查看: 3050|回复: 2
allegro出光绘前不规则焊盘生成.rou文件,提示成功但是找不到
发表于 2018-4-26 12:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Processing NC Parameters file 'nc_param.txt' ...8 E" m3 p& r) [$ ~! S! t
, R( a+ w1 j7 A, N7 t3 @8 R- N- k
NC PARAMETERS  p: Q' c. v6 g9 l9 o9 C8 M
-------------) `# @8 O. t' f- O4 z, b+ A
% E8 H* v) u1 I' H3 U8 O
FORMAT                   2.5
5 z& h* `( L" S7 h9 V0 h0 U$ z MACHINE-OFFSET                x:0.00000        y:0.00000   (inch)
+ Z9 c! w8 o' B+ p4 ^, N' x FEEDRATE                12 p8 R  Z. A0 n) g+ W
COORDINATES                ABSOLUTE
: ?% f; O, P$ `! n4 X" l OUTPUT-UNITS                ENGLISH! K/ x. a( a- \  d6 |
TOOL-ORDER                INCREASING! j2 ?1 J9 W3 N0 p, @5 ~& U4 F: p
REPEAT-CODES                YES- z! S1 S* [1 A, }. @( }
SUPPRESS-LEAD-ZEROES        NO7 l) Q! f4 p; R! D& O
SUPPRESS-TRAIL-ZEROES        NO2 ]$ g/ ]8 q% }- ^
SUPPRESS-EQUAL                NO
( h1 k1 Q, ^6 y4 K5 A1 {" S) S1 l& U" J TOOL-SELECT                NO
2 `% T9 h; z5 k) F1 g HEADER                        none
' P$ X2 l. t  T  U; o( x LEADER                        12
  G7 |# M* Y( T' |% O CODE                        ASCII
! i% Y. a/ i  D& F: C0 \ SEPARATE                NO9 h2 H. o' ~, Y5 e6 B5 B3 p5 F7 _
SEPARATE-ROUTING        NO
. A& ]. r6 B2 O! F OPTIMIZE_DRILLING        NO. y6 @1 g' G0 y3 T2 f7 x1 E1 B
ENHANCED_EXCELLON        NO
; I& x- H) Q! _ SCALE                        1.000000
3 L" x& i. T1 Z2 S: W4 Q/ Q6 s! x: q! h* w0 f9 Z8 N
WARNING(SPMHMF-326): Cannot find NC Route bit tool file 'ncroutebits.txt') p2 \, j/ Y( v% J
WARNING(SPMHMF-327): ... will auto-generate bit tool file 'ncroutebits_auto.txt'.1 `. r9 g2 p* T$ C& g: g
" _  P  ?* U4 C2 r0 o# s# [ Auto-generating tool file 'ncroutebits_auto.txt' ...+ e) o8 S# m1 {) W) B  r  Z( c  a
5 l2 ]4 m7 l7 G  e6 g! d-------------------------------------------------------------
8 L) m7 W1 S- g3 u4 K
5 S) K& J9 N1 I3 a) u Pre_processing route path data ...
  u5 Q. [7 d# {) \7 f2 d
9 v5 K  \0 |1 L3 A. ~7 K WARNING(SPMHMF-296): No route path data was found for processing." i" s* z2 T4 k+ ?
, F7 H* }# v# s+ T! [0 V7 I' h' a' Z5 |
, v9 n3 g' P' ^3 a, T
( V! l7 g* G# S) x- l: i0 d4 p8 z4 N5 K, r( ~6 j* i
Processing slot hole data ...2 Q0 p5 c, L% y- c" l( S; C
" c1 Z9 x: j; G! q! ? WARNING(SPMHMF-322): No slot holes were found for processing.
, G# _; Q1 Q2 m; N% H6 }-------------------------------------------------------------0 g' v' ]: j; p6 d$ r
% N1 ]; c, x& a0 d  T7 A7 M) o
Program completed., z/ E5 ~( i7 Q; l2 H, s2 Q  D
1 W9 _3 G% O4 k3 D% D9 \
. p& B2 m2 d* h. ~" i8 G+ u
    2020-11-5 15:08
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    发表于 2021-1-7 18:23 | 只看该作者
    我刚刚也遇到这个问题了,可能是板卡内部没有长孔的原因,没有的话就不会生成rou文件了
    是的,应该是这个原因,只有圆孔这个可以不出了  详情 回复 发表于 2021-5-24 10:41
     楼主| 发表于 2021-5-24 10:41 | 只看该作者
    baihushan 发表于 2021-1-7 18:23
    - G+ `8 O" x) r0 K我刚刚也遇到这个问题了,可能是板卡内部没有长孔的原因,没有的话就不会生成rou文件了
    " J' i+ c  F3 l# O) t! r
    是的,应该是这个原因,只有圆孔这个可以不出了, \* K0 k; l! A$ e
    GMT+8, 2025-10-28 00:09 , Processed in 0.140625 second(s), 27 queries , Gzip On.
