TA的每日心情 | 开心 2021-8-6 15:10 |
签到天数: 13 天 [LV.3]偶尔看看II
log 3如下:
: d! [' v7 m! ~; J; \
( w5 p( s8 v2 v5 W8 E( @& |U-Boot 2016.03 (Sep 07 2017 - 09:46:48 +0800)3 E% |9 o) I' H) o' Z
. x4 }% f3 B& d
CPU: Freescale i.MX6ULL rev1.0 528 MHz (running at 396 MHz)
: \3 A: w" G6 q6 U. ^CPU: Commercial temperature grade (0C to 95C) at 43C" ^+ u5 F3 |; H2 Q
Reset cause: POR: c+ N) O+ n, a8 { r4 W
Board: MYS-MX6ULL 14x141 D3 d5 m/ u1 `# [- {
I2C: ready
' Y! L$ v/ x4 j7 I4 v5 Z, V0 vDRAM: 128 MiB W+ z/ t/ f0 k3 R
NAND: 256 MiB7 u: G/ b4 i M' O1 W
MMC: FSL_SDHC: 0$ s1 `6 l- N( B
*** Warning - bad CRC, using default environment$ x; b) O4 T" i0 W2 s# P
. O# l( h8 W6 k; d
Display: TFT43AB (800x480)/ Z; e, z) n( k' o1 F5 H" n4 ~
Video: 800x480x24
4 E6 @7 G1 T; A9 kIn: serial
8 I( Q# v* T6 \, ]Out: serial6 f! w! w! h* g$ _+ K' K. I6 Q' _
Err: serial
8 m& M* s5 \1 B; c6 k! d* wNet: Board Net Initialization Failed
8 L! r0 [! t# f0 NNo ethernet found.
3 }: F4 g6 q. e4 U+ J, F; ANormal Boot' \% E- ^ Z+ L2 u
Hit any key to stop autoboot: 0
5 ]' F+ e' |3 j X" i; H: V* t& F4 i3 C. C+ Y
NAND read: device 0 offset 0x1000000, size 0x1
' ^$ \* s1 V' y4 p/ i9 S; N 1 bytes read: OK. V$ ~. g+ W1 Z. m) A9 ?2 Y3 d
**************************normal start*******************************
- Z v) M& k+ u- J5 G1 Q) _* H7 m$ D$ ^1 H! R" ?
NAND erase: device 0 offset 0x1000000, size 0x100000- E$ M- a" s/ u
Erasing at 0x10e0000 -- 100% complete.9 q7 c9 l. p# f3 H, u0 ]
OK+ J! o( p' ]. f8 Q9 q* G# S# S4 `0 s
- i$ u# D7 h4 ANAND write: device 0 offset 0x1000000, size 0x1
' m7 F* T* k$ x: t& L0 ~% h0 Y* Q 1 bytes written: OK
m" n2 [& m" U7 y- s; i. R- |; m: N1 J" X; O. z6 K
NAND read: device 0 offset 0x500000, size 0xa00000( |! g* _ D6 p
10485760 bytes read: OK! X7 U& b5 ?' M6 w2 M
5 t" K, `7 `1 |NAND read: device 0 offset 0xf00000, size 0x100000* C: y5 @/ F* `6 @! Q+ u
1048576 bytes read: OK# s3 E+ e O _- @- G+ V0 l# Q
Kernel image @ 0x80800000 [ 0x000000 - 0x5f08a0 ]" b, ]8 z' u X0 q M/ ]+ s+ m- l+ V
## Flattened Device Tree blob at 830000002 }7 l& H: }, P+ W. s5 E
Booting using the fdt blob at 0x830000005 G! _0 K( Q+ x9 a$ s! N* t
Using Device Tree in place at 83000000, end 8300c33f
. _. N5 N1 y" l% [8 R2 J7 G3 e6 I/ ^, y8 W% J6 y/ E
Starting kernel ...7 s$ y- ]- K) \* `9 X; n: j) i4 g. V
% `# |5 C" ?, ~& R+ {
Booting Linux on physical CPU 0x0
' c4 _" D# J2 ^3 ?( ?( H' ]9 {Linux version 4.1.15 (root@zgt-ubuntu16) (gcc version 5.4.0 (Buildroot 2017.02.5) ) #30 SMP PREEMPT Thu Sep 7 09:44:42 CST 2017, t0 [4 w5 z/ K5 Y
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d: q9 P' O/ ^) U: }! g2 T$ I" r
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
5 f4 i& {6 t8 |( M+ q! }Machine model: Freescale i.MX6 ULL 14x14 EVK Board
2 H0 w3 I! u P ~- a- i& lReserved memory: created CMA memory pool at 0x84000000, size 64 MiB
$ ^; n$ N, k8 B3 QReserved memory: initialized node linux,cma, compatible id shared-dma-pool
: N2 F/ ?6 t" q+ M& dMemory policy: Data cache writealloc
+ g! B$ M+ h, {, Y# a- BPERCPU: Embedded 12 pages/cpu @83eb2000 s16908 r8192 d24052 u49152
5 ~4 c3 S `6 Q8 U% wBuilt 1 zonelists in Zone order, mobility grouping off. Total pages: 325122 ^- x' V. V$ `% A
Kernel command line: console=ttymxc0,115200 ubi.mtd=4 ubi.mtd=5 ubi.mtd=9 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:5m(boot),10m(kernel),1m(dtb),1m(misc),80m(rootfs),20m(cache),10m(kernel_bk),1m(dtb_bk),60m(recoverfs),-(data)
/ s6 B1 s) |$ EPID hash table entries: 512 (order: -1, 2048 bytes)
7 w. J b4 M: z) ?1 M) X0 KDentry cache hash table entries: 16384 (order: 4, 65536 bytes)/ {" s7 Q9 L+ I5 s
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
5 ]* F/ a" m3 TMemory: 51076K/131072K available (8622K kernel code, 461K rwdata, 2992K rodata, 432K init, 453K bss, 14460K reserved, 65536K cma-reserved, 0K highmem)9 a X1 c; Q A% m4 J$ e
Virtual kernel memory layout:
* @3 t# I( a* U! b# D& ]) O& S vector : 0xffff0000 - 0xffff1000 ( 4 kB)
! O5 {( h) T- f" k2 }$ O fixmap : 0xffc00000 - 0xfff00000 (3072 kB)# n& H+ ~- S6 p& k' m9 q, Y( o/ N
vmalloc : 0x88800000 - 0xff000000 (1896 MB)6 ?4 I% i7 C5 Q6 M! y4 M
lowmem : 0x80000000 - 0x88000000 ( 128 MB)
9 {7 P, ^$ R$ } c pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)) O1 N1 |. D& v" W; m
modules : 0x7f000000 - 0x7fe00000 ( 14 MB). ^: q0 Z9 ?# n7 C; s7 l9 b
.text : 0x80008000 - 0x80b5fb94 (11615 kB); E8 N1 P+ F; I- N7 K' Y
.init : 0x80b60000 - 0x80bcc000 ( 432 kB)$ _* w" H7 i( t( ]
.data : 0x80bcc000 - 0x80c3f460 ( 462 kB)# T( {- n# @" I7 Y+ s
.bss : 0x80c42000 - 0x80cb3410 ( 454 kB)8 F: H0 ~7 F4 u8 e, F& j' @9 e) o
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1% o! @9 S) @, U0 T
Preemptible hierarchical RCU implementation.
% C1 e* Q) u4 y) W* v' O Additional per-CPU info printed with stalls.
" d( _0 Z9 O- C( m( m RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1./ |9 g }; d. _$ O8 H
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
9 I( Z! c, F+ o; p* kNR_IRQS:16 nr_irqs:16 16' U; ~* B% ?+ T+ U; f* j
mxc_clocksource_init 24000000# X- ~: E/ [- U5 c
Switching to timer-based delay loop, resolution 41ns
" o; P# Y3 B) C( Y, Rsched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
; k) \+ d# r2 b) x- `) u% fclocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
- s) `. Y9 a2 x. v1 BConsole: colour dummy device 80x30) N& A0 a& z. M6 V2 E
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)+ a5 A( ~! B% W! Y% b; i+ D/ R& S! R
pid_max: default: 32768 minimum: 3010 J2 u: D' \% _# R3 d! P
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
7 c5 y/ c0 L! m2 |4 T, v6 p# {Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
4 c# \, f" S$ X: FCPU: Testing write buffer coherency: ok
) K1 ~+ i1 O" s' w1 }8 L/cpus/cpu@0 missing clock-frequency property
$ R6 ]$ Z; }+ O4 @. @( q8 lCPU0: thread -1, cpu 0, socket 0, mpidr 80000000
, H" ?) ?) n/ U; E( HSetting up static identity map for 0x80008280 - 0x800082d80 @4 n# x4 K- {3 S1 |7 f' T
Brought up 1 CPUs
6 ]6 T# U0 j, I- I4 YSMP: Total of 1 processors activated (48.00 BogoMIPS).
9 a2 ]2 X9 b; U. vCPU: All CPU(s) started in SVC mode.
, y( `. X% d. U/ w* Q$ xdevtmpfs: initialized1 ~' Z4 P0 Q* h6 n9 w w4 e/ I
device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
! U: u; C( j3 `$ E- U9 s$ KVFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
* B, Q R2 m6 X4 cclocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
8 n6 S# W/ }( s- i/ J$ qpinctrl core: initialized pinctrl subsystem+ U. y Y* A% \+ Q/ G! B. d
NET: Registered protocol family 16
: j6 P5 A' l) d8 |DMA: preallocated 256 KiB pool for atomic coherent allocations
# \0 ?' M% J, m& s H+ ^* ?, hcpuidle: using governor ladder2 R- Q+ X# b. O @. M7 x, {7 c
cpuidle: using governor menu
+ t v% W. g* X u [hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
; m* g* c. M3 u* J$ lhw-breakpoint: maximum watchpoint size is 8 bytes.7 N/ x5 M9 g, d
imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
4 @- J( l2 x! W! uimx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
' j+ B' Y2 U/ M0 A. m" ^) T, i0 Emxs-dma 1804000.dma-apbh: initialized
; P# v/ r# g9 [- _5 C$ d, tSCSI subsystem initialized1 u1 i. z- m: _; a1 {. g0 @3 Q/ I1 `- N
usbcore: registered new interface driver usbfs8 b# y5 F8 _- P, W: n4 }
usbcore: registered new interface driver hub2 F: U# l/ H, e- ~& f1 m
usbcore: registered new device driver usb/ U0 f& a# L$ a. Z4 r* ^, Z
i2c i2c-1: Failed to register i2c client fpga_i2c at 0x37 (-16)
* D% b' F8 z9 V8 u7 Y" _i2c i2c-1: of_i2c: Failure registering /soc/aips-bus@02100000/i2c@021a4000/i2c_dev@37& v8 }) h+ U0 c. N2 H L( Q
i2c i2c-1: IMX I2C adapter registered
# v0 X* g2 W' E: Wi2c i2c-1: can't use DMA
" N M8 O- G8 y. P# h' }$ OLinux video capture interface: v2.00
6 W3 H# ^+ c) o2 g7 M" `+ M kpps_core: LinuxPPS API ver. 1 registered8 j- n7 V" x v" w# Z
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>0 ?2 \" p- z6 Y) X8 c
PTP clock support registered
5 G7 _) I9 ^ [9 O# \MIPI CSI2 driver module loaded1 ~. ~: Q- W' {" j( R- i# b" h
Advanced Linux Sound Architecture Driver Initialized.; }- S; e. F5 w3 Q% i
Bluetooth: Core ver 2.20/ A' g& b! q9 X! ]9 M1 T
NET: Registered protocol family 310 _$ B8 Z, q" Q3 p6 i' m
Bluetooth: HCI device and connection manager initialized
7 X6 v3 v# i5 l0 IBluetooth: HCI socket layer initialized
! {, [5 k7 [2 _. \: N, `Bluetooth: L2CAP socket layer initialized9 U# Y7 R! f4 N/ s8 a/ R
Bluetooth: SCO socket layer initialized" [7 E0 @- D3 N* d
Switched to clocksource mxc_timer1
6 |; P2 C( r( cNET: Registered protocol family 23 {/ G6 J0 u' F& {: H
TCP established hash table entries: 1024 (order: 0, 4096 bytes)4 M" p& ]/ s( \ O& g; x
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
. d( k9 {9 a* A' P1 I) e5 CTCP: Hash tables configured (established 1024 bind 1024)
0 ~( @' {* b: o5 E4 D. mUDP hash table entries: 256 (order: 1, 8192 bytes)
$ o8 ]7 B0 t% F" TUDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
( Q/ `, Y! w! L3 b, XNET: Registered protocol family 1
, I/ a4 ]: w9 m Q0 x# f# r. HRPC: Registered named UNIX socket transport module.- Q6 ]0 G8 c" v
RPC: Registered udp transport module.7 p6 w! g3 J2 K/ Q+ ~
RPC: Registered tcp transport module.. J! M7 x2 {! y1 u, f
RPC: Registered tcp NFSv4.1 backchannel transport module.! F( n' v L( h/ b: l
imx rpmsg driver is registered.
