3 t+ L1 @/ x5 Q9 `, u( ^5 q; ]5 y/ I5 [5 Q/ m$ n( t# |3 @2 }
TLF有了cadence SPB16.2 Hotfix。但级别太低,老连不上服务器,下不下来。谁有呢?分享一下??
- ?5 W, @" O3 x- _) a% {# t2 I
7 W) ]4 G8 K$ D& q已上传至Cadence_SPB16.2_by_dzkcool目录下。
/ A3 i% i( D8 \& u- M: L20 Dec 2008 SPB16.20.001, Version: SPB:Hotfix:16.20.001~wint
# |6 [1 ^3 R# A- x2 i" q; a' K6 [打了补丁后记得要重新用nolic破解一遍。
% |8 p* p' @" O ~% @; b9 u9 t
2 C5 h. |- A8 N- z6 ]3 WHOTFIX VERSION: 001
! s/ I) W; M7 N' @8 P' M========================================================================================================
1 H) f% K) M/ ECCRID PRODUCT PRODUCTLEVEL2 TITLE
8 b3 E) @$ m3 ?) a8 A========================================================================================================# O8 i- x2 r0 M, `, x) B
191020 allegro_EDITOR SHAPE Shape edits results in same net DRC being reported.; R1 T/ m5 O2 Z$ @ K# {1 J8 j
230469 ALLEGRO_EDITOR SHAPE Allegro improve peRFormance of Dynamic Shapes3 W! f9 D. b8 o" m, N; F
295039 ALLEGRO_EDITOR DFA Allegro DFA to be enhanced to include height
+ R, a' S6 u/ i/ C9 W& _9 q346863 CIS DESIGN_VARIANT Variant View mode is not working for multi-section parts
, e( @ s7 W2 T, D5 I8 X400036 concept_HDL HPF nihongo_vector_font should be listed in the Plot Setup GUI
4 _7 T4 \$ _- K% j7 ~, ?410092 CONCEPT_HDL OTHER The Imported sheets loses the write permission for the group
5 @/ k! Z. Y% }8 H415462 CONCEPT_HDL MARKERS The SPB157 Markers does not normally display the Japanese fon
4 W* ?0 c: w' n) m501802 ALLEGRO_EDITOR GRAPHICS When hilighting parts or nets the system is inconsistent on z
; E) \2 m N: [' `& Q503526 SPIF OTHER SPIF is NOT defining class for class to class rules./ I9 x' u; B5 L" q# J2 C
511175 CONCEPT_HDL CORE Copy All causes - No object selected error
- B8 R3 c$ k( _526774 LIBRARY DEVELOPER Pin抯 text size goes back to default size after change pin na
_9 {5 c; F+ Q( }, d533536 CONCEPT_HDL OTHER The font used in published PDF is not identical.5 i4 n4 }$ T, @, i1 d( h' H
537769 CONCEPT_HDL CORE Sporadic behavior of DE HDL toolbars for adding components ge
% r/ l/ C$ C3 g4 d544519 ALLEGRO_EDITOR mentor mbs2lib Generating extra "b" version of footprint during tran
W7 r% @. K n( e3 j( c m551528 LAYOUT OTHER Layout2Allegro L2A translator not translating reference desig& {8 v( D! D, H2 r8 p0 k$ [
551614 SIG_INTEGRITY IRDROP Import and export of IR-Drop setup
- W9 h; {5 `& R! J+ o$ S+ ]552127 LIBRARY LIBUTIL When -lib is missing from con2con PTF files get re-written in: e/ Q* j* f1 J6 {6 @/ X' ^8 k
560417 ALLEGRO_EDITOR OTHER Part Logic does not read part row from ptf file and assign in" n9 y' R3 r2 }, Z8 ~: e, S% {
564954 CONCEPT_HDL CREFER Crefer attaches $XR property to other $XR on RHEL./ S+ T, W9 _6 \% W0 {7 Q+ ]0 L( D8 S# r
565798 CIS DESIGN_VARIANT all the sections of mult part package are not coming as DNS i
2 \ `4 G( u) J; N' ~8 k571627 CONCEPT_HDL CONSTRAINT_MGR cmuprev fails to synchronize constraints on low assertion vec( |' f: F6 t( S( `! P
577915 CONCEPT_HDL ARCHIVER zero folder is not archived how the archiver is working ?2 J; r4 b% c1 ?; I
