查看: 3388|回复: 8
PADS 导入OrCAD ,出如下错误,该如何修复?如重复的"GND"针脚名.
发表于 2018-8-9 13:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 shymengcn 于 2018-8-9 13:52 编辑 # y+ F. I9 [" H0 b' h
" f1 E  g* R% @& W6 F$ g& s$ o4 r# t
pads 导入orcad 后,出现如下错误,该如何修复呢? 一直无法生成网表Netlist...,  . e* ^1 M5 C! _6 w5 v* B
但我本来设计就应该是这样的,看不出是哪里的错误!?0 p5 v, R2 x: F
5 Q3 k2 a9 ~6 @. R
5 e9 d' H8 r  ~- R
1 P3 y+ G, v- I6 f" G导出网表出现如下错误:
) i( ~+ m, n/ Q$ B' e+ `4 n# u{ Using PSTWRITER 16.6.0 d001Aug-09-2018 at 11:45:36 }
/ G- S6 @$ @3 Y: e
9 n+ `- }: K, p. N3 k' ?' H$ F* h. x5 U- z
#1 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 6: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.
5 z: ]& d: Y5 [1 @# B% w
. t$ b2 B) W8 Y. q7 _' g0 h#2 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 7: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.
- N0 ~2 G2 W3 B9 g
" @" f# t% k- I0 V( }" d#3 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 9: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.
( F2 e5 S- v  Y8 ~
' a+ [, c) m( _# f" i$ J! C#4 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 8: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.$ X, G# d: D* ~
7 G) m) L4 C( b5 n
#5 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 27: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
5 t8 ]4 G( A8 w; Z6 G1 C5 W0 f# g  g; a% V
#6 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 34: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.1 L( L- g5 W# z. t2 o
# |8 [/ S$ `5 m" ^+ e#7 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 36: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.5 `9 _" f' C) [3 Y
* ]) j! ]# p7 x) ]  P
#8 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 37: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.0 m( z! S' w& z3 H, T% X
8 r# h" w: {' Y! h6 n' R#9 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 40: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.3 m7 ~3 P7 P$ l6 G
4 u, o$ @* S/ @# l9 s
#10 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 41: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.8 W! `4 l0 U. R' i5 o9 x0 w# R6 f
8 n+ ~- ?) ^: v#11 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 46: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
. E! j5 r" ]7 @7 [  r2 G* Z, t) @5 J6 M& j! f4 e+ M3 ~+ t
#12 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 47: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.# S. Q) k- J) O2 E! V, C, h7 r
' x: b3 ?0 l; i
#13 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 55: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
  s8 \" g8 T! d# ]8 O0 [& @4 ?: d2 \6 \4 k0 x  ^9 v" r/ F, M
#14 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 56: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.! Q& w' h6 g+ k; ^/ g7 F
& M0 b1 |- H- ~* a1 M" F
#15 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 57: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
8 n; R* |" B1 J+ ^& ~- _$ F/ Y6 j
$ _4 h! Q+ _7 r#16 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 58: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.' H0 }( A4 A, c, a7 @
- _. f2 y7 }6 f% J6 }$ B
推荐
发表于 2018-8-9 16:09 | 只看该作者
Anne@1985 发表于 2018-8-9 15:08
2 L! p& z- `5 _( i( {allegro不识别相同的gnd,你那里面多了gnd pin应该把gnd分开来如6 gnd1 7gnd2 8gnd3,以此类推,不能有重复的 ...
! B4 @6 v0 ~1 o' _! A6 M
不是不可以,如果要相同的话PIN属性里面的type就得选择power,而不能选择Passive,不然就如你所说的,将Pin的名称区分开!! z$ _  X6 {' r$ ~& _
    无聊
    2019-11-18 15:57
    发表于 2018-8-9 15:08 | 只看该作者
    allegro不识别相同的gnd,你那里面多了gnd pin应该把gnd分开来如6 gnd1 7gnd2 8gnd3,以此类推,不能有重复的pin脚
    不是不可以,如果要相同的话PIN属性里面的type就得选择power,而不能选择Passive,不然就如你所说的,将Pin的名称区分开!  详情 回复 发表于 2018-8-9 16:09
    感谢Anne 的回复,在PADS 里面这样是合法的,在Cadence里面改成这样,好像很难看的样子  详情 回复 发表于 2018-8-9 15:19
    感谢Anne 的回复,在PADS 里面这样是合法的,在Cadence里面改成这样,好像很难看的样子  发表于 2018-8-9 15:18
    参与人数 1威望 +8 收起 理由
    alexwang + 8 赞一个!