+ e) C8 c) {/ s4 m8 z$ GBus freq driver module loaded
% f9 s- V5 L) o& I; H6 Q% k( f, zfutex hash table entries: 256 (order: 2, 16384 bytes)
) h$ |3 L" O4 B. J! j' nVFS: Disk quotas dquot_6.6.0" d8 B& g6 q) @) L7 k
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)8 Q9 O, ^ ?& f, c
NFS: Registering the id_resolver key type* x/ z) Q9 {1 `. k4 B9 j2 o
Key type id_resolver registered- L# h* }% `1 I( n0 S
Key type id_legacy registered" ~6 ^, O9 z! N2 M. B
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
& A1 @. a. c- K, ^7 hfuse init (API version 7.23). w" h6 A8 @- u) x
io scheduler noop registered- m+ d9 V( K( r4 x; o" Y4 q9 x
io scheduler deadline registered" ^. A" u% W, S; a, f
io scheduler cfq registered (default)
# k8 k4 `7 d4 ]" ^7 J7 H8 ]9 L; Yimx-weim 21b8000.weim: Driver registered./ u6 [8 d; U: H0 W
backlight supply power not found, using dummy regulator: g! ~1 C3 @4 h& B4 d O5 f% f
MIPI DSI driver module loaded
7 Y( C- O7 Q8 |MIPI DSI driver module loaded3 Z( `$ w; C) R
21c8000.lcdif supply lcd not found, using dummy regulator
, O9 F1 F+ a8 n @4 Xmxsfb 21c8000.lcdif: failed to find mxc display driver
7 m2 |, b8 [; u* s; t4 v5 ]$ O7 xConsole: switching to colour frame buffer device 100x30. {6 j, @! p# p5 Q4 R. }% I
mxsfb 21c8000.lcdif: initialized3 f! |( A7 e4 L/ I; w( _
imx-sdma 20ec000.sdma: no event needs to be remapped
. _2 a# G& e; p4 j$ V; k' Rimx-sdma 20ec000.sdma: loaded firmware 3.3
3 k9 c. y2 L- l1 a/ B, Iimx-sdma 20ec000.sdma: initialized
1 X+ Z* `! \% H3 W2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
- Y. p) Q8 p1 O( ^; zconsole [ttymxc0] enabled
1 l" e) J% v: ]# d21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 227, base_baud = 5000000) is a IMX6 _3 Q. I1 T4 C2 r7 _
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 228, base_baud = 5000000) is a IMX1 ~' ^$ H# h7 _9 ~1 h
imx-rng 2284000.rngb: iMX RNG Registered.
2 O4 T$ f" r3 [4 B* Oimx sema4 driver is registered.2 Z0 Q+ r- _ g' H$ r
[drm] Initialized drm 1.1.0 20060810
2 a2 n! s) S) M+ U7 a7 A' j# j[drm] Initialized vivante 1.0.0 20120216 on minor 02 R" n. n7 [& h0 m! g
brd: module loaded# c9 H3 r, J; c/ t' q; _. A
loop: module loaded$ X$ H8 F* ^; X) z2 T
nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda$ s w5 I F0 m2 ^9 p6 W, r* U
nand: Micron MT29F2G08ABAEAH4
+ C* H: T! G4 b [# }+ [2 q( znand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
" u3 P" |, B1 ]' T& b/ Ngpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
# |3 B. X' u3 s# }5 DBad block table found at page 131008, version 0x01! p. w+ z- Q( k! d F- l0 Q' _( F2 X
Bad block table found at page 130944, version 0x01
% }- p! l# z7 L% i. g10 cmdlinepart partitions found on MTD device gpmi-nand6 I1 P- ^8 v$ D: m" ^+ o
Creating 10 MTD partitions on "gpmi-nand":7 I9 S J G0 w4 n
0x000000000000-0x000000500000 : "boot"
4 \8 P8 x* g- `" A$ h4 f* ]0x000000500000-0x000000f00000 : "kernel"
- r$ k0 a3 v; m# a9 f k/ w# {0x000000f00000-0x000001000000 : "dtb"0 f' Y# l' i7 `6 q9 F
0x000001000000-0x000001100000 : "misc"
6 ^. q6 u, Q# {" r0x000001100000-0x000006100000 : "rootfs"% `% h# Q' h1 o7 G! ~4 ?
0x000006100000-0x000007500000 : "cache"* C0 B9 B6 ~3 p. b, E7 H
0x000007500000-0x000007f00000 : "kernel_bk"
; m3 l o# L( ~5 d9 ~4 w) P; ~0x000007f00000-0x000008000000 : "dtb_bk". t2 O, v* f% F2 C( Z' ]) b
0x000008000000-0x00000bc00000 : "recoverfs"
2 L; S( q m7 H& E0x00000bc00000-0x000010000000 : "data"
7 L; W9 H; B; W2 Wgpmi-nand 1806000.gpmi-nand: driver registered.
G3 U* Y5 l+ @" B3 L. H: lspidev spi3.0: buggy DT: spidev listed directly in DT
9 z6 Y9 {* q/ z' e* e9 Q5 }3 |/ w------------[ cut here ]------------* S/ S6 H; `$ W) L4 f1 i, u
WARNING: CPU: 0 PID: 1 at drivers/spi/spidev.c:731 spidev_probe+0x1a4/0x1c0()
2 Q. J4 X4 ?; {; G# ^Modules linked in:
: I: A0 L: F, xCPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.15 #303 o) }) A4 M( P* ?7 }) G* c
Hardware name: Freescale i.MX6 Ultralite (Device Tree)& h" L# l4 F' I$ L% M9 q4 u
[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)/ ~; z: {: P [' s' Q, G, b5 q
[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)5 H- O# w+ `) K
[<80834c60>] (dump_stack) from [<80035788>] (warn_slowpath_common+0x80/0xb0)3 d x1 n1 S3 N' r( ^" R. Z
[<80035788>] (warn_slowpath_common) from [<80035854>] (warn_slowpath_null+0x1c/0x24)
, c2 s9 @' }/ v% v4 l7 D0 s# ^[<80035854>] (warn_slowpath_null) from [<8042c664>] (spidev_probe+0x1a4/0x1c0)
& q; {0 M/ V) }& r[<8042c664>] (spidev_probe) from [<8042a4bc>] (spi_drv_probe+0x50/0x74)
. d; s. V" a+ f' c2 {; g[<8042a4bc>] (spi_drv_probe) from [<80388a04>] (driver_probe_device+0x174/0x2b4)1 [7 N/ O( \3 ~+ X7 D
[<80388a04>] (driver_probe_device) from [<80387138>] (bus_for_each_drv+0x60/0x94)% {2 [& s( W7 p/ L) j
[<80387138>] (bus_for_each_drv) from [<80388860>] (device_attach+0x80/0x94)& @4 G$ E8 V8 x& O0 i( j
[<80388860>] (device_attach) from [<80387f24>] (bus_probe_device+0x84/0xa8)
2 L8 i9 d5 K; r3 C% D9 v' `6 C[<80387f24>] (bus_probe_device) from [<80386274>] (device_add+0x370/0x56c)
9 T. l1 Z$ x" Z' z n[<80386274>] (device_add) from [<8042abd8>] (spi_add_device+0x9c/0x134)6 ?0 [, t$ B3 K: B2 G' W" f; Z5 b
[<8042abd8>] (spi_add_device) from [<8042bf9c>] (spi_register_master+0x49c/0x70c)- ]! t" l: ~; |$ S5 [0 f% b
[<8042bf9c>] (spi_register_master) from [<8042d7b0>] (spi_bitbang_start+0x9c/0x108)( j3 G1 U( b' q. h
[<8042d7b0>] (spi_bitbang_start) from [<8042f6d4>] (spi_imx_probe+0x3dc/0x648)
" h5 l8 g( `4 l5 x9 x8 H# j3 W9 Q[<8042f6d4>] (spi_imx_probe) from [<8038a168>] (platform_drv_probe+0x44/0xac); M' T4 O. S' Q- x) r2 s6 d" M
[<8038a168>] (platform_drv_probe) from [<80388a04>] (driver_probe_device+0x174/0x2b4)5 ~/ x* z7 m0 L" e
[<80388a04>] (driver_probe_device) from [<80388c14>] (__driver_attach+0x8c/0x90)
! ~9 t7 C5 t4 h0 M! t; J[<80388c14>] (__driver_attach) from [<80387090>] (bus_for_each_dev+0x68/0x9c)2 V$ R' B3 f( `: b' E4 j6 s0 E! I7 v
[<80387090>] (bus_for_each_dev) from [<80388194>] (bus_add_driver+0x148/0x1f0)$ _ T$ }9 |/ s* Z/ J: {6 v1 r
[<80388194>] (bus_add_driver) from [<80389214>] (driver_register+0x78/0xf8)* U! T. v! x! N0 |7 X* ~
[<80389214>] (driver_register) from [<80009718>] (do_one_initcall+0x8c/0x1d4)
9 v/ P0 O0 @' e5 p# J[<80009718>] (do_one_initcall) from [<80b60dbc>] (kernel_init_freeable+0x144/0x1e4); [8 O q& H1 F! U* B$ q o, n9 y
[<80b60dbc>] (kernel_init_freeable) from [<80830e68>] (kernel_init+0x8/0xe8)
3 p) b: u$ v) E Y4 T$ H[<80830e68>] (kernel_init) from [<8000f4a8>] (ret_from_fork+0x14/0x2c)
/ H5 p9 t$ X9 `) @4 M---[ end trace 8fe6a3798b149573 ]---* S. R( o* B, C5 y" r
spidev spi3.1: buggy DT: spidev listed directly in DT0 R8 O9 b2 w9 b/ W- _% W! e0 c+ T6 T
------------[ cut here ]------------0 c* Q$ E& u5 ?6 k& f7 b, J$ k
WARNING: CPU: 0 PID: 1 at drivers/spi/spidev.c:731 spidev_probe+0x1a4/0x1c0()' h% ?. Q* B9 S+ z3 l5 m& h2 G0 `0 U
Modules linked in:2 E1 U* e) w4 e# V
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.1.15 #30
% b& F. f1 k0 G6 `: E& I. eHardware name: Freescale i.MX6 Ultralite (Device Tree)
6 Y8 m/ r' U3 P7 T6 p[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)) o( P8 C$ h! r" D7 W7 s7 S* \
2 \' s& C" w0 Q2 `, K/ Z9 ~[<80834c60>] (dump_stack) from [<80035788>] (warn_slowpath_common+0x80/0xb0)
0 a4 X k# F# q4 T3 H, i[<80035788>] (warn_slowpath_common) from [<80035854>] (warn_slowpath_null+0x1c/0x24)
' Q7 Y7 U5 i8 n/ ~8 z0 F[<80035854>] (warn_slowpath_null) from [<8042c664>] (spidev_probe+0x1a4/0x1c0)
! \' ^5 K& Z' i5 M' Z D3 L$ Y. R[<8042c664>] (spidev_probe) from [<8042a4bc>] (spi_drv_probe+0x50/0x74)
