查看: 537|回复: 1
 RTC实时时钟DS1302液晶显示单片机源程序
发表于 2018-11-12 09:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
, j; f3 u2 \6 o6 w) x/*-----------------------------------------------$ K8 ^5 ^* y1 {) d
  名称:LCD1602显示实时时钟
9 U6 y4 {# f! G; Q. R  修改:无
6 s" e3 _( o- w4 ]1 g  内容:音乐闹钟  普通闹钟已被注释    音乐闹钟无法停止 自动播放后停止 (普通闹钟功能正常)" p. U+ A# z4 e6 @
        error:无( j: ~9 R+ m" S
        warning:四个 函数未被调用0 G6 p8 W; ~! L4 h7 j
. D2 w5 N6 `" Z#include<reg52.h>7 O! O$ v0 |! s8 Q! R, m4 Q& \
#include <String.h>$ s- N6 g. ^1 l2 g2 c% F
#include"ds1302.h"
% `& o$ Z% X- [- f' J#include"LCD1602.h"
( r* ?# |( E" e7 q7 }( t- v* r#include"key.h"
' I7 B/ s; _0 w! f* r( {#include "18B20.h". c# F; P! ~  H- @
#include "240c02.h"
; D0 K  _6 g  ^# p2 u7 {% h" y& B, e" }  ]; \9 C
3 F; l, h+ g7 h
sbit buzeer = P2^3;           //普通闹钟
/ h8 B+ o9 A4 N+ o5 S. e2 c- h
, d, m7 _) x# S, r& m9 Psbit led1 =P2^4;              //指示灯8 z( ~9 K9 Z! [. f& j  \9 |
sbit led2 =P2^5;0 o* I' U* }9 x' \( N
sbit led3 =P2^6;* K& I: {. h( t5 y3 ^! A4 r; \
- d7 m' M, N: I# e7 `) Ysbit fm=P2^3;                  //音乐闹钟 接口相同
( j3 ~4 V2 g9 P* s3 F, [! \# K; P$ o( y: A5 ?1 [
6 C$ p" E8 L8 G$ P1 E! hunsigned char timeh,timel,music;//            闹钟变量
) i8 Z  c! J" n0 {( j, R
' K) ~4 f: `% E: zunsigned char code zbjbxf[]={//0 y7 L* X% O6 F
0x64,0xA3,0xC1,0xA2,0x62,0x84,0x61,0x81,0x61,0xA4,0xA1,8 C8 j) ~# X* l+ g% ?( G
0x91,0xA1,0x81,0x64,0xA3,0xC1,0xD2,0xD2,0xD2,0xA2,0xC4,9 J( t2 T$ Q, V; K3 c! P( t
0xA1,0xC1,0xA1,0xC1,0xD2,0xD2,0xD2,0xA2,0xC4,0xC2,0x62,! u& b+ M9 f2 C, \) O
0xC2,0x62,0xA2,0xA2,0x84,0x94,0x94,0x92,0x81,0x91,% r% }. }5 l+ s9 W; o
0xA2,0xC2,0xD4,0xE4,0xA4,0xE4,0xA2,0xE2,0xA2,0xE2,0xA2,
# m: n+ n2 b1 }, I$ F8 x+ \& e8 M* R1 J0xA2,0x84,0x94,0x94,0x92,0x81,0x91,0xA2,0xC2,0xD8};. O& o2 I# T9 N$ b
! j3 V# G: S/ x" _! w* i7 N6 R& tuchar code chuzhi[]={
: S7 B4 H( s7 h8 N( v         0xff,0xff,//
4 t5 t/ Z0 b. a. C/ D2 h         0xFC,0x8E,//L1-7
* _' d! T" W$ U$ i  a         0xFC,0xED,        1 Y- J7 C1 @) n+ ]; v; o- _6 m- o
         0xFD,0x43,
5 q5 \0 y/ ?; s4 K1 R         0xFD,0x6A,        6 U% e' N% ^# L  _
         0xFD,0xB3,
- v5 n0 @2 g- Q0 @/ l- ?         0xFD,0xF3,
+ S; d2 S9 E! B5 B         0xFE,0x2D,
& n  B3 ^( ?2 D$ Z7 F         0xFE,0x47,//H1-7
- w1 ^6 \6 b1 Q         0xFE,0x76,% f$ D0 Q- D- V/ s' e
         0xFE,0xA1,
; q# j* l5 k3 |9 B0 _" m3 n         0xFE,0xC7,        : _1 k8 f' Y9 M. |8 v+ s
         0xFE,0xD9,
+ e* j* z2 ?3 Y& R9 |         0xFE,0xF9,' W$ e$ M9 d& w5 C) Y5 J# P
         0xFF,0x16
# S' t8 a7 W; h1 A/ R( @" X         };8 l! |2 I+ Z. c9 ]% X, F% L7 f
  d8 g2 |+ H0 }# ^void timer0() interrupt 1         //音乐闹钟中断( C- d" {4 H5 K: ~& m
{. e, ^. {  j& y4 M& e1 |9 `
        TH0=timeh;
9 v2 q3 K& I0 _$ s4 H% |, ?        TL0=timel;         3 s0 d# S5 {3 }1 ~- n
        fm=~fm;           G$ `% o3 {7 J+ U
, E3 W' E0 i4 O4 a* b
+ R! k% [: A6 _1 L9 Q# H- P! o
* A& N- h2 p+ m" \) @! M8 C0 V' ^void delay(uint z)        //??165MS,??????' \4 H2 C: I2 n, h) `9 o2 j4 c- Z
{        uint y;* Z; J- G" Y! _! E$ j! v
        for(z;z>0;z--). m9 v0 h- V* V( w7 u0 b8 l
                 for(y=19000;y>0;y--);//????
