烟雾报警器制作过程及相关程序
, ^7 Q* n2 N) ~0 e5 e' a//程序头函数
, u3 M/ G Y; ~: _/ Y2 Z3 U#include <reg52.h>
; A* b' A0 p& S" n1 }( P* E, O% O5 d( w# u
; D9 E; k/ f j4 ^; m5 v: G7 v q1 Z, x T& \0 Q) j( L- N
//宏定义
0 s9 F9 @( E& Q* J P) L2 K#define uint unsigned int
S0 [$ [9 B G+ e8 K7 N P#define uchar unsigned char9 |( Z9 ?9 X/ Q0 ?0 C
#define Data_ADC0809 P1
0 @) m2 o0 x' s& K
* i+ z! }5 s% O//管脚声明
8 i. ^! P5 P8 @5 y) i' jsbit Feng = P3^0;
% B3 Q! ?+ ^7 X, Y. N//ADC08094 n: ]4 ~- ~5 J2 J" G! M$ w9 Q
sbit ST=P3^3;6 s4 L/ S( S" |$ s9 \
sbit EOC=P3^4;1 Z$ O( V( u$ r+ d& I |
sbit OE=P3^2;$ G1 u" W4 S; N* r
//按键; b( u4 Q( Q6 g$ c( g
sbit Key1=P3^5;
?& {/ n% k! l; vsbit Key2=P3^6;7 L' _0 [- k& q6 X! U- r1 c
sbit Key3=P3^7;% \8 ~6 x6 n: Q: X$ x( ?
9 W$ c5 r1 A8 y9 {% s//显示数组 0-9+F3 n8 Z( V+ m3 S* C/ Y. g
uchar Data_[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x71,0x3f};
" B: U( E- f( `3 o7 Y/ X) ?sbit Wei1 = P2^7;
( m( t' C3 b3 Isbit Wei2 = P2^6;' F, C q9 ~% y5 {
sbit Wei3 = P2^5;
! J) r3 e! w: k' |% \: Z" \sbit Wei4 = P2^4;2 Q( ~# [4 M" c, n- I" n
//函数声明6 f# `" u" X3 X; m1 {
extern uchar ADC0809();7 B3 c! i5 t+ w h- f" K
void Display(uchar X,uchar Data);
: G2 l; z, M% w/ Vvoid delay(uint t);
! C: ? p( _" O- ^ v0 ^3 L! L
/ a2 ~$ {9 j& L, l; `! W//酒精含量变量
8 `+ ^4 O) P7 I2 T8 W0 A# O1 kuchar temp=0;
3 q3 }" B+ V# X: L6 V//蜂鸣器变量, y6 C8 Q) G$ k# u# j! C
uchar FF=10;
: z; H/ S. p( V- e$ Y4 Z2 D2 i% w//显示模式" d) ?8 p! u, l" M6 v
uchar Mode=0;* |* T/ @: [6 S, N& Y3 `/ s1 m3 @/ E
uchar p;! P: I9 N! \( f$ q6 D
# ]& F0 y" y6 @5 J
void main()+ m9 @8 {1 Y0 h3 U: R* K7 l7 }: Q
, H% e/ G( a# s( l; @, m
0 |* l7 P1 t! d' s, Ewhile(1)
; P: y2 e/ \8 w. V% M m, v{* F' K5 b0 [& C+ j6 Q6 E' w& o
//正常模式
2 l. w6 k$ {9 uif(Mode==0)
. F7 N* V* ?" Y6 C5 B{8 Q. V0 t B7 o% I1 S7 Q- D
//读取AD值
^( w% s E. l) f4 X' e0 Xtemp=ADC0809();1 R4 C! P$ R1 l( R: W8 T
for(p=0;p<30;p++)
& C) [7 _! Z3 E* a1 ~3 X, gDisplay(0,temp);1 G6 t* E$ v* ^ p5 Y- w
//判断是否报警# `, @) Y5 U+ R1 t
if(temp>FF)
- T- @+ Y) i r& o4 V{
6 L6 Y3 o5 X* x$ C4 J5 [Feng=0;5 ~6 @* U% j5 T7 b+ T
}! }6 L) E4 W: k6 r) o) E: B4 M
else
. g/ [1 u* c/ L3 y6 p2 P{
$ \2 k/ f. r) W" uFeng=1;; V$ m% {' G* e
}: z, x) p2 `# e" x
2 t; h2 j. G' g* }2 x//调整模式7 Y; n) f: W7 e/ [/ k
else
4 ?7 a8 K# S a{. G9 Z& U5 A) a
Display(1,FF);
. U: i' T: o3 r, Q8 N8 D* j}