* s5 Z$ K d; y3 r& }! b[<8042a4bc>] (spi_drv_probe) from [<80388a04>] (driver_probe_device+0x174/0x2b4)
8 g' c6 ~( z' k( S: W[<80388a04>] (driver_probe_device) from [<80387138>] (bus_for_each_drv+0x60/0x94)% e a! p% I/ m9 U1 E2 j
1 J# |5 H+ N5 A4 L" Y[<80388860>] (device_attach) from [<80387f24>] (bus_probe_device+0x84/0xa8)
% i3 d# ~. P- v" L- L* [[<80387f24>] (bus_probe_device) from [<80386274>] (device_add+0x370/0x56c)
* I1 E( W0 A7 J' |[<80386274>] (device_add) from [<8042abd8>] (spi_add_device+0x9c/0x134)! G8 }9 F+ d' |+ `
[<8042abd8>] (spi_add_device) from [<8042bf9c>] (spi_register_master+0x49c/0x70c)$ {. i' n0 l, J) O) ]
: u% d- \9 U3 @8 c! c[<8042d7b0>] (spi_bitbang_start) from [<8042f6d4>] (spi_imx_probe+0x3dc/0x648)
6 G( r- _, v& f7 q; A; n$ u* G5 v[<8042f6d4>] (spi_imx_probe) from [<8038a168>] (platform_drv_probe+0x44/0xac)
* m. J# [6 g5 Q5 V! b' x; S- V9 [[<8038a168>] (platform_drv_probe) from [<80388a04>] (driver_probe_device+0x174/0x2b4)! e# V8 `2 @& f. W( ^! B0 s* k7 f- C
8 `4 r+ f- N' c8 a7 Q3 B# ~[<80388c14>] (__driver_attach) from [<80387090>] (bus_for_each_dev+0x68/0x9c)
; q D* w5 W+ @; ~5 Y[<80387090>] (bus_for_each_dev) from [<80388194>] (bus_add_driver+0x148/0x1f0)
$ O* G+ B, U8 d! N4 D& g$ h[<80388194>] (bus_add_driver) from [<80389214>] (driver_register+0x78/0xf8)
" A: A8 @! H ~( b6 d) ~[<80389214>] (driver_register) from [<80009718>] (do_one_initcall+0x8c/0x1d4)3 \% k8 t) j5 Q6 X
[<80009718>] (do_one_initcall) from [<80b60dbc>] (kernel_init_freeable+0x144/0x1e4)0 q3 j) e9 b+ w, o$ n
3 w& X b- X- f4 w% R[<80830e68>] (kernel_init) from [<8000f4a8>] (ret_from_fork+0x14/0x2c); E- G* b( l2 Q, s
---[ end trace 8fe6a3798b149574 ]---
+ V4 U3 ^5 t# H5 E# jspi_imx 2014000.ecspi: probed
0 R5 {8 z" p2 {! YCAN device driver interface. a( K2 y0 W8 x: U
2188000.ethernet supply phy not found, using dummy regulator
& ?: I& E4 P4 a9 B" Spps pps0: new PPS source ptp0- D, z3 R/ V% R
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
8 r: a1 e. R8 ofec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 76:8b:88:58:fb:a79 r' z1 o$ N7 L; A: u, Q
libphy: fec_enet_mii_bus: probed; G4 a7 D$ ~& W7 M
fec 2188000.ethernet eth0: registered PHC device 0: u* d) r- v$ ~! s
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver# K; m* B$ S r; R W
ehci-mxc: Freescale On-Chip EHCI Host driver
, ]5 \' h0 T/ d- Uusbcore: registered new interface driver usb-storage
" Q6 p* [$ w# u' f, O! I$ X2 Kusbcore: registered new interface driver usb_ehset_test
- l$ q0 _- }% ^2 }4 d% b& U8 C2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
4 S& S; ^ x4 u; ~( c. [. G2184000.usb supply vbus not found, using dummy regulator
. [/ x9 a, B @- uci_hdrc ci_hdrc.0: EHCI Host Controller- \* Z& e2 \' u6 N
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1# l# @9 h* W+ t4 U1 Z% `% u
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
9 v, B; T u# w2 W! V0 R2 }1 zhub 1-0:1.0: USB hub found
$ _' v( U3 s9 mhub 1-0:1.0: 1 port detected
: @7 O) i0 l! ]1 Z8 z6 L/ e5 C4 [' @udc-core: couldn't find an available UDC - added [g_mass_storage] to list of pending drivers
n9 T5 W: R9 V* g' W( B6 qmousedev: PS/2 mouse device common for all mice
& u4 o! e/ R/ M' C9 k& {input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
( T3 V, c- k! V7 O p8 {tp reset gpio=-2/ t# }5 M- b, N+ P. N' @. y# Z
ft5x0x id: 0xF830
' z% ~9 i) D: `input: ft5x06_ts as /devices/virtual/input/input14 n8 s" g' W v7 g$ v9 N
ft5x0x_ts_init successful
' @: _* E1 L; p/ N: l4 E$ Asnvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
C! \( {4 U/ I, w L: qi2c /dev entries driver/ V4 M: `; A+ M9 e9 T3 `
IR NEC protocol handler initialized! R4 T8 A) x! f4 i1 u
IR RC5(x/sz) protocol handler initialized
1 w0 I& O& ]- J" q7 n7 ]IR RC6 protocol handler initialized
3 S+ H, J/ M0 ]+ n1 L5 oIR JVC protocol handler initialized
9 c/ R6 M t2 hIR Sony protocol handler initialized" X' C( b- P4 j
IR SANYO protocol handler initialized7 B! T s$ y* j6 `$ s
IR Sharp protocol handler initialized
+ G: i) y- b+ v1 _% DIR MCE Keyboard/mouse protocol handler initialized
3 r6 w2 W0 d G6 i/ \3 t% N0 vIR XMP protocol handler initialized5 z# s4 L5 F% M
pxp-v4l2 pxp_v4l2: initialized
! B/ L1 ]) C, Dusbcore: registered new interface driver uvcvideo
}* @- [# y4 v* bUSB Video Class driver (1.1.1); S& v! M+ Y# O
imx2-wdt 20bc000.wdog: use WDOG_B to reboot.7 @+ Z3 I, O: i: m
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)% Y1 B4 c% O2 f& g2 m
Bluetooth: HCI UART driver ver 2.3" {5 p3 \1 H. g* u( }
Bluetooth: HCI UART protocol H4 registered- ?9 l/ T; s5 C5 ]: R8 ?8 Y
Bluetooth: HCI UART protocol BCSP registered: G& C( m7 ?3 D( U4 `4 D& z, x$ F0 r
Bluetooth: HCI UART protocol ATH3K registered7 r M% X8 r% A
usbcore: registered new interface driver bcm203x
1 `( w- f, v2 A# S$ t- Xusbcore: registered new interface driver btusb
4 T) s9 S, D6 c2 D: cusbcore: registered new interface driver ath3k
& G* N ]2 d$ v! q! j. zsdhci: Secure Digital Host Controller Interface driver
5 e1 S) _4 N, g# U4 K2 @sdhci: Copyright(c) Pierre Ossman
0 o, z6 s& O7 q3 H5 G# E. [/ `sdhci-pltfm: SDHCI platform and OF driver helper
, m& `. A0 a: O1 i! _/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
- S9 {9 ~% m) e. F5 G: Qsdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
% ~6 p1 [8 f7 w. `sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
6 I- G. C3 P; H- F. _sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
* f- l5 {$ w, u1 gsdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
) q8 N% d8 e- h0 Kmmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
( }8 T5 L9 `) \( U8 L! jusbcore: registered new interface driver usbhid
! W5 x0 R2 z( r; v6 F/ S( `; O' S8 `usbhid: USB HID core driver
6 }/ f m) k, f0 x6 cusbcore: registered new interface driver snd-usb-audio+ [( X" D& U* n, M5 M: U! {( S" C
wm8960 1-001a: Failed to issue reset+ c) ]2 }1 r4 ?. S
wm8960: probe of 1-001a failed with error -53 n L/ L Q+ N7 {
fsl-asrc 2034000.asrc: driver registered6 e* @+ q; ?0 [) m; H. @+ H1 Z1 r! A
imx-wm8960 sound: failed to find SAI platform device
( a1 S' L+ \" B1 X, G# Fimx-wm8960: probe of sound failed with error -22/ ~) o% L4 Z) |! N. j
NET: Registered protocol family 26
9 [" Z5 U5 k aip_tables: (C) 2000-2006 Netfilter Core Team
( E! p: Z0 x, E) ENET: Registered protocol family 107 K$ j% H; `4 x
sit: IPv6 over IPv4 tunneling driver
- |0 {: T) ^% R# |4 E# MNET: Registered protocol family 17
: y. k; D# g* |+ ^can: controller area network core (rev 20120528 abi 9)$ F6 Z; {4 B5 M8 ]8 F) k
NET: Registered protocol family 29' P+ J" {& Y( g
can: raw protocol (rev 20120528)0 v; Z: U* p5 {& D: L0 a" S
can: broadcast manager protocol (rev 20120528 t)& Y5 C S% y0 \ t# {; V3 O
can: netlink gateway (rev 20130117) max_hops=1: x' `: ?( J) x4 Q/ M
Bluetooth: RFCOMM TTY layer initialized
2 j* u" M$ P. S0 i: s# e# r0 t6 E6 J, yBluetooth: RFCOMM socket layer initialized# ~ x* f6 X# H* K5 L1 w
Bluetooth: RFCOMM ver 1.11: v# y4 }! ?1 S" u1 v
Bluetooth: BNEP (Ethernet Emulation) ver 1.3+ }2 d l9 k! M" d' _
Bluetooth: BNEP filters: protocol multicast
9 }) J7 x. U( w' P/ d$ N PBluetooth: BNEP socket layer initialized: Q( U9 p( `9 K- H& a& q' [5 }* d: D
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
6 K3 ]( ^4 Y) y% nBluetooth: HIDP socket layer initialized
2 g+ ]. i2 e; C' K8 b- X% ~8021q: 802.1Q VLAN Support v1.8" l5 v$ V' g) r+ J) {
Key type dns_resolver registered5 j' F. T3 s4 g' L
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)( H# [5 x& e8 p; I# B/ n
ubi0: attaching mtd4% v9 x- J/ V. K2 Y- l1 H
