7 R0 N3 M7 ~3 {9 H5 @1 ]1 d# }( l
( Q) z3 H# m/ d# d; j" A) W }4 `谢谢超级!
( Q0 Y9 S9 S/ f" n7 n1. 可惜我依然不明白你的说明.
e8 J/ A0 F5 j6 A8 P2. 你的意思是, 此dataSheet 用平行四边形 表示这个信号的Jitter 吗?
, n! f( e- U8 C8 b9 ?1 f3. 如果是这样, 与题意不符, 它想表达Set up time/ hold time, (两个时间点)8 `" X( u6 t. ?- I2 k0 G! P. d
. U5 r) S6 K5 d' V6 \4 D! V
below is quotation from wikipedia
& O% l0 u. X3 X" D+ o0 t' D. }* }5 f) v! f& C
"6 {3 j" \' J1 }: _' \
Setup time is the minimum amount of time the data signal should be held steady before the clock event so that the data is reliably sampled by the clock.
- X( X/ g2 g+ t. R2 {1 I
; d9 a* _1 W) b' v- cThis applies to synchronous input signals to the flip-flop.. C# l4 t; N' D( ?: S7 y4 Q
, f" P* K; L; V$ k) R! [0 y r0 L/ m' J
Hold time is the minimum amount of time the data signal should be held steady after the clock event so that the data is reliably sampled. ! e/ c X& `+ p) k, X6 Y6 f9 O9 g- Z
, ~/ n; k. l8 Z7 V C
This applies to synchronous input signals to the flip-flop.$ a+ x. }( Q% J- P C
"3 u0 X! ?# r1 D0 A+ \8 u2 C
, W7 L: k7 u% X7 g3 ?4 t' G1 i3 H* t. I4 _5 H* O G
0 j% x0 m9 L$ X& Z/ _2 Q
0 @- O5 p7 R' D/ n( t" V2 y0 y- L8 _) l0 G3 t5 v4 c( n
1 Q4 E0 E! Q2 w; {
1 v r2 t8 d. Z" e- R; e" X7 O$ \. m! q& e2 p5 u1 R$ c! ~
