查看: 3428|回复: 22
Hotfix_SPB16.60.065_wint_1of1 (包括最新破解文件)百度网盘分享!
发表于 2016-2-18 14:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
+ l. G: b. F8 f, J7 ~9 Z8 i' }破解文件更新内容% U) I/ s+ X  I2 v2 h5 q; w' p
0 U5 D; k0 L) p; y ) C8 U* B- B- ^& e9 N% [' [/ i
- N! i$ ~9 X5 j/ T! d( k9 m+ B$ A
* q7 g9 R" l+ j- W 链接: http://pan.baidu.com/s/1gdLANXT
: _5 x+ d" Q2 ~ 密码: s6s2   y/ U9 M7 @2 I$ u! k
; D5 B0 u9 p- z
: ]0 V0 @  y7 M6 p6 D! }
参与人数 1威望 +2 收起 理由
yueyuan2003 + 2
推荐
 楼主| 发表于 2016-2-18 14:11 | 只看该作者
补丁包更新内容:
( _! S9 {; R- j3 u0 J9 x1 W7 M, m' A6 y, u: b
DATE: 02-12-2016   HOTFIX VERSION: 065/ [9 @' Y& W( Q4 c2 U* A) a
===================================================================================================================================1 y& \- T4 b6 n
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
6 n1 E+ G4 N6 y/ o+ O===================================================================================================================================" m6 O/ T' T2 P- ]
1511947 ADW            DSN_MIGRATION    Command line arguments of the 'designmigration' command are not working
! f2 s+ n: ]/ d# z0 J) v1517388 ALLEGRO_EDITOR SHAPE            DRC error reported as PCB Editor fails to read the void for a via
& z" w7 S, S" B" Z1521661 ALLEGRO_EDITOR PLACEMENT        'place replicate create': Automatically select etch objects connected to symbols, but not to objects outside the circuit0 f; z8 y2 a! h' Q! g  F2 }* I1 B
1522831 APD            OTHER            axlSpreadsheetSetColumnProp with 'AUTO_WIDTH' propName does not autofit the contents.
$ ]' V0 N3 K1 ?3 y4 T5 h$ \1524773 SIG_INTEGRITY  SIMULATION       Running PCB SI Probe and SigXplorer simulations show different number and shapes of waveforms
/ V; d2 I4 Q9 c6 F0 P2 }6 T2 ~6 g/ [# l1524875 F2B            PACKAGERXL       Packaging using csnetlister fails, while manual packaging of individual blocks works fine
7 i6 g) W4 H3 }5 {% Q+ x: ^1527785 SIP_LAYOUT     WIREBOND         SiP Layout stops responding when adding a wire to an existing finger. y! K# ]2 j" z/ Z3 Z
1528479 ADW            LRM              LRM crashes when opened on a lower-level block in a hierarchical design+ n% K5 w3 {8 Z- Y6 A8 n
1531425 CONCEPT_HDL    CORE             DE-HDL crashing while trying to add a NetGroup$ ]0 s) V5 |6 |" f& r
1532722 ALLEGRO_EDITOR NC               Backdrill NCDrill files not getting created with PA3100 license.
推荐
发表于 2016-3-19 20:19 | 只看该作者
楼主好,新系统安装完主程序SPB16.6后,直接安装065补丁,破解程序能否用原来的用于16.6的,还是得跟着更新。我是直接使用原来的16.6破解程序,但不知道是否破解完全。怎么查看是否全部破解了。
推荐
发表于 2016-2-18 17:50 | 只看该作者
请教下,用这个里面的破解文件破解完全吗?貌似和之前61号补丁里面的破解文件一样。
发表于 2016-2-18 14:19 | 只看该作者
这速度……。必须顶了
发表于 2016-2-18 15:45 | 只看该作者
感谢分享啊
发表于 2016-2-18 17:11 | 只看该作者
感谢分享啊
发表于 2016-2-18 20:49 | 只看该作者
感谢楼主分享
发表于 2016-2-18 22:08 | 只看该作者
这速度真是不错,感谢分享。
    2020-6-20 15:15
    发表于 2016-2-19 10:22 | 只看该作者
    真是快呀,谢谢楼主
    2025-6-10 15:51
    发表于 2016-2-19 14:14 | 只看该作者
    更新的太快了,有在使用的吗?
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    13#
    发表于 2016-2-19 14:53 | 只看该作者
    感謝樓主的分享囉..
    ) ^$ k% g5 c: I9 S  F: c
    14#
    发表于 2016-2-20 22:44 | 只看该作者
    刚打了064,这065就出来了……多谢啊4 c4 Z1 s5 N" @6 A; R) a7 {. D. y
    GMT+8, 2025-11-6 06:20 , Processed in 0.187500 second(s), 29 queries , Gzip On.