ubi0: scanning is finished0 E9 Y1 w. C) V9 ]( |2 G; u# i
ubi0: attached mtd4 (name "rootfs", size 80 MiB) m2 E9 j& \5 P) W# N1 Z9 n* S
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes3 p3 e1 b0 ^8 @2 U v
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
, L; m: {- q4 _3 Q; t* Bubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
& a* F/ S( m) M2 m* U- N( lubi0: good PEBs: 640, bad PEBs: 0, corrupted PEBs: 0" f; C# g+ E9 e4 w
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
7 }* h6 y3 y" ]3 R+ D& W. A# Uubi0: max/mean erase counter: 3/0, WL threshold: 4096, image sequence number: 13638486854 o& y1 J# @# N8 t7 b' \
ubi0: available PEBs: 0, total reserved PEBs: 640, PEBs reserved for bad PEB handling: 40
7 Z# k( c$ Q# Y& c7 h, y2 P+ Subi0: background thread "ubi_bgt0d" started, PID 80
: e. B, h% l% G, P8 mubi1: attaching mtd5
0 @* W+ ^( |1 n" B1 G* Yubi1: scanning is finished
: ^8 x( h$ ^3 N$ N7 W5 V0 ?1 Q. eubi1: attached mtd5 (name "cache", size 20 MiB)
3 k8 [6 ~+ P6 W$ Z' F* Tubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
7 { a/ w( q) D7 x) L# qubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 20485 T1 S3 ?+ V% R
ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
1 j. R# j j0 r. L- v( d& Lubi1: good PEBs: 160, bad PEBs: 0, corrupted PEBs: 0
7 [; A0 ^2 p; O+ b8 ?ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
) q' s5 O0 V: a1 Y' L6 ~! kubi1: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 122076603; p+ P9 A/ g; h) Y0 M H
ubi1: available PEBs: 0, total reserved PEBs: 160, PEBs reserved for bad PEB handling: 40
% K- c0 s! m0 J2 ~ f% V# Jubi1: background thread "ubi_bgt1d" started, PID 81) F% m6 }1 e4 v4 b
ubi2: attaching mtd9( P7 T3 q) U; I
random: nonblocking pool is initialized' Y' b: t! m$ h: [/ ?2 N# i. ]
ubi2: scanning is finished. i+ a+ q% j" y+ f: d0 C4 a5 @ ]
ubi2: attached mtd9 (name "data", size 68 MiB)
) ^. @" Q" w4 y' W. |0 {ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes/ R4 U6 r$ p5 ^0 r/ n% J2 ?; o
ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
+ A- K8 i, B3 f6 F0 P+ l5 Y5 \ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
0 u( w) x. m y6 {0 U# ?ubi2: good PEBs: 540, bad PEBs: 4, corrupted PEBs: 0
. a% y$ h9 M9 {' p1 Uubi2: user volume: 1, internal volumes: 1, max. volumes count: 128# F7 w1 ?; _6 ~, v8 y/ _* i8 d
ubi2: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 14853079194 ~: t# M" }2 O5 c
ubi2: available PEBs: 0, total reserved PEBs: 540, PEBs reserved for bad PEB handling: 36
8 Y/ g$ K+ I% U* E! d+ i5 Oubi2: background thread "ubi_bgt2d" started, PID 82; N; i. A/ I$ A! {
dhd_module_init in
* g- X" }, W; y4 ?3 zsnvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1). v* @* ^1 ~; ^
gpio_dvfs: disabling
) w8 n4 b7 ?7 e1 [VSD_3V3: disabling
; K" Y0 c. ~, K: ?can-3v3: disabling
( ~, ~+ w4 C8 w3 C2 e- CALSA device list:
3 |. \5 Q$ t1 ^% ]4 w No soundcards found.- i7 a' I4 ^7 y+ G0 u% `/ O
UBIFS (ubi0:0): recovery needed
; N$ G8 I0 o7 W& ?, vUBIFS (ubi0:0): recovery deferred
/ g) K" L: ^& TUBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
1 p0 d8 `; `8 M2 e! {! Y# m6 KUBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes9 C4 F6 D6 I5 ^# P" p
UBIFS (ubi0:0): FS size: 74407936 bytes (70 MiB, 586 LEBs), journal size 3682304 bytes (3 MiB, 29 LEBs)" p F: s H. N: F' g
UBIFS (ubi0:0): reserved for root: 3514470 bytes (3432 KiB)/ r8 k4 L/ I9 T1 g* m) f0 d/ Y6 ]
UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID C9D481D6-09A0-49C8-B1FF-0E8B325B2FE2, small LPT model
8 c" {! D6 A- t6 DVFS: Mounted root (ubifs filesystem) readonly on device 0:15.( Z% L& t& n) b I9 W: N
devtmpfs: mounted
+ \5 j: h; G$ H1 D2 [Freeing unused kernel memory: 432K (80b60000 - 80bcc000)
6 ~) A+ F; C* A6 X6 ~INIT: version 2.88 booting+ j( }: x* c1 t! f5 Y. g
UBIFS (ubi0:0): completing deferred recovery3 B) R4 F- m' q: ]+ F2 ]# n
UBIFS error (ubi0:0 pid 87): clean_an_unclean_leb: unexpected empty space at 476:09 D! M* s0 k3 `: \* ^. D: R
mount: mounting ubi0:rootfs on / devpts: called with bogus options% z* W0 w6 v- y5 H9 s
INIT: Entering runlevel: 3
2 N0 ]2 j, G0 G! U. B# Zmount: mounting tmpfs on /mnt/.psplash failed: No such file or directory
4 l- L8 n* v4 H- OStarting logging: OK
1 t$ {) C$ p% \4 ?Populating /dev using udev: udevd[117]: starting version 3.2.1" U2 s6 _+ ~0 I( }& K
udevd[117]: RUN{builtin}: 'firmware' unknown /etc/udev/rules.d/50-firmware.rules:3
, Z- q9 O5 \# [- y U: _udevd[118]: starting eudev-3.2.19 h; N8 m6 Q" I/ m. H- o
fpga i2c module in! D0 ?$ {7 n8 u, ^
input: dso_kbd as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0037/input/input2
) n0 S0 L/ A# x; F Ffpga i2c module installed! {' m4 A( X: k5 }* _4 d: z
ov5640 1-003c: no sensor pwdn pin available. ]8 _" t& x& U7 x7 a
done% l0 E( p6 m; k a( n! C% Q% X
read-only file system detected...done
6 I. C& W; \7 g( x0 z$ hStarting system message bus: done/ Y- U6 |- G0 ~
Starting network: fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:07, irq=-1)$ ]% J- W2 s! U( G2 w v
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
, t$ S" C/ [1 C% H- w$ G qudhcpc: started, v1.26.2
6 N+ |& a4 l3 h, l5 @" y8 |) IFailed to kill daemon: No such file or directory
0 L3 C5 m8 U9 s; W7 ludhcpc: sending discover
8 T( K i8 {- y9 k! Tudhcpc: sending discover
! C; n4 {8 X y- V6 v+ X; Vudhcpc: sending discover
9 m; c9 c' R* Rudhcpc: no lease, failing' T: G) ^ ?% ]. |, M: ~1 E8 z
FAIL* Y! Z0 D* H; s! }. s9 E
System Normal start ...9 h3 S. ^- i0 j: w Y* r
System normal boot start ..., w2 J/ N" }1 M% {: P- i
insmod drivers
% S6 b0 x% {6 ?6 C& d/ Efpga configure init
& u2 m; Y& W- y/ S4 q' P4 x+ }AFG3050_fpga_cfg_probe:in:2/ l0 T7 M5 b. b- y
AFG3050_fpga_cfg_create:2/ O9 _7 | d- U3 N* `
irq7 a6 j; u. F0 K w( }8 z/ B
AFG3050_fpga_cfg_probe:in:3
* H) l, Y% }; X" E+ ~; CAFG3050_fpga_cfg_create:3
# I5 h( O) U" n% Z2 e L+ V+ w$ Busbcore: registered new interface driver r8188eu5 Q) f. [2 i. g1 s& A
user file is dso6000b.bit5 W: {* N! R2 h/ q8 n+ U
irq
$ I$ |' n" o- _nstatus0 :0x03 K/ `7 S, l) Z$ Q6 H( v4 Y
nstatus1 :0x1
, [" q& f6 k% t0 Ffpga state :0x1
) ?' A* B3 I( k; S' @5 Hfile len is 742361/ W: X. k8 W" b0 T
irq
2 U, ?" E( I) m. tFPGA CONFIGURE DATA DOWN finish.0x1, 0
5 D% F/ O6 e' U4 L8 hFPGA CONFIGURE ok.
" T7 p7 i }; t, Xdso keyboard: key (code 0xf) released.: u2 B: {8 k1 D% k3 ?4 o U
dso keyboard: key (code 0xc) released.7 t2 \1 D' m0 R. i* n7 ?
insmod: can't insert '/lib/modules/4.1.15/extra/fpga_i2c_kb.ko': dso keyboard: key (code 0x10) released.) b- \; ^. R+ U9 w
File exists
+ v+ _1 y' u% B% S/ _dso keyboard: key (code 0x15) released.( ~0 B# |- T+ D! l6 i
dso keyboard: key (code 0x14) released.- [* @# t& g1 X* g
dso keyboard: key (code 0x17) released.
2 E2 @0 ]+ @( pdso keyboard: key (code 0x21) released.
0 p6 y. S/ b" R0 sdso keyboard: key (code 0xb) released.
9 `$ }# o* f+ X: `1 j: O: q) kdso keyboard: key (code 0x6) released.
* m% A4 ]. j( X9 D. ]0 _3 a8 mdso keyboard: key (code 0x5) released.. P& j6 C% s1 @% Z' L" B) P
dso keyboard: key (code 0x13) released.$ M# @6 u& U- r- |; |, m: B/ R
dso keyboard: key (code 0x23) released.
) S8 s5 @# }( O3 f6 _8 ^* `7 O1 pdso keyboard: key (code 0x4) released.$ \) r d# D' C! k+ [
dso keyboard: key (code 0x7) released.
4 j$ W: Q+ L, s1 u1 l$ {3 Wdso keyboard: key (code 0x25) released.9 g! H+ n( C: L9 K1 T1 [4 I
dso keyboard: key (code 0x1c) released.4 P; k' z0 ]( b5 z$ G. {$ b
dso keyboard: key (code 0x9) released.
* K: U- Y% a( U- E* nErasing 128 Kibyte @ 0 -- 0 % cdso keyboard: key (code 0x3) released.