* v% L* y- s6 K5 d' F* |}. }* {- ~3 j4 a' z
void delay1(uint z)        //??1MS
# V+ B# Y- ]% r{        uint y;& I4 g( ?3 P1 w$ F3 C& y
        for(z;z>0;z--)# d9 s' F& ~& t! K0 G9 t5 B3 Z0 K4 P
                 for(y=112;y>0;y--);//????( f1 Y7 o+ g8 J
! I2 w# ^8 o- M: Y9 K7 g6 z; O7 {/ \4 {+ k2 [& r
% T: c" b; s/ y/ J3 |
! S7 s* m7 z4 u4 k" u/ ?//sbit bell = P2^3;
; B. ^& A. k/ I) Nchar key;
" a# q0 X" b* o9 I% c& Echar keyflg;4 `% N+ D: e$ Q7 K' W1 m
//时钟变量
- K0 w9 V1 m1 g( t8 `; j2 p  g: c8 R, L; B
unsigned char times[7]={1};
* @' B- m0 \/ U9 X" iunsigned char time[3];, [' \- [+ S4 W8 e0 N
unsigned char PPP;; p! l$ e4 z8 D( }1 Y/ Q6 U
- f* B: o+ k4 i2 r$ Iunsigned char clock_buf[7];8 P( i% n% q, ^
//闹钟变量
2 e0 f$ d* \2 _, zunsigned char counter;
, g" ?, N2 s- A* J8 gunsigned char baifenmiao;8 p8 N9 |/ \  Y$ Y' k1 w: Y; v
unsigned char shifenmiao;2 @" S2 }2 U. w8 J( G
unsigned char miao;  y5 \  l( {3 U' K2 |  G' {6 K
unsigned char shimiao;
/ R& K" h3 A) H3 y! `% ~unsigned char baimiao;7 [" h' z2 U0 Z* U$ C* R' C
2 W/ k0 ]$ K  Z8 X7 c( a
6 A/ Y' M4 \9 C. kvoid key_timeset(void);
2 g+ p8 z- t# y- {5 n3 Zvoid dateTrans(void);
- C) C. P  p. K4 [# }void alARM_aclok(void);
0 h7 Q2 @: i; qvoid arm(void);. b! w2 ~. V! L+ v- x0 a4 V
void timer_run(void);
1 ^+ j) h9 w# Qvoid timer_runback(void);
* V, _; ]4 [1 p& A! M( }6 D1 jvoid clock_display(void);
4 t: w9 e: w2 X9 N% Cvoid clock_delay(void);
: F! t( H/ k5 \void start(void);
% P; a0 Z7 ^' v  I  Kvoid delay_ms(unsigned int z);
1 L' m; v1 j& e! ?- bvoid ds18b20(void);
& n3 w& d) z3 `0 O+ ~void ds18b20_xiugai(void);8 v, ~, n3 q0 v0 Z
void xieshuju(void);; X, @9 y- ?) ]
void dushuju(void);
. ]6 k) [/ [3 C( f) f  u+ x
, c2 X' z0 O8 B2 ?void buzeer_music()                    //音乐闹钟
0 I' o6 t- t6 M' S: }' c0 B4 C{
" S2 L. {/ C! Y, ?8 k        uint temp;        //??????????????????
. d) @4 H! m6 p6 O        uchar i=0;
! `/ y% r4 i  [* ~, p$ z/ r# I        uchar jp;        //jp????temp???8???8?7 [+ L  Q5 R' Y% U9 y
        TMOD=0x01;//?????T0?????1
) A: w5 d6 k0 Q        IE=0x82;  //??T0??7 H) J3 r: O( R7 g
        while(music)
3 ^) ]5 J+ C5 l8 W/ _( p        {: }+ z2 V$ g. m) ^$ F
                                        /*        ds1302_read_time();//读取时钟信息
7 G  i& d+ X  a$ v8 N% Z
5 K# q6 I; b7 B, g- W* B4 S                                                dateTrans();         //数据复制. f% l# ]" R& q, ?- F5 g  p
                                                disp();*/
6 U  S1 C- e) Z- i* C+ Z# n4 |                key = Key4Scan();
# R( I, H* }" d% @0 L& I% ^                if(key==4){cflg=1; keyflg=0;music=0;}        7 b% d2 b& \$ @& r+ Q0 c3 N. N( Z
                if(key==6){ keyflg=0;}        3 s5 d1 d" ]5 j+ _8 E; i
                clock_delay();& F1 T  I* d6 J% W3 o/ _
7 m& G+ t2 ?! z5 d5 u) B, V6 t, }
4 U9 h1 ~  Z- D! G9 ~/ M  B                temp=zbjbxf;
* Z3 b2 j2 @- V' a0 {0 g- |                if(temp==0xff)0 k! g- k. x: I0 ^" O* Q' h! B* h
                        break;
6 a3 e% C& P- I( r. C' K                jp=temp/16; //????4?,????
8 |% H8 p+ F1 [  g6 I                if(jp!=0)
! U1 E' W  ?" m: n! L; r                {+ C2 [& J/ y8 w1 n$ G' u
                timeh=chuzhi[jp*2];//????????8?
9 {5 t' u) w1 f5 X" z                timel=chuzhi[jp*2+1]; //????????8?
/ @" h- D9 V) r' T" U$ u                TR0=1;          //????2 V9 ~/ A- i9 h* u, O% t: N* w/ [
                }3 j% l+ n$ a2 f
                else
; G0 J; @; k# J1 B                {& y$ ~" m# h% O# Y5 o( Y
                TR0=0;          //????7 N1 [- ^' O2 o( F" f8 M
                fm=1;          //????
* G' e& W' M* L                }% ~- o; ^; R: _3 f4 ?
