复杂的安装说明,不过搞定。完美破解!!- B$ o. V; n- u
cadence SPB V15.2 好软件,再安装一次也值得。:)9 B0 s8 P7 _2 E8 ?9 \6 Q
# ************************************************' S( S [3 M B# `* x
# * Install notes follow, License info are below *$ k: q- O# r/ Q; ^! F, T
$ D q6 P8 d* t0 k: ^ A* t#
5 G# H! Z* x: t0 _$ d! N `8 b# - Edit this license file and replace the "hostname" field below with your computer hostname' K# j* r: S0 b8 |$ i4 o h
( ^! h* N( o' \1 E0 y# v8 T# - Create 2 environment variables: a) LM_LICENSE_FILE/ _+ x# |. C% ] d- j
# b) CDS_LIC_FILE
: l" V2 T- d8 L$ G# \; N! Y: d# assign to both variable this value => [email=5280@{your]5280@{your[/email] host name}
; Q. n3 Z6 k: ~, a5 @# note under win9x, use autoexec.bat (SET [email=LM_LICENSE_FILE=5280@{your]LM_LICENSE_FILE=5280@{your[/email] host name}) Z3 t7 W+ M6 X8 j' w1 l
! V9 y' v6 O3 Z+ |# - Install any Cadence Licence Manager from any cadence cdroms (ie LDV, PSD)9 N. g9 G! P( H; ~
# , r1 }# u3 c: x- {9 T+ T& n
# all the next operations suit the SPB 15.2 installation.
' Y2 t+ i9 S/ D) c#& R3 X$ A% n" ^8 d" l3 |3 _
#; Q4 r8 q: j1 x# Y
# - Feed the CD1, run setup.exe if your autorun feature is disabled
" Y) X1 }1 ~- w4 E#
, O6 h+ _4 I' ^# - Select "Set-Up Licensing" and point this license file when prompted about a license file
- Y5 z3 F( F' \2 [: q#$ R9 v" U' S1 D
# - Ignore the msg about the license can't be parsed if ther's any, this msg is fake , the license manager is already
5 C% c8 P; j; v' u) c# running peRFectly ( poor cadence coders ;D )6 Y. n% M- ~& A- `* q8 B. g/ N9 d
. A( j. [4 p' x* G3 l# - Once this License Manager installation is done, just select Install Products8 N6 G7 q% _% O7 O2 [
## m3 V' k1 C( F2 I1 A+ B6 Y
# - when prompted about controlfile.txt just makes the text box empty, and select items manualy.../ n m3 e8 k! {/ L
$ }9 e3 l4 ^7 c2 c8 \0 S#
- t; Y) O0 x! |% o j4 v# - Insert the cd2 when prompted# X3 t, b' g, r$ e+ n5 Y7 E: z
## Z4 U1 ]2 o7 D: U6 H2 R6 m* V
# - If you installed conceptHDL schemtic entry editor, u may install the librairies from the cd3( y' M3 J+ v# ~* }8 Z0 P
# and if u don't wanna use concept HDL at all, u just burnt a cd for nothing, , isn't that funny!7 b+ J7 O, a5 \1 w* |
# S/ q H: ~; a p# Last step, if the software ask you about a reboot, u should really reboot! |
