本文转自:http://www.dongeasy.com/software-development/embedded-system/2494.html) n( ~' w4 m- v
What's New in v3.40Add Plugin Category under Tools>Options - Addition of Plugin category for plugin configuration settings. Information currently under the Embedded category. Automatic notification of new MCC releases – Notify customers of MCC updates using an RSS feed. Modified Dual partition reads so always correct - No matter what partition is active the memory read will be correct. Enable Simulator Code Coverage on MDB - Ability to use the code coverage report from within the MDB command line. Repairs and Enhancements in 3.40SSR Description Device(s) Affected : W5 p1 I8 @+ a l8 Z
MPLABX-2792 Build/Program operations are not returning to the IDE when the Device Under Test is not detected in MPLAB X v3.35.
- Q& V1 P! V. m* `MPLABX-2790
On some occasions the debug (elf) file gets locked by MPLAB X IDE when doing a build / debug-build. The current workaround is to click the pe RFormance monitor to force a GC collection.
- @+ U! G/ k" X4 v aMPLABX-2788
On some Mac machines MPLAB X IDE can hang after a fresh install. Close the store window and select not to open on startup.
3 z5 c( G! x; W ]! l) k e9 ^$ GMPLABX-2783
When a PIC32MM device is selected, clicking "Generate source code to output" from Configuration Memory view window will generate the following line along with other settings: #pragma config USERID = USERID which will cause a build failure. PIC32MM Devices
4 ~0 t; p1 y& u/ D/ A* gMPLABX-2769 Disassembly listing file generation does not work for dual partition device projects
" s* q6 \: G G% q4 K3 OMPLABX-2749 You cannot set program memory breakpoints using the breakpoint dialog box and any use of complex program memory address breakpoints. Please double click on the Program Memory window line to set a simple breakpoint. PIC24FJ256GA606 and all other dual panel devices ) w c, ^- @! l5 W# s: m
UDBC-1387 PIC24FJ32/64GB004 have incorrect reset mask for OC5CON1 and OC5CON2. PIC24FJ32/64GB004
8 Z7 N' s* T3 a9 Z" R; w1 u+ O* _$ [! IUDBC-1385 Incorrect End address for when code protection mode is enabled for PIC18Fx5K40, 18Fx6K40 devices. PIC18Fx5K40, 18Fx6K40
. L$ O9 e; i5 W" h5 z, ^7 k! jUDBC-1383 PIC16F1777 should have PWM10OUT pin instead of PWN10OUT pin defined in the header and support files. PIC16F1777 ! P8 l* z8 e/ o9 h+ l; b
UDBC-1374 Values for Configuration Registers do not match programming spec for PIC32MMxxxxGPM devices. PIC32MMxxxGPMxxx
; b7 y4 s5 ]$ R- k' h" HUDBC-1367 Config Registers Settings are Missing Category Descriptions for PIC18FxxK40 Devices. PIC18FxxK40
# l7 P) x D3 t# C8 E0 K G5 A: HUDBC-1343 Simulator may display an incorrect TMR0L value after reset. PIC16(L)F18313/18323 ' F; \! d1 X8 ^
UDBC-1306 PIC16(L)F1507/8/9 missing PPS info in the PIC file. PIC16LF1503, PIC16(L)F1507/8/9 下载链接:4 `* f3 Y F' y8 o
http://ww1.microchip.com/downloads/en/DeviceDoc/MPLABX-v3.40-windows-installer.exe 4 u$ E" p G) Y& f1 B
