查看: 3096|回复: 0
出NETLIST有错误,大家帮忙看看
发表于 2009-3-6 11:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#90 Error   [ALG0013] Conflicting values of following Component Definition properties found on different sections of U0.4 M0 t! P* d! Q" ?+ v2 B( I9 s
              SWAP_INFO% ?% n) {+ Y5 ?+ p
#91 Error   [ALG0014] Conflicting values of part name found on different sections of "U0".
4 K  c3 h+ D, N5 f/ k1 R  Conflicting values:
* S& s, ^7 }: e) d, @ XC5VLX330-FF1760_1_1760FCBGA_(
+ Z4 p: ]8 w% z  Q8 |: HS1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11+S12+S13+S14+S15+S16+S17+S18+S19+S20+S21+S22+S23+S24+S25+S26+S27+S28+S29+S30+S31+S32+S33+S34+S35)_XC5VLX330_FF1760 & XC5VLX330-FF1760_1_1760FCBGA_XC5VLX330_FF1760
. B7 c/ G! p: y1 D3 u  Property values of "Device","PCB FootPrint" and "Value" should be identical " y( W1 K" F8 G' x) m) P  x) q
  on all sections of the part.6 H$ Y8 Q# f6 \: M1 f! O9 y
#92 Error   [ALG0013] Conflicting values of following Component Definition properties found on different sections of U0.2 s7 W' U: b4 `' Z
              SWAP_INFO
4 c. p; m1 I- Y# |#93 Error   [ALG0014] Conflicting values of part name found on different sections of "U0".
' o  x9 {4 m# G" m  Conflicting values: XC5VLX330-FF1760_1_1760FCBGA_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11+S12+S13+S14+S15+S16+S17+S18+S19+S20+S21+S22+S23+S24+S25+S26+S27+S28+S29+S30+S31+S32+S33+S34+S35)_XC5VLX330_FF1760 & XC5VLX330-FF1760_1_1760FCBGA_XC5VLX330_FF1760 % f% _- q+ Y* _5 P0 a$ v
3 i  n$ M6 ]' x8 x) P5 h  on all sections of the part.& [$ y$ x. `* M" i0 u% ]
#94 Aborting Netlisting... Please correct the above errors and retry.
GMT+8, 2025-7-26 20:34 , Processed in 0.109375 second(s), 24 queries , Gzip On.