     楼主| 发表于 2018-8-9 15:19 | 只看该作者
    $ a1 z" W1 v: |  R. [4 `allegro不识别相同的gnd,你那里面多了gnd pin应该把gnd分开来如6 gnd1 7gnd2 8gnd3,以此类推,不能有重复的 ...
    3 c4 t: E# b2 n/ i4 C7 {感谢Anne 的回复,在PADS 里面这样是合法的,在Cadence里面改成这样,好像很难看的样子
    ; u/ U( `! o' n% T3 ^9 j+ R
    但是cadence 里面就是不能有重复的pin neme,就算是相同的也得分开来看  详情 回复 发表于 2018-8-9 15:22
    无聊
    2019-11-18 15:57
    发表于 2018-8-9 15:22 | 只看该作者
    shymengcn 发表于 2018-8-9 15:19
    2 J+ `+ J7 ^  V8 B8 k  A& `1 A, z- j, H感谢Anne 的回复,在PADS 里面这样是合法的,在Cadence里面改成这样,好像很难看的样子
    / Q0 u- |/ E' t. J- O. v' O但是cadence 里面就是不能有重复的pin neme,就算是相同的也得分开来看4 e2 p/ ^3 h( Q
    发表于 2018-8-9 16:11 | 只看该作者
    如果是Power Logic画好了的原理图,建议你直接将Power Logic的网表转成allegro第三方网表直接调入allegro设计即可,省事又方便,转原理图可能会丢失网络和器件,后续还得从头到尾检查一遍和修改,工作量大,也有风险!
    因老板是Cadence 的粉丝,需要我们转成Cadence 平台orcad 和allegro 作业,暂时不接受PADS 平台的,虽然我对pads 相对比较熟... 我从PADS 装成Orcad 后,转成网表时,提示#29 ERROR(ORCAP-36018): Aborting Netli  详情 回复 发表于 2018-8-9 16:35
     楼主| 发表于 2018-8-9 16:35 | 只看该作者
    這侽孓譙悴丶 发表于 2018-8-9 16:11$ U! C0 Y& f5 z$ |
    如果是Power Logic画好了的原理图,建议你直接将Power Logic的网表转成allegro第三方网表直接调入allegro设 ...
    9 ]3 z3 z, Q% Z7 Q
    因老板是Cadence 的粉丝,需要我们转成Cadence 平台orcad 和allegro 作业,暂时不接受PADS 平台的,虽然我对pads 相对比较熟.... D( N% ?& N# @
    6 v* c0 L9 @* m& A$ s1 N
    我从PADS 装成Orcad 后,转成网表时,提示#29 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.本来原理图里面还有同一页的Part 内的GND 名称, 可能是暂时还没有检查到这个错误,因为是Aborting Netlisgting, 可能是因为错误太多了。
    9 G2 W5 }4 l: u) X4 `# p7 G/ B" G, M' ]$ ?1 M4 J; W- @; Z
    上传一下附件,大家有空,可以帮忙看看是否可以转出Allegro 的Netlist,  提示一下:我是首次使用这个Allegro 平台,所以不熟悉,希望熟练的大家可以帮忙一下我
    0 K+ }* m+ I1 [# R- e5 Y' @% G) B! P* E! Y1 S- z& v
    非常感谢!' k7 n1 C* X; a: c" |% {# ^3 z
    6 m4 R; d2 o/ ?6 v) W& i# }% y5 K8 m
    / l- }$ a& v0 j* q' H
    1 z( @  A; w" w$ S. [4 q1 E! H  x8 A$ B8 S4 L! T  O; _! n7 t9 W
    9 o" j' E. Z$ |6 B) O' T3 x{ Using PSTWRITER 16.6.0 d001Aug-09-2018 at 11:45:36 }
    / d2 I/ K1 H" f! }* G/ |1 |8 m) ]- ]) n) |
    3 A, b/ a! E7 L: ~% Q1 p. e( i#1 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 6: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.3 W' K9 n( Q; r9 D3 W, i) M
    8 s( N6 _4 B4 a$ p#2 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 7: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.
