================================================================* T! N4 g# i6 S' i
PROCESSING FILM < l1top.art > ...2 ~3 V) y5 [/ _! }0 {* M/ u. z6 {2 B1 A
& C7 C3 p. Z1 g7 B. W0 P1 Z6 R
) K( }* g8 c( k3 k0 { FILM PARAMETERS :$ s$ P9 Z/ q7 B! N8 @) D* `* |
---------------------------------------------------------! r7 [' U6 z" u( A( k! g% a
Undefined line width 0.0004 v z/ f+ W+ U9 n+ d1 O1 b
Mirror code NONE6 @# z' X* i- U
Rotate angle NONE3 y7 i1 v3 q7 p0 Q0 ^
Offset x: 0.000
( D8 r9 v# N8 Z* q4 ~ Offset y: 0.000* \3 e/ j* c! h* P/ v
Plot negative NO
* a% s/ h7 P3 Z+ I Suppress unconnected internal pads NO
- h2 Z$ ^1 S. @! }+ @, [) x# V+ Q; G7 y6 T7 q
WARNING: rectangle or unfilled shape composed 0 width line found at (3950.567 2168.898)
0 v2 H6 m% Z/ |3 ~! V3 y/ v ... ignored!6 H6 `5 { k/ y# N% A
. z, S% G% |8 n2 k9 g* o
WARNING: Shape at (6600.772 3592.772) contains void at (6600.772 3592.772)
2 ^- @4 G) r% T( y2 J which touches another shape.
0 b% ~6 B( T9 _! q. ? You need to manually resolve this problem.) i/ Y- x' z% q- j- ~
( I$ Y0 { f6 O8 k
ERROR: aborting film - artwork will not be generated!
! h; w' g6 b e3 a4 t Error in l1top--halting output. Artwork file not generated.
1 d/ s! Z# I' K' O- U *** ERROR with l1top
" N' A0 C2 p" {8 N% p* zSUMMARY:/ y" o* h" Z+ w) j: y
: g, d2 z9 T9 {3 { J: P- p5 u l2sig created with warnings
& {6 n0 Q2 s( j: w/ t w l3sig created.% L( U( _/ h. S- V$ Q3 C1 E
l4sig created with warnings$ M3 `1 z9 L0 R+ ?8 C& j* e
l5sig created with warnings
. S& Z4 t4 y) O; F l6bottom created with warnings, L( f4 Q, ]* l, r
l6mask created.
2 k8 X6 S8 F8 [( Y* d5 s1 d) f l6silk created with warnings
) p7 U/ `+ ]& e& r. W l6paste created.
6 Z6 ~2 u# g! ?; C; K# e/ d: G l1mask created.
/ U R/ L) U% k l1silk created with warnings
$ ^6 e3 }! A5 h/ L7 q1 c' X l1paste created.
7 m" E/ u8 |: C: ^
2 Q0 h' o( y; N3 {% D+ g8 k* ]) f ARTWORK Error
. q& ^5 b8 a0 F% E1 m9 A4 S1 q3 i7 s0 f' W
啥错误我的也导不出啊 |