                delay(temp%16); //????4?,??(?????): R: i( n7 k/ k( H% H. Z
                TR0=0;         //??????5MS
) @( f$ K( ]1 M$ P                fm=1;
* ^  L9 H" O0 Z4 z                delay1(5); 2 a; O6 X/ U4 \) q/ P
                //TR0=1;
  \8 q$ |( m  v2 e                i++;( ?: Y2 @" y' Z3 M3 `
        }2 s' ~8 x4 g% X4 f& c( L
        /*TR0=0;        //????- W, \- g: M0 Q4 Y
        fm=1;        //????*/                //JJX3 P' w; [  E% y! {8 ^% f
) f0 G- X! Q, G' C. d8 t/ lvoid Time1_Int(){          //用于定时 倒计时
8 B" w! d: E6 q( s: [# k4 m                TMOD=0x10;
. g- t7 ~2 B+ C  H0 _                TH1=0xfc;          //10毫秒
' h4 E/ `" p1 l! N) }2 g' A% L                TL1=0x66;! }0 U0 ?9 L5 i0 M& g; \
                EA=1;
; G& N0 Z/ {; c! ^6 j                ET1=1;
* m" e, Z# Y3 a! n& r1 T1 T                TR1=1;
; {0 K# r2 V7 B% G" Q9 M: R' g$ Y8 ~}) ^+ g4 S( t. Q" T- k. l: e1 \; z# q! w
, d8 {) P* R- s  Lvoid main()/ R9 @6 f, a$ c* w9 U" N
{: p" Y" b) B/ F$ |
                         //buzeer=0;        //闹钟停          $ h$ _! E/ q' X
                                buzeer=1;                                // 接非门后闹钟停3 M- E  i; U. R
                        // dushuju(); //e2prom 读数据 有问题
' n5 ?( B! l. S% |/ \                         ds1302_init(); /*DS302初始化函数*/
! ~, Y6 O* _& U8 C) O% c7 t; u9 }
5 }+ Y* l! q  a       ds1302_write_time();      / Y8 ?6 x& I9 a6 Q( E( {% |
                         ds1302_read_time();
/ h% I/ h0 y" H1 d                        // tmpchange();
' `, y" c4 e* A% k                         //Time0_Int();$ r; \, t- l; q6 F: z
       InitLcd();     //初始化LCD
) q/ r  x7 b( v4 T- _) k       DelayMs(15);   //延时用于稳定功能
8 h7 e( s3 G: `( H                         Time1_Int();4 R7 U' ~' w% A/ p6 ]
                         start();                //开机显示
8 N4 _6 Y2 R  ^, x7 H. H; j% `3 [! X+ V1 s# U% ~
' P1 z1 p9 R+ q2 L" e. S
  while(1)
1 j5 i: ~& H; `6 `4 w        {
  K6 _) @9 A3 w) v; G8 Z, Q$ s                                key = Key4Scan();        / q8 T% j: i& U
                    if(!cflag){: D4 I3 f' x8 V& |1 E! A  T
4 m( w6 E7 m" }! {$ Q                                                if(key==4) { buzeer= 1;/*buzeer= 0;*/}               //按键停止闹钟
, G) i/ [6 w6 Q1 C1 ]% b% t                                        //        while(1);              //调试+ B7 W0 g, j; L& E  \0 F. H1 M
                                                alarm_aclok();                                         //闹钟1 }6 L: V/ _1 H# |; |0 d
$ s( O) T5 N4 T; l- K+ H+ O# `
                                                ds1302_read_time();//读取时钟信息1 C1 A% d% Q# a! O: b# t$ [& ^
$ S7 r* h% q9 p5 i  \/ S9 _
                                                dateTrans();         //数据复制) v* O9 I  u) m
                                                disp();         //液晶显示时间信息# c( T4 u& ]5 B+ B& e/ ?4 c
                                                timer_run();         //秒表, y5 H, w+ f" Q( ~  x$ Q
                                                timer_runback();                //倒计时
2 b7 q/ _$ U2 F. o* o# o" a                                                clock_display();                //时钟显示
+ r2 \1 @9 ?2 ]                                                if(key==7) keyflg=7;        0 h" K6 f4 Q$ U7 G( L
                                                ds18b20();                                        //按键显示2 J3 S; R3 R9 r. D7 Y3 x; a
                                        //        ds18b20_xiugai();               // 显示位置修改
4 A+ B9 J# {+ ^9 v+ e6 i" H                                                if(key==4) keyflg=0;
# d1 H9 g) @2 c, f% c                                                if(key==5) keyflg=5;
$ O7 x) s. D! p                                                if(key==6) keyflg=6;/ I1 J  Q1 i$ \* |' t% L
) P/ ]9 Z0 G& j$ h- U" s$ S; M7 r  y* w( X$ L2 Z- i
                                                clock_delay();                  //瞌睡$ J  ~- N  W+ p+ f" L9 _& s, w
                                                xieshuju();                   // ——>到e2prom          ; v' i+ q  o! o1 f8 R! [
                                        //        WriteCommand(0x80+0x40+15); //按键调试信息
* b; P4 E7 r  ~/ C3 h                                        //        WriteData(shuzi[key]);          s5 c6 i0 J0 ]! F+ n- G, ~
                                }: ~) l: |& C& ^4 z) u* u7 \
                                key_timeset();           //案件时间设定
; N( u. g# M- h- V- P, f9 l2 |" v                        }6 H" n( i; C" v' i. R' I" J
, b. F/ j% V! c2 @  t- r8 r; ~  t}
% L8 J, L' k* r7 B0 ^$ h
: a* y$ J$ q3 ~" k: ^0 t
# r* w  M1 ^+ U0 E. Y8 ^1 \  d7 e# Q
/ r( `( g( g2 f, q3 r; W0 R' X+ m
1 ]. M3 V0 ^$ ~' Y4 m( G6 |
, Z" R) S1 B( N' m$ R! ]8 l
7 c2 x0 H4 b/ K" Q; M% i
2 C9 r4 w9 s) ^, X: f# B; z# U& a1 P9 n5 U2 {! g0 g* E
) D& m8 X2 @& j/ K0 {
6 R" F9 {( o1 S1 ^% H4 ^2 mvoid key_timeset(void){$ w0 ]6 p2 }; j
        char i;3 q% w2 z4 X: K! x1 V; N6 F8 r
                switch(key)   //Key4Scan()& N/ I1 J# V9 @6 G0 v( Z7 [$ J# O$ Y
* }  w5 g4 O2 ^) S, ]                                                case 0x01:
6 |) U8 Q' g2 l+ O5 a. ]        switch(PP++)      //??????
, J6 o/ Y/ H2 f# L, _7 H        {8 O" |& m  x- f. w/ e; |& K/ S
        case 0:  WriteCommand(0x80+0x40+7);break;                                                //秒" @3 `- A2 `  d5 w: ?