" M- F8 h) U3 E( w7 b- t! |Erasing 128 Kibyte @ 20000 -- 12dso keyboard: key (code 0x2) released.4 o0 I4 w* `" j% `
Erasing 128 Kibyte @ 60000 -- 37 % compdso keyboard: key (code 0x11) released.
0 C! {! a# n$ J2 [5 DErasing 128 Kidso keyboard: key (code 0x24) released.! @: Z$ U( t) o3 U; l [; ~
Erdso keyboard: key (code 0x1) released.+ R& ]1 M4 n4 n" `
Erasing 128 Kibyte @ e0000 -- 100 % complete
3 a% Q( P0 a( _% Ostart app
& E) m9 T' B* F$ D* u: Vdso keyboard: key (code 0x12) released.
4 A7 [/ N$ N8 g8 ^" C6 d; E: t* jdso keyboard: key (code 0x1f) released.; R! X b. _! }9 f3 A1 I
dso keyboard: key (code 0x1b) released.+ E) r2 x6 M; S. @; w
dso keyboard: key (code 0xa) released.
. ~ _2 y! J. B$ C" R9 R- Odso keyboard: key (code 0x1e) released.' j4 O+ P* x, F# g/ w# w
dso keyboard: key (code 0x16) released.1 i0 }! _4 R( [0 z
dso keyboard: key (code 0x22) released.
" B; `* g: r8 H7 s) A0 jdso keyboard: key (code 0x1d) released.
; _& M c6 H. Tdso keyboard: key (code 0x1a) released.
6 w' R3 U+ v# U7 o% Qdso keyboard: key (code 0x20) released.& R9 d( B1 J1 p* o' p6 q
dso keyboard: key (code 0x18) released.2 `" t6 g/ w2 Y! a; G0 `/ [
ln: /dso/app/media: File exists' v, l/ E( l3 L0 i2 S' W- x
dso keyboard: key (code 0x8) released.* @" u) g$ W5 r0 T! {+ x" \
9 v5 s" P. ?$ q
Welcome to phoenix
1 S3 R1 ?" m3 Gphoenix login: open backlight error
" @: P6 a* e5 }& B5 B0 wload_dotarray_font:font/lan_chinese.so
6 _/ q' V8 J& w; B* R$ b3 ~open kbd dso_kbd successful: m4 B" \: ^5 a4 D. [
open buzzer error
) e+ J# \4 B" @4 Qsystem info do beginUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1): [8 W$ e* m1 W* n) ~7 Z7 c
! Y: D5 O, _) b1 A
open i2c dev error
5 ?+ m# X3 [+ Y8 n! vinit systemUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0' p1 w+ H- O0 n5 L* g5 Y
info ...
- D6 ?8 I3 L# b* e/ S$ a3 m; sNot a node, first 24 bytes:
2 F4 S' p- k' [$ {0 z, h; ~00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................
; |* o) K' k2 {# g% V" h; _# ]3 XCPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30
. v* t5 z- W# E0 PHardware name: Freescale i.MX6 Ultralite (Device Tree)* H/ w3 _1 e) I* d1 W/ {
* n% p( v! z$ Z6 T[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)* P ?$ K% @, f) S' b7 k
[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)9 I% X* B# F3 Y# v# ^8 p. l) d' q* P
[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138); u7 m0 K5 Q# w D: r+ z" q4 ^7 s
[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)" U- d2 D }2 ?5 k! e: y t
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)
# b* X! z- X" K7 T* c+ q[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)
; W$ a; x& @/ a: l7 K[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)
0 n& h$ g' n; X( m q9 W8 g[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)3 B! C' t; j. u( L x
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)
% A, b3 e$ b7 C4 H- S \[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)" r$ K4 L4 `. |1 W2 _
[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)7 V m9 {/ K4 v7 P& B
UBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22$ G7 |8 O% s r
7 B) u; U0 V5 p8 QUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 02 L( ?2 o, E( J- B
Not a node, first 24 bytes:, l! q9 A9 W; H! q; j
0 _8 D. F/ Q5 W1 I& aCPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30
, V# X2 I2 q% D3 ^' XHardware name: Freescale i.MX6 Ultralite (Device Tree)
7 t1 i5 t3 U0 b$ K! F- a' e[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)$ I; k1 L: ~# r/ J$ ]
! r9 `1 M' H0 o% ?[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
! C# l9 v: E! }9 U: R# z9 u" d) d[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
1 m5 y# T/ ?& N: K[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)% O+ q; a2 K. M( q$ O
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)! G& d7 K3 A4 E) n7 P _5 ]
+ G5 G2 f% C" X9 U, E: j/ v[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8): r! D5 i. w' w, Q
[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)5 i8 }% a( q5 a9 k# T! p% ]
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108); U. i( C8 k8 Y5 m3 g" m& b
[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90): ~! f5 k2 O3 a+ O
[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)2 K, A6 B# Z7 l [ x
UBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -222 q! r' H! W/ M% b0 u
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)& g0 }! }% P- b2 v2 _. M& Q
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 06 h9 T: O2 B: z* H: }: c3 K
Not a node, first 24 bytes:3 X7 X* k. u& v; |5 r$ c4 Y
00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................" ]9 y$ |( b/ r a
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30+ k6 @, }& P2 K
Hardware name: Freescale i.MX6 Ultralite (Device Tree)! f: j$ S9 s# S; n% A5 d
8 _5 \- i5 s3 R! K; t" g[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)
* }6 Q. D F' L0 {" ?* U) P[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
$ o9 |- H- V% S+ |2 t- E4 k[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138), q `5 u2 g9 A$ n* C# T3 G
[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)3 ?, @# R% @8 e+ \6 A
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)# W7 d. H7 m" Z/ \; @% Q
$ I& K( C8 }0 g7 l0 t J[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)
& g5 a1 D2 ~ M[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)" v" x7 X, ~' U, \$ P
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)4 P$ \% a. P/ v M3 ?4 F+ P/ z
[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)/ v; z, M, {8 k7 s* E+ `) P' \
+ |! b5 k! [2 \! @- e5 n( gUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22% p! l- [' g$ l! D" Y3 F
/ i' V0 Z9 D E1 r+ FUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0
* \' I3 Y2 s* b6 p' sNot a node, first 24 bytes:& u8 S- n8 n& U4 C& N6 W* k: v k6 V
1 [ H8 M/ N' W8 `" bCPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30
) W4 Q, \/ U- }" }1 {" c! F7 P" EHardware name: Freescale i.MX6 Ultralite (Device Tree)
, \; O9 h0 }; B0 W# \[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)
4 Q# @; ?% D6 \& O" T: \* r[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)2 J& U6 O0 K6 J2 N( c% z
8 i8 \( I( W8 G- P[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)7 F2 C, P0 T& A, P" J7 [' y
[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)* K5 h& J; { k9 F5 v9 [3 ]1 @
2 K3 ~# u6 x o7 V2 h9 ~0 V[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)
! a! b; n" ]! J6 n' } h" C% L5 b[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)! I' N, K: C: A) M, k/ J* ~
[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)1 Y3 x1 _3 W7 Q$ |. C
7 e5 t% j f% m w( O9 ^5 F/ Q, @[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)
. H* s% g! }/ I% u: Q b+ {[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c) Y: l [0 R8 ? V1 J
0 i7 j+ g4 m+ M" [& n3 }4 A' oUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)
8 E; h9 n- @! {# `UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0
& J$ {" x2 \5 k/ [$ d7 m) GNot a node, first 24 bytes:7 ~5 r; g: p& t* H1 S# @* X- d5 Q
00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................7 P: I2 G, h. G7 Z+ y4 w( G2 H
! N# E' L5 n7 M" M" N2 p% e5 Q FHardware name: Freescale i.MX6 Ultralite (Device Tree)7 ]& T3 O; ~, B; K5 M& c+ A/ M) B
) x. D6 n( _- C7 N$ B* d- `0 m[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)5 x0 H1 a3 V. H/ l& B4 e6 x: Z* c
[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)2 T: a! W6 V0 P' Z9 C9 J6 }# }- M1 a
[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138), E! H! e* a6 }* x3 X5 @
[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc), y4 J! G# L# B1 J G( f& u
) Z0 `" W8 ^+ x- g3 {$ _[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)5 M8 q l' w3 y
6 J8 q M' C7 W7 W3 G, K5 k* {- @[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)5 y; ~3 R! s) `3 M( L, Q6 u9 ^$ x
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)6 _1 w# d" `/ ~/ o
[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)0 E, o1 k# K( U8 ?9 w4 u& X5 [% b
9 ]4 O3 V6 f4 g) S0 PUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22) r& L1 G: S8 w. L& H
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1); f1 L9 Z2 n. P. O( `" M
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0) f9 b$ S! i/ j0 A2 E
: H; {3 m4 r& U# @3 e, F9 R00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................' u6 v: h* L" J8 o/ K' \8 D
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #305 I( H' p# d- s0 j
5 T3 r3 a: {8 a, w. l[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)
: y# T2 Q! y1 T[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)8 _. z) A, g0 \. e5 E: h) e
# K6 r, U: E* S F[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
% O3 q0 ]! b3 A K, a* }5 s[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)
: x3 S9 {' C8 `/ M[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)( W O" n3 r! u8 |& ^6 Q
[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4): I% m* D% [$ T: B, T; A7 \
/ P' L( R4 Z! ?7 m[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)
+ [0 k3 D5 m( H[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)
1 S, F+ S8 ~, d6 O[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)
2 B3 r3 D2 E$ u/ H9 J$ X, }- _# ^8 _[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)0 b+ `: @- M$ h
2 u. G% Q1 P; }8 `/ F7 YUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1). x2 [- p4 I. t0 f1 A
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0" y' m+ e- V- e" h0 }) J" x
$ h9 D5 ]/ e4 w+ V8 x00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................
