TA的每日心情 | 开心 2024-9-14 15:26 |
签到天数: 9 天 [LV.3]偶尔看看II
和这个电路很像
8 v! \2 O' [) s* C( ?5 vLoad Dump Protection:
8 ^) ^, t( O4 D2 @* K, L) E) V4.4 Load Dump Protection
9 C" N2 u; ?* VThe ISO7637-2 norm, see Section 3.3, “ISO7637-2 Norm”, specifies the load dump test pulse 5: +174V,& c, Y8 L4 U/ m- C$ u2 W
duration 350ms.
- g4 }) v( W: a9 ^+ Y0 B5 K5 @In the case of a load dump condition, the Q1 P-MOSFET turns OFF and disconnects the power supply line.
' c: t; S7 m% bWhenever the C3 voltage rises above 32V, the zener diode D4 opens and the Q2 turns OFF the Q1. If the
2 Q- s. K) I$ E6 J. z5 AC3 voltage drops down below 32V, the Q2 turns ON the Q1.
3 Y3 u# v& E0 I5 c$ |: `4 M' |3 NThe diode D2 limits the Q1 gate-to-source voltage.
' k' T) {# k) H3 T' P$ s2 m/ N* u/ X" b5 } g4 s M; y J- g
6 }+ `/ M7 f0 c. U/ X h
