查看: 3186|回复: 0
C@dence.SPB16.20.winnt.Hotfix.001和002所更新的内容
发表于 2009-2-11 23:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
HOTFIX VERSION:  002
; ?) V/ R5 P1 z========================================================================================================
. Q6 R; b2 j) t- }$ n7 JCCRID      PRODUCT          PRODUCTLEVEL2        TITLE
& A5 E$ _. D& x* i) T& R========================================================================================================
0 e' D2 y5 n) }* e( b) \6 ?511865     SPECCTRA         REGIONS              Diff pairs should adhere to constraint area+ {5 L# O* ~7 a! q
564589     allegro_EDITOR   OTHER                The show measure command should show the actually measured po
( G  ]+ S; d. e570861     concept_HDL      CORE                 Unconnected mark does not be removed even after wire is conne
" T8 F+ b+ i5 j7 h0 P; N572188     APD              PAKSI_E              3-D model extract failed( w+ X2 T- @- A" q4 N
578164     CONCEPT_HDL      skill                Cnskill crash during Create Test Schematic step when large pi
" H9 g5 J( D6 W/ j1 n$ W( J578874     SIP_LAYOUT       DIE_STACK_EDITOR     Stackup editor in SiP fails to add layers above and below top( s2 H( I8 ~  n3 _$ j. h& s. D3 n' T
580315     APD              ETCH_BACK            Etchback trace fails with error "W- An etch-back trace cannot0 j0 A/ d# N3 }. X: ~
582308     ALLEGRO_EDITOR   OTHER                Create Detail for bondpads rotated at (0,90,180 and 270) angl
: W% n+ h0 M% {594370     SIG_INTEGRITY    OTHER                Wrong description in case update form when changing preferenc
/ q, {* u4 {+ ]% j6 R595755     CONCEPT_HDL      CORE                 Rumtime error happen when do Move Group in conceptHDL
. L' \! |; U9 P3 H  c/ c597922     SIG_INTEGRITY    TRANSLATOR           spc2spc doesn not handle inline RLGC DATAPOINTS' N# n6 g& n8 `6 t% Z
606620     ASSURA           DRC                  Problem with density checks in Assura
) j6 g+ \1 v% [* N; U0 [0 \/ o609866     SCM              SCHGEN               Schgen replaces CTAP with COMMENT symbol which causes net sho- N+ g5 I; ^& Z) A$ T, ^
611678     ALLEGRO_EDITOR   GRAPHICS             During Place > Manual Pins disapear if component is on bottom
/ f) x8 R, u( u' Z- ?( I3 @615630     ALLEGRO_EDITOR   GRAPHICS             Pins are not visible when place manually is used for Bottom s
: a2 Y4 J8 F* K7 ^6 c9 u$ c- L4 B615764     CONSTRAINT_MGR   TDD                  BOM report does not filter parts with BOM_IGNORE8 @% @! V% C' G9 i. Q* Y
616529     CONCEPT_HDL      CORE                 15.7 Design Entry HDL fails with Out of Memory message
/ m  O% u& b+ q: R% c& \* M4 q616928     CONCEPT_HDL      CONSTRAINT_MGR       Net_physical_type and net_spacing _type constraints not sync'3 `' C) N+ {; I1 q$ i1 @; p, }
