ T" b& c% S% @% t{/ f' k/ r9 ~3 }6 V6 O  ^
    switch(toupper(inputvalue)) 7 i, k4 K& w' v
: \& Q; C1 @$ z4 x    case 'A':
# @9 o. Q9 Z/ \# f* h9 N              Auto_Reader();
$ o0 ^; H! L6 N9 t              break;
) |" @1 g5 t) m# D    case 'F':8 p+ }, A6 ^. \; J# q
              Find_Card();- S) j& f1 b, A/ j2 V6 G
              break;) b& _  u% P$ d7 x
    default:( P. Q! Y; V6 V' O% |' |0 W$ j
              DisplayConfigMenu();  2 Z# M8 _7 P2 d# u" t! o, C# H3 k
    }  D7 c% W; m9 T( D
9 s- V$ o8 d9 }1 `. j$ p- J1 X
0 q; K" ~, S2 N: `
1 u% F. j  E1 A1 |# M……………………1 U3 p, `- X7 y+ r5 T6 E
, R; Q3 o  R/ [" D
* x- C" k2 _; q: A
…………限于本文篇幅 余下代码请从论坛下载附件…………0 w9 d$ K# |  T) o5 U0 N" W
" Y& X! X4 D! k7 Y' |( B$ c4 {; K9 A- d
游客,如果您要查看本帖隐藏内容请回复
# _) `/ z+ B; G% i
GMT+8, 2025-10-9 04:12 , Processed in 0.156250 second(s), 26 queries , Gzip On.