/ `' S" }) H6 @1 |1 _CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30
8 P) Z" k" j5 g3 ]! Z* cHardware name: Freescale i.MX6 Ultralite (Device Tree)
4 `$ ^5 g0 v5 F3 ^, H[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)
- c+ V5 `% r: F4 l: a# ][<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)
; W* m% c0 r* j( S8 v[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
' [5 C. m2 M, ?' m* Q3 ?[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
9 Q a' n, B7 Y+ e[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)9 g5 ~% l* y& p: c& Z! f
$ O Q% T6 ]8 L[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)
6 X' ]" ^+ U& w b[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)
3 n: Z3 s8 K5 a/ w" R[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)8 r6 A, Y, Q* Q* y1 t
5 R' g& p' X& j[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)
* A; \9 a/ O m5 N[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)
" w0 `. j. I* T/ @UBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22
: r% w" U& ~% _" o0 U2 f& cUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)0 v8 @/ N. _+ C4 ^( d" r
+ k+ W& ~7 I0 x+ f- P, ]Not a node, first 24 bytes:
: f& M4 C) s2 f$ s! f( {00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................0 ]( ]+ a" L' c# F8 ^9 v
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30' M! @. z* \9 ], P8 B1 M
Hardware name: Freescale i.MX6 Ultralite (Device Tree)3 a( S. G5 \* _# {; t; b5 u( w
[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)7 _1 W+ {. X& k0 M6 L
( G& R; e, q+ t3 x3 @) l[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)' l" ^, A+ P# r( v+ T! h2 m
3 D; O5 |8 |, S4 D" _8 O6 x[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)8 l) a1 w3 u4 v( q, b& o
$ O+ c: Q$ `* U; V4 [/ @2 R, i Q[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)
9 e2 `; ?4 m6 Z[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)
+ ~( O; h3 U+ n. E) @[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)
d. I6 h$ C$ s$ a) I2 h2 X[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)
6 P q2 g Q7 R7 f[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)* |! ~: i% m2 `4 C
7 \6 Z6 G$ R% r s7 Q. bUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22
# {$ _# h t/ O+ }9 h/ t& ]7 QUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)3 K x* q/ i; Y* Z f# p
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0! ~4 }0 J; D0 \ ?
c/ `( t7 |* s" [2 b( H4 g. i# e00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................* B7 q6 C: ]- ~$ i; Q4 E1 }
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #304 V: d; n# w( i2 T2 a
Hardware name: Freescale i.MX6 Ultralite (Device Tree). }0 w1 B8 J6 H; v2 `; T8 x. O: }
( f1 |( d* i% N1 Q6 e[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)
) k- \0 m+ j5 g' @/ S[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)( f& \2 I( x# s8 K
: E J( |7 z5 h& H) w[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)
0 W; S5 Z8 ?% B5 p. x[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)6 a% E9 ^& f/ O
[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4) {; Z$ I! @" y
2 T8 W/ y& {' E' A& D[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)
( x% ]; @4 t( H- T/ R, k[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)0 Y8 b' f5 G1 R! K! {! b
; D$ ^+ { S9 ~( q' H[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)
! ?" }9 V2 a. m, v$ q O6 OUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22; d, e L8 L* n* C- S O/ _- v
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)" j+ a# U+ d; |3 u1 I/ w- u5 n
# }. W# h0 b/ ` S/ p# \Not a node, first 24 bytes:
2 a4 _6 }1 ^7 w x1 d00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................7 j1 R( y, _6 H# j* S/ w' N1 A& X
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #304 H* J* ^% ]4 f. S( [
. q& }' c: J. Z7 _0 S[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)# w/ c1 ?& U/ m, ?! ~9 F
# J+ Y8 L# O K& ?[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308): V5 ]0 K0 ^1 G: h" t! }
9 g2 A7 z# ~) W[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc), \/ D7 ^- k( T# Z' v$ c B* X3 I
7 s- P% n: O* W3 ^3 r[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)
) ~3 }: n' c3 O" X0 M* P[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)$ C/ v3 U) A p" g" [. g# f% e' `
, P* [& h! b! x. Q! J& b4 J% `[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)9 a% [. x) r& I5 K
8 b9 Y" i ~3 n { x! i5 {" N1 p[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)
2 B; O0 i2 t: J8 l9 @' rUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -22
" m4 `3 I5 X. v' d) g( eUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)( X1 ~+ M3 c3 f' a# `
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:110592, LEB mapping status 0# h: w# k$ E6 ~# H: v6 @- w* o& g
Not a node, first 24 bytes:4 L, I' B' M# _1 S i
00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................, ^9 `/ E! {. B8 d& b! d$ N4 }. T# ~& J
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30# L4 I7 [ k5 I; q( [* c+ _
# g6 u3 ^4 r. f% { y) J- X) a: Q[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)
& v* j! g% I9 r( |7 I[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)/ x/ H* i" I: \1 d( V1 g1 y
[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)5 I( D9 {/ ~* P$ X5 U
5 E5 V1 `3 Y" O+ E2 \9 z[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc). S- A" _$ h4 b* K2 p
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)' n- h2 `2 X* v7 _0 _7 R
& ?4 r" T7 H0 A0 {[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)
* q3 I* r2 m) L6 ?0 q( M[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)/ ?% F# i: U. ?
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)0 m: P: @/ e( c5 r, O
8 D& E3 J+ F1 ?7 S: J- ~[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)
q1 F9 i" D( t' _& SUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2518, error -223 `& K! l' Q- N4 T' X
init system info over
) P1 |, L8 y4 M- Msystem info do end
3 ^; Q8 [7 K+ ~* k% o* d0 n6 `anolis_init:machine is
% C( D" i# _% p- m2 F' {8 W, z- ~UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)
2 j0 k8 f4 T* z3 ]. W# [/ ?+ L9 r" Z# xanolis_init:after adjust intensitUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:116736, LEB mapping status 0$ H1 E0 o- E3 B
y* O0 j* |9 n! |2 |$ p' T
Not a node, first 24 bytes:# u+ k4 h R( u x( ~" V
00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................6 \! C& e1 B. h$ H: m, o, |
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #307 y8 f, U4 Y) p) h# c- x
Hardware name: Freescale i.MX6 Ultralite (Device Tree)7 B/ p1 U1 q5 C2 m I
[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)8 d& Q6 o' a5 K9 y0 P; x
[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)4 s/ W0 {: Z3 j/ V M R, m
[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)& I; `: d! \3 y, x
/ _6 u0 n _( X1 l[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)
+ k; b2 Z4 h0 n0 {[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)
, x* O U+ J& {2 B8 F7 z i[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)& h" e" p( ~, }" T8 b2 ?
- T f) ^- O5 k- K[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)' n$ T. N- w% M+ f3 T
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108) Z/ R/ C' l3 T4 k# B. N9 C
! ^' h& g/ w4 W- t9 f[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)" F( Z& D9 f6 b( v- O
UBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2520, error -226 j$ y. o" e) p. b6 z, F
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)1 l& L6 R! M4 @" r
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:116736, LEB mapping status 05 K) Q* g9 q' R+ C! Z& y: H m
Not a node, first 24 bytes:" x( j8 g' O/ d6 L0 k& g) S
00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................+ z" b1 o6 X" H% R/ [
& u1 N1 V+ g* _8 M% x& G) NHardware name: Freescale i.MX6 Ultralite (Device Tree)* |& @* O6 c" i* y$ V! F
[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14). B6 b" C4 {7 v9 `
T/ Z2 ^. ?* P3 @[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
1 {+ {" @. L! X7 ] w0 M8 m5 f[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
6 V- ?; l# u1 P; v" V2 e% M3 _- ?[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc) R$ Y$ S$ m- J% |. C' }9 I1 b. g
, z2 [4 h9 T* ]8 R1 h3 n5 }& H8 @[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)6 K3 Q" n% _& r+ n
8 y2 U1 Z d( y7 i; X6 O0 c' H[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)& b6 K- @5 g" d8 J% d
[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)6 X: e3 C3 ^" D8 w* A) `' B. A
