查看: 1286|回复: 3
请教问题,报错问题,谢谢
发表于 2016-9-6 09:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(---------------------------------------------------------------------), j% \, F8 a6 V& v3 y+ a
' z7 w+ \- i, v2 X- q$ f
! V$ `( v2 D7 S  eThis database has been marked as a .SAV.0 n( P  x( s7 ~* Y' o: @& Q5 @3 w% v4 y
An attempt will be made to correct the problems.
' A; {& L$ V% ^5 A9 q( ?: }* q
7 L- k, z8 q2 B- f5 NERROR IN SYMBOL PIN   refdes = C203% R. t9 n4 K8 G6 Z
  pin# 2
# [# b& v( c# v# ?, r" v  symbol origin = (5775.00 11935.00)# W0 N, Z: ~3 h' p- O  ]
  POINTER TO SYMBOL PIN INVALID+ o  w; y, _, c: _
   Error cannot be fixed.: h; i" d6 M+ t& D4 i7 k! w3 A
) G# C. B/ ]. L3 `! Z/ e6 S
WARNING: The following vias/pins have connections using non-plated padstacks
: R4 t* n# p% |+ o$ S# ~3 l, b         This may cause issues with your manufacturing process.
- D& w+ B' M, n- _  i: d' B8 A) ]
# d$ W8 Y4 n8 f$ u4 h: f  Pin/Via         Padstack                                   Location" o+ x6 @* K' K" I. E
  -------------------------------------------------------------------------+ z* x, a' U' W- U5 F- k& ]+ Y& ~
  VGA1.16         PAD75CIR75U                              (78.66 5614.88)
9 T* A" R! m3 F4 `  VGA1.17         PAD75CIR75U                              (78.66 6364.88)1 L4 g3 D0 o/ {& j6 v5 _& B; H
  MH3.3           BALL30_B                                 (295.00 5550.00)
4 G, O3 H$ I6 V) z  MH3.4           BALL30_B                                 (325.00 5475.00)0 p0 u5 ]0 t+ A
  MH3.5           BALL30_B                                 (400.00 5445.00)
" i) A2 M* P, B- p/ g4 U* G  MH3.1           BALL30_B                                 (400.00 5655.00)$ T& q6 r9 B: q+ d
  MH3.2           BALL30_B                                 (325.00 5625.00)  N# P  K5 m5 U0 Z7 R' m! `- f) q$ T
  MH3.6           BALL30_B                                 (475.00 5475.00): k& C; k8 T5 H" S1 V0 M
  MH3.7           BALL30_B                                 (505.00 5550.00)
0 {. G/ [/ W* c1 b, _  MH3.8           BALL30_B                                 (475.00 5625.00)
+ P7 B  m$ n2 Z; ]* e9 I2 c  MH4.3           BALL30_B                                 (7095.00 5550.00)
& c8 T: ?+ Z8 p; O! [( E' P! g% S  MH4.4           BALL30_B                                 (7125.00 5475.00)4 z) T. n3 Q; `7 V2 J& a
  MH4.2           BALL30_B                                 (7125.00 5625.00)1 p. d, t1 V0 E% W6 B
  MH1.3           BALL30_B                                 (7096.57 11763.62)
+ K' ~: P. w+ j3 }& [6 _% F9 _  MH1.4           BALL30_B                                 (7126.57 11688.62)5 g$ w: R4 v/ x+ C& ^
  MH1.2           BALL30_B                                 (7126.57 11838.62)' x4 x' o5 T2 F& z/ O
  MH4.5           BALL30_B                                 (7200.00 5445.00)" W: J3 t4 c) _$ A6 p
  MH4.6           BALL30_B                                 (7275.00 5475.00)$ c" U* ~% \; y8 `- |
  MH4.7           BALL30_B                                 (7305.00 5550.00): _# n3 i: H" l' f3 n4 t* k7 e2 a# y
  MH4.1           BALL30_B                                 (7200.00 5655.00)
6 }$ j' A: |- t. u# }  MH4.8           BALL30_B                                 (7275.00 5625.00): R" m6 R1 _6 g, o* i, W" ]
  MH1.5           BALL30_B                                 (7201.57 11658.62)
( w6 R+ E7 C, R$ A/ T; r0 z  MH1.6           BALL30_B                                 (7276.57 11688.62)
6 B" W1 Q' S3 \  MH1.7           BALL30_B                                 (7306.57 11763.62)/ u% M6 ]& m' B3 o7 E
  MH1.1           BALL30_B                                 (7201.57 11868.62)+ Y0 P4 ~& z5 h: B
  MH1.8           BALL30_B                                 (7276.57 11838.62)
$ r/ ^. `' r7 H" X8 J  MH2.3           BALL30_B                                 (296.57 11748.62)
2 f3 L; ?# v) {- c; o8 v  MH2.4           BALL30_B                                 (326.57 11673.62). D3 S0 f5 M, J' a( \, E0 O7 u) X$ @9 `
  MH2.5           BALL30_B                                 (401.57 11643.62)" \- n7 W: E  l9 Y
  MH2.1           BALL30_B                                 (401.57 11853.62)# R# Q8 n) I9 E6 V
  MH2.2           BALL30_B                                 (326.57 11823.62)- n6 y4 w% M3 Q8 B( i. g$ Q
  MH2.6           BALL30_B                                 (476.57 11673.62)
% m/ r: T' j0 c9 T; g$ c1 N1 o# u  MH2.7           BALL30_B                                 (506.57 11748.62)* p3 U5 M! R* z5 @
  MH2.8           BALL30_B                                 (476.57 11823.62)
2 c5 [+ Y- Q. ^+ q% ^3 O$ ]! X6 c5 J5 V( B9 T3 x6 a+ d! H
& V9 s# X- U6 Y9 e4 X
Number of Xnets before update: 0        after update: 0* Q' m1 u% t) c, C% T* p- A
Number of Diff Pairs before update: 217   after update: 217% N& D- f3 l, n4 J: _- v
& p9 B9 M3 J  w. {) x( {6 `& m7 J" P
Regenerating DRC
4 j/ ^5 {1 [! e0 }  Original DRC errors:   15; G6 I. I! T/ \2 D1 ?1 {2 q
  Updated DRC errors:    15, M7 u& {9 ^0 N7 }' u4 w
  DRC elapsed time:      00:00:02
: S3 v( q/ ~* l0 S4 R7 x7 T# t* c3 N7 I( j4 A) z0 {: h
Problems could not be corrected, contact cadence Customer Response Center!
* S: `/ q* T9 I/ C$ A; o  W34 warnings, 1 errors detected, 0 errors  fixed.
0 x9 ~5 y) q( I
发表于 2016-9-6 09:44 | 只看该作者
检查下pad-stack:PAD75CIR75U 和BALL30_B  设置成non-plated的了,改成plated
    2024-8-22 15:58
  • 签到天数: 22 天
    [LV.4]偶尔看看III
    发表于 2016-9-7 10:16 | 只看该作者
    C203 的pin2 的padstack 改为plated。
    郁闷
    2019-11-19 16:10
    发表于 2016-9-8 10:35 | 只看该作者
    通孔未做电镀
    GMT+8, 2026-5-7 20:07 , Processed in 0.140625 second(s), 23 queries , Gzip On.