617441     SIG_INTEGRITY    FIELD_SOLVERS        Reflection simulation fails when using wideband vias+ u! f8 C( C! G) ?
617679     ALLEGRO_EDITOR   COLOR                The color palette will not be saved with the design unless co
) |2 t5 h# o2 V6 T617805     CIS              PART_MANAGER         Capture_crash' S2 t: J) q# C4 I) D) h/ ]
618988     ALLEGRO_EDITOR   SCHEM_FTB            Long bus names being truncated
/ p6 q  k8 Q6 b0 W1 {; h619588     APD              EDIT_ETCH            Poor routing peRFormance. 5 second delay after each mouse cli* _- ?2 b; `. [9 l8 z
619691     SIG_INTEGRITY    FIELD_SOLVERS        Problem of EMS2D by using FreqDepFile
* [- I. F& ]' W4 V- v619867     ALLEGRO_EDITOR   DFA                  DFA_BOUND_TOP shape doesn't display DFA Audit conflicts6 j1 O. i7 I& S0 h9 P  B
620359     CONSTRAINT_MGR   CONCEPT_HDL          ECSet and Netclass definitions lost in the FTB process
- [  ^! X" N+ @: a& s* _* \620424     CONCEPT_HDL      CONSTRAINT_MGR       CM restore from definition of subblock removes ECSets defined
9 D( j1 ^  k6 h+ v9 i620700     ALLEGRO_EDITOR   PAD_EDITOR           Shape has bigger void on Y direction for Oblong SMD Pads. Z8 b& x/ b! A2 p
620868     SIG_INTEGRITY    PAKSI_E              Wirebond material conductivity is not used by PakSI, only a d. K3 y$ I' e, ?( i# B, n
620895     ALLEGRO_EDITOR   DRC_CONSTR           About error message of cns_design command.
' k9 D* I+ F1 _8 o7 m620924     CONCEPT_HDL      OTHER                PDF Publisher 16.1/16.2 can not output some Japanese characte, _/ [* ^% [# i2 V
621156     SIP_LAYOUT       ASSY_RULE_CHECK      ADRC Rule for 揟race Minimum Angle to Pad?not showing all th# D* s2 o, p/ C
621163     SIP_LAYOUT       ASSY_RULE_CHECK      Ambiguity about the how is the 搒tart of the wire" defined in
6 m9 l0 U6 S; O' Y; D621298     CONSTRAINT_MGR   UI_FORMS             PCB SI crashes when importing a constraint file into Constrai" {, n; _4 t2 w$ v  O2 G7 m
621315     ALLEGRO_EDITOR   PLACEMENT            Getting wrong component when using Place replicate unmatched" ]5 ^+ \8 a. ?0 `
621848     CONSTRAINT_MGR   TECHFILE             techfile write fails with Failed writing object attributes
. e0 \1 ^7 @2 |0 _4 L! k& H- m621867     ALLEGRO_EDITOR   TESTPREP             Transcript window randomly locks up when running TestPrep
% G+ G5 ]$ D8 S1 }; l" a621901     SIG_INTEGRITY    OTHER                Incorrect extracted via drill/pad diameters and missing inter
' A: m& M" Z. Z8 R) w: d622010     ALLEGRO_EDITOR   DATABASE             Undesired openings in Negative shape' g* o% ^- O1 t9 C, R
622062     CONSTRAINT_MGR   DATABASE             Importing dcf file at system level crashing the Allegro PCB e/ y/ X9 D& S# _( U: `# w% M% Z
622156     ALLEGRO_EDITOR   SHAPE                Thermal/Anti value producing incorrect void sizes% l$ M; ?' y+ C1 ~5 D( U* a  \2 k
622450     SIG_INTEGRITY    SIMULATION           Field solution failed& b. {  l* ]1 Q3 P( t
622466     ALLEGRO_EDITOR   COLOR                layer priority in 16.2
. u. m2 N$ z/ [8 L# D7 ^# c. v( h622566     ALLEGRO_EDITOR   SCHEM_FTB            Replacing the components of same refdes on board after import
$ F; [6 Q' P$ x- \6 C5 w, z( o, X622700     APD              PLATING_BAR          Plating Bar Check is highlighting Nets that appear to be conn
% i0 w2 w2 U9 F4 d! t1 N, z622862     ALLEGRO_EDITOR   ARTWORK              Allegro crashes when we enter a value in the field file size1 _8 l6 d) Q+ a) U& a6 b8 Y
622989     SIP_LAYOUT       IMPORT_DATA          Type of Wirebond die changed after die import
