查看: 982|回复: 2
SystemVerilog for Verification
发表于 2016-5-4 16:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/ P7 W" _- p% ]( Q1 X+ g$ k& A1 ASystemVerilog for Verification:2 U2 n3 G3 w  t% W1 Z& [( V; h
A Guide to Learning the Testbench Language Features
) {1 _. g& R0 S" K! I: e1. VERIFICATION GUIDELINES 1
- U# Z4 K. j+ m! e) C( r1.1 Introduction 1
; x/ h$ w4 h% X1.2 The Verification Process 2
# x' Z. i. D/ D% U1.3 The Verification Plan 4$ H- d; h( i3 W
1.4 The Verification Methodology Manual 4
1 z' v" O' w' m. e+ k) V: d1.5 Basic Testbench Functionality 50 v# w  M. z: Q2 y/ A7 D, J
1.6 Directed Testing 5
" [  B( }8 V$ O- n7 A1.7 Methodology Basics 7
8 ^( K/ H& q' C/ h. x& v; `1.8 Constrained-Random Stimulus 8( n) Q+ |) d. \3 N$ R
1.9 What Should You Randomize? 10
" C3 \+ U( ?2 a1.10 Functional Coverage 13
  b( {  s( H0 b7 u; V3 R7 ]1.11 Testbench Components 15
2 Z& i9 }0 ?9 p3 @: r3 f# {1.12 Layered Testbench 16
9 w& R* n3 n6 m1.13 Building a Layered Testbench 225 `$ N; _* d5 t, v( X, L+ T5 Q  z
1.14 Simulation Environment Phases 23
; \! t: e9 T1 k. r+ f8 M' b$ W2 S1.15 Maximum Code Reuse 24
) ]* }$ A6 w' e/ w$ y$ e" a5 M$ s) }7 h1.16 Testbench PeRFormance 24; J1 i: b+ _! ^3 u" I
1.17 Conclusion 252 |: k+ p0 P3 X# T8 E, U% }
2. DATA TYPES 27
' c8 E# z1 Q/ j% B2 b* _* d2.1 Introduction 27
$ E5 R* f  g* e+ F; j( f1 f' v2.2 Built-in Data Types 27
+ k# @. i: k/ @7 ~1 x6 E. qviii SystemVerilog for Verification
% y9 X# o* e: T  h% \3 n0 S2 ]2.3 Fixed-Size Arrays 29
/ _( p) N5 K& Z2.4 Dynamic Arrays 34/ e  |9 J; n) |" \3 j, I- [9 I! F
2.5 Queues 36* D  l( P' t3 n! ~/ u& u* ]
2.6 Associative Arrays 376 K' X) }+ W2 \7 D6 M) p
2.7 Linked Lists 39) D3 k) z* ]3 q# K7 }# s
2.8 Array Methods 40
3 _" S; v1 E5 ?; R1 U7 v2.9 Choosing a Storage Type 42
5 l. W, T9 l+ T( x  R2.10 Creating New Types with typedef 45' t8 H# _* X& F. |
2.11 Creating User-Defined Structures 464 q% P. @# o+ X% V+ w& Y. Z$ `
2.12 Enumerated Types 47
: `( |8 M" L9 b: P  ~2.13 Constants 51
9 u" e5 _2 P; f  E" f: I2.14 Strings 51
  M0 H3 i' \2 ?% k- ^2.15 Expression Width 52
3 ]: |8 M9 d+ G! E" H# d4 I) A& N) X2.16 Net Types 537 D2 C2 ~6 y9 ]4 m; [: a1 j
2.17 Conclusion 53
. d* k; ?2 g" X& o/ Y* F7 _3. PROCEDURAL STATEMENTS AND ROUTINES 55
& r8 x: X5 U, p* A+ |) D- u3.1 Introduction 55
1 L7 e7 D% a% v+ @. E3.2 Procedural Statements 55- S0 S( C  W, Q- [
3.3 Tasks, Functions, and Void Functions 56
; b9 t, k+ C  b1 ^8 O3.4 Task and Function Overview 57' \9 c4 v5 B1 n7 W/ j0 w* G
3.5 Routine Arguments 57
8 U) r, u! @3 L8 s' f1 M  R3.6 Returning from a Routine 62. ~6 T% A6 l$ v& f% e) m3 [
3.7 Local Data Storage 62. F8 D6 X1 K5 n" v2 V$ h' X) g+ w
