查看: 3230|回复: 2
新手PSPice出现问题,向各位大神求助
发表于 2015-12-19 09:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电路是一个很简单的分压电路加一个运放,如下:0 l2 y4 Z5 D1 U$ W
- d  X5 J' W' f( H8 A
运放选用的是ad8045,从网上下载的spice model文件,然后点击仿真,想要得到输出信号的频响曲线,因此仿真用的是交流扫频,没想到仿真结果如下:
- O) C9 l& ~9 \& S. B1 I+ x- ?% k, S* G  t. q1 m
(在下初学cadence,这个仿真问题确实弄了好几天没有找到解决方法,求大神帮忙解答,感激涕零。)
2 E0 @, ]5 V0 B3 u. U2 [
  i6 M5 f! k( x( S; c**** 12/18/15 18:43:33 ***** Pspice 16.6.0 (October 2012) ***** ID# 0 ********
% ^: T# e5 V2 }6 B1 m9 S** Profile: "SCHEMATIC1-01"  [ E:\work\simulation circuit\simulation circuit of me\test3-pspicefiles\schematic1\01.sim ]
& ~. F2 B+ E, Z9 n9 @8 z
( T! z! W5 _+ t. H****     CIRCUIT DESCRIPTION9 g5 a7 W( u8 v- \
8 ~+ ~* c0 Y$ x) ]5 X
1 Z' {+ o$ C$ g' I) |! C# K. \; h4 `/ x: s0 N! g+ F( d& I9 E% r
1 j4 }% g7 ^' b9 ~  i/ U** Creating circuit file "01.cir"
" z4 {% ^/ Q8 f' [: K' r! j** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS5 {9 u0 g8 N9 z+ O% |
*Libraries: / a8 M: @& b9 @0 L
* Profile Libraries :
" w) S4 ]9 V6 T& M: u* Local Libraries :' `4 c" X5 C! \1 l9 i6 k* E
.LIB "E:/work/PSPice/PSpice_Module/AD8045/ad8045.lib"
+ J: k; k% }( c, A+ z8 q2 z; j' l/ W.LIB "E:/work/PSPice/PSpice_Module/PBF951/pbr951.lib" 8 U+ I: k3 s" U8 ^
.LIB "E:/work/PSPice/PSpice_Module/bfg520_xr/bfg520xr.lib"
) d3 E5 V. j$ P# Z: K.LIB "e:/work/pspice/pspice_module/ada4610/ada4610.lib"
5 q  m1 k3 j1 M: B2 `' V.LIB "e:/work/pspice/pspice_module/bf998wr/m4.lib"
7 ?1 M6 C/ S, y. V; F" K* From [PSPICE NETLIST] section of C:\Users\Administrator\AppData\Roaming\SPB_Data\cdssetup\orcad_PSpice/16.6.0/PSpice.ini file:
1 d3 T4 W8 u$ F*Analysis directives:
) w0 m" H  B9 _, N.AC DEC 10 10Hz 100000000Hz
5 k( V7 j# ^& m/ c& X' W, }.OPTIONS ADVCONV0 J# R3 o. {+ O+ V% a/ `6 i$ x
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
: Z7 W7 q6 V4 w) w$ f. ]$: @. U$ c1 i. ]# R8 ]  H% j) Z0 D
ERROR(ORPSIM-16058): Command ignored" \, b7 W' z, c/ v$ g8 y: J- p. [7 {
.INC "..\SCHEMATIC1.net" % I4 h. ], S: r! Q, p
! B0 |1 A6 E2 I
**** INCLUDING SCHEMATIC1.net ****5 r4 A1 z& N6 Z6 E+ v% z
* source TEST3
! U6 `6 d+ ^& S4 p9 g% PX_U3         N22677 N22309 VCC VEE N22589 ADA4610
. L3 U# q: q# E3 f1 h9 YC_C9         N22335 N22327  1000p  TC=0,0
" P- E9 D7 T6 R* F2 ?, IX_M4         VEE N22683 VEE VEE BF998WR/PLP6 n: j9 ~, g3 g
R_R15         N22317 N22589  10k TC=0,0 ( Q3 g# v1 G0 m; B6 `0 Q
R_R16         0 N22677  500k TC=0,0 8 e4 ?% n: h  F$ u4 m% b3 N
R_R19         N22309 N22387  500k TC=0,0 9 i7 X1 @, C9 ^+ e
R_R20         0 N22309  500k TC=0,0
4 x) V" m7 b5 W$ H! _5 P* x+ QR_R18         VEE N22387  500k TC=0,0
" Q9 k0 U6 n) d1 lR_R13         N22677 N22335  500k TC=0,0