& M; z( s2 ]8 J' q5 c/ G5 h623182     SIG_INTEGRITY    FIELD_SOLVERS        Extract topology crashed
; }2 z1 ]8 w9 Z, y! R! [! W5 O5 T623300     SIP_LAYOUT       3D_VIEWER            Wrong placement of Solder Mask Bottom in 3D view file
+ e. ^* B. {0 ]% w# I1 D2 e' g% F6 U623384     ALLEGRO_EDITOR   VALOR                Valor output showing padstacks on 45 degree angle wrong in 16
, }: B4 D0 h% p2 ?4 L3 O% X6 C623489     ALLEGRO_EDITOR   EXTRACT              Allegro tools Report etch length by pin pair takes forever to  G- ?# O2 C* M* T9 v5 t4 n- z
623529     ALLEGRO_EDITOR   EDIT_ETCH            Manual tandem diff pair routing has been lost in the 16.2 rel  {' g7 N# ?' p! M' t( t
623536     F2B              PACKAGERXL           packager fails with memory allocation error  i: D" A' E* E7 O8 b/ j) x
623673     CAPTURE          OTHER                Unable to get capture window size to full-screen in dual disp
" e3 _! R( o8 Y! G# i/ u9 S623701     ALLEGRO_EDITOR   OTHER                'Analyze' menu missing when opening Allegro PCB Editor L - Pe
% h. H! V. j) Z2 n623738     CAPTURE          PART_EDITOR          Create part from spreadsheet is not working correctly* G+ E( Z  B. y( ?5 r0 d9 ^7 h) G
623740     ALLEGRO_EDITOR   OTHER                Can we use variant.lst file as list file in find filter% \+ I, D$ g% C
623745     CAPTURE          OTHER                Capture crashes when the user tries to place markers
/ g5 }( M1 z: C) c623813     SIP_LAYOUT       WIREBOND             Add wirerbond only is not working in this case with a bondfin! @% h) d8 c$ O, k6 C) c
623830     ALLEGRO_EDITOR   MANUFACT             backdrilling is drilling through component pads on the bottom  C6 Y: S$ ^$ j+ U
624048     ALLEGRO_EDITOR   OTHER                Viewlog for Export to 16.01 is not closing from any of the 'C8 m8 }" Z6 b7 f& I5 `. Y4 n( K' {. t
624223     ALLEGRO_EDITOR   GRAPHICS             disable_datatips variable is busted( p7 c4 U9 F) [, m$ ]+ F
624495     ALLEGRO_EDITOR   SHAPE                Static shape did not void to drill holes( {9 @4 G* I6 t6 Q! @! n. y
624599     SPECCTRA         ROUTE                PCB Router hangs on route of design
8 j1 s, N0 A4 k4 A; j, n624653     APD              BGA_GENERATOR        BGA Generator fails at 400um pitch
) S- Q) q& W0 l- S- ~+ d1 S; o624812     CONSTRAINT_MGR   ANALYSIS             Importing dcf at the system level causes RPD constraints not5 ?! B+ T1 C4 T: X
624888     ALLEGRO_EDITOR   DRC_CONSTR           Regions and RCI's Cset not working as expected
4 m  \, W. l2 d0 ]: P/ a% [624958     ALLEGRO_EDITOR   EDIT_ETCH            Slide in region is changing etch to min line width# I; g) o% r/ v& W5 m0 n
625251     ALLEGRO_EDITOR   COLOR                16.2 Linux allegro - new subclass created does not reflect in3 i# Z/ H5 T7 \9 {7 a
625273     APD              IMPORT_DATA          Import a .mcm into SIP in order to edit the die pins. Edit ->
& j0 _# r6 l* [0 |' T625279     APD              DIE_EDITOR           die text in fails when the function name is >31 characters wi1 |, J! I: Z. @! t5 ^
625304     SIG_INTEGRITY    IRDROP               Need a better understanding of absolute current values report
% ~1 e( H& u  U" W/ O0 M& o625367     ALLEGRO_EDITOR   DRC_CONSTR           drc_fillet_samenet does not work correctly
5 `8 E) w( Y  n0 z% V625551     ALLEGRO_EDITOR   SHAPE                Dynamic shape is not voiding to route keepout correctly
: _9 y# K1 M) c, D  K+ l625852     ALLEGRO_EDITOR   DRC_CONSTR           Some buses in CM are disappeared after import CIS 3 .dat netl$ ~! t" K4 s& l# M8 Q