581446 LAYOUT TRANSLATION L2A fails with pin numbers do not match between symbols from" a' x" M+ k+ {' ]! u
583891 ALLEGRO_EDITOR MENTOR Mbs2brd will not run with PA5630 license (Allegro PCB SI GXL), t9 @. N9 X: Y5 K% w3 ?! e0 V6 M% P, o
586998 ALLEGRO_EDITOR PLOTTING Board shifts towards top left when plotting at higher resolut
4 o5 O9 _' k& e/ @9 P# z W587870 ALLEGRO_EDITOR PCAD_IN Import PCAD fails due to dupliate pad name. Caused by a peri
9 p, B& x ^; y: C1 g& t588949 CONCEPT_HDL CORE Importing schematic pages from another project crashes Concep
- o* G0 |0 a# ~" A' k$ p; G592340 ALLEGRO_EDITOR MENTOR MBS2LIB not creating the correct shape in symbol! ^2 G7 G V# p2 Y& L7 W) i$ ^
596530 ALLEGRO_EDITOR pads_IN PADS to Allegro Translator removing/renaming reference design
2 Y8 a0 ~6 E; F( p6 Q596638 ALLEGRO_EDITOR EDIT_ETCH The timing meter indicates untruthful violation
9 g, h% f! v- g2 t+ N' x596716 Pspice DEHDL Flag error due to part pin mismatch while create netlist0 o u" F4 |% W7 \
597685 ALLEGRO_EDITOR SCHEM_FTB ratnest are out of date error in DBDoctor after import logic
: X. j- l0 F0 P$ I597937 ALLEGRO_EDITOR PADS_IN Request PADs_in to translate keepout areas
2 n' P2 D9 y5 c! [) F& b598575 ALLEGRO_EDITOR OTHER During Split plane should it use settings regarding fill styl- f" b: C6 }+ _5 N$ j2 m5 s+ ^
598814 APD WIREBOND bondfinger does not move relative to its origin using ipick; @; R, [1 H/ V9 @3 F
599823 CONCEPT_HDL CONSTRAINT_MGR Lost ref to dml-lib causes loss of cm data even if the refere
- j) V; E" H, E3 M0 P5 H/ y599886 APD EXPORT_DATA bodygen batch tool is failing to generate .css file
/ q- Q5 N& [& d7 Q603425 SPECCTRA PARSER Do file fails Syntax error in command unexpected end-of-line
/ P* {* k$ @1 p( b3 l1 C603987 APD OTHER Offset via generator should ensure pitch distance is met or e1 D1 q$ i( J& ?$ S3 T
604377 SCM PACKAGER Output board name containing a dash causes scm crash7 {6 D: g4 ^1 G* H, W6 _( t5 j
604614 CONSTRAINT_MGR OTHER netrev is unable to update the Canonical paths with the new d
6 i% m- j b! r; V& c/ m+ Q% a5 t6 y604794 ALLEGRO_EDITOR PAD_EDITOR Replace Padstack reports error pad missing not true., o7 ~0 \8 A3 r- a# T v o
605169 ALLEGRO_EDITOR OTHER Can design_compare handle swappable pins?
( Z8 T0 U3 s* a* h606586 ALLEGRO_EDITOR INTERFACES Multiple drill in padstack cannot be shown in Pro/E IDF3 N+ |2 d# ~. z; C7 B8 w# x6 s
607217 APD IO_PLANNER wirebond die replacement from IOP
8 o9 C& _' k( y% [& C- w7 o9 A607222 APD WIREBOND auto wirebonding creates wirebond with DRC0 @7 \8 t) | o: t3 \+ X
607644 ALLEGRO_EDITOR MANUFACT Enhancement to increase the IDF export ''default package heig; s' v9 P1 P; ~3 a$ L" L
607718 CONCEPT_HDL HDLDIRECT HDL Direct Errors reported while generating simulation netlis
7 N) m/ d! p* H5 |: i608233 SIG_INTEGRITY FIELD_SOLVERS Convergence errors with analytical vias when drill size is 14 v. {9 t6 V& L! P/ M6 Z# {
609549 ALLEGRO_EDITOR INTERACTIV Mirror Geometry command to change BB Via's layer.9 ]( R1 j. R3 k$ a8 ]
