查看: 2098|回复: 25
有没有Cadence Hotfix 16.60.090的补丁
发表于 2017-4-17 13:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
9 \: g4 Y3 h) j; K7 Y) s4 Y) h7 `
7 Y$ ]( d8 `5 t% _/ SSPB 16.6   UPDATED KITS RELEASE: ISR 16.60.090    EST.DATE:  04-14-2017
. S+ F% M9 G4 I, J1 \------------------------------------------------------------------------------. F0 k" N+ M  t/ X% `
advanPakgDsnr16.60-s173wint
& Y+ b$ A% V" S) W$ e" _: p! salgroBase16.60-s176wint! n+ P" H. }9 S
algroCxt16.60-s105
& ?5 R1 j/ U0 L* g1 ualgroPadPcad16.60-s095wint$ [  g1 ?+ F9 _
algroRoot16.60-s096wint
  q+ }! d8 P/ g: W  {algroTextIndep16.60-s117- M: x& [  e. Y8 n; @
archiver16.60-s016wint) V& x+ z- D" R- `6 v6 V/ l
caeviewshdl16.60-s025wint
$ Q4 p6 b! `( \2 D7 e* ncheckplus_exp16.60-s029wint; ]& Z1 N% |! w" r5 K
conceptNT16.60-s147wint, r2 |# \: T& P; X
creferHDL16.60-s038wint. e+ `. T/ w" P  v
sipDsnr16.60-s174wint
+ V' Y; V1 p0 B3 w9 v8 O6 ^8 y5 e& u) B8 l# |7 r& s
) G' y/ {# D& p# e自己下载太慢了,网速不行。( [. k% _* Y5 n" M2 N
: A* Y( Z2 C& _+ u) P6 o4 d3 F; c
终于上传好了。。。。。。4 o: M8 `5 ~7 v
1 |( H' u  N) Q% t5 R! H
http://pan.baidu.com/s/1kUW5IXD
. Q0 i( ~/ v7 [# v
参与人数 1威望 +2 收起 理由
yueyuan2003 + 2
    2025-10-31 15:44
  • 签到天数: 17 天
    [LV.4]偶尔看看III
    推荐
    发表于 2017-4-19 10:30 | 只看该作者
    DATE: 04-14-2017   HOTFIX VERSION: 090 =================================================================================================================================== CCRID   PRODUCT        PRODUCTLEVEL2   TITLE =================================================================================================================================== 1679575 CONCEPT_HDL    CORE             Page numbers get duplicated in Hierarchy Viewer when editing page names 1697723 CONCEPT_HDL    CONSTRAINT_MGR   Differential pairs are lost during migration due to incorrect design name entries in the DCF file 1699796 ALLEGRO_EDITOR EDIT_ETCH        AiDT fails and reports there are no timing constraints even when propagation delay is set 1711564 CONCEPT_HDL    CREFER           CRefer crashes while processing a hierarchical design containing subdesigns 1711635 CONCEPT_HDL    CORE             The arrow keys do not work as expected in Windows mode 1713729 CONCEPT_HDL    CAEVIEWS         Not getting net property values from CAEviews report 1714532 APD            DIE_GENERATOR    Compose Die from Geometry creates incorrect pad shapes 1719754 CONCEPT_HDL    ARCHIVER         Path stored in the compressed file starts from /home instead of the current working directory 1725621 ALLEGRO_EDITOR DATABASE         PCB Editor crashes when moving a group of components or clines
    推荐
     楼主| 发表于 2017-4-19 09:35 | 只看该作者
    yueyuan2003 发表于 2017-4-19 08:533 ]6 f; g5 B/ N$ P- ]7 o( V
    谢谢zgyzgy!!!' N( B  \; z9 M( `
    楼主也可以做好事把ASI16.64最新的32位和64位的放出来吗
    % m, e9 k& S1 P' h% j# S# x; v现在都是SIGRITY 2016 SIGRITY2017了呀 都没有AIS
      d  n7 W6 n8 ~' p% X0 K  Q& z
    推荐
    发表于 2017-4-18 12:33 | 只看该作者
    zgyzgy 发表于 2017-4-18 09:54
    $ v0 ~# {! C; h5 f4 W1 ~' B好的,终于下完了,晚上上传到网盘哈。
    3 a9 O  {; o2 ]" Y3q,谢谢你这样的大神,无私奉献,记得你给这个论坛贡献了好多东西0 A( |' M" X: q8 F' Y3 e, D
    发表于 2017-4-17 21:00 | 只看该作者
    楼主,下吧,顺便分享给我们这些都没地方下的人吧,谢谢
     楼主| 发表于 2017-4-18 09:54 | 只看该作者
    好的,终于下完了,晚上上传到网盘哈。
    3q,谢谢你这样的大神,无私奉献,记得你给这个论坛贡献了好多东西  详情 回复 发表于 2017-4-18 12:33
     楼主| 发表于 2017-4-18 22:15 | 只看该作者
    不好意思还没有传完,网速太慢了,百度网盘都还没有资源,不能秒传。
    发表于 2017-4-18 22:19 | 只看该作者
    静静等候,感谢楼主。。。
    2021-11-4 15:17
    谢谢zgyzgy !
    发表于 2017-4-19 07:29 | 只看该作者
    感谢zgyzgy!!!!!!!!!!!!!!!!!!!!!!
    2025-11-5 15:30
  • 签到天数: 724 天
    [LV.9]以坛为家II
    发表于 2017-4-19 08:42 | 只看该作者
    谢谢楼主,很给力。
    发表于 2017-4-19 08:53 | 只看该作者
    谢谢zgyzgy!!!+ L2 x' y& u/ e. ?$ l: ]6 ~
    现在都是SIGRITY 2016 SIGRITY2017了呀 都没有AIS。  详情 回复 发表于 2017-4-19 09:35
    2021-11-4 15:17
    发表于 2017-4-19 09:28 | 只看该作者
    谢谢zgyzgy!辛苦!
    14#
    发表于 2017-4-19 09:49 | 只看该作者
    谢谢你的无私奉献~
    GMT+8, 2025-11-6 04:44 , Processed in 0.156250 second(s), 30 queries , Gzip On.
