查看: 5116|回复: 9
Cadance生成gerber报错怎么改
发表于 2016-7-25 16:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ERROR: aborting film - Layer polarity of layer ETCH/TOP does not* g" p. A! a% n4 N
           match film polarity of Negative. DRC may be unreliable.
- \& r* W3 m- _2 J. L6 Q% H, X: E/ ?+ \; y9 ]9 J# j: x# u
    WARNING: Null ANTI-PAD specified for padstack 0_95X0_65MMOVAL_MECH at (-3.6200 -1.3200).2 w- [( l* Y2 T
    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (-2.4200 0.0300).
  Q7 O& \. a. l: F& }% a0 a    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (-1.6200 0.0300).' F& K: @4 S1 y3 O2 q
    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (-0.8200 0.0300).
8 o8 E3 B  E9 M0 k* g' o4 }    WARNING: No thermal flash for padstack "CIR04_06MM", regular pad used.
. C% [' ]. |% k# s9 n1 k: Z    WARNING: Null ANTI-PAD specified for padstack 0_2X1_6MMREC at (-2.2700 -2.1800).
4 q) D8 r+ @( a6 M: O2 F- v    WARNING: Null ANTI-PAD specified for padstack 0_2X1_6MMREC at (-1.7700 -2.1800).
* i5 I0 `, K. V  Q9 S    WARNING: No thermal flash for padstack "0_2X1_6MMREC", regular pad used.. u6 E1 U2 i' P% q  c
    WARNING: Null ANTI-PAD specified for padstack 0_2X1_6MMREC at (-0.7700 -2.1800)./ \7 u: x4 q" R- S8 _1 p8 z
    WARNING: Null ANTI-PAD specified for padstack 0_65MMCIRCLE_MECH at (3.5800 -1.3200).! i2 ~% l2 G$ |6 |
    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (0.7800 0.0300).
1 s% p6 J8 h8 ]7 S    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (1.5800 0.0300).
) }( T3 q, ]! O% V+ ]4 m7 X* b+ d    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (2.3800 0.0300).
* ]7 T5 N- q& I0 d3 T    WARNING: Null ANTI-PAD specified for padstack CIR04_06MM at (0.3800 -0.6700).7 r4 j/ `& @+ {) k, V3 q
    WARNING: Null ANTI-PAD specified for padstack 0_2X1_6MMREC at (1.7300 -2.1800).
2 p* ?% J# ?5 Z# @0 N    WARNING: Null ANTI-PAD specified for padstack 0_2X1_6MMREC at (2.2300 -2.1800).
7 F" T; \) l) ^' D/ D    WARNING: No Photoplot Outline was found,
, ^7 I- Z3 O$ r; R& |6 {: pnegative shape outline will be determined by Board Outline
4 Y8 V: t8 d. n& m) G$ R
) x8 f0 k1 `+ F6 E( |% w2 `' N* Y8 ~
, F/ u8 J, m- Z+ s7 k5 }& S/ U( A7 P: P
发表于 2016-7-25 17:26 | 只看该作者
Artwork_TOP film  设置成了  Negative 。在 Manufacturing--Photoplot_outline 层,加一个框,将要出的都放到框内,可以消除 WARNING
你好,这个具体是怎么操作?  详情 回复 发表于 2019-3-13 13:02
发表于 2016-7-25 17:40 | 只看该作者
要定义pad-stack的anti-pad
 楼主| 发表于 2016-7-25 18:25 | 只看该作者
还有这个怎么改?
0 j7 ~0 R+ x+ m; Z FILM PARAMETERS :. T0 o1 n* e4 y% Y
1 @2 ?# N$ E  F  b% `  Undefined line width                0.0000+ a! a- l0 U& Z1 \' Q: l1 E# ^* c
  Mirror code                         NONE
+ B/ Q. e' d3 Q3 z7 v7 b  Rotate angle                        NONE' g. Z  L# z/ d8 P( S
  Offset x:                           0.0000; O7 ~% v. e( x: v2 I9 g# G/ e
  Offset y:                           0.00009 g6 B/ P  h. J# y  B- J
  Plot negative                       NO' X: h, L- x& j$ o2 v+ j: \
  Suppress unconnected internal pads  NO" v! X6 l0 k. b
  Draw holes only                     NO
: N, J& @8 ~; o; K3 v. w, x1 u
9 q' x# [2 l1 J6 O    WARNING: rectangle or unfilled shape composed 0 width line found at (-106.2482 34.6734)
2 Z: A9 F# I  ~6 Z" m* z. O+ p; a5 z           ... ignored.
' P8 q) v. l; @! u* W
/ p9 Y+ ]0 d* A5 u0 J. m1 D- `    WARNING: 0 width line found at (-106.2482 41.0234), z4 a+ z% H; ^
           ... ignored." g2 H; L0 U3 l
1 t" v- P. E+ r; R) k/ P
    WARNING: Multiple 0 width lines; all will be treated the same as the first.
# @9 n0 C9 U) {" [$ I. z/ O           ... ignored.' D4 i7 K- F% x6 j: ?6 Q. Y
" B& C. n9 j4 H    WARNING: text composed 0 width line found at (-94.8309 74.3609)
; y0 a  ~9 K+ F/ W7 A$ }' P% u           ... ignored.% i8 J& l- w: z% Z& {* C
: |# ~, m4 v0 c  Z0 d! n    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
- [# \! B0 a$ _' v$ @           ... ignored.
, R8 L% h9 Y  B. m0 p
将0线宽统一改成6mil宽  详情 回复 发表于 2016-7-29 16:25
    2020-5-19 15:39
  • 签到天数: 10 天
    [LV.3]偶尔看看II
    发表于 2016-7-26 13:47 | 只看该作者
    你没有anti-pad啊,这么明显的错误
    发表于 2016-7-29 16:25 | 只看该作者
    zhy19954 发表于 2016-7-25 18:25
    $ {* h. z! u& y+ A$ ~5 [还有这个怎么改?$ f$ ~8 B( e& k2 L% k- I
    FILM PARAMETERS :
    ; L, x  J8 [; O  E  q2 q" q5 T8 D3 `: n  ---------------------------------------------------------
    ) s" Y5 ~) L: @% e+ s: n将0线宽统一改成6mil宽
    发表于 2019-3-13 13:01 | 只看该作者
    你好,这个具体是怎么操作?搞定了没有?我也遇到这个问题。* }. r0 `3 c- p1 T
    发表于 2019-3-13 13:02 | 只看该作者
    mintjelly_abc 发表于 2016-7-25 17:266 ]0 g1 w; n4 W! E! n3 h4 {
    Artwork_TOP film  设置成了  Negative 。在 Manufacturing--Photoplot_outline 层,加一个框,将要出的都 ...
    # b) A3 H) V* P8 t6 o" |+ Y你好,这个具体是怎么操作?; i" I4 f; w5 A+ S$ _
    2023-2-2 15:00
    发表于 2022-12-26 13:19 | 只看该作者
    同问,也遇到了这个问题
    郁闷
    2024-9-11 15:25
  • 签到天数: 82 天
    [LV.6]常住居民II
    发表于 2022-12-26 16:00 | 只看该作者
    谜底就在谜面上呀,log上的问题已经说的很清楚了。% j2 y1 F9 B2 Z$ C- \5 v2 n
    其实你可以选择用正片嘛,ANTI-PAD的问题就没有了。
    GMT+8, 2025-11-4 19:58 , Processed in 0.125000 second(s), 24 queries , Gzip On.
