查看: 927|回复: 7
求助:文字转shape
发表于 2018-4-10 20:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
因为文字的Bbox比文字本身要大一些。所以想把文字转为shape再去比较文字和文字以及文字和其他东西有没有重叠。
之前在网上看到过大神提供的思路:先用axlText2Lines ,再用axlPolyFromDB,最后用axlDBCreateShape,但是我试了一下午都没有成功。有高手可以帮忙看看吗?或者有其他更好的办法不。我的最终目的是要判断文字和文字、焊盘、零件外框之类的有没有重叠。感谢感谢~~~
发表于 2018-4-11 09:32 | 只看该作者
axlCmdRegister("c2s" 'LCB_cline_to_shape ?cmdType "interactive"
?doneCmd 'LCB_Done ?cancelCmd 'LCB_Cancel)
axlSetFunckey("cts" "c2sXXX")
procedure(LCB_cline_to_shape()
let( ()
axlSetFindFilter(?enabled list("noall" "clines" "lines" )
                  ?onButtons list("noall" "clines" "lines"))
LCBpopup = axlUIPopupDefine( nil (list
    (list "Undo" 'LCB_unDo)
    (list "Done" 'LCB_Done)
    (list "Cancel" 'LCB_Cancel)
axlUIPopupSet(LCBpopup)
LCB_mark = axlDBTransactionStart()
notdone = t
while(notdone
  lclines = axlGetSelSet(axlSelect(?prompt "Select Clines to convert to a shape."))
  if(lclines then
    foreach(clinedbid lclines
      ;layer = "etch/bottom"
      layer = car(axlGetSelSet())->layer
       polydbid = axlPolyFromDB(clinedbid ?endCapType "ROUND")
       if(polydbid then
        ;axlDeleteObject(clinedbid)
        if(! axlDBCreateShape(car(polydbid) t layer)  then
          axlUIWPrint(nil "** Error. Failed to create Shape from Cline. **")
        ); endif
        if(cadr(polydbid) then
            axlDBCreateShape(cadr(polydbid) t layer)  )
       else
        axlUIWPrint(nil "** Error. Failed to create Polydbid from Cline. **")
       ); endif
    ); end foreach cline
  ); endif
); end while
axlDBTransactionCommit(LCB_mark)
)); let and procedure
procedure(LCB_unDo()
let( ()
  if(! axlDBTransactionOops(LCB_mark) then
    axlUIWPrint(nil "-- Nothing Left To Undo. --")
  else
    axlUIWPrint(nil "-- Replacing Clines. --")
  ); endif
  axlClearSelSet()
)); end let procedure
procedure(LCB_Cancel()
let( ()
  axlUIWPrint(nil "** Cancelled Program. **")
  ;axlDBTransactionRollback(LCB_mark)
  notdone = nil
  axlClearSelSet()
  axlCancelEnterFun()
procedure(LCB_Done()
let( ()
  axlUIWPrint(nil "- Done -")
  notdone = nil
  axlCancelEnterFun()
)); end let and procedure
改天再来研究下你这个。感谢Jordan童鞋~~  详情 回复 发表于 2018-4-11 16:20
楼主要的是文件转图形,不是铜线转图形  详情 回复 发表于 2018-4-11 10:48
发表于 2018-4-11 09:34 | 只看该作者
cline2shape.rar (838 Bytes, 下载次数: 0)
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2018-4-11 10:47 | 只看该作者
    lines = axlText2Lines(text)
    paths = foreach(mapcan x lines x)
    tPolys = nil
    foreach(path paths
          polys = axlPolyFromDB(path ?endCapType 'ROUND ?line2poly t)
          foreach(poly polys
                 tPolys = axlPolyOperation(tPolys poly 'OR)
    unless(listp(tPolys) tPolys = list(tPolys))
    foreach(tPoly tPolys
          axlDBCreateShape(tPoly t "BOARD GEOMETRY/SILKSCREEN_TOP")
    这个方式仅限于16.6及以上版本使用
    试了,很好哦,非常非常感谢您  详情 回复 发表于 2018-4-11 16:19
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2018-4-11 10:48 | 只看该作者
    ?doneCmd 'LCB_Done ?cancelCmd 'LCB ...
    楼主要的是文字转图形,不是铜线转图形
     楼主| 发表于 2018-4-11 16:19 | 只看该作者
    tPolys = nil
    试了,很好哦,非常非常感谢您
    检查文字是否与焊盘重叠,可以用axlPolyOperation(tPoly pPoly 'And)判断  详情 回复 发表于 2018-4-11 16:29
     楼主| 发表于 2018-4-11 16:20 | 只看该作者
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2018-4-11 16:29 | 只看该作者
    chengcheng123 发表于 2018-4-11 16:19
    试了,很好哦,非常非常感谢您
    GMT+8, 2025-8-21 14:17 , Processed in 0.156250 second(s), 33 queries , Gzip On.
