查看: 2305|回复: 4
这个名字在哪里改啊?无法生成网表
发表于 2018-10-29 10:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
#1   ERROR(SPMHNI-176): Device library error detected.
- }$ E( G2 ^' [' d% N6 [" F2 C" X0 K/ @) t( |$ r
ERROR(SPMHNI-189): Problems with the name of device 'MAG COMMONCHOKE_4_L2012_NC/TEF2012A4101MT': 'Name is too long.'." W1 ]* o/ ]) ~2 f8 Z) f
1 b  q; Y+ ~3 F" b- |( u1 L* J) qERROR(SPMHNI-170): Device 'MAG COMMONCHOKE_4_L2012_NC/TEF2' has library errors. Unable to transfer to allegro.
/ u; v" M5 h' |- p/ O8 n3 V
' r: T6 `2 |( f& M  r- l#2   ERROR(SPMHNI-176): Device library error detected.
6 q2 B% J/ C! e6 L8 {6 m1 r2 @
6 a& ?. o2 s! H; A; Q& F1 H7 CERROR(SPMHNI-189): Problems with the name of device 'MAG COMMONCHOKE_4_L2012_NC/TEF2012A': 'Name is too long.'.* C# o( v: I( ?; S  I& g4 x
: l( O- e' B) l: v5 `# t: LERROR(SPMHNI-170): Device 'MAG COMMONCHOKE_4_L2012_NC/TEF2' has library errors. Unable to transfer to Allegro.$ o+ |' G2 v1 x3 p6 I: K% @
! H2 ]1 R; D; U* z
#3   ERROR(SPMHNI-176): Device library error detected.
9 a1 A5 l6 c6 u' R7 L+ s+ Q; }/ I. _9 u& K' y5 G
ERROR(SPMHNI-189): Problems with the name of device 'MAG COMMONCHOKE_4_L2012_NC/TEF2012': 'Name is too long.'.: r) F9 V6 b! S
3 R' {) l: C5 R; J, A
ERROR(SPMHNI-170): Device 'MAG COMMONCHOKE_4_L2012_NC/TEF2' has library errors. Unable to transfer to Allegro.( O- Z9 Z$ [9 u) w) Q5 P7 E
( n3 _/ i* l$ V' S  k2 Z" k#4   ERROR(SPMHNI-176): Device library error detected.
  K9 v3 [5 S) ~* X+ F9 {0 Q7 K
. K0 i) {$ O6 u! O/ d4 }  R  e- jERROR(SPMHNI-189): Problems with the name of device 'BGA280_0_BGA282P0_80B14X14H1_30_R16': 'Name is too long.'.+ R- C6 O% _( }5 x; i
* h8 R: t: g( ?6 n9 I4 w! QERROR(SPMHNI-170): Device 'BGA280_0_BGA282P0_80B14X14H1_30' has library errors. Unable to transfer to Allegro.
" Y: T/ k$ R% ^, c1 }7 `0 d5 c8 z: E; v, T: Q. {
#5   ERROR(SPMHNI-176): Device library error detected.
8 @' n- _  f; ]) E2 W( {7 ~4 A( L( |9 F0 {2 L6 T+ X
ERROR(SPMHNI-189): Problems with the name of device 'EMMC_V50_BGA-12X16-169P-0_5_EMMC_FLASH': 'Name is too long.'.
0 K; f  Q- ]3 y, `% P& a: H' Z8 e2 k8 w; O
ERROR(SPMHNI-170): Device 'EMMC_V50_BGA-12X16-169P-0_5_EMM' has library errors. Unable to transfer to Allegro.
* x2 r, @" j! i. J5 W- }* R8 g6 N/ F4 K
#6   ERROR(SPMHNI-176): Device library error detected.3 @1 @7 w6 H2 `; h: K+ O: o" e3 H
0 c% E: \) @# K* @2 q$ d+ oERROR(SPMHNI-189): Problems with the name of device 'DDR3_1_FBGA96C80P9X13_DDR3-FBGA96': 'Name is too long.'.; w. M5 `3 q0 A
6 c2 y! p  |4 v1 u# T" ^ERROR(SPMHNI-170): Device 'DDR3_1_FBGA96C80P9X13_DDR3-FBGA' has library errors. Unable to transfer to Allegro.
