HOTFIX VERSION: 0038 v" @. o- P! O0 [
, J$ q5 {5 q! YCCRID PRODUCT PRODUCTLEVEL2 TITLE3 l' B/ c& q, w/ e7 L3 Y
G5 ~) Y+ ]$ m5 r8 Z402597 Pspice LIBRARIES Substrate pin appear floating for Mosfet symbols in breakout.
& L/ w( o( p" \! }% j) _: r525262 concept_HDL CORE execute "Reflesh Hierarchy" during the edit of page name and
, g6 {2 Z6 f% B3 C$ w559220 CONCEPT_HDL OTHER Color MONO not working as in previous releases; q9 m3 i) G/ I# C g \
618204 APD padsTACK_EDITOR updating renamed via into the design crashes APD
: c7 m& d3 Y5 \620606 CAPTURE PRINT/PLOT/OUTPUT Capture crashes during multi-page print preview
. P5 F. q; D. X' K: N' n x! T8 j622117 allegro_EDITOR OTHER Quickplace will overlap components when all sides are selecte, G% G' W1 A' j3 E' T
622739 SIG_INTEGRITY TRANSLATOR DDC Chip IBIS model not simulating as expected) v( g7 F" ]& g
622870 ALLEGRO_EDITOR INTERACTIV Allegro crash on closing Design Parameter form
# }/ g) ]: \( l: w0 O4 B) K% r623353 ALLEGRO_EDITOR INTERACTIV Using my_favorites created by Allegro gives Crash
1 G& h9 X: b) c5 k1 s623747 MODEL_INTEGRIT OTHER Negative TDR pulse simulates in SigXp but not in MI4 C. m. r+ X6 \( E
624535 CONCEPT_HDL OTHER Page navigation icons disabled in DEHDL-L in Windows mode8 \5 _# I4 x" V& H2 w1 K% }
627100 SIG_INTEGRITY SIMULATION segment xtalk crash - routed cline on plane and xtalk table i* [+ v( n5 R& f. K4 g, Q/ q, _
627108 ALLEGRO_EDITOR SHAPE Deleting cline segments doesnot delete dynamic fillets
( n( C) W" {) j a' k! ?627776 SIG_INTEGRITY OTHER Cross section impedence not calculating for SPB 16.2 with sin' q: g" B0 I/ h
627984 ALLEGRO_EDITOR MANUFACT Autosilk cuts line in the pin number character.
3 ~; o& z& V/ @+ N& `2 s628629 ALLEGRO_EDITOR MANUFACT Circular arcs were lacked by Auto silkscreen command.. v9 ^. \4 H( U j
628690 SIG_INTEGRITY OTHER In Cross section form the Impedance Calculation is not workin
$ M6 }0 F3 D' u2 c6 f628739 CONCEPT_HDL CORE I would like to disable the DEHDL crash debug files
7 Q; I. K) f5 [, \628775 ALLEGRO_EDITOR DATABASE Import tech file does not assign proper Referenced Spacing CS5 g6 N1 i2 \/ [1 Y0 L
629426 ALLEGRO_EDITOR DATABASE DBDOCTOR has Irrecoverable error POINTER TO RATSNEST INVALID.5 k* @1 S( X7 }9 z2 F, x+ M" t
629511 ALLEGRO_EDITOR SHAPE Shapes not filling fanout vias properly when dynamic fillets
+ l8 f* X+ m$ x629807 ALLEGRO_EDITOR SHAPE Updating shapes with shape_rki_autoclip set will crash.9 `# E1 `0 z. Z5 r8 W& k4 v6 B+ F
630527 SCM IMPORTS Import ECO netlist with non existing Pin causes SCM to crash
! {* U% j) e: N* ^- B630574 SIG_INTEGRITY OTHER Upreving a 15.7 board file causes a corruption of the cross s
8 B. B1 D R) r8 C2 P6 O/ x630690 SIP_LAYOUT OTHER The default axl placement function used to be "Wirebond" but
6 g" b, Z2 @6 M8 k& a630691 ALLEGRO_EDITOR DATABASE dbdoctor uses .brd as default extension when none is given in
3 P1 n2 v% `: v" D# f630751 ALLEGRO_EDITOR EDIT_ETCH Differential pair selecting wrong mate while manual routing
. B, f& e5 s# z- p* t' V p630861 APD WIZARDS about die text in wizard. Z6 R$ r% k2 X' c/ @: i# V9 T
630946 SIG_INTEGRITY OTHER about the specification of Frequency and Cycle to Measure whe, d( H5 R$ B" Y7 A( N# @
630990 ALLEGRO_EDITOR OTHER Using Uprev on some pads does not work* q* r7 I4 q P% e' c
631017 ALLEGRO_EDITOR SHAPE Fillet shape oveRFlows PAD5 u' Z# c6 x; [9 E
631104 SIG_INTEGRITY SIMULATION Use_accurate_delay_calculation variable causes geometry windo. o" _. J+ ?+ s ^0 ~+ A+ T4 k
631127 SIG_INTEGRITY OTHER Geometry window incorrect in Display Parasitics when board ac% J/ d5 J7 p2 Z# S4 ^8 E7 B+ A
631150 APD REPORTS Problems running copper usage reports5 d8 Y! B2 }9 f. {! S
631156 APD DATABASE Doing a Show>Element on IC component crashes APD and creates/ s9 N" U4 J p* {
631534 ALLEGRO_EDITOR CREATE_SYM Unable to edit text on Refdes/Assembly for a mech symbol3 M5 E+ B! q$ Y
631677 ALLEGRO_EDITOR MANUFACT 16.2 Create Detail figures are filled solid.
0 h" N3 S7 H& G; E. p+ E631907 CONSTRAINT_MGR OTHER APD crashes in constraint manager when selecting Net All Laye
" t$ n9 j- i' V" {633093 ALLEGRO_EDITOR PAD_EDITOR Pad Designer crashes when opening a Non Existing padstack
5 n! A) s4 m% V4 D$ R% R633119 SIP_LAYOUT DEGASSING Shape Degass crashes the application% a$ f$ R2 G+ @: @# o: A1 Q ~
633203 ALLEGRO_EDITOR DFA Show Element no longer shows DFA_DEV_CLASS applied to symbols |