        case 1:  WriteCommand(0x80+3);break;            //年& A0 x6 s/ B! M# K; m* C
        case 2:  WriteCommand(0x80+6);break;                                                //月5 q2 T/ B  _! q7 q
        case 3:  WriteCommand(0x80+9);break;                                //日( t, }3 O. G) q1 b6 e
        case 4:  WriteCommand(0x80+15);break;                                //周
' E- E: ~- s) a$ T! A( v        case 5:  WriteCommand(0x80+0x40+1);break;                                //时3 \: m! P/ G. w" c
        case 6:  WriteCommand(0x80+0x40+4);break;                                //分: v6 ~( U' g: h5 N
        default:break;6 K$ P5 ?# g7 V* ?% u$ X
9 }+ b1 Q! q/ d0 v9 T5 E9 B        WriteCommand(0x0f);//光标闪烁
7 Q& u6 ]' |! ~! w7 M        if(PP == 8) PP = 0;                 //7还是 8好像和编译器有关系
0 ^6 G7 p. @9 ^& j, R  M* o4 H: `1 u
        cflag = 1;          //????3 |! t) u7 A9 O- J* r+ O  I+ u! }5 R
" \$ N4 H  l% C7 O
        break;
# v# j5 N) y) q6 ^/ d                                                case 0x02:
3 s# `; l' U5 X6 O8 }( I3 i        if(cflag)
. K& P. P: s9 H; h; s/ z        {$ K7 w) U% P# ]* ^7 Z5 s% g; G
        switch(PP-1)4 u( D: q. D$ y: m& i5 x
        {+ V# R7 _, |7 ]# F
        case 1:          // 年
) Z) K% v3 Z, u& Z) }        times[6]++;: O; h" U0 _, S* z
        if((times[6]&0x0f) == 0x0a)                   //  0000 1111 1010  转变为16进制$ `7 Z) V  _* W* a
& ?! Q/ W1 v( `" ^, @/ \        times[6] += 0x06;
0 q8 l( S) ^' Q0 W9 O        }
1 q" X% T: S& `% x- ~5 G        if(times[6] > 0x99)
- ^) N5 j$ |8 ^( o6 @        {
. t9 s) j8 _/ u# J. F        times[6] = 0x00;    5 v' w! @! P( Y- ^2 Q: m
        }( x4 y. \7 o: T  a2 e
        WriteCommand(0x80+2);) T% ~$ `0 W- j( U% k
        WriteData(shuzi[times[6]>>4]);5 z+ p, g3 B# s- u6 l
        WriteData(shuzi[times[6]&0x0f]);' @& W) X" N+ V) ^
+ \4 ^4 g1 X# O& l! J: }        break;
4 C- w  R9 S0 K& O        case 2:                                 //月
0 e' Q: ~  {; Y' t, P        times[4]++;7 x) {* n& Y- h  X! U% `: E
        if((times[4]&0x0f) == 0x0a)  ~0 E  C( ]! f6 d% i
/ v: e6 w; z3 P: E$ f        times[4] += 0x06;       3 i  m/ ]( y! p6 C$ ^" j
( I. w/ O: [8 @% F6 n  ^        if(times[4] > 0x12)" N1 v) L2 r2 ?2 E( h
# w! O9 V4 k8 ?& |9 v% \0 z        times[4] = 0x01;
* ]# z$ C, K# E3 m6 [        }
; w; h  Y1 F& a: k' H+ E. Z/ r3 K        WriteCommand(0x80+5);% A# V! [1 ]& D: g/ O& D* t
        WriteData(shuzi[times[4]>>4]);% p9 Z" z# _0 u+ R) u5 ^3 Z3 G
        WriteData(shuzi[times[4]&0x0f]);
% ~% o4 E/ Y; p  v$ A& u        WriteCommand(0x80+6);' a* X% c6 J# V5 v8 w, t
        break;
5 X, t3 b/ M4 G3 i2 s  E1 M        case 3:                        //
& G0 V$ k% n& D% h) Z  ]        times[3]++;1 m5 n/ a% m2 h. [# {1 L
        if((times[3]&0x0f) == 0x0a)
$ o+ ?' J1 Q% U' M        {
* i- a% B6 }' J# C# Y        times[3] += 0x06;       % v2 W2 j4 `: ~
        }$ R: v- P( I1 D! [
        if(times[3] > 0x31)
3 q7 w' ]& k/ |/ r$ J  ]6 t        {
$ U2 R( H; G6 ?) w4 p/ P5 R9 w: n        times[3] = 0x01;
; R# I4 s' X( A& f7 [; N        }/ ~4 @# ?+ _7 O$ K0 Z$ J4 l! }
        times[5]++;9 F7 A9 S$ \3 U/ u8 t, h+ X
        if((times[5]&0x0f) == 0x08)
4 l  I5 x% o3 p0 {5 }3 b& ?$ @/ z        {* j# m( X6 b4 V" F! E" m
        times[5] = 0x01;       3 O4 M) A4 |5 v2 h; |# H' {
        }) M, C# E' j0 n7 s5 E' A
        WriteCommand(0x80+8);( H7 {( F- {3 g9 D8 z+ C, N9 d! a$ Q
        WriteData(shuzi[times[3]>>4]);
0 a5 ?+ p. T& J1 W        WriteData(shuzi[times[3]&0x0f]);; P# M) j7 v) Z
        WriteCommand(0x80+9);, C- {: f: H7 D+ C4 E; H! T( V
  d. F# L- A4 P+ Q) K5 Q* ^        break;
1 L: r) R  o& ]& }/ w/ v        case 4:         //?, a# h6 _9 @& \$ D
        times[5]++;
7 F7 l6 @7 ^2 J% ^% u' i; h        if((times[5]&0x0f) == 0x08)4 J4 W0 T' ~% v( L  {. a
. S  J) f) e& I0 @/ U0 d$ N! `2 g# q        times[5] = 0x01;       ; [% i" P* \4 W5 K8 [) G! U
        }, q" T/ V' j( Z/ p" H  I
        WriteCommand(0x80+15);6 I9 B* Y6 Q# o! y! i
        WriteData(shuzi[times[5]]);
: y$ R% V- J, _5 j# l" R- t( S        WriteCommand(0x80+15);7 s" d/ v. R' R+ k8 h: g
. e* P9 ?6 V3 c9 V
        break;6 T& p# N/ f' q# s6 {1 A" T1 Z0 K
        case 5:         //?