8 U8 q. T2 x6 m1 b9 Q& l3 V" E# A6 }6 g* \, [7 ]9 S4 F
#7   ERROR(SPMHNI-176): Device library error detected.: N4 d" C* A* \, x+ C4 d' m7 _
# B  w& t2 e( _
ERROR(SPMHNI-189): Problems with the name of device 'CRYSTAL-4_2_DM9621_QFN48_DM9621/A': 'Name is too long.'.
2 }7 _" j+ k- A' x. N- T% |) h: h
2 X4 ^4 [! B& }ERROR(SPMHNI-170): Device 'CRYSTAL-4_2_DM9621_QFN48_DM9621' has library errors. Unable to transfer to Allegro.
, T$ B3 W9 P/ x" X  O4 R, d2 V+ l6 V( n
#8   ERROR(SPMHNI-176): Device library error detected.
9 ]4 `9 z; |( K& f
) F. Y( _5 W  M3 QERROR(SPMHNI-189): Problems with the name of device 'WPM4005_11_DFN8P0_65B2_00X2_00H0_WPM1481': 'Name is too long.'.# N& g& h7 I3 _, v& j2 e  @2 C' s
# n. [. d7 z. {3 M1 r& ^ERROR(SPMHNI-170): Device 'WPM4005_11_DFN8P0_65B2_00X2_00H' has library errors. Unable to transfer to Allegro.
3 G+ d# K2 a' z1 \
5 j/ W9 \) D1 p# `' \#9   ERROR(SPMHNI-176): Device library error detected.
& P7 v/ @# A7 [  \* W2 H* ]8 h# V4 _- ]( H3 T* E
ERROR(SPMHNI-189): Problems with the name of device 'MAG COMMONCHOKE_1_ML0302_NC/MCF08062': 'Name is too long.'.
; v  i! x: R  `9 z& f/ V
# B, N2 ^% P& H6 g; _ERROR(SPMHNI-170): Device 'MAG COMMONCHOKE_1_ML0302_NC/MCF' has library errors. Unable to trans;?X粽?'N?* E) F9 j, [+ H- M
fer to Allegro.
% z. Y2 Y9 ]& k- |# ~% M! g# }. o3 }3 c: L" U% U( [
------ Library Paths ------
. b. z7 q  E) j2 B: Z& ~+ TMODULEPATH =  .
1 Y" `* b  w. |  K  `7 x           C:/cadence/SPB_16.6/share/local/pcb/modules . _  k2 D) a1 j
2 T% F7 M  z$ GPSMPATH =  .
/ f: i+ q' C" y; s. f6 R3 H( S           symbols
/ Q$ v2 I& J; e- f! L           ..
6 S* z% _3 Y/ i7 l  y% o           ../symbols
, A% e9 w3 w+ I+ ~+ B% [           C:/Cadence/SPB_16.6/share/local/pcb/symbols ( b+ }( B% Q. R; A4 m
           C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols
: y+ b8 M1 }. D6 }# |           C:/Cadence/SPB_16.6/share/pcb/allegrolib/symbols 8 `% S) q) ?  E  P
           D:/project/mylibs/ 0 h; g. `( }4 X0 p9 T% k
" E. {$ V4 ?/ ^- z; o# d7 w. KPADPATH =  . ' |4 q- |/ S- R5 P6 S1 B# X
           symbols
' r( n$ h( _( S! G           ..
