#1 ERROR(SPMHNI-176): Device library error detected.
0 K+ Q4 a% e( l9 E* |; p
# ~2 D8 l0 H N( DERROR(SPMHNI-190): Device problem 'RESISTOR_0402_10.5K/1%'. Package property error: 'VALUE'='10.5KΩ/1%'. Illegal character(s) present in the name or value..$ C' ?7 u; A3 P) _$ p# z9 A/ `
$ f; D; r" Y/ Q7 |
ERROR(SPMHNI-170): Device 'RESISTOR_0402_10.5K/1%' has library errors. Unable to transfer to allegro., m, _8 n; _* [/ Q1 E/ R
7 p4 f1 K+ w& P1 l @% i4 v4 K8 q#2 ERROR(SPMHNI-176): Device library error detected.0 l D! J1 H# |! C! V- w
, m" [5 B/ M9 W- |$ y' V2 Z4 Z) J
ERROR(SPMHNI-190): Device problem 'RESISTOR_0402_215K/1%'. Package property error: 'VALUE'='215KΩ/1%'. Illegal character(s) present in the name or value..% @7 @( N9 O' z7 N" c
2 g; h `. N2 j/ gERROR(SPMHNI-170): Device 'RESISTOR_0402_215K/1%' has library errors. Unable to transfer to Allegro./ L) v% R# [# E+ r5 k
5 t U5 T" v3 S. \4 M
#3 ERROR(SPMHNI-176): Device library error detected.: v! D) [5 F7 ^% g! V: _" Q
8 |5 F, q$ z/ ?; K7 m$ dERROR(SPMHNI-190): Device problem 'RESISTOR_0402_17.4K/1%'. Package property error: 'VALUE'='17.4KΩ/1%'. Illegal character(s) present in the name or value..+ W/ w6 P' S1 H7 x' b
5 ?- G( t; ~! `ERROR(SPMHNI-170): Device 'RESISTOR_0402_17.4K/1%' has library errors. Unable to transfer to Allegro.
& ?* L) X, a9 E$ E+ g" P& R. f3 c' b' M* r
#4 ERROR(SPMHNI-176): Device library error detected.6 K3 B% G+ U% V3 U9 g; z
5 W( m6 C( h2 \) I% f6 S, h# X
ERROR(SPMHNI-190): Device problem 'RESISTOR_0402_90.9K/1%'. Package property error: 'VALUE'='90.9KΩ/1%'. Illegal character(s) present in the name or value..
/ L8 D0 ]$ k9 ]2 f X0 g* L5 c0 v" Y- K6 |- W2 M. O2 d$ G
ERROR(SPMHNI-170): Device 'RESISTOR_0402_90.9K/1%' has library errors. Unable to transfer to Allegro." ]! s" e$ b) S, [! ]
% P: R: T5 m0 p2 T7 ?#5 ERROR(SPMHNI-176): Device library error detected.
% g. r! y9 e/ `, y( U9 q
' f) c$ S) m3 `1 o9 w, gERROR(SPMHNI-190): Device problem 'RESISTOR_0402_147K/1%'. Package property error: 'VALUE'='147KΩ/1%'. Illegal character(s) present in the name or value..1 R$ ? ^/ r* z, {$ I5 E
8 O8 w4 u$ A0 m; k4 |( p6 eERROR(SPMHNI-170): Device 'RESISTOR_0402_147K/1%' has library errors. Unable to transfer to Allegro.( g0 Y2 t+ y8 I6 `6 _
: Y& ~8 _- }3 `% H) C5 T) r9 D#6 ERROR(SPMHNI-176): Device library error detected.
! a) M- E) g8 C
' T! d2 A2 ^1 Q# E( ]3 f- I ZERROR(SPMHNI-190): Device problem 'RESISTOR_0402_142K/1%'. Package property error: 'VALUE'='142KΩ/1%'. Illegal character(s) present in the name or value..
8 e! i# \& V, U
+ X) g h* y7 x" M. ~% R/ `7 Q4 `9 rERROR(SPMHNI-170): Device 'RESISTOR_0402_142K/1%' has library errors. Unable to transfer to Allegro.# ^) J7 t ^! g: i! o. R& b/ C+ Z& I
% d# D C+ ?1 K4 L, y# P v7 m2 K. @
