查看: 32850|回复: 383
Cadence 17.2 Hotfix_SPB17.20.048_wint_1of1
发表于 2018-10-22 13:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
% [: d) w8 v2 S# _% a& l7 Q+ Z0 q, z& i* q
cadence 17.2  Hotfix_SPB17.20.048_wint_1of1补丁下载链接!
9 ~5 e, m1 f$ ?( ~0 e, u
; G( i6 p& r8 e- {) q2 o5 T听说软件在3D显示,模型加在,约束管理器硬软板子规则,数据文件对象更新上都有了更新。具体得自己去了解!
- x6 E  _: F7 I& z: U$ W; ^: M) }( B+ o
. d' l/ X3 Z- F5 {! l
& g  r2 m9 E  Y" p2 _* U
游客,如果您要查看本帖隐藏内容请回复
6 |1 g0 x. l, l$ a" @! B  t: R
+ j' H0 x$ G$ Y' E9 E4 c) y
参与人数 1威望 +5 收起 理由
gleefly + 5
    郁闷
    2023-9-28 15:01
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    推荐
    发表于 2018-10-22 14:22 | 只看该作者
    2 K+ e5 b! I- X; j
    9 ?0 E6 Q% q6 o# Q感谢分享,能共享一下都更新了哪些内容吗9 u  o- }6 K& E1 U) m2 H- n6 t! j
    5 Y- |. N. V: x: P: L3 U- U+ G% z1 D0 q3 ]0 ^
    ) {# K* K0 f! X9 L9 L2 q% `% UFixed CCRs: SPB 17.2 HF048
    6 t  K: `$ z4 I- V2 X# _10-13-2018
    2 ?# x& C" V% X- p5 B========================================================================================================================================================
    , C8 z5 q, B9 v+ B0 g9 v( [5 dCCRID   Product            ProductLevel2 Title
    + D) a6 v& c. W========================================================================================================================================================6 t9 s) _' Q! Y) }
    1913039 ADW                ADWSERVER     EDM Library Server exits with error message on starting library server service7 D) T& v6 o2 X& H' \0 [
    1709155 ADW                COMPONENT_BRO Search query does not search for all the parts in the library
    " A6 O" s+ [' d! n# s/ q' c4 A1827231 ADW                COMPONENT_BRO Clicking the 'a' key in Part Manager launched from DE-HDL crashes DE-HDL
    - T+ `" ^6 F- U; r+ p1903818 ADW                COMPONENT_BRO Parts that have comment_body do not display version' c! N, d9 C) ]( k& K: S: G  J4 V6 |
    1917961 ADW                COMPONENT_BRO Component Browser PPL column values are truncated when selecting the top '*' filter3 p8 K  _2 u/ d& k# r
    1938172 ADW                COMPONENT_BRO Symbol version with COMMENT_BODY set to TRUE cannot be instantiated% z6 q! H9 Q  t/ V# O7 t7 _
    1914103 ADW                CONF          conf creates incorrect path in fetch_dump.ini when MLR is enabled.+ D0 T; b6 \* C; v( M5 m0 ]) S: b
    1911422 ADW                DBADMIN       RuleP101 - PACK_TYPE check against schematic model not working
    ) i2 }2 Z1 h: h1926691 ADW                DBEDITOR      Adding a new classification and immediately trying to delete it results in errors" B6 ~- ^& z9 a% l* Z
    1926694 ADW                DBEDITOR      Renaming a classification and then renaming it back to the original results in error8 ~# u4 T' v7 ^: P1 a
    1934870 ADW                DBEDITOR      Adding a new classification and immediately trying to delete it results in errors
    & O! k7 B5 a- ]1872387 ADW                DSN_MIGRATION Design Migration does not cache all used parts into flatlib/part_table.ptf3 ~" k# A) H0 W
    1254292 ADW                FLOW_MGR      Flow Manager Open Last Project should open last project closed! A! ?  F$ e& O6 @7 |9 v) _2 J
    1281817 ADW                FLOW_MGR      '-proj' switch in 'pcbdw_fm' does not work; launches Flow Manager without loading any project# v. k5 `1 l! T  r& n
    1727286 ADW                FLOW_MGR      Product options for PCB SI and Power Integrity are incorrect in the flow and tool launchers
    7 l% ^& M& |& \1 h2 C* q1875498 ADW                FLOW_MGR      EDM fails to open or becomes unresponsive.; f6 y0 t; B% k. f( \
    1879386 ADW                FLOW_MGR      Unable to access COS with the default Firefox version in the 17.2 installation! K  z; d: [! \6 I# c/ g
    1922541 ADW                FLOW_MGR      Warning message for unavailability of Java version appears on opening a project on Linux& y1 N+ F8 P  K: X8 S0 d0 E
    1945451 ADW                FLOW_MGR      Checklist does not work with two-byte characters
    4 h( t5 ~. o+ E  V! V, @/ \1956213 ADW                FLOW_MGR      Not able to invoke Flow Manager on the remote system
    5 Z8 Y$ X) c: {/ ]+ S, j& u" G1892285 ADW                LIBDISTRIBUTI Symbol not consistently available in 16.6 ADW Library
    $ \! i% m2 _* U" `  j* V6 f1961731 ADW                LIBIMPORT     libimport fails to create tar for two Capture models
    + }1 U8 R, B, ~9 F1836620 ADW                LRM           Library Revision Manager crashes on clicking Help( U) e0 Z" u: y: f! E
    1961845 ADW                PART_BROWSER  Error regarding environment variable9 k  m1 A) C+ L7 P8 S/ M- w$ T# K0 Q
    1890782 ADW                TDA           Launching TDO dashboard connected to PLM returns a license error
    3 R$ {& {8 Y7 d4 g8 T2 o1980914 ADW                TDA           Cannot start Design Entry HDL and Component Browser in a TDO design
    ' R7 ^1 j7 A. I7 q5 j; [6 I# R1833750 ALLEGRO_EDITOR     3D_CANVAS     Soldermask Text is not shown in 3D Canvas
    # M: R+ ]* R* M/ ~1891230 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas Viewer not bending PCB with proper radius$ z1 R, y: f3 h* u8 s
    1913338 ALLEGRO_EDITOR     3D_CANVAS     STEP models missing from exported .stp file
    " S( N/ }' l+ Q- l' y9 J1927507 ALLEGRO_EDITOR     3D_CANVAS     Get Error: All bend operations are disabled due to licensing and/or DLL installation issues on invoking 3D Canvas& ?& A6 p4 W, m: d! d