! z0 `2 @4 e1 c( Q( ]& w2 j" A//功能键: O5 H2 b/ e) _; s, h5 D
if(Key3==0)
0 t0 g' U* e; h3 z7 i{8 |4 I( k4 h9 W
Feng=0;
( U* C$ n# [! n+ J2 rdelay(100);
. Q8 b" e9 J% L3 R9 Qwhile(Key3==0)
; b& k4 ` n, r3 n8 P+ r{
3 O. }' k7 X8 @; u* C& }! x& zif(Mode==0)
5 _4 U! ?, n5 ]2 q2 U" r) FDisplay(0,temp);
$ z* T# E/ _: ^' }8 s; o' {& Gelse U) H3 @, b% A' e: T
Display(1,FF);
1 o* z) |. z3 d+ Q8 ^+ D}
, Y2 r; e; x4 ]- \% v* |if(Mode==0)* O- T- O6 V" X9 h# W
Mode=1;
0 i. O! u r/ L- relse4 N/ x7 Z" \( c% M7 X3 e' L
Mode=0;
5 C, G5 K! r3 S; c# w. N# D- LFeng=1;& H% L( e4 f# C0 i7 e# n9 h
}* o6 J! ^4 e+ P( b4 V) }& \
//增加" g/ o" m& h- t1 r. |% |! {# e) D6 i
if(Key2==0&&Mode==1) \0 S# I1 g: _3 {) i* E
3 o7 P& ^+ ]( U) JFeng=0;* N5 O+ o+ U: l' @" o% n
delay(100);( Z2 u9 o$ b. X* U+ }/ ^' J0 u0 ]
while(Key2==0). k- B, {2 a9 g$ ~7 p
+ I0 N/ F" f1 ~* HDisplay(1,FF); ( v- W1 R! @5 c: [
0 y5 x/ o% [3 u7 G( x4 sFF++;
7 Y4 D* ]: c4 }8 n( K6 J( f9 `# q/ sif(FF==251)
+ i: q Q% v U R0 ~( tFF=250; 7 D& n8 ^- S! _) @. q! e2 q2 |& d5 x
Feng=1;2 v% t! H1 A: o
$ I, p' y& M- c; H$ K//减少
2 i! x3 D, }7 ?6 Tif(Key1==0&&Mode==1)- Q6 f% u$ z% J7 C7 }% z
5 O6 S2 u/ d, v' MFeng=0;
1 M7 b& ~4 B: a' G4 o+ o: Sdelay(100);
3 m: p3 Z, ~1 b" W( x" dwhile(Key1==0)
4 u* _! k/ z! k( D( H/ |( a7 V7 D* n{* Z# q. X$ A, X/ @
Display(1,FF); + F" V' ^7 Y& |% {4 ]2 e$ d. y
}9 u' ^" q5 m" |8 B9 ~, D
FF--;; z l0 _: v! g- Y# U8 e, k
if(FF==0xff)
9 l3 a) {: k# N* x% ~: sFF=0; & G- I0 T# X! ` c% i9 d
Feng=1;: z* v$ j. j; G8 V9 {4 X
. v L- l6 z$ P: w$ X}
5 H' ^; h9 O/ ~6 c}
' P- C( t( L; q/ a- K) `& M4 z( L//ADC0809读取信息+ E. o) \2 w4 ^- r8 i# {
uchar ADC0809()2 d) X+ T- D8 e9 p7 Q- r Y
{7 ]5 E! D% A& _" }9 r, ^
uchar temp_=0x00;
5 m) ]5 ~, P! u$ C//初始化高阻太
t+ L7 ~' @9 E, q @% yOE=0;
: y$ G" K1 L, X- U& o0 b* V//转化初始化
0 t6 c; C+ ~* z1 c, z& N" X8 L, sST=0;
2 I1 z; A' Q, o) V9 n//开始转换
* @* x3 N# z- _& p) w7 JST=1;
& I7 |4 e! v! ]' ~0 MST=0;
' p" f& p" E/ d1 z//外部中断等待AD转换结束6 ^4 u9 g2 x3 x6 ?! `
while(EOC==0) h O* }5 U" f- T% B+ F
//读取转换的AD值, r2 g" f/ o- W. X% w8 y9 h" h
OE=1;5 C& Y% r; v) |4 R
temp_=Data_ADC0809;
: A/ P" @+ c9 H, |OE=0;
/ ~' E' ], {! p) r' ~0 m, a% Breturn temp_;
- c3 y4 r8 |+ L+ Q% G7 d}" S# `, h8 P6 g% D8 s$ ?1 _7 I, Y3 ~( c) X
//延时8 b$ l9 D7 y1 c. S e
void delay(uint t)
* `# R5 X) G* l; `& S8 u4 v{