625885     CAPTURE          DRC                  Report misleading Tap connections check for DRC reports error8 }" Q0 n2 U/ f! H# g' U2 q% D
625972     CONSTRAINT_MGR   TECHFILE             techfile import fails with Failed writing object attributes, Q! _' V) E: |- O9 `
626630     CAPTURE          NETLIST_ALLEGRO      Capture 16.20 hangs endlessly but Capture 16.0 prompts result+ _/ W( s  a; @' W9 e7 s) c! a
626669     SIP_LAYOUT       OTHER                16.2 radial router find filter does not have option for bond
: e+ m3 N) A$ h9 e9 S  t' l# ?626671     SCM              OTHER                Adding signals in ASA is taking too long" B$ l( w9 R, Q, \" O3 I7 D' r
627228     ALLEGRO_EDITOR   MANUFACT             Dynamic Fillet is disappered, when use slide command.
3 v" i, t$ o' W2 }627289     SIP_LAYOUT       DIE_GENERATOR        Pins connect at the same net name after Die Text In
1 s/ I! e  K7 J2 T5 S  Q627864     CONCEPT_HDL      EDIF300              EDIF c2esch crashes. H5 Q% }& m, J6 |3 S
628169     ALLEGRO_EDITOR   OTHER                write command changes design name in constraint manager# [# U7 t& o5 a/ Q
628220     SIG_INTEGRITY    SIMULATION           Reflection simulation failed with filed solver "EMS2D"! m+ b' Z8 s; z9 N" T9 S
628261     APD              OTHER                no "Tangent Via Line Fattening" in APD products+ Z) u1 t' k6 f; ~
628922     APD              REPORTS              Metal Area Report shows 0.00 on one layer3 F9 `3 ]1 T, h3 Z# g
HOTFIX VERSION:  0011 A" W8 t" _" x/ `3 K3 \
0 ]( G% k4 [& X5 x0 K" uCCRID      PRODUCT          PRODUCTLEVEL2        TITLE
1 L% }0 F0 X# _* n* U5 A: M========================================================================================================# {6 t6 @; \% E: Y. G
191020     ALLEGRO_EDITOR   SHAPE                Shape edits results in same net DRC being reported.' ^! N" L" b) Q2 u4 v
230469     ALLEGRO_EDITOR   SHAPE                Allegro improve performance of Dynamic Shapes9 N& q9 V: R: }/ `
295039     ALLEGRO_EDITOR   DFA                  Allegro DFA to be enhanced to include height
( p; l) S7 d' _. u4 c; L346863     CIS              DESIGN_VARIANT       Variant View mode is not working for multi-section parts
2 I# N& x# c3 R) S8 V: q6 [3 i400036     CONCEPT_HDL      HPF                  nihongo_vector_font should be listed in the Plot Setup GUI+ a4 g/ ~; G3 R8 \4 O
410092     CONCEPT_HDL      OTHER                The Imported sheets loses the write permission for the group
7 `$ k+ |/ k- F% ^3 d! K+ z- Y5 B/ E415462     CONCEPT_HDL      MARKERS              The SPB157 Markers does not normally display the Japanese fon
! D" S& q; p% A4 y2 M501802     ALLEGRO_EDITOR   GRAPHICS             When hilighting parts or nets the system is inconsistent on z
  ]0 y- h4 z! d4 z503526     SPIF             OTHER                SPIF is NOT defining class for class to class rules., F1 d0 g- k. H: t5 N- s
511175     CONCEPT_HDL      CORE                 Copy All causes - No object selected error
4 I) u7 `5 _% a; Z9 r526774     LIBRARY          DEVELOPER            Pin抯 text size goes back to default size after change pin na9 B( t& S) p3 X. C
533536     CONCEPT_HDL      OTHER                The font used in published PDF is not identical.; d. [3 I- s0 C. @
537769     CONCEPT_HDL      CORE                 Sporadic behavior of DE HDL toolbars for adding components ge  j- v( F! u6 Z% z
544519     ALLEGRO_EDITOR   mentor               mbs2lib Generating extra "b" version of footprint during tran
. C% S. A' r! V551528     LAYOUT           OTHER                Layout2Allegro L2A translator not translating reference desig