6 i  Q9 ?9 S' j        times[2]++;
1 @0 E( c' j- M+ p9 w5 K8 V        if((times[2]&0x0f) == 0x0a), H, S  [' y# K5 s% w) |0 V
) ^) R4 V6 J2 a        times[2] += 0x06;
; b# l% m4 g9 N6 u- b5 @  L) p        }7 P$ b* W& {* ^6 X" w
        if(times[2] > 0x23): I9 ^) d) B  z% d
        {% {6 H9 L0 ]2 m( q1 {
        times[2] = 0x00;    2 Y* X; S' |5 N8 s2 T! `
        }6 X& U6 c  d8 R+ `$ ~7 a2 P
        WriteCommand(0x80+0x40+0);
* }  Z. {' j' t        WriteData(shuzi[times[2]>>4]);
- d" x: T: D# Q* c$ U        WriteData(shuzi[times[2]&0x0f]);8 j7 c/ ?' f8 O% M1 _. {; U
        WriteCommand(0x80+0x40+1);: Z6 S7 e  d  M' R) I
" A7 O- d) Q! T6 y; }4 |7 e
        break;
# Z0 K; @( ^2 m; l* s        case 6:         //?6 W& S1 L, j6 n. Z; o7 w
        times[1]++;1 H" l% h, a8 H  p+ e
        if((times[1]&0x0f) == 0x0a)4 r7 z$ N3 g8 o. J8 I! ^
/ M  _) s5 Z4 L  |        times[1] += 0x06;       7 U; }5 a4 J/ N  ~, s8 K
3 J6 I7 U6 J! y! b& x, @$ l        if(times[1] > 0x59)7 o- j$ Y, f4 M+ _8 E
        {' M8 n2 @5 ^  T, G: o+ Z# P
        times[1] = 0x00;    % }3 K# ?. }# l6 Q/ X. h
        }6 E+ x9 x- [/ n1 n
        WriteCommand(0x80+0x40+3);- Q% w. R; J3 M  b6 A
        WriteData(shuzi[times[1]>>4]);$ k9 k, b0 F' `9 P- L
        WriteData(shuzi[times[1]&0x0f]);$ T0 Y! O7 W- {
0 w( m& {# f, B1 W* B; o
$ _! v2 b7 b4 ]+ E6 u3 [        break;
0 ~: Q$ B$ t) n: l! L7 m& ?" i7 \        case 0:         //?: _5 ~8 \0 p" o2 a& b8 p& H+ [
        times[0]++;
3 [3 A" Z+ h  S' M. k        if((times[0]&0x0f) == 0x0a)
3 Y. A6 \) J. p9 H3 a2 ?        {
' ]! ]- v" m+ m( q        times[0] += 0x06;       ; X7 U( W1 Z9 e
        }2 A" d) k1 W+ m) m: }* I: [- V9 P! S
        if(times[0] > 0x59)1 O0 N* M6 ]5 U' P1 H
! I4 l- D1 j* ]1 n4 q+ `+ o$ _        times[0] = 0x00;
9 U& d. i( _. {* j# U% j2 O8 j        }, |) `$ B* r3 u1 m. G
        WriteCommand(0x80+0x40+6);0 x. R  d' {0 @; K/ H
        WriteData(shuzi[times[0]>>4]);- j6 r# J5 M$ X, ^& _! S, ]( F
        WriteData(shuzi[times[0]&0x0f]);
! s" h: x- a* p& m        WriteCommand(0x80+0x40+7);
, X3 T5 ]9 v7 m8 k& q* |" K
* y9 m3 L- W6 P! J0 L/ E# F        break;
3 R7 v, Q) }8 M        default:6 \+ e9 O2 z! M/ o
        break;
" M) D0 f& G1 m( s$ u
7 r! w+ B9 V- N9 V) E        }
/ x) m7 b- X0 e+ d* e# }        }! R# X$ p- D2 u* f
        break;
: b2 R) _. m1 \4 G  h" d6 N: [# n                                                case 0x03:
" i8 I7 k8 q9 Y        if(cflag)
3 y) ]* s! V$ v; f( H7 }8 m1 F/ W' r  c! I        {
8 C2 u( N( c8 p! Z/ ~& o        cflag = 0;. ^( D- ?6 k  g$ M
        PP = 0;, Q5 F. q$ X0 \* W
        WriteCommand(0X0C);   //取消 并关光标
/ V% X' g( O2 L% V2 {2 l" g' Z) B) z        }
; G" E/ i9 [3 f: ~8 g! S' D) ?        break;% L0 r; L; w( e  L& Y
                                                case 0x04:                                 //保存数据到 DS1302
( |' Y1 u/ d0 P+ ]7 A! y8 B  f2 S        if(cflag)
, A. Q- F1 U5 Q' \        {
$ Q, ]: s3 |- {" x4 e        cflag = 0;
( X) W( }2 s- C, F5 t5 C, r2 w! j" N        PP = 0;% o' P8 y7 |3 f, o: |1 R4 Z
        WriteCommand(0X0C);   //关光标
0 W3 J0 @* z' r6 s        ds1302_write_byte(ds1302_control_add,0x00);                        //关闭写保护 7 m; R7 U. I& }4 `
        ds1302_write_byte(ds1302_sec_add,0x80);                                //暂停
2 E4 H; {, P6 U* r0 a* M( @        ds1302_write_byte(ds1302_charger_add,0xa9);                        //涓流充电 0 n4 X/ Z' M& |. A6 M' ~
7 E0 ?. r% n; M: d% B  s
        ds1302_write_byte(ds1302_year_add,times[6]);                //年 2 x' v3 I3 _0 l0 M( ~3 K0 m
        ds1302_write_byte(ds1302_month_add,times[4]);        //月 ; l9 J& }- a  }* e
        ds1302_write_byte(ds1302_day_add,times[5]);                //周 ! U* r! F4 t8 W4 [9 T( l/ h, G
        ds1302_write_byte(ds1302_date_add,times[3]);                //日
& Q0 T7 }' D7 c# f: E! {
! f9 q/ m4 H$ K* \        ds1302_write_byte(ds1302_hr_add,times[2]);                //时
# A5 _7 w, ]* L4 Y        ds1302_write_byte(ds1302_min_add,times[1]);                //分  ?0 A/ ]+ ?  R
        ds1302_write_byte(ds1302_sec_add,times[0]);                //秒, i/ c) _& m4 q8 r
        ds1302_write_byte(ds1302_control_add,0x80);                        //打开写保护 % s5 C( H1 X8 G/ t5 E% K* _/ \
' e$ R9 Y! Y7 |) ]1 D% N  h
        // Set_DS1302(times);   //DS1302 写入时间. ~% r, Z5 w7 E
7 S% M% f0 {* q1 {6 l! {$ [- ~        break; : \2 M& _9 O7 `8 ?2 ~8 |% o
                                                 case 0x05:            //保存数据到闹钟
) d3 s" h! o) s6 a; R2 D/ O        if(cflag)/ K) `# K# T. ~3 e8 \; J
        {; N( H0 Q; v- s$ Z
        cflag = 0;
& S5 {; Q+ K7 f  i: B5 [3 L5 t        PP = 0;' M- a5 A5 ?" R, @1 F- ~! P/ f
        WriteCommand(0X0C);   //关光标7 ]5 d  Y- ^3 o/ C" `0 {
        for(i=0;i<7;i++){, O* ?  `  P/ @0 C
        clock_buf=times;% |6 V3 v# e( T+ b
6 a) i7 c; ?2 i7 \6 G
        }- N% @: W. z; t/ k! }) @
        //        strcpy(clock_buf,times);) C. {/ u# i4 c/ s/ W4 j2 ~+ y; o1 m8 J
        }3 j+ b# [5 \2 C
        break;
# Z: p. S: l. @" o1 r                                                default:
6 O, C6 h" y8 L( S        break;                    # }( g; j, @, f: A0 C
2 W0 j1 ]* {- P1 S7 k}) J2 K! _6 S$ _5 z# A
void dateTrans(void){
9 f  g, V5 x* ?. O6 q
1 r9 a: C' U9 h9 N/ I5 c        times[6]=time_buf[1];
2 b) S! ~& I  ^8 m. V8 D, v% o        times[5]=time_buf[7];1 W5 D# N* [: k4 c
* O! q9 z: E2 X+ x! N+ L        times[4]=time_buf[2];/ ^5 N# z0 A- E, Z
        times[3]=time_buf[3];5 S# }* e! ?: Q. k$ Q0 O
        times[2]=time_buf[4];
