查看: 3910|回复: 8
orcad library builder 16.6.62创建PCBfootprint库导出后没管焊盘管脚?
发表于 2018-3-4 23:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在创建PCB footprint库导出时,没有焊盘不知道什么原因?如图所示,并出现下面提示:E- (SPMHAP-2): No padstack specified.E- (SPMHAP-3): Problem loading 'c45.pad'.; [; f) \- T! ~# \% F! @: ^! c0 j, V( s" Y: A6 u* ^4 C
E- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file." Q* @' ^( w" D) ^4 E! t# L0 E
E- (SPMHAP-2): No padstack specified.4 A) [6 B5 @6 ~& o, J0 r% D% A; |# `3 _1 ^; t! E. N
E- (SPMHAP-3): Problem loading 'c45.pad'.: |7 l' m) @9 ]' K
: y9 }: w/ I  N, K9 t! f  k9 zE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.
: u6 r) {* `4 t) b0 `  IE- (SPMHAP-2): No padstack specified.2 p3 \5 F$ c$ f" u+ I1 V  }& N& e! k, W7 H3 ^  }2 e8 n
E- (SPMHAP-3): Problem loading 'c45.pad'.1 B) l# ~! d% X  E& V2 O
* H- e+ F+ ?  D9 l8 a5 u% g' ]4 [* CE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.8 w/ I$ p2 s! f" f  I4 E; _; R! ^; k' k7 v# w- ^+ u  k
E- (SPMHAP-2): No padstack specified.! y3 Z/ p( v. P* A( T  w/ ~$ ~4 _$ Q
E- (SPMHAP-3): Problem loading 'c45.pad'.+ k5 B: [8 `+ y# _" `
7 s0 z6 m8 f! E8 vE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.* K# J0 O* q) @0 U, _
E- (SPMHAP-2): No padstack specified.1 n/ b, r. c$ B9 y1 A7 E2 }7 x
$ f2 S) @9 }- a) A8 W2 cE- (SPMHAP-3): Problem loading 'c45.pad'.
& d0 u5 T5 J0 D' ]3 TE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.9 C$ x% y# Z$ Z' _2 x
: M! H; i  J) R: @5 [. @! kE- (SPMHAP-2): No padstack specified.9 Y8 r5 K6 U# A2 _# F: p+ Y4 X, L- R- z. c1 }1 @
E- (SPMHAP-3): Problem loading 'c45.pad'.: F7 H8 C6 t2 ?6 u3 Q5 i7 W. w# l: `- j+ M5 K' S* R
E- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.; S2 _5 t8 ^1 F4 I  P2 I2 e) O/ i9 n7 o. }; A
E- (SPMHAP-2): No padstack specified.! W+ r! j/ e! b- [& b
+ C8 s8 B) P+ Z9 f  `, `- ?E- (SPMHAP-3): Problem loading 'c45.pad'.* p) ]! r* U. z2 x( k1 H
9 }0 ~* S. U) i/ QE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.5 Y7 s; s5 ]: Z
 楼主| 发表于 2018-3-5 00:10 | 只看该作者
2 、在allegro中,软件默认的焊盘那些路径不能删除。即padpath路径下的$padpath不能给删除;出现此问题只和padpath路径有关系,和psmpath路径没有关系,路径设置如下(可以在原来的基础上添加其它路径): 1! D/ N( A: x9 `6 f) D, w& S, P9 M
    2024-8-22 15:58
  • 签到天数: 22 天
    [LV.4]偶尔看看III
    发表于 2018-3-5 11:08 | 只看该作者
    export libraries 之前先把要导出到 的folder 路径也加到padpath 里面
     楼主| 发表于 2018-3-5 21:12 | 只看该作者
    为啥通孔类的没有焊盘了 擦  能否给个详细的教程
     楼主| 发表于 2018-3-6 16:46 | 只看该作者
    能不能自动 DB doctor 生成的焊盘总是有问题
     楼主| 发表于 2018-3-14 22:50 | 只看该作者
    能有大神给个解决的办法了 多谢了
    发表于 2018-3-16 22:33 | 只看该作者
    你能够导出OLB文件吗
    ) a/ V) \) F- K3 K% D  K
    发表于 2018-8-2 16:30 | 只看该作者
    我的也是,问题我之前版本没问题,后面卸载重新装了就不能生成封装了
    GMT+8, 2025-8-20 09:57 , Processed in 0.109375 second(s), 23 queries , Gzip On.