1 r% U% Y. P' G( _1 Q# w; h551614     SIG_INTEGRITY    IRDROP               Import and export of IR-Drop setup! ]9 @$ ]& u& x  m4 K, W
552127     LIBRARY          LIBUTIL              When -lib is missing from con2con PTF files get re-written in
# q; N1 V; D! I$ H560417     ALLEGRO_EDITOR   OTHER                Part Logic does not read part row from ptf file and assign in5 i! m/ c( c  s# ^4 _3 }
564954     CONCEPT_HDL      CREFER               Crefer attaches $XR property to other $XR on RHEL.9 u1 f8 `2 \+ ?& T$ x8 l
565798     CIS              DESIGN_VARIANT       all the sections of mult part package are not coming as DNS i' [, T, {: O3 ~* Y' n
571627     CONCEPT_HDL      CONSTRAINT_MGR       cmuprev fails to synchronize constraints on low assertion vec! r' k5 n* d8 _! Q: L$ y$ v
577915     CONCEPT_HDL      ARCHIVER             zero folder is not archived how the archiver is working ?/ Q, X4 _  _1 K4 S' d' B/ H
581446     LAYOUT           TRANSLATION          L2A fails with pin numbers do not match between symbols from
, d9 A3 O8 M9 q+ p3 p$ G4 @0 n  \583891     ALLEGRO_EDITOR   MENTOR               Mbs2brd will not run with PA5630 license (Allegro PCB SI GXL)
" {: A7 C7 W4 i) R$ q1 G586998     ALLEGRO_EDITOR   PLOTTING             Board shifts towards top left when plotting at higher resolut) E1 |9 A+ y) n: \* B, G, S6 H) g
587870     ALLEGRO_EDITOR   PCAD_IN              Import PCAD fails due to dupliate pad name.  Caused by a peri! P, F$ }% T1 W2 A) A
588949     CONCEPT_HDL      CORE                 Importing schematic pages from another project crashes Concep
8 r7 ^- B: y$ T; i0 t1 d592340     ALLEGRO_EDITOR   MENTOR               MBS2LIB not creating the correct shape in symbol
8 f4 g2 H) ^7 B  ^1 s) o3 }596530     ALLEGRO_EDITOR   PADS_IN              PADS to Allegro Translator removing/renaming reference design
% T* V- N8 S$ P" u; h: f# w0 p596638     ALLEGRO_EDITOR   EDIT_ETCH            The timing meter indicates untruthful violation! N- T) \( P0 N' F$ t/ A
596716     Pspice           DEHDL                Flag error due to part pin mismatch while create netlist' @" u. a; ]9 S, f
597685     ALLEGRO_EDITOR   SCHEM_FTB            ratnest are out of date error in DBDoctor after import logic7 U# \& ~, C7 I
597937     ALLEGRO_EDITOR   PADS_IN              Request PADs_in to translate keepout areas9 h& v, }. z6 p4 g- V7 S9 u6 {
598575     ALLEGRO_EDITOR   OTHER                During Split plane should it use settings regarding fill styl
/ I4 X+ G" _8 U6 S) `$ M% s/ S' Y8 p598814     APD              WIREBOND             bondfinger does not move relative to its origin using ipick( R3 y; I; |9 a9 e
599823     CONCEPT_HDL      CONSTRAINT_MGR       Lost ref to dml-lib causes loss of cm data even if the refere! Q# N7 D/ T3 ?  i( g: K+ r  V8 J1 H! X
599886     APD              EXPORT_DATA          bodygen batch tool is failing to generate .css file4 f0 S7 r$ u0 ], `, X
603425     SPECCTRA         PARSER               Do file fails Syntax error in command unexpected end-of-line7 r0 p( j; Y: N" S$ h9 G) N' _) I9 P$ p
603987     APD              OTHER                Offset via generator should ensure pitch distance is met or e  ~, D8 j/ |2 V+ X* n
604377     SCM              PACKAGER             Output board name containing a dash causes scm crash
+ y9 U# l% w, ?7 W; v604614     CONSTRAINT_MGR   OTHER                netrev is unable to update the Canonical paths with the new d
" E, \) X1 n- H/ o7 U) F604794     ALLEGRO_EDITOR   PAD_EDITOR           Replace Padstack reports error pad missing not true.