    0 u$ N& b$ b3 U, R! F* X% K5 b* T. s
    #3 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package MICRO-USB_UAF95-05254_0 , J104 Pin Number 9: 01_BC26.SchDoc, 01_BC26.SchDoc (17.43, 7.30). Please renumber one of these.  L3 N& [7 \9 V- ~. ]3 t2 c
    + T$ Z! X- p% o5 Q/ J
    , E9 L$ \9 w: G9 t; d) |2 [& }& i/ |) S/ p
    #5 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 27: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.* E" O- k4 J8 ]1 F. [. }
    - \2 v) p. b# @! Y5 |3 [# c  O$ Q#6 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 34: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
    8 g/ V  U9 w4 B  h3 \: _) o) j$ j$ k; F
    4 k( F2 j5 [# v0 ], Q/ z, x' z% G5 P: m& f- L+ s; {
    , G0 j' e3 ?% x( d/ K" _% v; m3 `1 V% r$ k3 E  @+ _
    #9 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 40: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.( ]/ ~  Z" R4 r3 n5 V
    ) U  s8 }$ F: I9 p+ g1 Q
    #10 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_3A , U101A Pin Number 41: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.+ b' A3 j- k$ ~5 g, T8 t4 S
    2 ^5 f- G6 }, @
    #11 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 46: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.5 r2 Z, R" r* j  r3 t' r) R
    ( l! D: k, Z0 g
    6 G/ K+ c) {0 v0 q' R. J
    * l4 d, T* _: A/ r! G6 x3 \8 Y#13 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 55: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.. Q. e7 v2 Y$ x
    * I  y, f( p* w#14 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 56: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
      ]4 y2 M) L, y% V/ Y% O. n- k; V( k5 c0 @) f
    , }( y+ Q' K* o9 u$ o
    / U' V' q6 g( n1 c% a  K#16 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_3B , U101B Pin Number 58: 01_BC26.SchDoc, 01_BC26.SchDoc (11.00, 3.00). Please renumber one of these.
      Z! P) I1 P  {# J  b0 \7 r8 e. j4 O7 M$ ~& B
    #17 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 27: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.7 K' Z5 j' F# L2 L
    6 P, @8 o( m9 z" m  b6 }0 q9 v
    #18 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 34: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.. ^. Q' y4 i8 R3 R! M. |
    5 W. c& s6 O7 H7 ^
    #19 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 36: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    2 ^4 J. \& h$ D- [8 ^* G% H9 a3 i% A3 z* @( x/ k1 F! @8 _$ t
    #20 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 37: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    / k( }4 ?6 q7 M& X: |$ P& K* ~8 C
    ; L: f6 W; o, r& U+ `( M#21 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 40: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    . J4 g) {) G9 m- s5 W& w
    - F- I' ~; L; f2 D#22 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package BC26_0A , U101A Pin Number 41: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    0 X) Z! W# E. J
    6 ~4 m( t4 j' L/ ~* ?( ~: P#23 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 46: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    2 D, n* J& M5 C
    3 ]0 I, F+ F% I#24 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 47: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    7 w2 f- T" S4 {9 C9 Y! v* c. e- r. R" s9 M: T, b/ d7 _
    #25 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 55: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these., x" L; m* R% k" r; q; p& l
    ( w: M: L& x/ _0 W2 ~. a& e
    #26 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 56: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    & `/ |9 w3 s' Y  C( Y  I
    0 a, K) r5 }7 E, k) X#27 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 57: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.
    " ]8 {$ u" A6 p1 p8 ?( G$ |6 V2 Y. ~; H" B( v& h3 y& D9 Q
    #28 ERROR(ORCAP-36041): Duplicate Pin Name "RESERVED" found on Package BC26_0B , U101B Pin Number 58: 01_BC26.SchDoc, 01_BC26.SchDoc (3.10, 3.00). Please renumber one of these.1 p; E, x8 Q4 Q- Q2 j
    # W* `' ]" L* w7 G. K2 @; x! b! V1 ?/ c
    ' @9 \- e7 j/ d$ W% U
    0 b5 r" t( V4 V# h4 g: v, O$ e( Z" r; @) L. w# m9 ~$ R; `# O5 B
    3 q1 Q1 f, J3 Y9 |9 N4 r" F/ I
    BC26_20180808_6PINSIM.rar
    46.23 KB, 下载次数: 0, 下载积分: 威望 -5
    GMT+8, 2025-11-6 16:32 , Processed in 0.171875 second(s), 29 queries , Gzip On.