    1931508 ALLEGRO_EDITOR     3D_CANVAS     Place Bound Bottom is displayed on Top, when dra is opened in 3D Canvas
    4 J# q4 Z* Z8 y' d: x, p. N- K1943060 ALLEGRO_EDITOR     3D_CANVAS     Placebound bottom is not showing correctly.
    ) s7 E6 Q* N7 Z8 S9 A3 q1950099 ALLEGRO_EDITOR     3D_CANVAS     Place Bound Bottom is displayed on Top, when dra is opened in 3D Canvas
    ; t# W0 _1 M$ D) ~1988307 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas error: All bend operations are disabled due to licensing and/or DLL installation
    # C% n4 M4 o; [+ E' d1923585 ALLEGRO_EDITOR     ARTWORK       Additional unwanted subclasses appear in film control when a new film definition is added  ?" [/ e+ P0 y+ N8 }( ]( r
    1944079 ALLEGRO_EDITOR     COLOR         Export of Board Parameters (Net Colors) does not contain entries for nets with spaces' Q# W9 {* ^* ?; R" N' }
    1856320 ALLEGRO_EDITOR     DATABASE      Donut pad fails to connect with cross-hatched shape in full contact thermal mode, despite hatch overlap of donut.! C( S! W+ s0 O! f
    1912313 ALLEGRO_EDITOR     DATABASE      Database corrupted during background process6 I: n  T2 |5 _. \
    1913344 ALLEGRO_EDITOR     DATABASE      When changing accuracy of design, the thermal relief for donut pad's outer pad connects to inner pad
    5 ?2 J# t1 X( m2 H( [5 u8 K1914470 ALLEGRO_EDITOR     DATABASE      Release 17.2-2016: export libraries command does not inherit posi/nega information
    ! R, d5 I1 c3 W) G) D: f1932086 ALLEGRO_EDITOR     DATABASE      Unable to resolve DBDoctor error' I: n9 D, p! i4 |% K9 w$ N9 w  n
    1963932 ALLEGRO_EDITOR     DATABASE      DB Doctor is not recognizing placed parts and showing them as unplaced.( x( c/ p& T, i% K# M- T# ]
    1987735 ALLEGRO_EDITOR     DATABASE      Interior sub-lamination backdrill holes are displayed with Top Soldermask pads where backdrill does not exist& k7 T1 k  s5 B
    1977622 ALLEGRO_EDITOR     DFM           Not able to add value '5' or multiples of 5 in in DFF constraints for maximum stacked via count
    4 N9 `; B, ]/ i0 M4 h+ o1892809 ALLEGRO_EDITOR     DRC_CONSTR    NODRC_ETCH_OUTSIDE_KEEPIN property is not working on TEXT$ [* S( c0 v) P; \7 _" s
    1894765 ALLEGRO_EDITOR     DRC_CONSTR    DRC for no_drc_component_board_overlap is not created if the place bound is outside Place Keepin4 B+ r2 e8 Q( \
    1896627 ALLEGRO_EDITOR     DRC_CONSTR    Moving components takes long time while doing placement' \3 x$ N2 H$ B8 a, }
    1914591 ALLEGRO_EDITOR     DRC_CONSTR    Spacing constraints for Mechanical to Hole shows resolved constraints different from the actual air-gap/space
    # W- |- j) S3 t9 }; U1 O. \1956468 ALLEGRO_EDITOR     DRC_CONSTR    DRC getting generated while moving the uvia and getting removed after updating DRC.
    & W5 ~5 z; x* j( t1884149 ALLEGRO_EDITOR     EDIT_ETCH     Arced Routing of differential pair creates unexpected arc radii
    ; h8 L9 N. B+ w5 o: o: f+ N( w1891985 ALLEGRO_EDITOR     EDIT_ETCH     Etch edit does not follow the constraints
    9 e1 j0 u3 J2 U# y/ j; K3 Y; @1860056 ALLEGRO_EDITOR     GRAPHICS      PCB Editor crashes on right-click after choosing the Move command$ f) d, u7 p) c/ w# C' C, o1 L4 Y
    1860723 ALLEGRO_EDITOR     GRAPHICS      APD crashes on right-click when using the Move command2 n) s1 n9 o( j9 w# `( O; f" A; |
    1870058 ALLEGRO_EDITOR     GRAPHICS      PCB Editor crashes when using Place Manual -H command
    , z' W- Z1 p9 C) N7 m+ x1930282 ALLEGRO_EDITOR     GRAPHICS      PCB Editor crashes on executing axlVisibleDesign(nil) from allegro.ilinit1 F5 S- s! x4 u& q. r
    1882813 ALLEGRO_EDITOR     INTERACTIV    Unable to set the end point with 'snap pick to' when adding an arc
    9 ?* o0 p2 @2 {' P, x2 P1884725 ALLEGRO_EDITOR     INTERACTIV    Edit and Move vertex operation not working as desired
    2 v' p2 G6 |6 J, s1902359 ALLEGRO_EDITOR     INTERACTIV    Connector boundary remains ON for a layer if visibility toggles in Shape Edit application mode/ \. e, N9 n8 f; u/ A6 @
    1909004 ALLEGRO_EDITOR     INTERACTIV    Parameter description showing wrong for Padless Holes under Design Parameter Editor1 s9 g. p# E' O$ M, c3 W# `3 L
    1912055 ALLEGRO_EDITOR     INTERACTIV    PCB Editor crashes on Delete By Query - AutoSilkscreen - Find By Query! Z! Q3 h: w6 O- i  o
    1924503 ALLEGRO_EDITOR     INTERACTIV    Editing shape causes PCB Editor to crash+ i' L  V$ V- ^4 \% B$ @
    1929614 ALLEGRO_EDITOR     INTERACTIV    Unable to Place Via Array when Staggered ring is selected in Global Ring Parameters.6 N8 G# B! j  Z0 c