4 C, G: J3 k7 y% F# ^+ u& j3 @5 s605169     ALLEGRO_EDITOR   OTHER                Can design_compare handle swappable pins?, h% [1 X* @8 q
606586     ALLEGRO_EDITOR   INTERFACES           Multiple drill in padstack cannot be shown in Pro/E IDF; J  v8 `- s+ B+ t, Q( Z: \
607217     APD              IO_PLANNER           wirebond die replacement from IOP
% A8 _: H  E; m  X3 D607222     APD              WIREBOND             auto wirebonding creates wirebond with DRC
" c) T. U9 e* t607644     ALLEGRO_EDITOR   MANUFACT             Enhancement to increase the IDF export ''default package heig
! Z/ u" ?; d6 E0 Z( c( Y  d607718     CONCEPT_HDL      HDLDIRECT            HDL Direct Errors reported while generating simulation netlis
7 O* ]1 Q" j7 E$ y608233     SIG_INTEGRITY    FIELD_SOLVERS        Convergence errors with analytical vias when drill size is 1$ Z8 B0 s. z4 C4 U
609549     ALLEGRO_EDITOR   INTERACTIV           Mirror Geometry command to change BB Via's layer.
! \/ ?# [9 _9 ]1 H610028     SIP_LAYOUT       IMPORT_DATA          De assign NC nets during aif import
6 a  B* S0 D, }0 R" ^9 }6 A2 h+ C610134     CONSTRAINT_MGR   INTERACTIV           Cross-probing from CM to Allegro no longer works on system le! B( v. O% J! U6 k6 ?4 W7 o
610276     ALLEGRO_EDITOR   PADS_IN              PADS to Allegro translation is failing with error.
. Z, M) {; o5 \& W. @" ]610482     ALLEGRO_EDITOR   SCHEM_FTB            Netlist swapped net names on 2 pins causing shape to lose its# f9 Y# g' f0 d; V
610681     CONSTRAINT_MGR   DATABASE             An exported constraint file can not be re-imported in V16.01& m5 M( g) ]" s0 p3 A+ J; {5 {1 ]8 u
611260     ALLEGRO_EDITOR   DRC_CONSTR           Routing a diff pair it does not follow Physical line width se: t- y! `7 ^/ z5 x# s1 X2 q7 P
611425     ALLEGRO_EDITOR   MENTOR               mbs2brd crashes when importing Mentor) ]3 p8 y; \0 V
611697     SIP_FLOW         SIP_LAYOUT           octagonal bumps have offset in SIP compared to the chip view
) F; s/ v3 g0 ]611807     APD              WIREBOND             Duplicate paths created on wirebond import for some cases.7 D8 o% p+ n! T2 R% x! F# x
611856     CONCEPT_HDL      GLOBALCHANGE         Ref des deletions after runnning Global Change to change $LOC# }0 W  a: p8 A$ ~9 A5 @
611874     CONCEPT_HDL      OTHER                Crossprobing one symbol in Concept using Occurence edit mode5 a& x4 C6 S( T
612088     PSPICE           DEHDL_NETLISTER      Fail to create the netlist for G value expression( I/ A, `9 q* S- J: m
612195     ALLEGRO_EDITOR   DATABASE             Adding layers to the default cross section causes phantom tex
) p: _  N0 ]$ a  c  f2 h8 M2 p2 {3 ?612237     ALLEGRO_EDITOR   SKILL                axlFormColorize does not change the full background area of a- q3 F, h) V* ]8 Y; b
612299     APD              DEGASSING            Degassing static shape creates voids inside of voided areas
. X) O+ m2 S2 n* @, O! |& b612560     CONSTRAINT_MGR   OTHER                Diffpairs don't show the CSet assigned through Net Class