[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)2 V# l) @, F+ y* l+ [
( B o0 `7 a4 H) RUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2520, error -22
# E; l& M0 r& o4 zUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)7 H& f# P- W( s% k+ Z. ]
( q; g8 I% x0 A" [4 F5 b& xNot a node, first 24 bytes:; U8 K- {7 i* z
' z' B/ z5 l K) C' ?1 m6 aCPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30* l- A% N K! q; ]$ N# }; R
Hardware name: Freescale i.MX6 Ultralite (Device Tree)) y9 y; N" Q9 t" _
1 E" o: ~% Y& g7 }[<8001269c>] (show_stack) from [<80834c60>] (dump_stack+0x84/0xc4)
% F( `# ^5 T Q[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
% u4 E; J% b( ?8 T. I8 x[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
: Q" p0 @/ ^1 M4 z- y7 r[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)
' P, L d0 k+ s3 ^5 U. h3 A[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)" B( y: Z H0 y: w0 W- b1 E
[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)" N/ {- `$ g3 _6 m9 q( H
, o! D( {8 l5 b6 v, C4 V4 q[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)3 o: b$ @7 ^) U: b5 K* J7 Y
, Z& ~' o' q% ~$ W$ Y2 P G[<800ea8b0>] (vfs_read) from [<800eb13c>] (SyS_read+0x3c/0x90)% x' B* ~3 C6 R3 V2 q7 `
6 n% Z( E9 z! o1 kUBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2520, error -22* D( x5 c- l+ |6 R( ~' N% _9 y* { i
* W( B2 m( F& `. S. a; J. \0 yUBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:116736, LEB mapping status 01 m6 ^9 n; z% e8 z2 o: _6 Q, ?8 i1 X# y
z }4 }3 d* V( i00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................% o/ K5 W" a9 @- M" k' V
. h+ c5 E& P5 P# d% F" KHardware name: Freescale i.MX6 Ultralite (Device Tree)5 `' D# v6 D/ t7 D* \* h& r
[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)! r9 {8 V& t% C0 ~' v; Q
" w( }' t5 V' F# u1 H8 k# D+ v[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
# {0 |* a2 t( N4 m/ P9 d7 A[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138). b, A* Q+ ?7 s. Q3 o% {
[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)- ]+ b2 u5 P7 x3 C# ]$ v$ {# t. _
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)+ Q" r- p+ X P2 m* p
[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4)* |# b1 H/ A. l. k' M, [* j
[<8021a5c4>] (ubifs_readpage) from [<800aef14>] (generic_file_read_iter+0x320/0x5f8)1 H8 }+ a7 N% ]
/ X1 ~' M' v7 ][<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)3 X5 X: m" S. p2 U( r
% o% U8 O7 K3 A[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)5 @+ h$ h: g0 m7 p) r$ f
UBIFS error (ubi0:0 pid 402): do_readpage: cannot read page 0 of inode 2520, error -22, l/ t5 `+ Y) H8 G+ }$ l- Y
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node type (255 but expected 1)4 A1 f8 a9 k5 ^
UBIFS error (ubi0:0 pid 402): ubifs_read_node: bad node at LEB 476:116736, LEB mapping status 0' N- o6 [7 R# J$ q# s+ T
. f3 Y# z3 |! x5 X00000000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ........................: B1 i2 r" ?- v; Q
CPU: 0 PID: 402 Comm: phoenix Tainted: G W O 4.1.15 #30" L9 e- y7 x! R9 |
& T9 p8 r9 A) F% t[<80015cf8>] (unwind_backtrace) from [<8001269c>] (show_stack+0x10/0x14)5 A% ]4 R. N( u1 n: g$ F
! p+ w. l9 u% E- o! V3 p[<80834c60>] (dump_stack) from [<802237a4>] (ubifs_read_node+0x28c/0x308)
" F- A F( V1 i' n+ g3 U; Z$ I[<802237a4>] (ubifs_read_node) from [<802404a4>] (ubifs_tnc_read_node+0x12c/0x138)
5 Q m2 m# X! O[<802404a4>] (ubifs_tnc_read_node) from [<80226cd4>] (ubifs_tnc_locate+0x1a0/0x1cc)" y0 R+ l0 ?% w, r2 [# P
[<80226cd4>] (ubifs_tnc_locate) from [<8021942c>] (do_readpage+0x130/0x3dc)- B5 U, s/ G# A& b' ?; f# `8 g
[<8021942c>] (do_readpage) from [<8021a5c4>] (ubifs_readpage+0x38/0x4c4); w, C) l k2 l! Z
( C/ z" c5 t) _ E; Z. [5 i[<800aef14>] (generic_file_read_iter) from [<800ea154>] (__vfs_read+0xa8/0xd0)
7 n& n r) x1 P8 b# t5 g0 z$ W[<800ea154>] (__vfs_read) from [<800ea8b0>] (vfs_read+0x7c/0x108)/ i8 f5 m3 e- A k" b
) |" F- j: v$ f& q' h" w[<800eb13c>] (SyS_read) from [<8000f400>] (ret_fast_syscall+0x0/0x3c)/ r& j) l2 Z0 y% `% j
1 b- n$ N' i# P. j' z, d2 Danolis_init ver1 b9 ]& u7 [& e d
open gpio-iobank error
: a) g" c9 i& X* h; a$ {$ ^spi mode: 0x0) P: n6 S) D8 p$ W8 Y
bits per word: 8
5 n% z, @$ P. s- `+ I6 i% \6 Smax speed: 3000000 Hz (3000 KHz)
# `! _3 |$ |8 U/ z/ fspi mode: 0x0
; V3 f7 `/ n1 J/ x; e9 u4 |bits per word: 8- B& \* I6 T+ r& e; f
max speed: 3000000 Hz (3000 KHz)+ `; \2 s3 e1 ~# n" t
fpga version is 0x1003: q& O$ j5 b8 e) u5 V9 S* t4 K( a
open soc adc error$ {$ s4 J" H: g! Y" `
[fpga_write_spi_adc_data],data =0x 110007
% q! M5 |7 T+ a& b' ]5 ~[fpga_write_spi_adc_data],data =0x 110077
c/ U1 a. m. }' x' `$ Z# l) Y[fpga_write_spi_adc_data],data =0x 110777' }6 d3 o" {$ ^1 m+ i
[fpga_write_spi_adc_data],data =0x 124000
y/ G" y& L- i$ L[fpga_write_spi_adc_data],data =0x 124700/ b8 _8 I( J" ^
[fpga_write_spi_adc_data],data =0x 124770% P. G- `* w% u9 j
[fpga_write_spi_adc_data],data =0x 124777
% l3 d# Q7 `! }5 S9 R2 k$ ]; F& K[fpga_write_spi_adc_data],data =0x 250000
/ f3 z: F5 m7 e6 ^( y. ~0 _[fpga_write_spi_adc_data],data =0x 310001
$ b% o( h' C# ^4 \# w[fpga_write_spi_4360_data],data =0x 300065
5 m: I- C* w0 t5 v- Q[fpga_write_spi_4360_data],data =0x ff1285 l2 J: @5 j' F7 V0 ?! i
[fpga_write_spi_4360_data],data =0x 13812& H! N; o& ]. c$ {
pll is locked3 D3 A; ~" W9 D
gpio not inited
( q3 h& Y) C e5 A K* Sgpio not inited. G+ l# h! h, u7 x8 f" B
gpio not inited0 _ H7 R! F ?5 _
gpio not inited) K- E2 V" \* c' \8 N. q
gpio not inited
, y. D$ x, R; `" D. Kutil_helper_load_setup:0, 13 K& R1 E+ {! [+ Y' m
init_calibration_result: in:/config/root/cali.dat4 E1 _( I/ W% {' W
[fpga_write_spi_595_data],data =0x 204 j) w) F) \; _6 U' p
[fpga_write_spi_595_data],data =0x 303 o0 i- B& o T4 Y6 H0 ]( ?, |
[fpga_write_spi_595_data],data =0x 38
+ b5 O* n& P: S1 [9 z3 b- e[fpga_write_spi_595_data],data =0x 78
: C. V4 N9 v# @# p" @! r' ozoom:inf, atten:1.000000, 0, 1.000000$ e$ c4 G2 q. k
h:-2147483521, l:2147483647
+ u& [! K' }2 F& H: K2 r1 Eh:-2147483521, l:2147483647+ G, c4 ]* L- T% _; d, V: N
$ M7 V2 A& I$ F* Vh:-2147483521, l:2147483647
. A9 g+ h, p; C" G1 Wh:-2147483521, l:2147483647, _) b3 {' I. }0 M2 X
h:-2147483521, l:2147483647: z* E3 s6 n L
h:-2147483521, l:21474836472 D. D) S' ]' K0 X! L
9 U' W& W7 F* s' w7 Qh:-2147483521, l:21474836474 @9 o9 R, z0 h0 |
' [6 |: o* k k' m; ^h:-2147483521, l:2147483647
1 d: j4 j' E- |' U! t1 k2 }h:-2147483521, l:2147483647
( e* P6 K) K; o5 ~h:-2147483521, l:2147483647% Z6 {0 R8 _. G7 s( S( h- a
" D* A. w$ M) `8 o$ J, rvgah:1995776000, vgal:1995776000" J3 b6 J- \* t" y ^+ l( g- D
vgah:-1.000000?inf, vgal:-1.000000?inf- N7 A8 H3 a9 N) r/ z
error:no prop vga and adc code found* P# T1 i; M, f3 h }6 s! z. x
atten:1.000000, gain_factor:1.000000, vga_code:0, adc_code:0, bias_code:29286
, w4 V3 u5 w* L" v9 Tspi_dso_chn__set_attenuation:chn0:0, 0, 1.000000' l* z0 j$ A; l$ A2 s( i
[fpga_write_spi_595_data],data =0x 78: I8 Z6 T- _& F7 }1 N! n
[fpga_write_spi_vga_data],chn = 0,data =0x 0
J* l$ s1 H0 [2 b) o[fpga_write_spi_adc_data],data =0x 330001 n3 q" M1 h* m
[fpga_write_spi_adc_data],data =0x 2a00000 m* p) Q8 [, ~
[fpga_write_spi_adc_data],data =0x 55003f0 ^3 ]) ?9 E, E) R* s0 @. J/ h
fpga_write_chn_zero_value:chn0:0x4000
% l5 S4 e0 d, t! R/ Ffpga_set_adc1_amp_factor:in:1024. f+ A* [! t6 j0 j/ k* Y
fpga_set_adc2_amp_factor:in:1024 A4 z0 `! o7 M4 G8 a! z; L
fpga_set_adc3_amp_factor:in:1024/ B O& C; T0 o+ h" V* g
fpga_set_adc4_amp_factor:in:1024
/ V2 H$ i8 Q9 l) R# b- `1 K! gfpga_acq__set_adc1_zero_coe:in:0
4 _9 ^* v, d) I8 ? N1 _fpga_acq__set_adc2_zero_coe:in:0+ n1 ]4 `5 f+ u8 t$ e$ J9 k/ q
fpga_acq__set_adc3_zero_coe:in:0
* N) {. Q. H$ s& q: ]- L, ifpga_acq__set_adc4_zero_coe:in:0- Y$ ?% `( u/ f# b3 L" P1 l
[fpga_write_spi_595_data],data =0x 2078
2 t( U* _1 b% y[fpga_write_spi_595_data],data =0x 3078& |6 `. z9 b k- | [, x: W
[fpga_write_spi_595_data],data =0x 3878
6 n. ?8 a$ [9 P! o[fpga_write_spi_595_data],data =0x 7878/ H6 @7 J5 N. K+ o& }$ ~
[fpga_write_spi_595_data],data =0x 207878
$ o7 J5 O1 N" O- d2 i# _2 b* m" G[fpga_write_spi_595_data],data =0x 307878, Z R) V8 e- d& r0 T1 V" k& k
[fpga_write_spi_595_data],data =0x 387878
% j+ q# X% l* \4 G ~5 \[fpga_write_spi_595_data],data =0x 787878
- n( f5 W: J. B8 k* B* A[fpga_write_spi_595_data],data =0x 207878786 w5 b; v3 Y& s' Z; @8 K
[fpga_write_spi_595_data],data =0x 30787878
@/ z! G4 {& D$ U) @[fpga_write_spi_595_data],data =0x 38787878
( j0 b9 k% {' r6 D8 H" W8 W[fpga_write_spi_595_data],data =0x 787878783 c# w' Y8 R3 k5 Z! k
[spi_dso_chn__set_op_enable][129]chn out of range:4/4* @& K+ i) f# m" A; H$ a' m
[spi_dso_chn__set_vga_enable][176]chn out of chn:4/4