3.8 Time Values 64
  f! y1 E1 t9 p8 y4 T3.9 Conclusion 65: s! r2 Y$ b& z5 j+ L9 i/ {7 Y+ q/ t
4. BASIC OOP 67
: N+ y& f$ C4 Q4.1 Introduction 67
1 f4 Y' }' b- m3 H! Z  J. ^4.2 Think of Nouns, not Verbs 67' N( N% \+ D1 F9 d& s  r* ^
4.3 Your First Class 68
! m! [# v- {' s. O% `3 k) H* @4.4 Where to Define a Class 69
! K) n6 }6 \' B% v- b1 @! F1 A9 Z4.5 OOP Terminology 696 j2 W, j/ Y" c0 B
4.6 Creating New Objects 70
* w$ }* b/ v. M: {. o" N4.7 Object Deallocation 74
1 {- N, N; E" z. u) J4.8 Using Objects 76
2 K4 l4 ~5 Q( b8 n4.9 Static Variables vs. Global Variables 76
# B+ c  ^# K3 ]$ N- k4.10 Class Routines 78
. C1 t. J5 J8 q7 T' Z2 V0 F4.11 Defining Routines Outside of the Class 797 L; n$ ~$ u, S. |  T- W8 V9 {
4.12 Scoping Rules 810 s% {6 s  w1 i' B
4.13 Using One Class Inside Another 85$ k( w" k9 a8 S& u8 Y
4.14 Understanding Dynamic Objects 871 v9 p; v6 t- Q0 `, V2 V5 k
4.15 Copying Objects 91
0 ]1 A: u/ ]( z4.16 Public vs. Private 95: @% e, m& _% z( |5 `
Contents ix
( c! C& ~1 k" U4.17 Straying Off Course 96
# i/ j( z1 k7 l$ \6 g, ~4.18 Building a Testbench 96
0 }) s5 H7 I. r5 R; q4.19 Conclusion 974 }! ~8 U9 O/ q4 T6 [- @
5. CONNECTING THE TESTBENCH AND DESIGN 99  R; E5 `5 w/ ?
5.1 Introduction 99# d& V$ P6 j% F+ G; o  u
5.2 Separating the Testbench and Design 99% E' H3 [0 _2 [* Z1 V7 r/ |# A$ [
5.3 The Interface Construct 1021 c0 }1 t1 Q- b9 [$ F
5.4 Stimulus Timing 108
' F& L/ q5 D# d$ V# v" m5.5 Interface Driving and Sampling 114
& i5 ^+ P% I5 U9 x6 w; \& E) d5.6 Connecting It All Together 121) O* @: u" x, f: C2 a& Z3 A
5.7 Top-Level Scope 1210 [# ~- _$ G- t' V/ v1 m! H9 n
5.8 Program – Module Interactions 123
  p7 E# I" [3 o/ O5.9 SystemVerilog Assertions 124+ r5 o" A5 @- `: p1 N# \% s
5.10 The Four-Port ATM Router 126: Y  q  R0 B" C2 b
5.11 Conclusion 1348 f3 J0 y- W6 s+ ?' y; v2 z
6. RANDOMIZATION 1355 t3 L: z4 [' b  i7 ~6 Q
6.1 Introduction 135
6 e( c8 r+ f$ z; X2 _" x6.2 What to Randomize 136. j, i( F* `  d0 L9 }2 Q) t5 ]
6.3 Randomization in SystemVerilog 138: e5 h1 l. c) A8 F1 V( F& A
6.4 Constraint Details 141; a% L3 H* n' S  ~" J
6.5 Solution Probabilities 149
, n3 w$ u; p% N+ ]6.6 Controlling Multiple Constraint Blocks 154' H; }6 `( G# H; a! o" C- ^
6.7 Valid Constraints 1541 v, L7 H8 ?; M+ `, a4 Y/ }
6.8 In-line Constraints 155
& P. I9 }! A( y( w6 k( v6.9 The pre_randomize and post_randomize Functions 156$ M" [3 ~% I1 n$ E" A
6.10 Constraints Tips and Techniques 158
% v* G% F. w& v6 x6.11 Common Randomization Problems 164
; o# O6 M' ~4 u$ u) |6.12 Iterative and Array Constraints 165
" c1 o% N' ^! n. s: N2 q6.13 Atomic Stimulus Generation vs. Scenario Generation 172