# U! @- p1 \7 D; }! }: i612587     APD              WIREBOND             Unchecked Allow DRC option creating disconnected wire bond.) u( t* Y3 N- x% K+ r
612884     SIG_INTEGRITY    SIMULATION           When using ViaModel, J$ i) t# `+ A: A" }8 f  C
612914     ALLEGRO_EDITOR   EDIT_ETCH            Centered via option in fanout command not available when swit/ [: D: e: L0 y% r/ @$ g
612939     SIP_LAYOUT       ASSY_RULE_CHECK      ADRC Continuous Solder Mask check problem
4 I' w" W7 F3 A1 S613553     CONCEPT_HDL      EDIF300              edif schematic writer crash on this design: X  z, k! v$ h: X# @
613565     ALLEGRO_EDITOR   EDIT_ETCH            Allegro Editor Differential Pairs are routing incorrectly
8 _# I1 ^, U: s2 d/ H613736     SPIF             OTHER                Spif fails to write class data" j( O9 q% L( n  _/ Y& ^
613990     POWER_INTEGRIT   INTERACTIV           PI is crashing during capacitor selection
! g. C( Y' o+ s) s9 P5 \% ?' Q614278     CONCEPT_HDL      EDIF300              pin text note and flag are not visible on reloaded edif file
: o7 o* i3 A7 R, l) X) q614371     SIP_LAYOUT       WIREBOND             Any wirebond command crashes the application
( R: Y2 d' a2 j% R( N: D' K614407     POWER_INTEGRIT   INTERACTIV           PI crashes when editing capacitors6 t# ?( x3 P/ p8 f! r& Y' l; z
614727     SPECCTRA         GUI                  Allegro PCB Router can not process the dsn and rules file for+ _2 o; b  V- S8 H
614972     ALLEGRO_EDITOR   SKILL                axlCNSSetSpacing does not change the value of the "testvia to
+ N# F2 F* }4 O5 q* ^( H/ l615144     SIP_LAYOUT       3D_VIEWER            die placement does not change with changing in soldermask thi" T+ x8 e7 n. m! i$ F, d
615431     LAYOUT           TRANSLATORS          padstack names are crippled or renamed if it has over 18 Char
; A# O+ T, t  g5 ]0 V; ^615506     APD              MANUFACTURING        Sort by die pin location for Manufacture Doc Bond finger brok  q0 E7 R) `; @4 g7 S/ \6 I9 V
615745     SIP_LAYOUT       DATABASE             Move die symbol with stretch etch on is disconnecting wires f
% F: B2 Q+ l" s615816     SPIF             OTHER                Allegro match group members not translating to PCB Router; mi
/ H' ]. J5 B$ {9 ~- w616104     CONSTRAINT_MGR   OTHER                allegroTechnologyFile XML format issue
* P" k- j" e- F0 `616122     LAYOUT           TRANSLATORS          protel to MAX translator problem with package outlines and re4 B2 q! s6 {: S+ ^
616404     ALLEGRO_EDITOR   OTHER                Design compare fails with message "Invalid input argument" wh
" g8 q9 n$ I' G3 J$ q4 N# P# g616713     CIS              PLACE_DATABASE_PAR   property name with "&" charecter in access database causing c8 E- w0 V- L& M4 v
616818     SCM              PACKAGER             BOMHDL -type scm fails on schematic block
) E( u) G' _$ g% m( o2 p# P( A616907     SCM              VERILOG_IMPORT       scm crash during Get Module Name# U& @" e- [7 z7 b