610028 SIP_LAYOUT IMPORT_DATA De assign NC nets during aif import- G7 r) W6 m2 S# V/ l; M* A& I
610134 CONSTRAINT_MGR INTERACTIV Cross-probing from CM to Allegro no longer works on system le* z! Y) w: A5 h3 b8 A- Y9 B- B3 J
610276 ALLEGRO_EDITOR PADS_IN PADS to Allegro translation is failing with error.1 B+ E0 F1 ~" A, [/ U5 ~
610482 ALLEGRO_EDITOR SCHEM_FTB Netlist swapped net names on 2 pins causing shape to lose its2 T7 T5 t3 d$ n, \+ ~0 E! U. ]
610681 CONSTRAINT_MGR DATABASE An exported constraint file can not be re-imported in V16.01" U M/ f4 Z0 O* E4 j0 y4 }( P
611260 ALLEGRO_EDITOR DRC_CONSTR Routing a diff pair it does not follow Physical line width se6 N S* A4 \, ^' B3 K2 ~5 L; y
611425 ALLEGRO_EDITOR MENTOR mbs2brd crashes when importing Mentor& j( x( c0 q' \5 e2 `9 a
611697 SIP_FLOW SIP_LAYOUT octagonal bumps have offset in SIP compared to the chip view
N- C. e: I- l611807 APD WIREBOND Duplicate paths created on wirebond import for some cases." S( f# \( C5 v& X/ V
611856 CONCEPT_HDL GLOBALCHANGE Ref des deletions after runnning Global Change to change $LOC
6 [3 e) E }0 q4 E; T611874 CONCEPT_HDL OTHER Crossprobing one symbol in Concept using Occurence edit mode
, H6 P, ], l, H- I$ x! P612088 PSPICE DEHDL_NETLISTER Fail to create the netlist for G value expression
; m3 Z5 s+ A( K5 R7 R) A612195 ALLEGRO_EDITOR DATABASE Adding layers to the default cross section causes phantom tex- H3 R& d# M/ _: `5 n) J! i1 [3 `
612237 ALLEGRO_EDITOR skill axlFormColorize does not change the full background area of a
! h; R6 w* I- T1 l% ]& R612299 APD DEGASSING Degassing static shape creates voids inside of voided areas
& q2 W) U% i; s' I( X612560 CONSTRAINT_MGR OTHER Diffpairs don't show the CSet assigned through Net Class! q- M" x# z' U8 Y7 b' l G- F
612587 APD WIREBOND Unchecked Allow DRC option creating disconnected wire bond.( K! g. v9 `3 b& V) Y
612884 SIG_INTEGRITY SIMULATION When using ViaModel
: Z( u+ R! |3 ~$ b3 \612914 ALLEGRO_EDITOR EDIT_ETCH Centered via option in fanout command not available when swit
3 }" \' h0 _0 v) A( X612939 SIP_LAYOUT ASSY_RULE_CHECK ADRC Continuous Solder Mask check problem/ i- V& |1 @# z
613553 CONCEPT_HDL EDIF300 edif schematic writer crash on this design
" ~ k' Q) ^. N" L; v0 W, k! ^. N613565 ALLEGRO_EDITOR EDIT_ETCH Allegro Editor Differential Pairs are routing incorrectly
C- f W. ]+ W. z4 S& Q613736 SPIF OTHER Spif fails to write class data
+ p& w8 }% ^( E6 ~% M' B613990 POWER_INTEGRIT INTERACTIV PI is crashing during capacitor selection9 g7 U' D+ v# u* [* y! C2 V
614278 CONCEPT_HDL EDIF300 pin text note and flag are not visible on reloaded edif file
0 Y" P) c1 l/ R0 Q, ?" d614371 SIP_LAYOUT WIREBOND Any wirebond command crashes the application
4 Q' S! y! f' }$ }# Y3 A& Y614407 POWER_INTEGRIT INTERACTIV PI crashes when editing capacitors. m [; m3 H# h% N/ v4 a
614727 SPECCTRA GUI Allegro PCB Router can not process the dsn and rules file for
6 e. z$ \. W5 t& E) U5 x/ `: [9 v614972 ALLEGRO_EDITOR SKILL axlCNSSetSpacing does not change the value of the "testvia to" j/ c# E# [2 B1 T