+ v% x& @3 F& Q) |$ [- Q3 wR_R14         N22589 N22327  10k TC=0,0
: g& V. ~' k( i0 u" ^* f" W" J- {X_M3         N22683 VCC N22327 N22327 BF998WR/PLP2 s4 ?$ Q, ]0 p; y; R/ U; l
R_R17         0 N22317  10k TC=0,0
! _. }' k  |4 z7 QV_V7         VCC 0 5Vdc
; g8 ?! L/ [( G0 v6 k3 e% A' aV_V8         0 VEE 5Vdc
# T3 Y/ N: v4 l( x+ m# d6 GC_C10         N22309 N22317  1000p  TC=0,0
, G- N3 v; M9 |9 r$ A! H  I) SC_C7         0 N35645  91p  TC=0,0 2 p# @' ~& o8 x& D, A$ O
V_V2         VCC3 0 5Vdc: g! i# Y* k$ B  P/ b* t) O1 j
C_C1         N35593 N35663  1p  TC=0,0 ; n- U1 ^( c9 m3 n1 e
C_C5         N35645 N35531  1p  TC=0,0 ! D2 v( [0 {% ]; z8 ?; N$ x
C_C2         N35531 N35663  10p  TC=0,0
% W( D2 v2 K* w8 O9 c  fC_C4         N66667 N35531  1p  TC=0,0 # a- l$ E+ j9 K$ [8 ]  z
V_V1         N35593 0 DC 0Vdc AC 10Vac
5 d2 ~0 c" `1 H& Q* F7 OC_C6         0 N35531  1p  TC=0,0
: n6 l: H1 k; I3 ~R_R2         N35593 N66667  680k TC=0,0 ' c- A5 c! @* N( e* k
R_R6         0 N35531  200k TC=0,0
- a- p, U: n# E1 B% C1 pR_R1         N35663 N35593  91 TC=0,0 9 W4 [, b5 E3 ?# ?( |/ j
R_R5         N35531 N35645  10 TC=0,0 4 j- w7 _$ q  d% N% p
V_V3         0 VEE3 5Vdc
/ a9 n. @' |7 U3 H8 wC_C14         N44706 N44772  1p  TC=0,0 : p- }. n0 C- e
C_C13         N44754 N44702  1p  TC=0,0 7 |  b0 E5 [( l* s( `2 ]# c
R_R24         N44702 N44754  10 TC=0,0
% t& e6 r/ H+ AC_C11         N44702 N44772  10p  TC=0,0
, F. r! R. F- ^/ U$ VR_R22         0 N44702  100k TC=0,0 ' Y, v/ F+ t% Q$ o, |/ f1 O
V_V10         N44706 0 DC 0Vdc AC 10Vac
1 t# {3 M8 m) UR_R23         N44772 N44706  91 TC=0,0 ' u" J1 z  r( ?7 C
C_C15         0 N44702  1p  TC=0,0 + L5 D% N7 v3 F
C_C16         0 N44754  91p  TC=0,0 8 c4 H/ b) b% F
C_C12         N44706 N44698  1p  TC=0,0
# P; m, I) s4 i3 tR_R26         N44698 N44702  220k TC=0,0 , ?0 \5 G% O' e' X
R_R25         N44706 N44698  680k TC=0,0
8 s6 c6 ^" m) cC_C17         N44698 N44702  1p  TC=0,0 $ z( \7 E1 C# ~' n
V_V9         N22335 0 DC 0Vdc AC 1Vac
/ B$ g" X* M0 S8 \X_U8         VCC N22683 N22387 PBR9514 w" g$ l8 A, j+ T$ d- q9 o
R_R34         0 N64836  100k TC=0,0 . b- }% e, @- I6 K, g
V_V13         N65556 0 DC 0Vdc AC 10Vac
: g; A1 s6 ?  W: i* l- e/ b/ dC_C25         0 N65078  1p  TC=0,0 - v# r/ h4 N& W( A3 L  ?! x
R_R39         N65606 N65556  90 TC=0,0 5 k4 l7 g/ P/ j7 s4 j5 i# J8 @
R_R28         N64854 N65118  100k TC=0,0 ) c% G: x3 K- }- V  t# }
X_M6         N65382 VCC4 N65084 N65084 BF998WR/PLP
, [3 f7 v$ B3 b: Q: _5 |R_R37         N65556 N65078  900k TC=0,0
# Z' w# |8 g2 tR_R29         0 N64854  100k TC=0,0
* a& V/ O! u; x  y, `2 iV_V11         VCC4 0 5Vdc$ H  V0 n+ [0 d, I" E
V_V12         0 VEE4 5Vdc
1 e1 k. X& g+ {C_C22         N65556 N65078  1p  TC=0,0