- t6 J+ v% E& d1 Cuint i,j;
7 P5 H: e: b2 z( f e& e1 \" Bfor(i=0;i<t;i++)
8 j: l' p" G; p: t; a1 u" f/ @/ A cfor(j=0;j<10;j++);' p. H+ K& g, z2 c: W
}2 V% f0 \7 n1 n' S# F7 H
( c7 u6 a4 k$ b! i* Z0 V
//显示 X表示状态 Data表示数据
7 }& u9 }+ Q" \- N* b3 v2 jvoid Display(uchar X,uchar Data)- N' j4 M0 H: d# Q1 `/ `4 o
{. Y+ {: g4 M9 }5 I" i4 Y2 K+ t; D& c
Wei1=1;# `9 G+ b# P0 ^4 O
Wei2=1;
) p( E* F. h' ]) Q+ N4 Q; V- qWei3=1;
6 p9 W; ^# O2 S- F0 @, ]2 FWei4=1;
7 R( h; n4 D" T8 pP0=0xff;
8 z) V* p9 G' E) W+ Y1 {7 S6 h- r6 I; U) {, ~$ }- ]
//正常模式9 B4 ^4 m: w1 j2 S1 f
if(X==0)- r% Y6 q7 l. o* k7 N
{! D+ L! q9 F9 J1 U- w
P0=~Data_[11];: q* S; t. E, U1 Y$ i* {- c2 V
0 J0 @2 m9 h- C2 ^' @: z! w# n) G//非正常
; t2 Q6 o+ F* f* Velse
. q& o: A( ]+ ]$ a' ]6 t{& X7 q5 O7 j% v5 W/ z
P0=~Data_[10];) L! w$ Z- M+ \0 A: Z' ]# f# Q+ F! p0 B
}2 z3 }' u$ H W& X9 ^
Wei1=0; Z4 u+ d: Q5 F3 J. l
Wei2=1;& @8 x; J( s w! m8 y0 x
Wei3=1;
. O6 |0 ]1 e9 S) a& a- @0 ^Wei4=1;- {1 j7 H# r1 Z. s% D
delay(10);# h, J' g& |2 u2 `" h | C2 R
Wei1=1;
2 ]0 o+ ]" K }( Y8 P _Wei2=1;9 U' t& P+ V k- s& E' p! W5 A
Wei3=1;& U4 g D" E: ]9 z% ^ P
Wei4=1;" C! b' o3 v* u
1 `' i; Q% P! y4 r2 v! @7 {! B# cP0=~Data_[Data/100];( c: l( C/ T& z$ }$ ^
Wei1=1;
: H' {+ F" z% k9 eWei2=0;
: g2 h# N- q; W, r* m g! nWei3=1;
8 C, w8 o4 C3 ?2 m* w; @) o/ XWei4=1;
7 h2 J- ~( s2 ~3 T; {delay(10);/ L' Z8 `; i w p* X. k# @/ q
Wei1=1;( E9 ]+ V( x2 [. W
Wei2=1;
# H: ]- k( O9 ]0 ]Wei3=1;
2 i. U% X9 r7 M0 M5 wWei4=1;/ a3 O& V; t# w$ }: |1 u
/ n' v4 }6 R' ^
& Z0 V$ D0 A. C/ jP0=~Data_[Data/10%10];
" i0 _; P$ E* m+ }% f# `# }2 wWei1=1;
7 {, y0 J' h1 w; I2 e- C$ X6 K5 ZWei2=1;
. l) N; B3 u& U i1 s5 r: bWei3=0;0 `( {7 D6 a3 i1 r0 f/ p
Wei4=1;
7 h! a. G' ^4 F, u5 cdelay(10);
6 h# [7 | m5 O& P0 x8 @- d# @Wei1=1;
5 R' I* _6 ]* j5 R5 C/ DWei2=1;
- c( R$ t0 }4 ?8 P/ BWei3=1;
, n, |! c8 d u+ Z {: S( fWei4=1;
3 Q4 d; H x6 `2 X
% S3 {% i% l9 n3 _5 {. l3 [( UP0=~Data_[Data%10];
- I6 _: [: F& NWei1=1;
; w5 W5 O1 ]: t* \+ W& L( H9 S: ]Wei2=1;/ S/ J; h: ^5 p; U9 V1 A4 C0 r
Wei3=1;2 F! L j3 I1 ]+ m' x0 ]7 ^
Wei4=0; |! x* H0 s# A4 i/ k
delay(10);1 F3 \6 [* B9 J& }' P8 a* r
Wei1=1;, W W0 }8 o7 m2 \ }
Wei2=1;
+ _3 t# U: t2 U" i( R2 WWei3=1;
7 Z" n' G% A1 p- {Wei4=1;
5 T6 w- J/ H. Q# T( B! N4 C
" B8 S: g; w; E% Y: t}
+ F* I$ X4 _( A) _$ l! c
: N( b5 w# P8 d& H& r4 B# q1 S) P |