617058     APD              WIREBOND             wirebond space evenly does not work for fingers on power ring8 l4 ^: k1 ?' G) {# v& G* V& I
617083     ALLEGRO_EDITOR   INTERACTIV           Windows tabs hangs on Linux
! k$ b# Z( U1 R: N" m617236     ALLEGRO_EDITOR   SHAPE                Editing a shape in a void causes the bigger shape to drop seg& |  e9 [1 u& m( l& I
617351     CIS              DBC_CFG_WIZARD       XML writer fails if DBC location doesnt have write permission$ j, ]4 ]$ M* U& j/ k* D
617515     SIP_LAYOUT       OTHER                Be able to invoke Velocity from cdnsip
5 l2 u) x) l7 T$ w, R  |617761     LAYOUT           TRANSLATORS          Value property for Library symbol of orcad Layout is not tran- D' [5 W! B7 c: Y
617890     SIP_LAYOUT       WIREBOND             Push and shove on Bond fingers with multiple bond wires cause
& a) S* R. R( I1 h% Q) Y, q- o618184     APD              OTHER                database diary on unix/linux
& A/ E2 Q. F9 b3 f$ c1 \618201     ALLEGRO_EDITOR   OTHER                Dynamic fillets take a long time to complete
! R* `* X: J$ Z618545     ALLEGRO_EDITOR   INTERACTIV           Allegro crashes when we place a package symbol for Jumper usi: ~7 g  }0 Q- f1 ]7 w  m# G( ^
618610     ALLEGRO_EDITOR   MANUFACT             Delete a cline seg creates a fillet9 a9 U) ^% Q/ n  l' j3 J# V  H
618651     SIP_LAYOUT       IO_PLANNER           Bondfingers and die are shifted every time an update package
: A* K& @, V+ O. D1 f8 T7 h7 ]618712     ALLEGRO_EDITOR   EDIT_ETCH            Shove mode is not working on Diff pairs in PCB Design L; q$ m; e( @5 t+ y8 ?5 g8 V! Z
618836     ALLEGRO_EDITOR   SCRIPTS              Allegro does not interpret recorded macro script files proper( ]- J& w: z$ x% _7 y
618946     ALLEGRO_EDITOR   INTERACTIV           Allegro crashes while using Place Manual -H/ ^' s# i& ]: E- F) D
618984     ALLEGRO_EDITOR   COLOR                Layers on Allegro Canvas does not match Color Dialog Box
8 t. f; G2 Q$ C! D; W) W619007     ALLEGRO_EDITOR   SKILL                Skill command does not accept spaces in file path/name
$ t" p6 |# N  G# H* I) D619033     F2B              PACKAGERXL           Pinswap lost on backannotation/ T/ g) r5 F- ]
619268     POWER_INTEGRIT   SIMULATION           IR-Drop can't sees via on pad as open
" K2 `9 R) V2 C1 C0 ^; {% T* [619356     CIS              FOOTPRINT_VIEW       Footprint preview only from 1 directory in Capture.INI4 w, n! Z" v' \' H0 _# R! M
619712     ALLEGRO_EDITOR   EDIT_ETCH            Unable to route in the Bubble Mode for Partitioned board8 K, ~$ H# s9 L8 E
619773     ALLEGRO_EDITOR   DATABASE             Uprev for 13.6 and 14.0 files not working with SPB 16.2 on Wi
9 ^% M* w8 I( ~' `, T( _620064     CONCEPT_HDL      CONSTRAINT_MGR       Loosing Diff pair constraints from lower blocks when packagin# F  \4 `+ _" ]+ A
622132     CAPTURE          NETLIST_ALLEGRO      Incorrect ALG0078 error for complex hierarchical design
GMT+8, 2025-10-11 19:09 , Processed in 0.171875 second(s), 24 queries , Gzip On.