2 U+ v$ t: Q/ T9 mC_C21         N65078 N65606  10p  TC=0,0
+ `2 d4 H, l# Z2 y9 _3 ER_R33         N64836 N65078  100k TC=0,0 ; o+ Q0 p# S1 a6 c
R_R30         N64844 N65304  10k TC=0,0 ' S* e( x# a4 w- e: q' n+ r2 U& k7 S
C_C23         N65594 N65078  1p  TC=0,0 ; p9 O; }- y# D: v5 ^, k
X_U10         N64836 N64854 VCC4 VEE4 N65304 ADA4610 / M9 n5 A0 Q3 G+ R0 {- S4 g: t
R_R31         0 N64844  10k TC=0,0 ) U1 I* W7 n0 P% _, f. K5 E
X_U11         VCC4 N65382 N65118 PBR951* p! L: R' R5 j, a
C_C19         N64854 N64844  2p  TC=0,0 4 l4 i% [% t* A/ Q
R_R40         N65078 N65594  10 TC=0,0 # ?1 X% K$ [+ K8 C+ P" k  K6 {
C_C26         0 N65594  91p  TC=0,0 # k7 J' F. a7 O* |: l, i
C_C20         N65078 N65084  2p  TC=0,0 2 f6 W3 L+ ]( c+ d7 R6 I3 Z3 Y
X_M5         VEE4 N65382 VEE4 VEE4 BF998WR/PLP& a7 w5 A; p' h& z  A  ]0 n
R_R32         N65304 N65084  10k TC=0,0 : B. T2 b' A0 H  {1 O
R_R38         0 N65078  200k TC=0,0
6 L( {" m7 ?) m3 k4 [# U3 JR_R35         N64854 N64844  10000k TC=0,0
: e" K  B9 [" G, O6 U6 uR_R36         VEE4 N65118  1k TC=0,0
, x4 ~3 \6 a& l3 Q' g( n+ D# XC_C24         N65556 N65606  1p  TC=0,0 + ]0 O9 v6 n. U# o& b" y, f. h/ T/ n: \
R_R41         0 N35593  100 TC=0,0
" Z% ], t0 I. y3 [6 u9 SR_R42         0 N35593  100 TC=0,0
$ d& n& S0 U  ?4 X/ `! @0 R8 S8 QR_R43         N66667 N35531  220k TC=0,0 & X# u4 S; f4 S8 D" Z. X" V8 i
C_C27         N35593 N66667  1p  TC=0,0 " u& k. S& ?% l
R_R44         N68082 VCC3  1.1M TC=0,0 3 u3 G+ u$ }$ V* l) ~6 f
R_R45         N35531 N68082  1.1M TC=0,0
- J  M& y4 [1 U  U, j9 t- T! ^4 KX_U12         N35531 N71678 N71678 VCC3 VEE3 AD8045
. P6 {- G! T2 _. P.PARAM  rx=500k+ @5 F/ c$ \$ z0 L. g1 B- b
**** RESUMING 01.cir ****
9 A7 c9 ]- D$ c; `9 G5 z3 e$ J3 x.END
, {2 a' ~+ G9 P: D/ w! g( t& s" }/ L0 C) T2 J! H7 ^2 _
**** EXPANSION OF SUBCIRCUIT X_U12 ****
, Y0 [8 w' ^2 J3 ]: a1 M. wX_U12.RCM15 N35531 X_U12.105 10MEG
5 q9 x1 A4 @5 k+ ]! f% |/ QX_U12.RCM25 N71678 X_U12.105 10MEG9 T* F" e2 A& Y" ~$ ?6 ^
X_U12.EOS N35531 X_U12.92 POLY 1 X_U12.300 X_U12.100 0 1" l. O3 c8 h$ x, F/ S! g
X_U12.Q1 X_U12.5 X_U12.9 X_U12.7 X_U12.NPN2 A8 S5 f+ \/ p; p# n% t# |2 g
X_U12.Q2 X_U12.6 N71678 X_U12.8 X_U12.NPN& L2 {( R/ o5 o3 B: z
X_U12.RC1 VCC3 X_U12.5 537.15 T_ABS
8 S& w# n# S& q8 v------------------------------$, H# \7 X, p( M8 H* ^0 F
ERROR(ORPSIM-16145): unknown parameter
! H4 l: V" t' d
- p$ [* f* f" g4 S
发表于 2015-12-20 21:44 | 只看该作者
多谢多谢  详情 回复 发表于 2015-12-28 14:17
 楼主| 发表于 2015-12-28 14:17 | 只看该作者
jacklee_47pn 发表于 2015-12-20 21:44
# r  B3 s3 w( _5 X1 k# z5 w0 ^參考 https://www.eda365.com/thread-66309-1-1.html
& k+ O* x+ W0 W2 P多谢多谢
GMT+8, 2025-10-31 20:15 , Processed in 0.156250 second(s), 27 queries , Gzip On.