    1938523 ALLEGRO_EDITOR     INTERACTIV    Change Shape Type message is same for dynamic and static shapes
    7 c! u7 S" r" o1940827 ALLEGRO_EDITOR     INTERACTIV    Irrelevant/incorrect warning message when doing Edit- Change on Clines- N! I9 f, f- ^8 P: B* p$ k8 z+ V: \
    1872653 ALLEGRO_EDITOR     INTERFACES    DXF export shows embedded layers in the layer configuration file
    ! b; c, z6 p$ r2 E1873971 ALLEGRO_EDITOR     INTERFACES    IDX proposal comments are not shown when importing the IDX file into Allegro9 n% t6 j; t2 U9 Q  E( U! J
    1892172 ALLEGRO_EDITOR     INTERFACES    STEP Package Mapping form needs to be larger
    ( e4 x" j: \: W; X! d: b* X1893311 ALLEGRO_EDITOR     INTERFACES    A line became two lines after import dxf, [0 f8 q9 Y# {
    1937816 ALLEGRO_EDITOR     INTERFACES    Unit as % in Property Definition not supported by SubDrawing
    # C1 l$ c$ [5 X9 q- M# d1 s1973084 ALLEGRO_EDITOR     INTERFACES    Physical library not placed if design and IDF database not matched while running: D: h7 G+ y2 V( X) [
    1987526 ALLEGRO_EDITOR     INTERFACES    IDX import Fails to recognize SURFACE FINISHES Class
    0 j7 g- }1 Q* I9 ^1872856 ALLEGRO_EDITOR     IN_DESIGN_ANA Message displayed when creating directed groups needs to be improved
    5 M0 W+ U. P; T; t, v3 J1900832 ALLEGRO_EDITOR     IN_DESIGN_ANA RTP: Return Path DRC does not check circle void correctly
    , y; v# k# C  W" K$ e8 J  Q/ [1935641 ALLEGRO_EDITOR     IN_DESIGN_ANA Return path DRC crashes PCB Editor
    ( e7 P5 S) g- d+ _3 ]1649465 ALLEGRO_EDITOR     MANUFACT      Manufacturing options are not visible in OrCAD PCB Designer legacy menu
    + _' z5 Z1 V4 j1873417 ALLEGRO_EDITOR     MANUFACT      Autosilk fails to add line information. Only part of the line is getting copied to the autosilk layer.
    # a% r+ T/ s( }5 f0 J  t7 m1911596 ALLEGRO_EDITOR     MANUFACT      Documentation Editor drill chart shows two different rows for the same slot.& M+ p) j! \. ^8 V+ t
    1937721 ALLEGRO_EDITOR     MANUFACT      Drill figure character scaled up in GERBER: e. a: Q2 K) y+ C3 x* \+ H
    1957768 ALLEGRO_EDITOR     MANUFACT      Import IPC2581 on cross-section does not import line width and impedance2 [, L  R, |. R+ ~
    1969363 ALLEGRO_EDITOR     MANUFACT      Pressfit connector backdrill depth is considering MNC Layer
    1 g" N3 a; ?1 ^! I0 E1891102 ALLEGRO_EDITOR     MULTI_USER    Rejected by server error messages when using Symphony Team Design
    # W5 q+ O# B9 _2 ~1928082 ALLEGRO_EDITOR     MULTI_USER    Unknown SubClass BOUNDARY/MULTI_USER_LOCK automatically added when defining Artwork Output.
    / J# I* d+ Z6 r. e1976705 ALLEGRO_EDITOR     MULTI_USER    Symphony client disconnects from server without any notification - despite ping mechanism
    * C  V6 e% y! i2 m3 O( L1972554 ALLEGRO_EDITOR     NC            Mill symbol moved from Nclegend-slots-1-2 to Nclegend-1-2 subclass if nc_param.txt not present: `  [1 V! Y( Y
    1914412 ALLEGRO_EDITOR     OTHER         Autosilk lines do not clear padstacks that are not rectangular0 C% t/ Q# P& I/ f1 ~
    1921933 ALLEGRO_EDITOR     PAD_EDITOR    column clearance cannot reset to 0 in padstack editor5 X. |5 `% S; W  F
    1922234 ALLEGRO_EDITOR     PAD_EDITOR    DBDoctor reports 'illegal value for pad' and does not fix when zero corner radius for Rounded Rectangle is defined
    9 _, F2 |4 V- m! K1932183 ALLEGRO_EDITOR     PAD_EDITOR    Drill Symbol information not exported in Padstack XML if Drill Figure in none
    4 b5 E9 e! ^" O1934880 ALLEGRO_EDITOR     PAD_EDITOR    Shapes with offsets not displaying properly in Padstack Editor views
    1 m$ I& v# ]1 L- P) v7 z* ?1813270 ALLEGRO_EDITOR     PLACEMENT     When a place replicate module is updated, the vias used in thermal pad are removed1 ~* G* F, X& s: ^
    1840275 ALLEGRO_EDITOR     PLACEMENT     Placing component with the Mirror option causing display problems! Y" m3 v1 L6 i+ }, i
    1854099 ALLEGRO_EDITOR     PLACEMENT     Align components to zero spacing causing mirrored components to overlap7 D- E" A1 D, l7 H3 [
    1854696 ALLEGRO_EDITOR     PLACEMENT     Pins shown incorrectly when the Alt Symbol and Mirror commands used consecutively% z& A( C$ a7 S( Y
    1862863 ALLEGRO_EDITOR     PLACEMENT     Too many messages in the command window when symbol does not support mirroring
    . z0 J8 ^: y- a7 @, h1909857 ALLEGRO_EDITOR     PLACEMENT     Using Mirror with Alt Symbol placement displays incorrect graphics
    " A3 b/ x: H& D! k1917128 ALLEGRO_EDITOR     PLACEMENT     Place - Autoplace - Room when all the components of the room are placed on board causing crash; ^5 I9 J* e& q
