本帖最后由 超級狗 于 2019-10-31 10:53 编辑 0 F/ D1 {' \7 |8 A3 }
, q B- D* o* B樓主的洋文兒還不錯吧?
) `' M) z' n" O* `, c ^ V0 p9 a, Q
有個洋人在花旗國網站上,問了同樣的問題。
2 @+ ?4 A1 S) E$ v& S* S5 r
0 J/ T' s" u& U* j: H結果………
# A2 t9 e# c% X, @+ J; j
/ s% L6 j3 ?5 ?" |: e; d
$ q2 g7 H- a4 J) V9 I S1 r3 }4 r# v1 P/ g6 \
2 D9 m1 a: T, Z' ^! j/ F
+ ~( Z+ A. ^; Q0 i/ u9 w7 PWhere should I put AC coupled capacitors?
& H+ B( L5 ^- P& d0 s7 b
! u, i7 G% {8 wThe coupling capacitors are usually placed close to the transmitter source.
D$ r5 r: q0 | ]) z* y6 m/ s+ i% w! Y
$ L$ u5 z; J0 O6 z
Going along with Dr. Johnson, we need to figure out the distance. The propagation velocity of signals on most FR4 types of board isabout c/2. This equates to around 170ps per inch for internal layers and morelike 160 ps per inch for external layers. & v( c5 [7 e5 U% C
# Z3 I) _- W1 n# \+ p9 R! Y
, ?! Z& e/ N1 C9 Y$ SUsing a standard interface running at 2.5Gb/sec, the unit interval is 400ps, so according to that, we should be much less than 200ps away from the transmitter. If this interface has been implemented in an IC,then you need to remember that the bond wires are part of this distance. Belowis a slightly more in-depth look at the issue.3 w* A& a* ^4 p: M {
+ I g* R2 ~0 N. o% x+ R- e9 B" K: o
In practice, coupling devices are placed as close as possible to the transmitter device. This location naturally varies depending onthe device.
l7 l$ D$ j. @ x9 Q) E' A( f; b) r3 p
* L8 c4 s9 _, T( l" Z; F. UNow the capacitors. This is an RLC device at these speeds, and most devices are well above self-resonance in multi-gigabit applications. This means you may well have a significant impedance that ishigher than the transmission line.
' a5 e3 E- T, O# Z; q
1 ~9 V3 I* {# Z* _
4 t j7 w |7 Y4 f, jFor reference, the self inductance for a few devicesizes: 0402 ~ 0.7nH 0603 ~ 0.9nH 0805 ~ 1.2nH9 m S+ n$ l& P' c9 i6 \ p6 s8 U
7 l# ~- `+ c8 c H
* c7 T: K+ |2 v
To get around high impedance device problems (a majorissue in PCI express due to the nature of link training), we sometimes useso-called reverse geometry devices because the self inductance of the parts issignificantly lower. Reverse geometry is just what it says: An 0402 device hasthe contacts 04 apart, where an 0204 device uses the 02 as the distance betweenthe contacts. An 0204 part has a typical self inductance value of 0.3nH, significantly reducing the effective impedance of the device.
7 T' H; [% l4 i- t/ t3 }/ e8 O
1 u$ k, ^& q8 z) P8 B* c3 n% z1 I" }) \# f
Now to that discontinuity: it will produce reflections. The further away that reflection, the larger the impact on thesource (and energy loss, see below) within the distance range of 1/2 of the transition time of the signal; beyond that makes little difference. ) h4 b" z" P* i# h
9 e* ?& d' e# f) ^+ }% ^2 Q
2 t$ Q5 n6 k9 W0 J7 AAt a distance of 1/2 the transition time or furtherfrom the source, the reflection can be calculated using the reflection coefficient equation ([Zl - Zs]/[Zl + Zs]). If the reflection is generated closer such that the effective reflection is lower than this, we have effectively reduced the reflection coefficient and reduced lost energy. Thecloser any known reflection may be situated with respect to the transmitter,the less effect on the system it will have. This is the reason that break-outvias under BGA devices with high speed interfaces is done as close to the ballas possible. It is all about reducing the effect of reflections.
1 z% g% _! S) Z% x+ c8 U @& L3 I- o
, ~) {. N6 s9 Y2 _6 f0 W$ y# u$ pAs an example, if I place the coupling capacitor (forthe 2.5Gb/sec link) at 0.1 inch from the source, then the distance equates to a time of 17ps. As the transition time of these signals is usually limited to no faster than 100 picoseconds, the reflection coefficient is therefore 17%. Note that this transition time equates to 5GHz signaling artifacts. If we place thedevice further away (beyond the transition time / 2 limit), and use the typical values for 0402 100nH, we have Z(cap) = 22 ohms, Z(track) about 50 ohms, and wetherefore have a reflection coefficient of about 40%. The actual reflection will be worse due to the device pads.
1 G' [# N& A6 @3 j
c! `4 V( x8 q; O: c3 u! L# }, n. g5 w
