! u, E: R! u1 p链接:http://pan.baidu.com/s/1qX3MdtE 密码:ajq4) |2 j& F1 b) R1 y5 K0 j, Z
% w+ @3 S# D6 ]2 ^更新如下
- d. ~3 E0 c$ _1 C1 [: Q/ IDATE: 01-15-2016 HOTFIX VERSION: 063/ z9 C# P$ i% u+ {4 ?
- G2 V- H9 s! M0 [% g8 _CCRID PRODUCT PRODUCTLEVEL2 TITLE
- v- Y& |# K- h6 A* t2 c+ z===================================================================================================================================( h* v3 H4 Z5 I: [; x+ }
1472414 allegro_EDITOR SCHEM_FTB netrev changes pin-shape spacing rulein constraint region" s9 p( w: y( q) |
1494194 concept_HDL CORE Random display of the'PHYS_NET_NAME' property in hierarchical designs
1 J C! ^/ ?1 |7 ~1500190 ALLEGRO_EDITOR EDIT_ETCH Snake Router Creates Line-to-Line DRCs' V$ b% \0 n1 i
1501093 SIP_LAYOUT OTHER Package design variant showswirebonds connected to a die which is not part of the variant
* P- V/ A1 I, G+ `1509184 ALLEGRO_EDITOR DATABASE BB vias in mirror have terminal padssuppressed by artwork
- |* F! _/ }; o2 p1511397 SIP_LAYOUT TECHFILE Tech file exported from release 16.5cannot be reused in SiP Layout in 16.5 or 16.6
6 |6 @" G3 O% y& K6 |- c/ t0 z1511744 ALLEGRO_EDITOR OTHER Allegro PCB Editor removes propertyfrom component instance
& |: m# Z3 s9 J+ k. E: b1511761 SIG_INTEGRITY OTHER Allegro PCB Editor crashes onrunning the cns_show command.4 D; F% g% K/ B3 x& F- h ~
1511787 ALLEGRO_EDITOR INTERFACES IPC-2581 not exporting overlappingshapes correctly.
* ?+ y# u2 ^/ n" \. h3 s1512071 ALLEGRO_EDITOR OTHER The color of 'SHAPE PROBLEMS'subclass is reflected in the color of 'NCLEGEND-1-4' subclass when executingPDF out: W7 C; F7 C, f; I I z6 {
1513085 CONCEPT_HDL CORE NC pins combine with NC_1 androuted as one net in Allegro PCB Editor, j2 a' }1 U% b2 h. \
1514469 CONCEPT_HDL CORE Unable to get rid of an underscorefrom the PHYS_NET_NAME property5 c9 j0 C, L8 d0 b2 r
1515318 PCB_LIBRARIAN IMPORT_EXPORT Import Pin Table: 'CTRL + C' and 'CTRL + V'not working correctly. J8 h. U7 q+ a! j5 L! j
1516093 ALLEGRO_EDITOR PADS_IN Pads library translator does nottranslate slot orientation
" ^* e( q$ u/ Q1517351 CONCEPT_HDL CORE Genview does not update anexisting split symbol; i+ n( s. l8 O1 M) Q2 d
1518032 CONCEPT_HDL SECTION How to get rid of error 'SPCOCN-2009- Symbol has the SEC property but the required SEC_TYPE property is missing.'1 v. S8 r$ i/ \0 T6 G" T
1518724 PCB_LIBRARIAN PTF_EDITOR PTF Editor is not saving changes
. x2 U$ E& m8 [1519518 CONCEPT_HDL OTHER Genview does not generate splitsymbols) l! b2 @# }* w+ q
1519623 CONCEPT_HDL CORE Differential pair added to aNetClass does not display 'NET_PHYSICAL_TYPE' on the canvas! k7 t3 z: q' B* t
1520207 CONCEPT_HDL CORE Genview crashes after renamingports |