" d- u3 r9 ^  |  H6 L8 F+ x        times[1]=time_buf[5];. F5 |, O! l. @6 i2 b) }+ A
        times[0]=time_buf[6];
( }' I( }( |" K8 U- x: X' e, N" S: b
- d! P3 X& }4 H5 l' l1 ?void alarm_aclok(void)( P: s2 {9 ^! J$ Q
% ]+ J( r, u. d1 J# M
; b; I7 d! i* B$ d( M. V! n                if((times[2]==clock_buf[2])&&(times[1]==clock_buf[1])&&(times[0]==0))        {/*buzeer= 0;*/        music=1;buzeer_music();/*可替换为普通闹钟*/}     //1111 0111 P2 & 0xf7
# [! R+ ?: |1 \                //else        {        buzeer= 1;}" X3 k( |: R# e& m6 Y
}: R$ J* ]: v. d" L! C" H2 M
* n$ G/ ^* p# H7 V! J2 F9 t' O
void T1_time() interrupt 3 {6 c0 n% l& C4 q; a, f
) {0 a# q5 H$ d$ ?' ?                TH1=0xfc;4 b# [1 b) v: T1 g; o
                TL1=0x66;
4 \1 S5 p+ a  h0 ?4 b' ~3 I% I5 Q                counter++;
& ~% D' ]" G. u& ^. R        if(counter == 10)                { counter = 0; baifenmiao++;}
' g% o+ I) N# k2 w) j        if(baifenmiao == 10)                {baifenmiao = 0; shifenmiao++;}' w2 N$ n! M1 q4 d* m) S
        if(shifenmiao == 10)                {shifenmiao = 0;led1=~led1; miao++;}6 f' D6 H8 U7 W- T* N9 I
        if(miao == 10)                { miao = 0; shimiao++;}9 t7 b. X+ z0 h) R7 I( F+ T1 T6 \) C: S
        if(shimiao == 10)                { shimiao = 0; baimiao++;}
. F3 j% g# S' [/ o        if(baimiao == 10) baimiao =0;
+ w# y) R8 F+ G4 J, a! ?7 V2 H" C+ r; m6 a" S0 ~
0 g& U4 M/ }7 @3 B" y# h5 f; e2 @$ I5 `: _5 Z
void timer_run(void); C6 S; a! [" n" {
{! H; p# V- a6 \$ I
                if(key==2) keyflg=2;                       //计时功能 * u- i6 U' o  u
                while(key==2)% q! ], X: N5 @
                                {        ( Q% L+ A& z+ _! |3 w
                                                WriteCommand(0x01); //显示清屏! P7 ]: g& e! n2 I/ w
                                                while(keyflg==2){: M3 m( V9 M) o2 ?3 ^* m
        key = Key4Scan();3 M* i& j3 L, P6 r8 j( o
        if(key==4) keyflg=0; " C9 A; k- A+ m+ \
        WriteCommand(0x80+5);            //计时功能
* M" b# y$ c; Q9 z% i9 u8 B        WriteData(shuzi[baimiao]);! ~# @" q( W5 k. Z2 {
        WriteData(shuzi[shimiao]);5 P1 u$ o1 N$ u6 D
        WriteData(shuzi[miao]);6 p7 t) o1 S0 Q7 f2 ^4 O
        WriteData('.');
& k9 j& {5 \% }" S1 F        WriteData(shuzi[shifenmiao]);
! e* c% p6 _8 A; N& L3 U; H9 S7 N        WriteData(shuzi[baifenmiao]);
; n5 U/ y8 V: p3 N7 r  u) y                                                        if(key==2) TR1=~TR1;
  Z/ G$ H% m$ O$ ?2 }                                                        if(key==3) {shifenmiao=0;baifenmiao=0;baimiao=0;shimiao=0;miao=0;TR0=0;}5 l) M, }: o. |0 \; Y7 A9 |
                                        }5 J- A, y! A  q% g
7 A" `8 K1 i1 d) ]                                }* c! S; Z! j% w  w2 J2 }, f4 @$ \6 b
1 q: u* d# S8 q6 g( Y( U9 l9 K$ A* Hvoid timer_runback(void){( c/ B  D5 [1 |. g+ Z
                if(key==3) keyflg=3;                       //倒计时功能
! T- {% [) X2 ~% @$ C/ t                while(key==3)/ V" o2 I4 j4 w
                        {) E. Z# M3 r6 E. V
7 O  [+ ^4 C' [2 c; ~) Q( T                                WriteCommand(0x80+5); //显示清屏   k1 功能选择 k2 定是数据选择 k3数据保存
4 [% g. [- K+ ?                                                WriteData('0');
) A1 f8 I, `7 A, u; \                                                WriteData('0');
2 s$ ?4 O6 `1 e4 |+ D) K4 g2 c3 S                                                WriteData('0');9 b3 H" U7 p% a
                                        /*        WriteData(':');: `/ \4 Y* ~& W* U5 B0 Q* @
                                                WriteData('0');( ?$ b/ R0 _3 L3 }! Z% A
                                                WriteData('0');*/' o9 c2 y- m. B/ ~8 I
                                while(keyflg==3)
! e; h3 _( U# G  _                                        {
, P! x- M  O! p. B2 q& i                                                key = Key4Scan();! _& g/ z1 u; |% Y' P
                                                if(key==4) keyflg=0; # P! O% t2 A% l+ K' W4 ~! ^! {- R
4 V; |4 w7 D6 F& V) n9 {5 l) _
                                                switch(key)   //Key4Scan()) w& K% K6 _% k& `) a9 ~
1 k2 Q$ E1 C5 D; t8 D  u1 s$ w                                                case 0x01:& k1 b3 B* i; b* f
        switch(PPP++)      //??????3 w) i+ f8 n( e  `% {3 f  v
        {+ f, W2 H& n+ I4 E
        case 0:  WriteCommand(0x80+5);break;                                                //分钟
# e" x0 s6 Y7 F6 s        case 1:  WriteCommand(0x80+6);break;            //
$ H, u( d) p  _$ _* _) ~        case 2:  WriteCommand(0x80+7);break;                                                //6 W1 Y, J: l9 F$ W0 ~. c  M2 T# U
        /*case 3:  WriteCommand(0x80+9);break;                                //        秒% w& A! {  I7 `$ `1 z5 Z, H, ^9 h
        case 4:  WriteCommand(0x80+10);break;                                //*/
0 m/ \- [- p$ N; d* w; W        default:break;% G+ j' f$ ~. N
* N' b& @! W" g6 O; V        WriteCommand(0x0f);//光标闪烁$ V  b$ E& ]: p3 ^: C/ F2 Z
        if(PPP == 4){ PPP = 0; time[0]=time[1]=time[2] =0; }              //7还是 8好像和编译器有关系 ) X1 k5 x" a/ k+ E0 c, Z3 m* E
" E+ K! m1 w9 r0 J$ q! K$ v( T
        cflg = 1;          //标志位4 ^0 ~/ a) {0 V& Z+ _. z
" [' @) }* g% a# s
        break;
+ N* p3 z" ]3 {4 V/ P& b2 g( e                                                case 0x02:# r$ _# C( ~# s
        if(cflg)
: V- `: y, `+ I9 z% ^        {$ K* X. Q  c; p3 e
        switch(PPP-1)6 o+ p2 n8 U/ P% v
        {8 i0 D' K' z' D+ E6 }' k# r: e! ?
