电路是一个很简单的分压电路加一个运放,如下:
EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  % y$ ~1 n* A, n8 y
   - p0 I( c" x. G4 [, N1 x, H0 M运放选用的是ad8045,从网上下载的spice model文件,然后点击仿真,想要得到输出信号的频响曲线,因此仿真用的是交流扫频,没想到仿真结果如下:6 ~  ^8 `, {% N. \& \+ X
 3 R0 R2 \7 }9 R) w3 f(在下初学cadence,这个仿真问题确实弄了好几天没有找到解决方法,求大神帮忙解答,感激涕零。)4 ?: h( R5 D$ W9 \% @
 9 N- t1 c' @" o1 T) {! z**** 12/18/15 18:43:33 ***** Pspice 16.6.0 (October 2012) ***** ID# 0 ********
 0 `3 E5 N# O3 l7 M- x% [# p9 Z4 _ ** Profile: "SCHEMATIC1-01"  [ E:\work\simulation circuit\simulation circuit of me\test3-pspicefiles\schematic1\01.sim ] % u6 i* ^; N2 [
 % }" `/ O( f1 U2 R: e. X ****     CIRCUIT DESCRIPTION3 z% s7 t  n" s: d' S; u
 `$ n$ D( A0 }: v8 q******************************************************************************. I& I" n: \* R* T
 ; O! h9 S& w* M3 n1 P3 `1 O  {" p, a$ r7 a( ~9 F% D
 ** Creating circuit file "01.cir"
 4 S. e! W8 ?1 P, A. [) L# p** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
 0 @7 B' i% i* i( O& c( a* I) P) ?! M*Libraries: 7 V  G- N2 f0 \* \9 H
 * Profile Libraries :! F0 O# ~1 Q& D5 S, s+ [6 j
 * Local Libraries :
 9 C8 Y" [( P( N3 X5 h: }6 Y.LIB "E:/work/PSPice/PSpice_Module/AD8045/ad8045.lib" 6 R" i2 i  p2 u4 B- h
 .LIB "E:/work/PSPice/PSpice_Module/PBF951/pbr951.lib" ) y  l1 J" b  t) H/ ]
 .LIB "E:/work/PSPice/PSpice_Module/bfg520_xr/bfg520xr.lib" 7 c. z- S7 {9 S, v! k$ _2 p! ^; L+ T6 C
 .LIB "e:/work/pspice/pspice_module/ada4610/ada4610.lib"
 6 F! N- L" y: n* C1 X/ A) a.LIB "e:/work/pspice/pspice_module/bf998wr/m4.lib" * {4 a7 e- h4 I/ ], J6 z; _* d
 * From [PSPICE NETLIST] section of C:\Users\Administrator\AppData\Roaming\SPB_Data\cdssetup\orcad_PSpice/16.6.0/PSpice.ini file:
 6 W# r  J$ L: N$ W: }*Analysis directives:
 + D1 f+ A9 n5 r; w  W6 B1 S.AC DEC 10 10Hz 100000000Hz
 ( T. q/ D& b/ ^4 p$ o' h5 m5 B.OPTIONS ADVCONV& t2 p2 v& W, W: `2 h
 .PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
 \, ~7 b0 A2 D$4 a6 c# `- T* ]( ]) ^+ V0 u
 ERROR(ORPSIM-16058): Command ignored
 ) \) Z! J5 E, q' m8 k: h.INC "..\SCHEMATIC1.net"
 3 T/ `: ], N$ l0 M6 R7 g, n
 3 |* c6 j' r% k. w/ F& f**** INCLUDING SCHEMATIC1.net ****2 H3 R6 r) Q  s: R7 P3 T* C
 * source TEST3
 3 `  C: x! e1 pX_U3         N22677 N22309 VCC VEE N22589 ADA4610 2 g) u9 z) {& @1 m# o
 C_C9         N22335 N22327  1000p  TC=0,0
 4 _& l. K" S6 g% w$ oX_M4         VEE N22683 VEE VEE BF998WR/PLP
 4 u, ]1 h: |% X8 S$ d4 v2 i) ^R_R15         N22317 N22589  10k TC=0,0 ) A$ b3 k5 X3 C0 _- k) B
 R_R16         0 N22677  500k TC=0,0 4 ^  ]# J. C& W# ]2 s5 ~" D
 R_R19         N22309 N22387  500k TC=0,0 0 }& ^; r1 z' L3 U0 j
