查看: 10117|回复: 181
Cadence SPB16.60.067补丁,强烈建议打上
发表于 2016-3-15 20:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 partime 于 2016-3-15 20:20 编辑 . r0 _. Q8 D: y
& N$ Z8 }. @% f7 i/ ~4 T真是够了,这么快又出补丁了。这次还fix了不少bug,这个补丁还是需要打的。下面放出链接,回复可见
5 F# w; A, L, G9 h+ U# [http://pan.baidu.com/s/1gdRQM1l" K7 ~; L* F5 ^+ k9 A
, a% J2 ^3 `8 \! w/ O  x% ?+ A; p这里是CCR。8 h- i- v( A7 T" {; N: d) [; q0 x
4 `  Z, A4 \! l# `7 ?
DATE: 03-11-2016   HOTFIX VERSION: 067
5 t0 E6 ^& e) Z# H' I4 I===================================================================================================================================2 a) t" v/ H1 l: h
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1 ~7 _$ v: A7 E* i! y! M===================================================================================================================================
+ E8 C: z6 B$ y" n' ^" p, U3 t  ]1482953 allegro_EDITOR DATABASE         Part change disassociates parts from Group7 S; m$ t8 E+ `, f, r
1484075 ALLEGRO_EDITOR pads_IN          'pads_in' imports ASSEMBLY_TOP  and PLACE_BOUND_TOP outlines that are defined as shapes as lines; t: R( }* N  l1 F) W+ y5 m
1519155 ALLEGRO_EDITOR OTHER            IPC-2581-B Negative Plane Error6 W& \( \8 G. Q  A. j2 {
1528075 concept_HDL    OTHER            Auto Generate: DML model assignment fails with error 'There is PHYS_DES_PREFIX property in PTF file.'( q" Z2 [1 g" O# F8 e2 Q
1528398 ALLEGRO_EDITOR SCHEM_FTB        Problem with pin number format used in NC property" h" g" N% P' r1 Z7 z2 P2 R' h. k
1529178 SIG_EXPLORER   OTHER            Values not transferred correctly for PinPairs when created ECSET from a net. a$ @/ _* x5 i- G6 i0 X6 W: o
1529720 CONCEPT_HDL    COPY_PROJECT     Running ADW copy project does not update the 'master.tag' file9 F. T  S% R* P2 ~
1530707 CONCEPT_HDL    CORE             Request to recover a 16.6 design after DE-HDL crashes3 M1 S) b: B7 D
1532124 CONSTRAINT_MGR SCM              'File - Export - Technology file' in Constraint Manager crashes SCM if .tcf file is missing
" T8 t  n6 q8 o2 I/ P! M: y: d  D& f1532788 CONSTRAINT_MGR OTHER            Pin pair is hidden when Highlight Filter is ON in Constraint Manager
7 W1 E: ?5 i8 `7 j# S$ z; N1536912 CONCEPT_HDL    CORE             Customizing keys in DE-HDL - Disallow mapping a command to alphanumeric characters( J* b/ l/ l! O. J2 z0 ^2 O1 N
1537055 CONCEPT_HDL    CHECKPLUS        Rules Checker - POWER_PINS value not obtained when schematic instance has the POWER_PINS and POWER_GROUP properties
" P- B% M' ]! x7 {1537278 SIG_EXPLORER   SIMULATION       SigXplorer (Allegro Sigrity SI) crashes when simulation is viewed in SystemSI Waveform Viewer) ]0 J# B" l. n/ |) G
1537339 CONCEPT_HDL    INTERFACE_DESIGN No warning is flagged when moving a Net Group over a net* O6 F+ v% l" E, i+ G7 g; z
1537521 FLOWS          PROJMGR          Do not allow project creation if there are spaces in directory or file names on the Linux platform# G* U4 e5 q+ ~7 R8 z$ `' ?, }