    1925144 ALLEGRO_EDITOR     PLACEMENT     PCB Editor stops responding on using the Autoplace - Room command
    0 S0 H% P$ p' N! `$ I3 n$ o/ n  S# b1961509 ALLEGRO_EDITOR     PLACEMENT     PCB Editor crashes on choosing Place - Autoplace -Room) I- a4 Q" m- O; l; T$ o
    1930669 ALLEGRO_EDITOR     REPORTS       Net 'VSS' not included in the Etch Length By Pin Pair Report
    * A! y* M/ s& Y  N7 r1982934 ALLEGRO_EDITOR     SCRIPTS       PCB Editor stops responding if Generate button is used to create script from journal file7 y/ f* N- p: X
    1337346 ALLEGRO_EDITOR     SHAPE         Shape Check is generating problem point errors that seem unnecessary* h. ^! }( c& B% V" ^
    1396692 ALLEGRO_EDITOR     SHAPE         Zcopy with expansion not following board outline9 C3 V/ k0 G# u. |/ u7 `9 P
    1902001 ALLEGRO_EDITOR     SHAPE         Shape behaving differently across hotfixes) r6 f$ K: O5 p/ f+ j9 W  o8 \4 j
    1921287 ALLEGRO_EDITOR     SHAPE         3D canvas is showing some stray objects4 F* p4 j( o7 S: L0 O( c5 \2 C$ n; [, ~
    1936482 ALLEGRO_EDITOR     SHAPE         Option for Fillet to not obey NO_SHAPE_CONNECT Property- h4 l% v. ]. O3 R4 @
    1943899 ALLEGRO_EDITOR     SHAPE         Only one Shape to Route Keep In DRC in release 17.2-2016 compared to two in release 16.6
    ' }- F7 G1 u0 D6 ?1944041 ALLEGRO_EDITOR     SHAPE         shape_rki_autoclip makes shape voiding incorrect* U7 w0 N  ]: d. H. q
    1947675 ALLEGRO_EDITOR     SHAPE         Shape void error when dv_squarecorners is enabled+ s0 T- m, A# h: z5 T) @* x
    1949250 ALLEGRO_EDITOR     SHAPE         Shapes are filled even after raising and lowering priority/ z! h2 K! G* U( D5 `* e8 s7 N1 O
    1984526 ALLEGRO_EDITOR     SHAPE         Same net shape voided is inconsistent with respect to vias
    ) Y) o( @8 \) [$ K2 l# Y1984955 ALLEGRO_EDITOR     SHAPE         Dynamic shape creating same net spacing drcs.
    : u2 u. Z" \) t8 y+ Q, D1839147 ALLEGRO_EDITOR     SKILL         axlDBGetLength() reports that the segments of a filled rectangle shape are invalid database ID arguments- e% ~; A( L4 P5 O/ G
    1882776 ALLEGRO_EDITOR     SKILL         SKILL documentation for axlIsBetween() is wrong
    ( s1 P- U3 }# k; C5 |1882882 ALLEGRO_EDITOR     SKILL         Example for axlMathConstants needs correction in Allegro SKILL Reference+ `5 x/ i9 T* p/ Z; P* \6 [2 m1 R
    1902712 ALLEGRO_EDITOR     SKILL         axlAltSymbolReplace moves symbol to the top of design while replacing9 e! B2 O( b2 c0 q+ a& c
    1906329 ALLEGRO_EDITOR     SYMBOL        Mechanical Pin to Conductor property set on a pin in a symbol does not pass to the board( a% j- u  ^4 O) a6 x" j
    1911343 ALLEGRO_EDITOR     UI_FORMS      Global Visibility not turning all layers off) S; a2 `& a$ }8 F* s8 i
    1985584 ALLEGRO_EDITOR     UI_FORMS      Import logic changes the Current Working Directory0 [8 Q  f7 j) c& R$ x$ ]1 G' S
    1987829 ALLEGRO_EDITOR     UI_FORMS      Import logic changes the current working directory. G0 ]% ~+ {5 A9 n& b% v
    1992722 ALLEGRO_EDITOR     UI_FORMS      After netlist import process, the board file is changing its current path9 |$ s9 m8 W( F7 C- v+ J6 V
    1697506 ALLEGRO_EDITOR     UI_GENERAL    Stroke Editor working in OrCAD PCB Editor of release 16.6 does not work in release 17.2-2016: ?, i7 V' }1 M. T4 o% I
    1702631 ALLEGRO_EDITOR     UI_GENERAL    Etch Length by Net report does not list correct net name for nets in a bus: N) z9 u" H5 e' J; K' X
    1703105 ALLEGRO_EDITOR     UI_GENERAL    Bus net names are incorrect in reports when using the allegro_html_qt variable9 ^$ H% t: g9 A( z$ ~
    1770786 ALLEGRO_EDITOR     UI_GENERAL    Stroke Editor working in OrCAD PCB Editor of release 16.6 does not work in release 17.2-2016
    & b, p3 @; B9 C5 {1 p* s1784938 ALLEGRO_EDITOR     UI_GENERAL    Etch Length by Net report does not show net names with angle brackets in release 17.2-2016
    3 q- x2 s7 h: \8 }( `1822557 ALLEGRO_EDITOR     UI_GENERAL    axlUIWCloseAll is not closing text window in release 17.2-2016, T* r' R9 b1 J7 f- g3 W7 w( O
    1836400 ALLEGRO_EDITOR     UI_GENERAL    Net names are truncated in HTML reports
    * U# @/ G1 Z4 F6 l+ k$ Q1869879 ALLEGRO_EDITOR     UI_GENERAL    Links not working in the Net loop report4 X) C3 ~4 p! C8 s1 P1 z, d
    1895878 ALLEGRO_EDITOR     UI_GENERAL    axlUIWClose()/axlUIWCloseAll() functions do not work when allegro_html_qt setting is enabled.9 {- Q# J( y7 L8 S6 V5 x
    1912282 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor exits with error message on editing objects