 R_R20         0 N22309  500k TC=0,0 ' T9 K& K( v0 `6 k- C
 R_R18         VEE N22387  500k TC=0,0
 5 [! |0 D* P# nR_R13         N22677 N22335  500k TC=0,0   N* M0 c7 q# b0 p0 ~
 R_R14         N22589 N22327  10k TC=0,0 ( p3 [+ _) e, w  {4 \: r* m
 X_M3         N22683 VCC N22327 N22327 BF998WR/PLP
 1 X: m/ u1 D  _- g1 T/ ?) M% s# ?" b/ NR_R17         0 N22317  10k TC=0,0
 1 M# L* o) L4 k3 w  _V_V7         VCC 0 5Vdc
 ! D5 o6 g3 I4 }V_V8         0 VEE 5Vdc" V& Y8 |: O0 A- O, ^
 C_C10         N22309 N22317  1000p  TC=0,0 1 |0 x( k$ g- @( d+ ~% N$ f1 F0 \9 e
 C_C7         0 N35645  91p  TC=0,0 5 b8 D5 z) F( A
 V_V2         VCC3 0 5Vdc5 v7 _, D8 l/ ]# \* N' V) N. j. G2 A1 U
 C_C1         N35593 N35663  1p  TC=0,0
 0 a0 N( X1 D! W7 O* rC_C5         N35645 N35531  1p  TC=0,0
 & S8 e; P( I; z1 eC_C2         N35531 N35663  10p  TC=0,0
 5 l( g& y/ Q2 k3 _C_C4         N66667 N35531  1p  TC=0,0
 : f& {. j" F4 L' N3 z. ^V_V1         N35593 0 DC 0Vdc AC 10Vac   h  B, a5 d. ]% d- H
 C_C6         0 N35531  1p  TC=0,0 + r, m, ^, m9 U/ h. Z2 l! l
 R_R2         N35593 N66667  680k TC=0,0 + i( k+ a: J- J( ^- b" V! F3 q
 R_R6         0 N35531  200k TC=0,0   H* k% m2 S% o6 x
 R_R1         N35663 N35593  91 TC=0,0
 % a8 p' U9 t& _& Y3 r  yR_R5         N35531 N35645  10 TC=0,0
 # h7 A6 i& s3 F4 JV_V3         0 VEE3 5Vdc; E( T. @9 y' t' d
 C_C14         N44706 N44772  1p  TC=0,0
 ! o3 c0 t5 ~5 @0 ^. d, WC_C13         N44754 N44702  1p  TC=0,0
 ( q: W7 |1 @, a& ]1 Z0 a4 S0 lR_R24         N44702 N44754  10 TC=0,0   m$ ?2 i" E# w/ c( _
 C_C11         N44702 N44772  10p  TC=0,0 % d# A( j0 k: o$ y) L6 O# u6 O
 R_R22         0 N44702  100k TC=0,0 + `5 v8 F7 K% E3 X$ `/ i
 V_V10         N44706 0 DC 0Vdc AC 10Vac 2 s, G4 Z6 ~3 i+ W. C) O
 R_R23         N44772 N44706  91 TC=0,0
 / Z% p) {) j6 A( A# ~6 pC_C15         0 N44702  1p  TC=0,0
 1 J0 q5 Z1 C" Y2 ]& r" L( dC_C16         0 N44754  91p  TC=0,0
 8 ~& x& k5 r4 ?: S! IC_C12         N44706 N44698  1p  TC=0,0 5 B/ d% n# R3 P. j% r' d
 R_R26         N44698 N44702  220k TC=0,0
 5 ^. f  p3 a3 R9 i* PR_R25         N44706 N44698  680k TC=0,0
 & r9 N5 T- J) k$ a! FC_C17         N44698 N44702  1p  TC=0,0
 $ ]5 Z; E4 R# y$ j4 A, c/ V' `V_V9         N22335 0 DC 0Vdc AC 1Vac ' @5 \9 j! t2 Y( ~
 X_U8         VCC N22683 N22387 PBR951
 + s7 F7 T, k7 [R_R34         0 N64836  100k TC=0,0 ! X( @* Z( z( y, g) C
 V_V13         N65556 0 DC 0Vdc AC 10Vac
 6 L: k. \$ n2 H0 M7 H7 TC_C25         0 N65078  1p  TC=0,0
 $ @5 [" s& y! m- }* {* F/ K2 b7 nR_R39         N65606 N65556  90 TC=0,0
 + _+ z9 V9 m* v! c# h7 YR_R28         N64854 N65118  100k TC=0,0 5 k4 Q6 c; b9 [
 X_M6         N65382 VCC4 N65084 N65084 BF998WR/PLP