        case 0:          // 百秒                                       6 e8 q0 H, t8 K" Y$ d/ l' }+ q
        time[0]++;$ O) v( t: `% P9 s: Q
3 Z, t  E- N* J        if(time[0] > 9)
: q/ ]* |; b1 M# m9 e7 m3 d        {# E* C+ r) {+ \/ g/ A. r; M- t
        time[0] = 0;    9 M4 j! z( p# N
$ k' E7 f* G1 L- B* I        WriteCommand(0x80+5);% J, d7 g4 C1 v4 r$ ?
        WriteData(shuzi[time[0]]);
! k* I( M: T6 T) [  S' h; ~        WriteCommand(0x80+5);: q3 }- M  m* t7 ^; u7 s' c
        break;
1 k" \8 V  d1 `% K" n  \        case 1:                                 //十秒
$ `3 k4 k( E4 X' y6 S& }$ l        time[1]++;8 {& y8 p- b9 V/ z! O/ ~) w: m
2 }0 t( z4 ~( Z* E" L6 Z# O        if(time[1] > 9)
& w) O. X, _" y4 ^4 n  }        {
# p- n; I, n4 K3 ]        time[1] = 0;    % j1 l0 \# G& J! A* _
        }% R% k3 h) F  i- }
, Z$ \/ {- r) t3 J! n) i1 M' V% Z        WriteData(shuzi[time[1]]);& D+ S. O4 f4 I1 }1 f) R) l
3 F5 L( K* }. D) {8 {: D" c1 p- I        break;' ~, h; e  W. o2 Q4 ^' D  n
        case 2:                        //秒
( T+ d9 y; w$ m# S, a0 s; ^7 n0 w7 k        time[2]++;
6 f- p9 K  K' j1 k. x        if(time[2] > 9); ^. _! K- c. J; M( X" s
        {% Q, [4 w# E3 Z, Z( ?0 v
        time[2] = 0;    $ }( a, L8 p$ ^' _4 {3 C( a% I; L
# t3 _3 C1 q6 o+ K8 a- v5 m' S- X, _        WriteCommand(0x80+7);
. b0 J6 R; v0 p9 z        WriteData(shuzi[time[2]]);;& j4 i- g. Q+ p' z' H9 I$ c
        WriteCommand(0x80+7);$ [/ g4 N% V. q6 c( S0 O/ p# U
7 O, m# r, w) R% H/ a        break;) w- l" C# h+ A& N/ {8 [
; {8 w& X. F& |9 D; l7 r
1 u/ r2 t, H" H+ z* |5 b( j4 \+ L        default:
# e  K, v) _8 \) `        break;
$ X) a# W1 S, Q1 @
% V  \& |2 Z6 n+ H3 f+ Q        }$ N; Q( M5 n# p) u5 o
( b+ Y4 w2 J2 f        break;
$ w# Z( _* X: d2 e: h$ y. I                                                case 0x03:
5 E8 S$ \5 D, O& t5 g0 L        if(cflg)) B# X7 r5 g' K  ?2 o
        {; x" \) G. g3 f2 {8 e, _
        cflg = 0;
* P* T. F5 k- M: W        PPP = 0;
/ D& h6 ]2 Q2 A        WriteCommand(0X0C);   //取消 并关光标7 a2 r1 W! ~+ C" }: E& U% K6 P
        miao=9-time[2];
, _, q& X5 a1 ~7 ]$ J9 E4 W        shimiao=9-time[1];  ?' ?- ]  V# L
        baimiao=9-time[0];
) c# [; ?' m- q: M+ d! {
0 P& N' T$ U  Z. C        }
  c# ~- e/ f4 K4 C, a; b" z( F2 g% ~7 b        break;6 o0 L* R4 x* v8 D7 y0 ]
2 N' w. N2 }- V                                                /* case 0x05:            //保存数据到闹钟 / z4 W  `' ]) {( r# W9 R: E
        if(cflag)
) P+ B$ a2 P' X4 @/ U$ C) H        {: f& W3 A* V/ d9 b2 p' [+ ?