    * `4 y& |! z7 m4 Q# Q7 k# B! p* W1913962 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor toolbars change on choosing View - UI Settings - Save Settings and then restarting! v5 k5 o# h) J+ o) |
    1933172 APD                UI_GENERAL    Cannot paste text into the command prompt without clicking when 'enable_command_window_history'  is set
    $ N1 d% M$ i, a2 Y+ q2 ?. _7 P8 I1843712 CAPTURE            NETGROUPS     Signals shown only for first segment of NetGroup5 j) L8 r6 o3 b. Y6 _
    1917768 CAPTURE            NEW_SYM_EDITO Missing package pin overview in Symbol editor
      H( O* R9 H- L6 w3 J% \9 S/ i3 d1920088 CAPTURE            NEW_SYM_EDITO Package view missing in the new Symbol Editor! @# P: ^" a$ ?/ t" g7 I3 E
    1922196 CAPTURE            NEW_SYM_EDITO Snap to grid issue in Symbol editor
    2 v0 B5 @* U' }0 `1927268 CAPTURE            NEW_SYM_EDITO View Package is grayed out in release 17.2-2016, hotfix 038 and later versions! g) x4 Z( H& B, }% W7 `1 P
    1928012 CAPTURE            NEW_SYM_EDITO In new Symbol Editor, View - Package is grayed out
    " z# W) A/ W7 H- l1930865 CAPTURE            NEW_SYM_EDITO View Package missing in hotfix 038
    " Z( F# Z  N6 j+ I" v5 a1938507 CAPTURE            NEW_SYM_EDITO Issues with new Symbol Editor: Justification and spreadsheet usability
    % }1 R& E: C" J: J6 H1940869 CAPTURE            NEW_SYM_EDITO Missing pins in 'Edit Pins of All Section' table view for 4k resolution but not in 2k resolution: {' V9 d2 k3 {& W  `* e+ q
    1940888 CAPTURE            NEW_SYM_EDITO Copying pins from a part and pasting on different parts not working properly.  v  z7 S5 i% R' }' N
    1942994 CAPTURE            NEW_SYM_EDITO Cut / Paste of object in New Part / Symbol editor always pastes on grid
    . g* J; ~# \. M  U1944396 CAPTURE            NEW_SYM_EDITO JavaScript error while copying from 'Edit Pins of All Sections'
    - k# c+ U& g5 Q) D2 O1950224 CAPTURE            NEW_SYM_EDITO Cyrillic alphabets are not displayed properly on Schematic.
    6 w4 U' V0 @, {8 v* \, d: B1951369 CAPTURE            NEW_SYM_EDITO Cancel closes Symbol Editor
    : R; K0 U& F3 I1966785 CAPTURE            NEW_SYM_EDITO Edit Part is grayed out2 L) d! u) V0 l% _; Y6 z( i
    1973135 CAPTURE            NEW_SYM_EDITO Issue with new Symbol Editor: cannot copy-paste pins  A2 V2 H; h( c
    1973344 CAPTURE            NEW_SYM_EDITO JavaScript error on opening part from design
    * E. o0 G; G* \3 Z" q; `1974122 CAPTURE            NEW_SYM_EDITO Cannot copy-paste all pin list on the new Symbol Editor
    * E6 x9 o& @! v) ^1983593 CAPTURE            NEW_SYM_EDITO Script error on copying and pasting to property sheet
    & Z9 v# R! \' E' f3 l3 p+ Y1929692 CAPTURE            OPTIONS       PACK_SHORT issues with Pin Numbers that contain letters/alphabets
    ; d# o, J! i# q. }5 Q/ |( ^) b1876939 CAPTURE            OTHER         Incorrect Capture renaming error (ORCAP-1310)9 {  f) `6 L1 C* ]  K" o
    1916090 CAPTURE            OTHER         Incorrect error message when 'save as' fails due to long directory path- O- t4 g' z. ~% c" J
    1921927 CAPTURE            OTHER         Two functions are mapped to Shift + R in OrCAD Capture in hotfix 038
    : s! [- `9 W0 E1946453 CAPTURE            OTHER         Shift+R shortcut is assigned to two functions.  V; Y6 |7 U% Q& n7 w( E1 b/ r
    1965456 CAPTURE            OTHER         Shortcut Shift + R is not opening the Independent Sources dialog box
    + M9 @7 s" }" q/ n: I1968757 CAPTURE            OTHER         Close CIP is grayed when right-clicking on the tab in Capture.
    5 h. k1 R1 Q( H/ j" v6 i1 B1938437 CAPTURE            PART_EDITOR   OrCAD Capture new Symbol Editor Pin Type missing in table
    ( j1 F; c9 k9 ~6 S8 _1906757 CAPTURE            SCHEMATICS    Intersheet reference is overlapping with the offpage connector name  i+ C7 U: i0 P! G. y" b8 R3 \' ^: c, Q
    1867016 CAPTURE            SCHEMATIC_EDI Part placeholders not being positioned when moved( X; f5 i. L4 v- |0 F' h2 T7 _2 C
    1932837 CAPTURE            SCHEMATIC_EDI Parameters graphics are not correctly positioned
    6 V0 m* G( U/ K% _$ l; o7 t1949518 CAPTURE            SCHEMATIC_EDI Getting error when comparing designs1 K, [3 V  y  v6 r# i' T& t
    1967545 CAPTURE            SCHEMATIC_EDI Only section A of heterogeneous part being placed and not sections B, C, or D
    7 f( v; g! j( s# j1933919 CIS                DBC_CFG_WIZAR New CIS Configuration .dbc file created in release 17.2-2016 shows release 16.3& H& [/ f) ^6 T* A  x7 M3 c