. M+ {% @/ o5 x# o/ m  s0 Q' [           ../symbols   ~# z% u% W4 u  d5 ~, S
           C:/Cadence/SPB_16.6/share/local/pcb/padstacks
( G; f" y. L6 O0 m) W5 @) s           C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols / h( V3 `$ o( F- f2 c
           C:/Cadence/SPB_16.6/share/pcb/allegrolib/symbols . A5 W/ `, v" [+ e( j1 H
           D:/project/mylibs/
2 Q/ z' F2 }/ M) M, [0 x, V  e' u3 K/ x& o3 A1 e
, }1 x- ?* j( x8 A! j3 |------ Summary Statistics ------, y; m# U: B1 D7 Y
6 b/ A7 z' d: R7 q
8 Q" z( o% T! g2 j/ f7 [#10  Run stopped because errors were detected  o( ]0 N* p) w
2 X  _3 e7 Y; [  [: {
netrev run on Oct 29 10:20:41 2018! W; b, V" M) ]$ N
   DESIGN NAME : 'R16_CORE1024'9 S" s* {# |4 D+ L$ F9 K- [2 B
   PACKAGING ON Sep 10 2012 04:46:09
. M) b$ ]. d. f! C; w% b
+ k7 ~: S' S! e4 @9 d- o1 p   COMPILE 'logic'
3 z  \* ~: t0 G   CHECK_PIN_NAMES OFF& u7 R; J1 y2 H
   CROSS_REFERENCE OFF
/ c" U2 Y3 m5 _- w   FEEDBACK OFF
7 ^  ^7 b2 A; A3 k8 h& y, z   INCREMENTAL OFF
$ x/ P6 T: `; b* s   INTERFACE_TYPE PHYSICAL% }/ y# x& b! D# M( G
   MAX_ERRORS 500
0 S2 {2 Z& L/ `% W( h, Z( V; ^   MERGE_MINIMUM 5: x$ P9 F, i3 ^4 H; T
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
# z4 U* u+ x' S8 {; S% q   NET_NAME_LENGTH 24; T, n' `: j( g2 ~0 V+ u( S
   OVERSIGHTS ON
, L& x  N. f, y" s   REPLACE_CHECK OFF
* H5 y& ~0 ^( `/ x+ }; h" x! X; Y7 s   SINGLE_NODE_NETS ON* j! k- g) Y3 ^5 I; X
   SPLIT_MINIMUM 0
  U1 C$ l( x9 B. ^   SUPPRESS   20% q1 N. q' A+ \7 r1 `, e  |3 i
   WARNINGS ON
" p) T3 q  {3 b- q
" r4 Y* e3 @1 a, v* H; C" z 10 errors detected
2 e% z2 r  i0 s& S- I! x/ l; R No oversight detected; Y) s0 D2 b9 ~3 f1 l6 r2 j) m1 T
No warning detected' G3 n3 n7 P4 F' [& A) }! E
$ _: X; P' |: X' {cpu time      0:00:31: f+ q0 M( l- g8 f
elapsed time  0:00:00
7 {+ e8 ~8 k! l9 b8 i8 r5 c; q) ^3 E9 J) I0 v+ C" o
. a2 Z3 i- C, e; w6 n5 c7 o# _$ C$ d
 楼主| 发表于 2018-10-29 10:34 | 只看该作者
点开器件,改掉VALUE值,有的可以,很多都不可以,这个PART NAME在哪里?怎么会生成这么奇怪的东西?
发表于 2018-10-29 13:27 | 只看该作者
* _) @& j- K# q% g% g8 K, n在导网表时,在这里设置一下,就不报错了
- w6 ~5 i7 w2 l* z7 g& |) c
谢谢试过了,可以生成网表不报错,后面导aalegro又出现同样的错误  详情 回复 发表于 2018-10-29 13:30
 楼主| 发表于 2018-10-29 13:30 | 只看该作者
蝶语 发表于 2018-10-29 13:277 F: F; M: B# q% K/ f5 P* r, C
在导网表时,在这里设置一下,就不报错了
7 Y5 Y9 [# q: R; \) o" D' w- y
谢谢试过了,可以生成网表不报错,后面导aalegro又出现同样的错误# W$ T. {7 {( C
 楼主| 发表于 2018-10-29 13:32 | 只看该作者
修改方法:$ G2 a' D# a( w# F
- h2 H# u  m( j4 ^. f        明白了当库中的名称与part下方的名字不一致时软件的识别partname的方式(库名_封装_下方的名)后,很快得到解决:将库中的name与part下方的name改一致为最好的方法,当然有时识别的名字没超过31时也不会报错了  n+ j: ~' J5 y( Q- t5 S
# S% w' }  ?- \$ u; A
参考这个,回过头来改PCB封装名和value值,因为库不会操作
GMT+8, 2025-11-6 09:52 , Processed in 0.171875 second(s), 30 queries , Gzip On.