        cflag = 0;
) M0 K% r# V2 D) r' `        PP = 0;, c4 _# Y. y. }! G2 X9 f) j
        WriteCommand(0X0C);   //关光标* |5 F: J) J) h
( r  v( ^0 }9 p- j6 x1 H( W! l
        }) E# J; t! A! {* m' L# q0 c* |
        break; */
* M/ @4 m+ B) `) l6 {+ T                                                default:
- e; A- A6 m9 I5 o* x/ @        break;
8 I! o% y1 y4 F" d# Q                        }
' O% f  w0 \6 |9 y                                while(!cflg)        " d5 |" j5 B; [1 W1 e- U; i
; X8 T1 j* L* J1 @  H8 g  J7 q
! S! F" B/ x4 C3 J& u8 {4 g                                                WriteCommand(0X80+5);   //取消 并关光标                7 H! C; c9 H/ I  n9 |1 ~3 C
                                                WriteData(shuzi[9-baimiao]);- G0 K0 j* t8 N
                                                WriteData(shuzi[9-shimiao]);& Z. q; C# J; ^5 z3 ]! N# J
                                                WriteData(shuzi[9-miao]);& r" u& p8 F* o% S7 s, y
                                                key = Key4Scan();  V6 T$ V( L, \! a2 C7 ^
                                                if(key==4){cflg=1; keyflg=0; }
: b. y6 L0 f9 V% x! m, Z0 X7 H5 B                                                while((9-baimiao)==0&&(9-shimiao==0)&&(9-miao)==0)
! F9 Q; E1 ^/ A                                                {3 {4 e; q4 F+ \. L
        while(keyflg){
' e3 h$ g  ?" M        led3=~led3;
1 r6 o2 I; E$ p        DelayMs(3500); * l3 L! z6 \1 M( J$ w/ ?  K
        key = Key4Scan();7 t: m% I3 w# A0 w
        WriteCommand(0X80+7);. S  A* ~! b) l0 S; m6 t$ _
        WriteData('0');4 w( X! m4 O: u* \5 c% b/ K
) V( o/ w( x) B# V- g/ o/ T        }
* ]2 U/ _6 K. g                                                }
% e  C# s, r. O2 o- v8 |8 e* ]; [/ t. S! l3 F5 A* |5 x1 H
                                }1 T/ S* o6 I- }$ Z) u: D, m1 l/ }
: _3 [7 w4 u0 J3 X6 Z                        WriteCommand(0X01);        5 W8 x1 I. T: S1 Z7 J- f, W3 f( s
                        }, Q9 v; B5 a: V8 I
! u' L" z( ~9 u& h
' |1 t' r. i9 X5 V* \" a$ _. i, D! j3 g7 r. I
! q' F3 j6 R1 u; S0 A{
, I) |# h5 M- x2 n1 c- G8 M                if(key==5)/ d( n+ z7 I7 c! {. T
$ C4 i4 c7 ^7 e5 \9 ^5 a/ V7 ~0 ^# j  {8 k                        WriteCommand(0x01);: Q* h* ^. j& F' O% b# A
- b7 y, V$ R# H) \                        WriteData(shuzi[clock_buf[2]/16]);; d) k( C* g- A5 q" q
                        WriteData(shuzi[clock_buf[2]%16]);  s7 c" ^4 ^* ~% l  b
                        WriteData(':');
. D  Q' v1 k2 D                        WriteData(shuzi[clock_buf[1]/16]);
  C! l: ?$ i8 W# ^                        WriteData(shuzi[clock_buf[1]%16]);
9 n8 I6 f: I0 i9 V" d9 M# f                        delay_ms(2000);
" z, |$ g# s5 p' J2 F. h
; R1 }& j* {6 h* Q! k  u- o7 ~8 f$ b) x( U% R, S4 w3 L
& w4 I% _& H8 C! f                }8 m, m* R+ [6 z" ]5 Q
}1 j: p. C! H- o* r7 P
void clock_delay(void)$ H: L8 g4 G$ O6 h+ T! I8 t
4 w3 B, k" S% F; a% E* b8 ~# K5 |2 S+ g8 \- I8 B: S( d2 p5 k
                if(key==6)
+ S+ W9 z3 N9 n                {  E! h1 ?) f( K7 t& K( N
                        miao=0;1 P: c0 y, }8 l- E1 X" u5 M
                        shimiao=0;7 U+ F! T; y. `. |8 f
                        TR0=0;3 K' ?+ f. v6 L' _" D$ W: d/ j
                        buzeer=1;) A* y# k. F2 R- Q$ i' F/ R  Y
                }+ ], v7 O6 J  ~/ G  s
        if(keyflg==6)
& E' ?1 ~# G0 ]$ u$ _% U                        {
( l& J- K6 i) C; m# s- G9 W                                        if(miao==9)
" E/ N) n) g8 W2 X4 Y0 C& a                                {0 c0 I" B- ~/ k6 U4 n* e
+ `+ k! V' N# y# T        //buzeer=0;1 b3 Q, f- b2 h" w) \/ e# H$ q
                                                        TR0=1;
+ @) o  r2 ^' k: Z0 _' E3 i% m1 Z1 [: l                                                        buzeer_music();7 s, [8 [' p! ~; d2 D* H
" z1 i4 ]5 t& s0 W                        }        + q! V# m' N7 i/ R# f5 R# ]
* R0 A# K! F+ j' Z  i
}7 H5 o/ I1 F* m! d2 \* K/ Y! t
( J- R; y  o  J) I2 a) d/ y- v0 Lvoid start(void)! x/ F, p1 A- [5 ]
+ ^6 v" }5 s/ @2 R! ^* ]1 O3 y- H+ V
0 d2 Y6 v( H- J# k: n; c
" I6 n$ U( I7 p1 }/ Q                WriteCommand(0x80+3);
6 Y7 ~4 E' G; ]' R( N( @, }# `; R; Q1 I) R2 s
          WriteData('3');
" Q  T" m' {; {% g! }& }+ p4 k. |                WriteData('-');7 Q$ j% _( T; j/ P& k. I& `
          WriteData('0');8 }# s' U# G. d
                WriteData('5');# t2 [' z" f! G* I+ ]0 N2 M
                WriteData('-');: p  Q" g% I5 e' W. H9 q
                WriteData('0');
& `) j  N* M. Q- C8 @$ A7 R                WriteData('6');
8 S. q1 C. X% |. @. [* g! W& A7 k/ Q2 ^5 r
' Y! {! n3 V7 e! b3 Z
          led2=1;
$ t7 x8 z3 G* b5 Z  C                delay_ms(1000);         ; n5 i2 V4 k7 A1 x" v
% u& O8 }8 L$ j) t
- N8 m9 i& o/ `( A…………限于本文篇幅 余下代码请从论坛下载附件…………
9 U5 h. |* N4 A# Y, j: G  X- X4 L3 Y( I2 \5 r9 v% x- k0 a
游客,如果您要查看本帖隐藏内容请回复
0 u" [% |: L# o& a$ D4 T
发表于 2019-1-3 15:36 | 只看该作者
看看楼主的代码
GMT+8, 2025-10-8 19:43 , Processed in 0.234375 second(s), 26 queries , Gzip On.