    1932550 CIS                RELATIONAL_DB VIEW NAME in Relational Database configuration is not working as expected.
    : N, n# j5 m  t! x8 x1832524 CONCEPT_HDL        CHECKPLUS     Default checkplus rules show body height of 0 (sym_2 of the attached cell). This causes the cell to fail verification.& z8 @. k; }. n- m+ }% ~
    1912023 CONCEPT_HDL        CHECKPLUS     signalWidth predicate does not recognize SIG[1..0] as bus.
    ' o- r4 U) ~% f; k' a7 H  g" e1966120 CONCEPT_HDL        COPY_PROJECT  Copying release 17.2-2016 project results in message stating the project is of an older version
    , r) f+ [# Y: @+ E% V1 j$ j1879425 CONCEPT_HDL        CORE          Adding signals with the right-click menu is not following the defined color scheme
    ) p9 N' ]; N: A  t7 z, n5 a1890542 CONCEPT_HDL        CORE          Getting ERROR(SPCOCN-1911) when running export physical with backannotation
    ' F) j0 m5 g  d# @: F1907684 CONCEPT_HDL        CORE          Moving symbol makes canvas unresponsive for a long time
    . L: |: r5 ?! x0 u2 a1920711 CONCEPT_HDL        CORE          Pin names changes when mirroring the swapped section.
    + v' H6 y9 U9 L5 n; n( J9 B1931421 CONCEPT_HDL        CORE          On Linux, 'cpmaccess -read' returns incorrect value# l5 J5 ?8 F8 w: J6 z% S
    1931782 CONCEPT_HDL        CORE          Setting DONT_FORCE_ORIGIN_ONGRID to ON does not work for sig_name5 E0 K: z# R5 x
    1932433 CONCEPT_HDL        CORE          _movetogrid causes signal disconnection
    7 O' ]) v  Z4 o& u+ i7 j/ a1946993 CONCEPT_HDL        CORE          DE-HDL Part Manager fails to update parts on schematic if new KEY properties exist in PTF but not in schematic
    # U, ]  q+ v. }( a1947029 CONCEPT_HDL        CORE          Design Entry HDL Font Support not working for signal rename
    2 F* W* K2 P% S1962865 CONCEPT_HDL        CORE          Schematic symbol creation with '-' as pin name not packaging
    ; z4 ?7 Y; f9 T1966805 CONCEPT_HDL        CORE          Issues with packaging design containing cells named with a leading underscore* ]/ F; v- g% \1 Q7 a- z
    1967760 CONCEPT_HDL        CORE          DE-HDL crashes on moving Net Group/Port in release 17.2-2016, hotfix 044( v. {, N# K* _& X1 t
    1968282 CONCEPT_HDL        CORE          DE-HDL Part Manager fails to update parts on schematic when new KEY properties exist in PTF and not in schematic0 E0 n% t7 ~0 y$ _
    1972815 CONCEPT_HDL        CORE          Part Manager not updating missing key attributes from the ptf file by using 'Update instances' option
    # a! ]0 g& y$ r9 L& {% t  j- m1887790 CONCEPT_HDL        CREFER        CRefer links not working in selected cpm file! g3 m8 a" k: W& t" q. o3 T# @
    1898535 CONCEPT_HDL        INTERFACE_DES Global Navigation window does not reflect removal of a net on page2 that is part of a netgroup on page1
    1 F! L2 |' W% V1888048 CONCEPT_HDL        PDF           Japanese characters are not output correctly to PDF on Linux.  F- \' |1 [' I! U. [
    1937505 CONCEPT_HDL        PDF           Missing intersection dot in schematic PDF& U+ [  g2 l2 g' N
    1942486 CONSTRAINT_MGR     CONCEPT_HDL   CM crashes when you save after importing a TCF file! U4 ~& `+ |# w  `$ `! o( x
    1983743 CONSTRAINT_MGR     CONCEPT_HDL   Region Class-Class members are being duplicated in CM in the current session6 ~  p: ?; t3 g
    1906573 CONSTRAINT_MGR     ECS_APPLY     Database corrupt and DBDoctor reports illegal database pointer error
    6 b2 `) [* I3 B/ ~5 t, r) `7 [1913805 CONSTRAINT_MGR     OTHER         Setting environmental variable CM_PARTIAL_DCF in release 17.2-2016 causing crash( e3 e/ ~0 h; g
    1914813 CONSTRAINT_MGR     OTHER         C++ Runtime error and non-recoverable crash in class-class worksheet4 M' L9 h2 A5 E" n- y
    1920142 CONSTRAINT_MGR     OTHER         Xnet names are not consistent in the design9 X0 ~$ s' h  w
    1898549 CONSTRAINT_MGR     SCHEM_FTB     Importing netlist causing crash in release 17.2-2016, hotfix 0360 v4 p! D3 ~' G
    1814851 CONSTRAINT_MGR     UI_FORMS      Field solver /DRC check running forever3 ?0 Z# n. w) h6 I' i! U/ r* r1 R
    1889862 CONSTRAINT_MGR     UI_FORMS      PCB Editor hangs while assigning net voltages in CM
    3 j& q! x- W6 m3 I* T1 @1965470 CONSTRAINT_MGR     UI_FORMS      Constraint Manager GUI Issue in release 17.2-2016, hotfix 039: Font size small and rows/columns in shrink mode
    . e* P- I, b* ]! w' f' |- G. }1945406 ECW                ADMINISTRATIO Tree view was not refreshed soon after changing the site permission.
