What is a Switching Diode?
5 @* v* h% c$ PSwitching diodes are a single p-n diode in a discrete package. A switching diode provides the same functionality as a switch. It has high resistance below the specified applied voltage similar to an open switch, whereas above that voltage it changes in a sudden way to the low resistance of a closed switch. Switching diodes are used in devices such as ring modulation.
1 z0 |% v& }; x/ `+ {
8 X( x5 s5 ]" \5 TApplications for Switching Diodes:0 a' ?$ e) S. C: {9 p$ I
The switching diode is the most basic function of almost every electronic application. Switching diodes are also used in high-speed rectifying applications, such as in radiofrequency receivers. Applications also include high-speed switching, general-purpose switching and reverse polarity protection in the consumer, automotive, and telecommunication industry.
3 s) ?" F# Y: H" Z, U- {. f/ e% H
0 \6 l. k/ _/ W% C1 }0 {8 D- y1 B