1539227 CONCEPT_HDL    CORE             Renaming a page from the hierarchy browser crashes the schematic editor.
) A4 h5 Q  F4 @) {1 J7 k1541532 SCM            SCHGEN           Generate Schematics crashes with 'Out of Memory' error+ W: ~# K( o9 |9 A
1541589 ALLEGRO_EDITOR INTERFACES       STEP model incorrectly shown in 3D viewer. Shows pins as angled.
! r6 x, X  n4 a8 k- ^- B+ |1541680 CONCEPT_HDL    DOC              A dot (.) or period in design name created 2 separate design folders in worklib/ Y" C6 D5 h: w8 [
1541687 ALLEGRO_EDITOR PADS_IN          PADS closed polygons are imported as lines
% z  [6 }0 V, ^/ {0 u: b9 t2 R1542722 ALLEGRO_EDITOR INTERFACES       IDX export: RefDes and PART_NUMBER missing for mechanical symbols
# }/ j' p$ |5 r: P7 b3 O: E9 J1542817 ALLEGRO_EDITOR DATABASE         Import Netlist not getting completed on specific board
4 S2 ]$ Z  t( I1 l5 a5 w1544060 SCM            SCHGEN           Generate Schematics causes Allegro System Architect to crash( ~5 F& O/ E' _$ C
1544633 APD            STREAM_IF        The 'stream out' command causes Allegro Package Designer to crash
, ^4 s0 T7 b' o9 S$ J& R1544698 ALLEGRO_EDITOR PLACEMENT        'place replicate' does not add clines and vias to fanouts if fanouts are marked/ [; I  a$ [4 L4 |& I/ z" p
1544859 APD            PARTITION        Timing vision menu is missing in APD/SIP partitions.
: f/ k8 {2 N; n1545136 ALLEGRO_EDITOR PLACEMENT        All fanouts are marked as part of one symbol instead of the symbols they attached with
9 \! _( t) r6 q8 W9 J) J- H- }0 ]1545370 APD            OTHER            Pads in .mdd file getting placed on different layers as compared to the design
" b0 k! k* i4 b0 x! D+ V. o3 o. u- `2 x  ?
% y& W! j* q1 Z4 S" A: z1 Q
- S; C$ {  \  @  A0 G, B" _
- ]) r) }% P  P- J- \+ G- e补充内容 (2016-4-5 21:12):
. x9 F2 z. i& ]& E% P8 h( K068的hotfix已经出来了。这个就关掉了吧,链接已经失效~~~6 S5 E" ^  i) d) m
7 `$ T+ H! H) K9 r7 C* Z
补充内容 (2016-4-11 19:50):( v6 `8 ^4 K0 e9 c
068的hotfix请移步到这https://www.eda365.com/thread-132946-1-1.html9 i2 f, k/ Q4 o, H
9 R6 I5 C* ~) u5 i
补充内容 (2016-7-15 20:46):
  b2 T& j5 q' A, q1 k7 yhttps://www.eda365.com/thread-135499-1-1.html
/ W; B2 u" U( s5 Q! _( h, v4 AS071的补丁
参与人数 1威望 +2 收起 理由
yueyuan2003 + 2
发表于 2016-3-15 20:23 | 只看该作者
此帖仅作者可见
发表于 2016-3-15 20:40 | 只看该作者
此帖仅作者可见
    奋斗
    2023-7-11 15:12
    发表于 2016-3-15 20:43 | 只看该作者
    此帖仅作者可见
    发表于 2016-3-15 21:35 | 只看该作者
    此帖仅作者可见
    发表于 2016-3-15 21:58 | 只看该作者
    此帖仅作者可见
    发表于 2016-3-15 22:26 | 只看该作者
    此帖仅作者可见
    慵懒
    2024-8-14 15:51
  • 签到天数: 193 天
    [LV.7]常住居民III
    13#
    发表于 2016-3-15 22:27 | 只看该作者
    此帖仅作者可见
    14#
    发表于 2016-3-15 22:48 | 只看该作者
    此帖仅作者可见
    GMT+8, 2024-11-24 11:39 , Processed in 0.109375 second(s), 26 queries , Gzip On.