    : [1 J3 n' b" ]3 ]0 p) H1826848 ECW                METRICS       SPDWECW-551 and SPDWECW-553 should be warnings, not errors
    % v7 A4 ~+ M8 S+ C9 H3 X' k1933373 ECW                PROJECT_MANAG ecwbatch does not accept password and does not ignore invalid users7 t1 B& s. w/ i$ f6 n
    1921502 F2B                PACKAGERXL    Errors on running Export Physical:SPCOPK-1138 and SPCOPK-1149; p/ _& e! K/ H% Y0 d/ A3 x. L, W
    1929846 F2B                PACKAGERXL    PackagerXL is still creating the pstcmbc.dat file on a release 16.6 design uprevved to release 17.2-2016
    9 [# D5 R2 [: y6 w1953780 F2B                PACKAGERXL    Updated subdesign package information not updated on the top-level design in the reuse flow
    % n8 c7 M$ E: W) }/ B0 G) j1971738 F2B                PACKAGERXL    Deleting blank space from pstxnet.dat file crashing DE-HDL9 S1 M: [0 e( l  D3 p& \. k
    1891002 INSTALLATION       DOWNLOAD_MGR  Issue with Download Manager (Change Preferences Option does not Work)% r; c5 i% s: |# X7 h
    1972890 ORBITIO            OTHER         OrbitIO-APR failed to run if PCB design included  V9 [! U! E2 D" P& }1 [4 R$ C5 D; J
    1954262 PCB_LIBRARIAN      CORE          Footprint model check in fails with verification checks failed error0 N5 t& \1 J+ z3 v
    1943656 PCB_LIBRARIAN      GRAPHICAL_EDI Symbol Editor is blank if .ascii file is newer than .css file1 I+ H' R8 N2 S
    1897887 PCB_LIBRARIAN      SYMBOL_EDITOR New Symbol Editor: Inconsistent symbol results when adding vector pins in Part Developer
    ! S* Z6 C+ p" u2 g) _1898003 PCB_LIBRARIAN      SYMBOL_EDITOR Issue with Page Border Symbol2 x5 O7 r4 _% c/ ^$ v2 ^
    1842007 PSPICE             LIBRARIES     Change required in swit_reg.lib
    ' S) j7 x/ E( K# n/ J1 q) j+ ^1906922 PSPICE             LIBRARIES     Mismatch in mapping of IC pins in model and PSpice template for analog device AD8138+ `4 f: ?0 d% J# _
    1947586 PSPICE             LIBRARIES     Update the model AD8138/AD in ANLG_DEV.OLB8 s* h+ k2 f' D& N# [$ Q" n
    1748470 PSPICE             MATLAB        PSpice displays an error when sending current in co-simulation
    2 T- G: N5 q1 ]2 I2 A/ S$ }1802455 PSPICE             MATLAB        Incorrect current direction for pins in SLPS flow/ \' R2 b: Z/ O. p9 U3 E2 |
    1852811 PSPICE             MATLAB        ORPSIM-2604 being reported in SLPS simulation4 L" w# U  l4 r+ i! S8 I
    1858716 PSPICE             MATLAB        Co-Simulation fails if 'RC' is used as reference of resistor4 E- c& s; r2 G
    1921641 PSPICE             MODELEDITOR   Model Editor in Client Server installation slow to invoke' O% `  K# K' [+ N1 k6 x! H
    1922160 PSPICE             MODELING_APPS New Capture Associate Symbol GUI not reading libraries9 ?  v: v0 c3 v4 e! z( L
    1843698 PSPICE             PROBE         PSpice icons appear very small on a specific computer
    & ^: |. _. K, n; a1773841 PSPICE             SIMULATOR     orSimSetup64 crashes when running the simulation for attached design
    2 K# M- `0 |. y- B9 g. J8 l1816316 PSPICE             SIMULATOR     Simulation stuck; however, the status bar is correctly updated during Pseudo Transient Analysis7 l! T9 x6 Z3 V
    1887119 SCM                IMPORTS       Cannot selectively update changes in VDD4 |$ e8 I2 j: F2 ]0 l
    1889362 SCM                IMPORTS       Cannot selectively update changes in Visual Design Differences
    9 i4 V: q6 k% J$ t9 E% o6 g1958545 SCM                SETUP         Auto assign models does not work in SCM same way as in DE-HDL# I) y* {) K# z& f4 S/ {3 A$ s* R5 k1 K
    1988841 SIG_EXPLORER       INTERACTIV    SigXplorer stops responding or crashes in hotfix 047 when a design is saved
    ! _+ i0 [2 k# m" ^1988943 SIG_EXPLORER       INTERACTIV    SigXplorer crashes on selecting Update Constraint Manager
    ' o5 E: N4 K0 V1991375 SIG_EXPLORER       INTERACTIV    SigXplorer crashes when clicking Save
    ; b/ H  z  E& p+ c% G2 G1993749 SIG_EXPLORER       INTERACTIV    SigXplorer crashes on saving topology& L- l2 \' j4 h7 ]( i' T
    1969975 SIG_INTEGRITY      GUI           Model Browser edits model above the one that is selected2 t  P3 B" S1 C
    1953184 SIP_LAYOUT         IMPORT_DATA   Sub Drawing not saving dashed lines7 t" g& R& R0 V% @
    1913864 SIP_LAYOUT         ORBITIO_IF    SiP Layout design import results in wrong die rotation0 m! h1 V% c, v# k
    1880237 SIP_LAYOUT         PADSTACK_EDIT Background Window comes to the forefront when closing the Padstack editor
    + q8 ?  R" i2 F$ P1972560 SIP_LAYOUT         STREAM_IF     GDS Export fidelity issue: inverted arcs
    1 Q: C$ o% k4 d1 R1920317 SIP_LAYOUT         THIEVING      Thieving pattern does not allow for OOPS operation
    2 x, {2 o0 Q  t6 E) [1909075 SYSTEMSI           DOC           SystemSI PBA channel and circuit simulations do not respond if bit pattern is 1s or 0s8 J) X# @9 o; q& E
    1916101 SYSTEMSI           DOC           Lack of stimulus in file causes Serial Link Analysis to become unresponsive
    ( O- V3 N, N" A4 C8 Q2 x1919562 SYSTEMSI           ENG_PBA       SystemSI generates wrong timing bathtub curves in channel simulations for write and read$ e( }& R2 [% `5 t( H8 P
    1964064 SYSTEMSI           GUI_PBA       Able to sweep AMI parameters in SSI-PBA
    : D, ?+ H6 {  O7 }" D% {1971266 SYSTEMSI           GUI_PBA       MCP header shows only 49 ckt nodes instead of 52 for s52p S-parameter file- a/ F& M) Z* N0 G3 Y
    1885625 SYSTEMSI           GUI_SLA       Manage AMI + DLL from Setup Analysis Window
    5 i. W/ U! c" G$ x& k8 G1924382 SYSTEMSI           GUI_SLA       Data Rate field in SystemSI Stimulus property form is confusing for PAM4 operation6 t3 a" D8 y+ C  \1 Z( Y# j
    1982341 SYSTEM_CAPTURE     CANVAS_EDIT   Signal rename does not maintain new signal name value$ A9 w" _' C1 u9 E, G& {1 Y; d* L
    1976857 SYSTEM_CAPTURE     CONSTRAINT_MA System Capture-CM Match Group Creation is not updating correctly
    0 S5 |' E. j; I. o+ x1929606 SYSTEM_CAPTURE     DESIGN_CORRUP Opening design causes System Capture to crash5 h; U( ~8 G) c" i0 a) e9 N. T
    1914697 SYSTEM_CAPTURE     DRC           Overlapping component DRC does not work
    , M3 D( F7 J$ J4 T1973467 SYSTEM_CAPTURE     IMPORT_PCB    System Capture Import Physical shows many component and physical differences on a design that is synced up9 k7 a$ \9 e2 b4 Z
    1962603 SYSTEM_CAPTURE     NAVLINKS      Ability to not underline hyperlinks for Navigation Link values
    7 V, |! k$ m3 |& V$ ]2 N1967639 SYSTEM_CAPTURE     PART_MANAGER  Part Manager does not open in System Capture for part property value changes even after setting the cpm directive.
