查看: 1666|回复: 5
EMI PCB layout design checklist
    2020-6-9 15:41
    发表于 2016-3-3 11:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ) ]! h; w$ W  s
    file:///C:/Users/F2159499/AppData/Local/Temp/artED06.tmpLAN
    8 Q. u) s. S# T, J
    uthe length of the LAN signal traces should be kept as short as possible(<3000 mils), LAN chip/phy to be located near the connector
    7 |2 |" i% x# C5 T( c$ {' \
    , a, ^/ _, ]" [9 B, Q
    uall traces are routed referencing to GND throughout the length
      n) `* p2 P) `2 h' p
    uall traces not to cross any GND or power VCC plane split (moat)
    " B0 ]/ y* h1 G6 O2 g
    u all LAN signal traces not to lie adjacent to any CLK traces
    ! o3 M: X; C7 w: B; m, K1 P; ]
    ucheck their unity of LAN differential pairs trace width and spacing
    $ }% ^7 F6 S" i# J
    udifferential pair termination located on chip side and should be populated
    ; U* r& r# h/ q+ s! D
      y0 p# R" N/ S
    0 t) R# N- X/ o: M: B5 A" A
    5 ~/ O+ o5 a: i' P0 {* c
    $ B/ f+ g" f. ~# s2 t- M4 e1 K1 ]
    ; m; b2 n5 c. {
    # Z/ G/ l' l8 q6 v8 r: t
    发表于 2016-4-22 15:01 | 只看该作者
    2026-3-10 15:20
  • 签到天数: 156 天
    [LV.7]常住居民III
    发表于 2020-3-29 15:32 | 只看该作者
    什么意思?没看明白
    GMT+8, 2026-5-7 20:07 , Processed in 0.140625 second(s), 23 queries , Gzip On.
