查看: 853|回复: 1
变压器PSpice模型
发表于 2018-10-24 14:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
变压器Pspice模型
等效电路变压器模型
*Transformer Subcircuit Parameters
*RATIO = Turns ratio= Secondary/Primary
*RP    = Primary DC resistance
*RS    = Secondary DC resistance
*LEAK  = Leakage inductance
*MAG   = Magnetizing inductance
*Generic Transformer
*dw: 2-8-99 corrected VISRC polarity and FCTRL configuration
*Connections:
*             Pri+
*             | Pri-
*             | | Sec+
*             | | | Sec-
.SUBCKT TRANS 1 2 3 4 PARAMS: RATIO="1" RP="0".1 RS="0".1 LEAK="1u" MAG="1k"
VISRC   4 9 0V
FCTRL   5 2 VISRC {RATIO}
EVCVS   8 9 5 2 {RATIO}
RPRI    1 7 {RP}
RSEC    8 3 {RS}
LLEAK   7 5 {LEAK}
LMAGNET 2 5 {MAG}
.ENDS TRANS
等价于用K_Line把两个电感关联起来.
. _( h- _' {: S, S9 D# I
CT中心抽头输出变压器模型
*TRANSCT:Transformer Subcircuit Parameters
*RATIO = Turns ratio (= Secondary/Primary)
*5:1 Centre-Tapped Transformer
*Connections:
*               Pri+
*               | Pri-
*               | | Sec+
*               | | | SecCT
*               | | | | Sec-
.SUBCKT 5TO1CT  1 2 3 4 5 PARAMS: RATIO="0".2 RP="0".1 RS="0".1 LEAK="1u" MAG="1u"
RPRI  1 7 {RP}
LLEAK 7 10 {LEAK}
LMAGNET 6 10 {MAG}
VSEC1 9 4 DC 0V
FSEC1 6 2 VSEC1 {(RATIO/2)}
ESEC1 8 9 10 2 {(RATIO/2)}
RSEC1  8 3 {(RS/2)}
VSEC2 12 5 DC 0V
FSEC2 6 2 VSEC2 {(RATIO/2)}
ESEC2 11 12 10 2 {(RATIO/2)}
RSEC2 11 4 {(RS/2)}
.ENDS 5TO1CT
, L3 P. c8 i+ O$ @* K' q2 q
GMT+8, 2025-10-1 04:36 , Processed in 0.125000 second(s), 26 queries , Gzip On.