4 C5 K$ u: P% Q8 O0 R4 j6.14 Random Control 175
: U, [/ ]0 h: q$ v: j0 I# {# ?6.15 Random Generators 1774 n; ]' O) a' K
6.16 Random Device Configuration 180$ _* Y7 T4 z2 t9 n5 i: |0 j( g" ]/ l6 E
6.17 Conclusion 1826 V6 Z  S' d# g0 s
7. THREADS AND INTERPROCESS COMMUNICATION 1838 P" D4 }9 _  f
7.1 Introduction 183
- g5 G5 ^5 a! |( B" s7.2 Working with Threads 184
. x* v( \6 P+ M$ W7 a* }0 k5 L7.3 Interprocess Communication 194
3 m  Z7 o) I& a9 K, V, K+ q7.4 Events 195- h% p0 S! D- D; b4 Z6 ^
7.5 Semaphores 199
% m$ w7 ?9 R' n3 K8 k4 Y; C7.6 Mailboxes 2013 C1 f6 K9 `: ~( t5 l
7.7 Building a Testbench with Threads and IPC 210- k% _' ?/ P2 C( Q8 B; K
x SystemVerilog for Verification
& S0 s- l/ Q: T7.8 Conclusion 2146 U9 C) K+ m3 ~+ q, Q/ Y  |# ~
8. ADVANCED OOP AND GUIDELINES 215, N0 W! ~7 ~2 L8 l9 T
8.1 Introduction 215* E8 H" U9 b+ j+ B  w, r
8.2 Introduction to Inheritance 216; t# }# E8 E. f& {% V$ V6 g
8.3 Factory Patterns 221
8 F$ ^) s8 W# I, b5 w3 T6 L. R2 c8.4 Type Casting and Virtual Methods 225
/ H: ^- N* k6 X5 T$ a9 F* q1 ]8.5 Composition, Inheritance, and Alternatives 228
( h3 E( y6 D5 V/ r2 u8.6 Copying an Object 233/ u" t$ S# k7 F
8.7 Callbacks 236$ E2 b6 X- Q9 m0 c! h1 ~+ X
8.8 Conclusion 240
/ l0 H, }# Y0 |" L9. FUNCTIONAL COVERAGE 2412 N5 j( @+ I. n" @
9.1 Introduction 241
7 K/ Z/ b. E' F6 k- y9.2 Coverage Types 2433 k' B7 [0 o9 U  I9 R; A
9.3 Functional Coverage Strategies 246
; `# X! J- S) d, Q: E9.4 Simple Functional Coverage Example 248" l; N8 k) y4 M; D# b) ^
9.5 Anatomy of a Cover Group 251  ]/ o/ K1 @/ N) v5 m* J8 R
9.6 Triggering a Cover Group 253
3 O* ?' M/ w8 S/ B( `( {. z9.7 Data Sampling 256) _1 E- J( Q( Q- i
9.8 Cross Coverage 265
" m" M6 |6 J" V5 ^2 H3 c9.9 Coverage Options 272
" z! X5 ~. P# g+ \9.10 Parameterized Cover Groups 274
- t, G& M" b3 B  l9 \9.11 Analyzing Coverage Data 275
( I$ p) H8 v+ ?3 |2 W  o: `9.12 Measuring Coverage Statistics During Simulation 276
4 o( g+ r6 G: L) a& ?" d; U9.13 Conclusion 2770 d! ]! \3 R9 W; ~: E0 q
10. ADVANCED INTERFACES 2797 u3 V6 O* j( g& Z% l; i
10.1 Introduction 279
% A  r$ x) p$ ~, V2 k& c7 @+ K10.2 Virtual Interfaces with the ATM Router 279
, ^1 o; [& {3 e! M' x) g( E; m10.3 Connecting to Multiple Design Configurations 284
& n4 `: d% g5 `8 `10.4 Procedural Code in an Interface 290
8 W1 X6 b5 U0 Q% h10.5 Conclusion 294
/ j5 r) R& Z0 G( a) SReferences 295* R) U) R* R* j( f
Index 297
; n3 n8 {. \. @7 L8 v- n1 f- X
Systemverilog for Verification.rar
1.26 MB, 下载次数: 0, 下载积分: 威望 -5
发表于 2024-12-27 17:58 | 只看该作者
学习了学习了学习了学习了
GMT+8, 2025-8-19 16:01 , Processed in 0.125000 second(s), 26 queries , Gzip On.
