& O8 j; m" Z5 M6 J# h5 q9 _3 |# f/ V4 K5 \; K' ?, R2 ]
我知道大家討厭洋文兒,但是古人有言「師夷之長以制夷」,大家就忍耐一下!
$ ^3 Z! \3 B# U% }" ~: ]) P3 c$ O, J; Q6 W2 q( V8 G( s' y6 L
IPC Land Pattern Standards for SMD technology IPC-SM-782, IPC-SM-782A, IPC-7351, IPC-7351A and IPC-7351B have always promoted Rounded Corner pad shape as the preferred pad stack. However, Most CAD tools did not support Rounded Rectangle pad shape until recently both PADS Layout and Altium Designer added this feature to their PCB library editor.
" Y1 L! y( B# s/ ?2 V
$ a7 c) F7 [6 w% ?& eHowever, all component manufacturer recommended footprint patterns recommend a rectangular pad shape. So the great compromise between the world standards and component manufacturers is “Rounded Rectangle” as the default. In the Library Expert program, the user can easily switch pad shape to Oblong, Rectangle or D-Shape but the default installation is now Rounded Rectangle and this will be the recommendation in the upcoming IPC-7351C standard due for release in Q2 2016. It should also be noted that most fabrication and assembly shops prefer Rounded Rectangle pad shape and some say that it is better for lead-free solder attachment.& X9 r* R% [: n9 n0 N
 ; S$ b7 q& y+ ^2 N; O% Y( o
 some say = 有人說 + v2 ~" U+ {5 M$ x. K# R+ r) x
還是沒看到實驗數據!
+ h8 `- `0 [* i. T2 W |