    2 A1 `8 G6 A  S1964388 SYSTEM_CAPTURE     SMART_PDF     Some shapes are not visible in the smart PDF schematics9 X7 g; K# N! C+ [
    1976832 SYSTEM_CAPTURE     TDO           Rolling Back local lower-block requires check-out of higher-level packaged & variant views
    + a4 `( B( s; p# ]1976844 SYSTEM_CAPTURE     TDO           CM - TDO check-out dependencies are broken' I0 b5 b) e: ?/ P
    1976859 SYSTEM_CAPTURE     TDO           Variant Editor in System Capture -TDO allows to delete a variant without checking out variants view
    ' N+ Y9 Z7 k- p' x  V  b; ~1 E. `1839816 TDA                CORE          All the design objects are locked in the EDM dashboard after a DSFrame error
    1 s( G* h2 L1 [* |8 b- F1889898 TDA                CORE          Cannot check in the top level of the project in TDO5 e5 }' h+ }0 D+ n" V
    1892411 TDA                CORE          Unable to undo the block checkout if something fails
    * G3 p& F6 I& d0 _2 r2 g1877757 TDA                DEHDL         Refresh Hierarchy does not show latest TDO lock/unlock status in DE-HDL7 p- y: G( l% }2 U. i
    : D- H  d7 V2 k
    具体没去了解,听说软件在3D显示,模型加在,约束管理器硬软板子规则,数据文件对象更新上都有了更新  详情 回复 发表于 2018-10-22 15:26
    推荐
    发表于 2019-3-30 12:44 | 只看该作者
    17.2各种bug,每次的打补丁又会引进新的BUG。而且有的BUG很明显,发布前只要测一下就知道,说明这个公司发布前都没怎么测。现在后悔了也回不到16.6了。
    2 Z( t' C8 j  r: u这个048的BUG最多,3D不能旋转就算了,打开文件经常要双击好几次才打开,一般第一次双击文件一点反应没有,连启动界面都没。
    ! j" ]+ g$ n" t6 q: Z8 @. L布线时有次突然所有网络名没了,重新又有了。还有一次关了软件后发现刚编辑的文件不见了,回收站里也没有。
    " t) _  C; ?3 Z7 X移动过孔时,会抓狂,过孔闪来闪去,不跟着鼠标走,最后我发现原因是在移动过孔时,teardrop并没消失,还在原来的地方,导致软件认为那里有铜皮,所以过孔会避开那里,所以就闪来闪去,一下跑左边很远,一下跑右边很远,非常气人。像这种明显的BUG官方也检查不出来?发布前画个板就能发现这个BUG
    发表于 2018-10-22 14:24 | 只看该作者
    thansk for shairng
    : P# ^2 L, [: |8 t4 F$ R
    发表于 2018-10-22 14:38 | 只看该作者
    thansk for shairng
    0 \0 r0 J& R, r1 {9 f
    发表于 2018-10-22 14:49 | 只看该作者
    谢谢分享!
    发表于 2018-10-22 15:04 | 只看该作者
    这男子好帅
    发表于 2018-10-22 15:09 | 只看该作者
    感谢分享,用不着先收藏
    发表于 2018-10-22 15:23 | 只看该作者
    buzhidaobugshifouxiuzheng
    / S! ^! T: F" }$ C
    2020-3-6 15:04
    发表于 2018-10-22 15:25 | 只看该作者
    谢谢大侠分享
    + t$ X- X) Q% D# D9 s! M
     楼主| 发表于 2018-10-22 15:26 | 只看该作者
    i4dm99 发表于 2018-10-22 14:22" M7 c7 z; j8 k: @1 k
    感谢分享,能共享一下都更新了哪些内容吗
    : \# ]& D* C# V具体没去了解,听说软件在3D显示,模型加在,约束管理器硬软板子规则,数据文件对象更新上都有了更新
    * i% O% ]7 I) a& [+ q% a7 K# j4 ~6 @1 V
    2023-9-13 15:19
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    13#
    发表于 2018-10-22 15:39 | 只看该作者
    thansk for shairng1
    慵懒
    2024-12-9 15:04
  • 签到天数: 384 天
    [LV.9]以坛为家II
    15#
    发表于 2018-10-22 16:03 | 只看该作者
    * u) \2 c  {  H4 z  \' U9 t
    thansk for shairng
    GMT+8, 2025-7-5 00:33 , Processed in 0.156250 second(s), 27 queries , Gzip On.