615144 SIP_LAYOUT 3D_VIEWER die placement does not change with changing in soldermask thi* |! k% S. O# H0 J6 R2 A" R8 ?
615431 LAYOUT TRANSLATORS padstack names are crippled or renamed if it has over 18 Char; B+ N# x P/ w0 C2 ~/ f" m5 E
615506 APD MANUFACTURING Sort by die pin location for Manufacture Doc Bond finger brok9 H( d: g+ g4 {, S5 k+ M
615745 SIP_LAYOUT DATABASE Move die symbol with stretch etch on is disconnecting wires f/ R2 ?+ t2 ~$ j' T$ X4 g
615816 SPIF OTHER Allegro match group members not translating to PCB Router; mi, J3 @, Z& r# P+ C1 `6 P
616104 CONSTRAINT_MGR OTHER allegroTechnologyFile XML format issue
# n% y; X/ V$ i) [! Z6 b1 W616122 LAYOUT TRANSLATORS protel to MAX translator problem with package outlines and re
# l) v' E4 q" \$ k$ e616404 ALLEGRO_EDITOR OTHER Design compare fails with message "Invalid input argument" wh
! Z% P' E8 [* s" U5 y: @( U1 k616713 CIS PLACE_DATABASE_PAR property name with "&" charecter in access database causing c
1 _; J7 ~" O4 h6 g, x4 q616818 SCM PACKAGER BOMHDL -type scm fails on schematic block
7 q9 t- v. Y. d# R$ p) @8 j616907 SCM VERILOG_IMPORT scm crash during Get Module Name
" s+ [* I; G$ k$ W617058 APD WIREBOND wirebond space evenly does not work for fingers on power ring* {: `$ P( }" z9 ^% n, E8 V2 W
617083 ALLEGRO_EDITOR INTERACTIV Windows tabs hangs on Linux) h/ z( Q; h0 S& _' O- I3 e+ G' |
617236 ALLEGRO_EDITOR SHAPE Editing a shape in a void causes the bigger shape to drop seg
$ D1 \* R! |; v: b3 _! ]) I7 f l617351 CIS DBC_CFG_WIZARD XML writer fails if DBC location doesnt have write permission* q! Z& P4 N# _. L4 ~
617515 SIP_LAYOUT OTHER Be able to invoke Velocity from cdnsip" g3 `! ~7 ?! C6 I* S3 s
617761 LAYOUT TRANSLATORS Value property for Library symbol of orcad Layout is not tran. O9 S! r& ?! ^' l# j$ w
617890 SIP_LAYOUT WIREBOND Push and shove on Bond fingers with multiple bond wires cause* r$ i: S0 M* C8 U4 S" M! |
618184 APD OTHER database diary on unix/linux
! L0 r2 J; ^5 |; y y' W6 r618201 ALLEGRO_EDITOR OTHER Dynamic fillets take a long time to complete+ x% m% v" Z* I& j0 a8 h
618545 ALLEGRO_EDITOR INTERACTIV Allegro crashes when we place a package symbol for Jumper usi1 R: U1 Z4 |, }) P: q2 e
618610 ALLEGRO_EDITOR MANUFACT Delete a cline seg creates a fillet+ F+ p8 o9 k z/ }% @% h
618651 SIP_LAYOUT IO_PLANNER Bondfingers and die are shifted every time an update package
0 @- ^! v: x% l- V618712 ALLEGRO_EDITOR EDIT_ETCH Shove mode is not working on Diff pairs in PCB Design L( ^7 E' I6 n6 f8 w$ V2 r
618836 ALLEGRO_EDITOR SCRIPTS Allegro does not interpret recorded macro script files proper
, o' Y# C0 T4 f" m618946 ALLEGRO_EDITOR INTERACTIV Allegro crashes while using Place Manual -H! X E$ h1 U9 i( g/ W6 o
618984 ALLEGRO_EDITOR COLOR Layers on Allegro Canvas does not match Color Dialog Box
& H3 l9 H/ u5 q9 {! T* f7 G619007 ALLEGRO_EDITOR SKILL Skill command does not accept spaces in file path/name" q2 q' n. F% R5 i* @! W2 W
619033 F2B PACKAGERXL Pinswap lost on backannotation i* e( x) p+ m9 }; O
619268 POWER_INTEGRIT SIMULATION IR-Drop can't sees via on pad as open8 Z v& H c5 q x' ^- |
619356 CIS FOOTPRINT_VIEW Footprint preview only from 1 directory in Capture.INI
* H8 n" L* x' C9 A0 r/ M/ i& S619712 ALLEGRO_EDITOR EDIT_ETCH Unable to route in the Bubble Mode for Partitioned board
" G5 Y/ w. ]/ m$ H619773 ALLEGRO_EDITOR DATABASE Uprev for 13.6 and 14.0 files not working with SPB 16.2 on Wi
& W+ T3 ^7 q9 d620064 CONCEPT_HDL CONSTRAINT_MGR Loosing Diff pair constraints from lower blocks when packagin
3 T w9 Y: l/ n/ h622132 CAPTURE NETLIST_ALLEGRO Incorrect ALG0078 error for complex hierarchical design |