 - K( o, s  M8 E. n8 d8 Y8 IR_R37         N65556 N65078  900k TC=0,0
 : O' S. Z' V* z6 J* c, E, u3 e( ]R_R29         0 N64854  100k TC=0,0 - ^8 m3 d. M( t& W/ \7 @6 m% m& B
 V_V11         VCC4 0 5Vdc( a2 r# b/ A8 m- X- i$ e
 V_V12         0 VEE4 5Vdc, ~! u2 T9 c8 a: u0 t2 O
 C_C22         N65556 N65078  1p  TC=0,0 : w9 B1 J; V! [, F) A9 y
 C_C21         N65078 N65606  10p  TC=0,0
 , Q$ W- Q2 K0 C$ d3 [6 ?R_R33         N64836 N65078  100k TC=0,0 7 h* u+ o) i, x% F% L8 \, m1 W% {& j
 R_R30         N64844 N65304  10k TC=0,0
 ; k3 s6 N" b9 V% u* z& T8 R9 V, j; BC_C23         N65594 N65078  1p  TC=0,0
 6 [8 b2 c6 M4 w9 D# mX_U10         N64836 N64854 VCC4 VEE4 N65304 ADA4610 8 N2 ~' d6 j" a% d; x- b
 R_R31         0 N64844  10k TC=0,0 - T! e" Y' L* c2 [: `" m
 X_U11         VCC4 N65382 N65118 PBR951
 + g2 z9 T/ E/ x* d7 V) @C_C19         N64854 N64844  2p  TC=0,0 . j2 Z/ _9 d1 F. v- T. w& w
 R_R40         N65078 N65594  10 TC=0,0
 1 R8 ~9 B% ~0 r! e- T1 YC_C26         0 N65594  91p  TC=0,0
 & M$ r: y: B% D" yC_C20         N65078 N65084  2p  TC=0,0 ' L6 H: p( @% t" Q5 u
 X_M5         VEE4 N65382 VEE4 VEE4 BF998WR/PLP
 0 ?, d9 t5 ?4 u* e6 c6 g6 D# MR_R32         N65304 N65084  10k TC=0,0
 / c* Y5 s4 y# e5 i: {R_R38         0 N65078  200k TC=0,0
 7 i2 H8 l9 A' n% A9 u3 \2 ~R_R35         N64854 N64844  10000k TC=0,0 & Q' R8 p* ]# G2 ]
 R_R36         VEE4 N65118  1k TC=0,0
 7 u0 b/ i% U$ ]. S3 L% q9 j- xC_C24         N65556 N65606  1p  TC=0,0 2 h5 R3 o* D9 Y6 _- z
 R_R41         0 N35593  100 TC=0,0
 " c7 Z) z) @# U. LR_R42         0 N35593  100 TC=0,0 ( \. _% Y8 C* O; T
 R_R43         N66667 N35531  220k TC=0,0 9 b1 x' n/ Z. u# f
 C_C27         N35593 N66667  1p  TC=0,0
 ! ^+ F2 s- g; i' M9 S9 c" dR_R44         N68082 VCC3  1.1M TC=0,0
 8 r  l4 Y! r, \1 ~R_R45         N35531 N68082  1.1M TC=0,0 0 \2 i$ v/ _8 d1 e" g1 m
 X_U12         N35531 N71678 N71678 VCC3 VEE3 AD80455 W8 F! T; G6 I- ?. f+ [
 .PARAM  rx=500k
 $ I0 Q* x/ W/ m3 Y6 X) t**** RESUMING 01.cir ****" j, S) D$ v$ a/ S- s
 .END4 M7 v% Z6 ^6 s& e
 . ]( z/ q6 {" }9 q
 **** EXPANSION OF SUBCIRCUIT X_U12 ****. X  _9 K: S0 N; i6 Z: o7 g
 X_U12.RCM15 N35531 X_U12.105 10MEG* T/ l; Y/ a5 `
 X_U12.RCM25 N71678 X_U12.105 10MEG9 W2 q8 [, t' W* `4 K8 ]- k
 X_U12.EOS N35531 X_U12.92 POLY 1 X_U12.300 X_U12.100 0 1
 $ x! y0 _: m1 T$ W  u  Z% QX_U12.Q1 X_U12.5 X_U12.9 X_U12.7 X_U12.NPN
 7 `4 e" q4 {1 _9 GX_U12.Q2 X_U12.6 N71678 X_U12.8 X_U12.NPN% [* N/ D# d& g  j4 U$ ]: s# r0 _% L$ C
 X_U12.RC1 VCC3 X_U12.5 537.15 T_ABS/ g0 p  g3 }: X( g
 4 |9 m6 z0 u6 [7 m  F- pERROR(ORPSIM-16145): unknown parameter% y( {) [' l! T0 N7 i
 " p$ I& q! k' S1 d% O