6 y! ?# L& P& R/ {! O[spi_dso_chn__set_ac_enable][109]chn out of range:4/4
! S: i% ]2 d8 V) h; Q# R[spi_dso_chn__set_band_limit][151]chn out of range:4/4. W* D% f/ d& N: Z9 u4 D# I2 e. v
[spi_dso_chn__set_op_enable][129]chn out of range:5/4
5 S( q# l/ h; N& E9 v[spi_dso_chn__set_vga_enable][176]chn out of chn:5/4+ P$ r3 H' q4 G) i9 }0 _
[spi_dso_chn__set_ac_enable][109]chn out of range:5/41 q- Q! I' A2 W- N$ b
[spi_dso_chn__set_band_limit][151]chn out of range:5/4
0 b2 F* m# o+ |4 j, q h1 F[spi_dso_chn__set_op_enable][129]chn out of range:6/4
2 h$ S/ Q& u5 b8 M2 U8 |[spi_dso_chn__set_vga_enable][176]chn out of chn:6/41 L6 p+ b. N- V# ^; e
[spi_dso_chn__set_ac_enable][109]chn out of range:6/4/ K+ b! @0 V4 B& C8 d
[spi_dso_chn__set_band_limit][151]chn out of range:6/4
% G: M z/ Q7 y2 ^: v! _[spi_dso_chn__set_op_enable][129]chn out of range:7/4
" T, k, a$ D! F1 R* y[spi_dso_chn__set_vga_enable][176]chn out of chn:7/4
7 U$ _/ \* U1 e) r# Q0 ]8 V R[spi_dso_chn__set_ac_enable][109]chn out of range:7/4, X5 p& b+ x5 Y3 A/ i- y) U6 o. j
[spi_dso_chn__set_band_limit][151]chn out of range:7/4
( F1 \; {+ G H' j* d# Fdso_trig_set_type:type is 0& k, w0 C# ~" Z/ o. X2 V! a
[dso_trig_edge_set_src] trig_src =0, chn_used_adc =09 M5 i) Y0 y. {5 l3 |0 Y
# A/ `' t9 N: l6 D8 R) b: o6 M9 H3 U+ h/ L! _8 ]5 D$ h% d
level =0,level1 =0,sensitivity =6
" c& j/ F$ l/ D# j# ndso_trig_set_level_normal:t1:0x7a, t2:0x80, t3:0x80, t4:0x86
# o: B l0 R) v8 [ K& H) s. l[dso_trig_edge_set_src] trig_src =0, chn_used_adc =0: E$ t) a$ J2 T* v2 w( h
measure_helper_set_one_chn_all_only:0
( e8 ]) v9 S" r, z+ U9 X) R[fpga_write_spi_adc_data],data =0x 310001
; M* e& q% H9 ^! o( a3 |5 D[fpga_write_spi_adc_data],data =0x 3a0010
) }! [7 z$ E9 x[fpga_write_spi_adc_data],data =0x 3a1010( ?& a0 _1 K6 i% a4 O2 {7 X
[fpga_write_spi_adc_data],data =0x 3b0010
7 o6 t! B/ Y* B/ i }% N3 u: ~% T[fpga_write_spi_adc_data],data =0x 3b1010$ D9 ]7 P1 r. o' G+ ~4 |5 ?& L4 C
dso_adc_mode_and_fpga_data_pack:1 chn mode
, `6 ?9 ]3 ?3 L% q$ O/ `# s[fpga_write_spi_adc_data],data =0x 310001
: n8 a0 n( X- r) M! e[fpga_write_spi_adc_data],data =0x f00008 ~8 D7 j- p( N
fpga_packet_to_chn_read_info:11111111, chn_dot_nm_per_packet:8, bytes_per_addr:1
5 m" J" N: y, l; x$ F" @fpga_packet_to_chn_read_info:0:chn:0, off:0
+ s6 T5 {9 E9 T- R; gfactor =1.000000,max =1000000000,sample =1000000000.000000
. w& `& U( ^5 ~% ?: s: `7 Yfpga_enable_chn:0, 1' x/ D( Z3 ]% n& ]2 b2 [. ]
fpga_enable_chn:1, 01 Y# J5 p7 y- M' K) B
fpga_enable_chn:2, 04 d* m# `$ \, B7 t, j
fpga_enable_chn:3, 0# N/ E, i" ~, B2 M2 |
fpga_enable_chn:4, 0
* c# t6 A1 g! Q4 B2 D. _+ Cfpga_enable_chn:6, 0
/ v( j4 K3 V4 t4 z, c* ~9 @* sdso_acq_control:adc_chn_used_nm:8
' S1 T0 E4 ~# J1 \% Z+ Wfpga_write_dso_reg:div:0x00000000. C9 |. Q9 b; K5 g, f
dso_acq_control:sps:1000000000.000000, div:1% Y5 s, E. @! W
acq_dot_nm_of_timerange =1600,time_range=1600000,dso_acq.dot_factor =1,sample_rate =1000000000
/ Q/ y; O, c& Q4 F8 |* r) Ddso_acq_control:1:2032, 2032,0: q" Z8 M: _! H; p0 P8 t
dso_acq_control:2:2032, 2032
$ A* s% V) O1 l* F% G5 h3 D- X0 Adso_acq_control:3:254, 256
" _# b1 q* l# d' T4 Mfpga_write_u48bit:before:256, 0, 71
p! y4 \5 w7 A( k6 z6 Tfpga_write_dso_reg:before:0x0000000001009 ?* M' V2 q2 \& u8 O! l( n
fpga_write_u48bit:after:254, 0, 777 J# ]4 \3 T. Y* j* C
fpga_write_dso_reg:after:0x0000000000fe
$ ]& P8 X. ?" O+ kdso_acq_extract_enable:0, 0
+ W1 w5 c, h" w. b[fpga_write_spi_595_data],data =0x 78787878
( [3 m$ e6 ^8 d[fpga_write_spi_595_data],data =0x 78787878/ b; C3 p8 B/ E1 v: |; P. k; c
+ o" s6 O- e! ~+ s' c, ^# d5 h[fpga_write_spi_595_data],data =0x 78787878
& F$ C& ^" {6 ~set_bias_and_scale:0, 2000006 Z1 w9 X* ^7 q' |/ S1 R
zoom:1.000000, atten:1.000000, 200000, 1.000000& I. }* ?6 W( M
h:130, l:17
6 C% c( |2 {8 }& a1 B( {/ s kh:130, l:14
9 }& s4 N" [; C* i0 W5 }vgah:130, vgal:17
- Y' e* ]) d- A; x/ Rvgah:0.789275?1.000000, vgal:0.947648?1.000000
" F6 M/ G x) a8 g& H" xvgah:0.210725, vgal:0.052352; S! z; w! ?6 S" X* R5 ^
atten:1.000000, gain_factor:0.947648, vga_code:17, adc_code:0, bias_code:39830
+ M0 k: m( n: l0 u4 s- Aspi_dso_chn__set_attenuation:chn0:0, 0, 1.000000" a* _# k" v4 x+ @4 [
8 z* e$ `+ g8 F% N9 g% Y[fpga_write_spi_vga_data],chn = 0,data =0x 11! B" l' L7 p/ U% H5 C
[fpga_write_spi_adc_data],data =0x 550000
9 w2 Q* e/ M1 T8 p[fpga_write_spi_adc_data],data =0x 330001
: F/ a! U2 W ~+ I( q. w[fpga_write_spi_adc_data],data =0x 2b00006 \% {( q! e) t3 K( a
: Z Y$ [2 M- I4 `8 Nfpga_set_adc1_amp_factor:in:1024/ e3 g. l( A6 G8 G
fpga_set_adc2_amp_factor:in:1024/ Y/ s6 L9 Q7 R+ [
+ G* S2 L( J0 ~: ufpga_set_adc4_amp_factor:in:1024
, v/ _* ?. ?9 X8 M: |, i/ B8 g; Bfpga_acq__set_adc1_zero_coe:in:0
9 k u6 o, C( {3 ?fpga_acq__set_adc2_zero_coe:in:03 m( N; ?$ r8 t3 I5 M
4 D, t; C$ w2 D, A- `fpga_acq__set_adc4_zero_coe:in:0& Z# X' _3 L0 W
( D3 }! V; m6 h+ o( h3 S2 K1 E/ J[fpga_write_spi_595_data],data =0x 78787878- _1 c5 I9 D! J* I
' s [, n* w: j# y[fpga_write_spi_595_data],data =0x 787878789 e6 o! H+ N* R7 x3 _) I i
set_bias_and_scale:1, 200000- u/ ]5 {5 O' k9 X
}0 H: p$ G# e" K8 h[fpga_write_spi_595_data],data =0x 78787878& U. z8 J) _+ [% L Z
[fpga_write_spi_595_data],data =0x 787878780 K" `* x( @) ~7 |
) c+ k1 c8 T2 ~. M4 o4 X) ^set_bias_and_scale:2, 200000
3 D1 K# p: h: [) B3 [& i& u4 z8 g[fpga_write_spi_595_data],data =0x 78787878
Q" K" g6 G7 N% |[fpga_write_spi_595_data],data =0x 78787878
! f z' q+ a9 w2 Y; h[fpga_write_spi_595_data],data =0x 78787878( u; b- Z/ K9 N- u' D9 |8 I. |" n
[fpga_write_spi_595_data],data =0x 78787878! d3 A2 I7 r1 E0 v( {
set_bias_and_scale:3, 200000
+ u) e8 E1 B! B2 O( C[spi_dso_chn__set_op_enable][129]chn out of range:4/4
" u( \3 @- l9 `/ W$ |[spi_dso_chn__set_vga_enable][176]chn out of chn:4/47 F3 p1 q ?2 c4 |* Z
[spi_dso_chn__set_ac_enable][109]chn out of range:4/40 _- F+ X. n1 F% k
[spi_dso_chn__set_band_limit][151]chn out of range:4/4 C8 V4 s) p- ]# Z1 c4 z- y
set_bias_and_scale:4, 200000+ u: t# x' f1 K
4 v* z0 z9 Y8 o[spi_dso_chn__set_vga_enable][176]chn out of chn:5/4
8 `6 L8 f% A% ] H[spi_dso_chn__set_ac_enable][109]chn out of range:5/4
3 c1 U9 F, c4 ]) c: {) G# ~[spi_dso_chn__set_band_limit][151]chn out of range:5/4+ V5 z) H' p. C' ~* b ?
set_bias_and_scale:5, 200000+ }9 D" O/ {5 F* M; V
4 `3 B. R! e6 _- G[spi_dso_chn__set_vga_enable][176]chn out of chn:6/4
/ |: e6 v. \6 h* l& g* v: U[spi_dso_chn__set_ac_enable][109]chn out of range:6/4/ f- c0 k6 A/ J6 X2 B/ B7 z% O: l2 d
[spi_dso_chn__set_band_limit][151]chn out of range:6/42 Q1 f$ S3 G; [9 n1 }( \* y
set_bias_and_scale:6, 200000
^2 }4 K6 d- O, P[spi_dso_chn__set_op_enable][129]chn out of range:7/4, @7 _4 }( ~# N- S; q- l' B" p
[spi_dso_chn__set_vga_enable][176]chn out of chn:7/4& o5 w& ^7 z; j/ N; U, f5 E: K
[spi_dso_chn__set_ac_enable][109]chn out of range:7/42 s Y# U5 j5 n: s! Q9 j; {( q5 j
[spi_dso_chn__set_band_limit][151]chn out of range:7/4: b) \. i) r7 `( n" Y
set_bias_and_scale:7, 200000
3 R. F* R& ~- J# E7 R[dso_trig_edge_set_src] trig_src =0, chn_used_adc =2
M' V+ B9 l( V7 d' O: p! X5 {$ |/ H! f9 X$ Z
( V- g1 T/ u; n3 |
% p; J0 V' ]/ z* g6 L3 f0 |dso_trig_set_level_normal:t1:0x7a, t2:0x80, t3:0x80, t4:0x868 `( ]& f1 }9 L) r9 |2 O" s
( I8 [! e" _1 g# _& venable =13 S5 w; g$ V) X. l; ?+ I
fpga pll is ok& D1 V* `1 }7 v. H3 B
util_thread_start:thread 0x2856500 is running. t5 s+ L) C' w
unable to open /dev/video for output, continue searching device.3 J6 P8 B) J) z; b% E/ _
Found v4l2 output device /dev/video0.* c. w- F, r# B% c$ n; O
V4L output 0 (0x86100000): PxP Display Output
- J0 q' m" z% g. J) |. f0 XVideo input format: 640x480 24-bit RGB6 A* }( C% ? H% p) z: ^
win.w.l/t/w/h = 0/0/640/4805 s$ L! g3 \7 M! t, h
crop.c.l/t/w/h = 15/0/640/480" a0 p$ ^% X) m6 b9 e
Found v4l2 capture device.
" [. C7 c7 C' lVIDIOC_S_PARM failed
9 j0 f$ \& v& ~. I2 aVIDIOC_REQBUFS failed3 T! j8 b% V0 M/ i# U! E
start_capturing failed
$ [! P% a7 q$ @5 _* ?" ydds_cali_uniformlize_amp:7.000000, 1.500000
6 X# B% J U! D k+ i X. G8 \; bdds_cali_uniformlize_offset:0.000000, 3.500000, -3.500000, 0.000000, 1.000000, 0.285714, 0.000000. ?. R9 X& r5 H
dds_cali_uniformlize_amp:7.000000, 1.500000- J- e" Q8 M4 L/ |, T+ j
9 B6 Q9 c8 b( e% g4 K) P rdds_cali_uniformlize_amp:7.000000, 1.5000007 {9 o, ~% Q- p
5 ]% r+ S5 h0 Wsh: /dso/etc/insmod_usb_driver: not found/ f- P8 D5 j2 V& ^# k
open usbd_serial device error !!!!
" A6 q5 J+ F) x) {, J" Awe have net% y% a& E* u6 `5 ~3 v# G& D
[init_server]thread_id=4020 v# Q) B* _" m! c# t5 D% q
[init_server]glibc version=2,23& s* B- x9 Y" L
[thread_send]thread_id=410
. ?2 T0 ?: H7 b; C7 H1 s& l! C/ n[thread_recv]thread_id=4098 A2 x3 c4 s) ]3 q) b0 L
[thread_depackage]thread_id=411
: n3 A# A8 D- Q+ J$ ~) A% G* b |
