查看: 4562|回复: 2
为什么画原理图时网络名不要太长的原因!!!
发表于 2008-9-28 11:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#1 Warning [ALG0047] "No_connect" property on Pin "U501.16" ignored for U501: P545_C01, 24 - NVVDD Power Supply (5.90, 6.40). Connecting pin to net "PGOOD".4 M; g) o! R. r1 f
Diff Pair DRC check Warnings:% c. s0 L' W) M( S) I1 P% z
Differential pair NVVDD_SENSE_GPU has only one net NVVDD_SENSE_GPU associated with it. A valid differential pair must have two nets associated with it.
4 S! V1 a( L1 L& FDifferential pair PEX_PLL_CLK_OUT has only one net N06381 associated with it. A valid differential pair must have two nets associated with it.
& ~  J. D2 S( z* P& c+ h$ l. ADifferential pair PEX_TX3 has only one net PEX_TX3 associated with it. A valid differential pair must have two nets associated with it. , z0 j  l7 x4 M) X' z6 M3 y
Differential pair PEX_TX4 has only one net PEX_TX4 associated with it. A valid differential pair must have two nets associated with it. # Q: k3 P4 c  u, x1 g3 E
Differential pair PEX_TX5 has only one net PEX_TX5 associated with it. A valid differential pair must have two nets associated with it. 1 s5 z4 d; u8 I. t2 Q$ U
Differential pair PEX_TX6 has only one net PEX_TX6 associated with it. A valid differential pair must have two nets associated with it.
% b7 [# l) r+ |- A1 x3 [! Y#2 Warning [ALG0016] Part Name "C_POL_0_SMD_7343_NC/330UF/2.5V_20%" is renamed to "C_POL_0_SMD_7343_NC/330UF/2.5V_".+ z0 c  v6 F+ B
#3 Warning [ALG0016] Part Name "CON_MIO_26_D_0_CON_FINGER_MIO_026_D_CON_MIO_26_D" is renamed to "CON_MIO_26_D_0_CON_FINGER_MIO_0".) k# t+ g( W8 ]5 w% E* z
#4 Warning [ALG0016] Part Name "CON_PCI_EXPRESS_0_NONPHY-X16-B_CON_PCI_EXPRESS" is renamed to "CON_PCI_EXPRESS_0_NONPHY-X16-B_".7 E. z7 T" x- Q" X( ]- H
#5 Warning [ALG0016] Part Name "PAECD3P_0_PAECD3P59_NC/470UF/16V" is renamed to "PAECD3P_0_PAECD3P59_NC/470UF/16".
& [2 P' e% Z0 V6 r#6 Warning [ALG0016] Part Name "U_GPU_GB1_0_BGA_1504_P080_350X350_U_GPU_GB1_256" is renamed to "U_GPU_GB1_0_BGA_1504_P080_350X3".
; `7 M: E' ~) Z( C$ v. W2 I#7 Warning [ALG0016] Part Name "CON_DSUB15HD_0_VGA_SLIM_CON_DSUB15HD" is renamed to "CON_DSUB15HD_0_VGA_SLIM_CON_DSU".  Y6 r. D% ]4 j" i8 B* q& y6 L
#8 Warning [ALG0016] Part Name "CON_MINIDIN_0_7P_COMP_10P_CON_MINIDIN_7" is renamed to "CON_MINIDIN_0_7P_COMP_10P_CON_M"./ e6 r4 A# n# y& D5 A' ^
#9 Warning [ALG0016] Part Name "CON_DVI_I_2_DVI_I_SLIM_SHLD_M_CON_DVI_I" is renamed to "CON_DVI_I_2_DVI_I_SLIM_SHLD_M_C".% Q, A8 R: Y: n/ x0 w! t
#10 Warning [ALG0016] Part Name "DIP INDUCTOR 1UH_0_PALB1806_FB60R" is renamed to "DIP INDUCTOR 1UH_0_PALB1806_FB6"., h" V% M6 L# K) ^
#11 Warning [ALG0016] Part Name "L_0_MULTI_IND_SMD_150X135_NC/1UH_20%" is renamed to "L_0_MULTI_IND_SMD_150X135_NC/1U".
- Q" G8 o: a8 x6 ]+ x- c#12 Warning [ALG0016] Part Name "[email=L_1_BEAD_0603_180R@100MHZ_+/-25%]L_1_BEAD_0603_180R@100MHZ_+/-25%[/email]" is renamed to "[email=L_1_BEAD_0603_180R@100MHZ_+/-25]L_1_BEAD_0603_180R@100MHZ_+/-25[/email]".
8 I, W2 t" B' T#13 Warning [ALG0016] Part Name "INDUCTOR IRON_0_AS1R0-01_1.0UH/35A" is renamed to "INDUCTOR IRON_0_AS1R0-01_1.0UH/".7 d) V9 _* c7 T7 A" Z
#14 Warning [ALG0016] Part Name "INDUCTOR IRON_0_AS1R0-01_1.0UH/30A" is renamed to "INDUCTOR IRON_0_AS1R0-01_1.0U_1".+ N5 Z  ?6 s7 R* k6 t7 P- _
#15 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#4_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#4" is renamed to "U_MEM_SD_DDR3_X32#4_0_BGA080_12".
3 |- Q) A2 R1 H7 ?, `7 l3 F#16 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#3_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#3" is renamed to "U_MEM_SD_DDR3_X32#3_0_BGA080_12".( y4 R, O; C! Z" ~2 S
#17 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#6_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#6" is renamed to "U_MEM_SD_DDR3_X32#6_0_BGA080_12".+ f# ]  @; o" b! A& I
#18 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#5_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#5" is renamed to "U_MEM_SD_DDR3_X32#5_0_BGA080_12"." [0 Z* W( w* c. m$ |
#19 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#2_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#2" is renamed to "U_MEM_SD_DDR3_X32#2_0_BGA080_12".
6 u+ V; ~# R' Y#20 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32" is renamed to "U_MEM_SD_DDR3_X32_0_BGA080_12X1".; F0 u& _$ g, \, `
#21 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#1_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#1" is renamed to "U_MEM_SD_DDR3_X32#1_0_BGA080_12".+ x1 x3 L3 D6 ~, V
#22 Warning [ALG0016] Part Name "U_MEM_SD_DDR3_X32#7_0_BGA080_12X14-136_1_2H_U_MEM_SD_DDR3_X32#7" is renamed to "U_MEM_SD_DDR3_X32#7_0_BGA080_12".
9 @$ E0 W. c* R8 |  H! u3 n#23 Warning [ALG0016] Part Name "Q_FET_N_ENH#1_0_SOT23_Q_FET_N_ENH" is renamed to "Q_FET_N_ENH#1_0_SOT23_Q_FET_N_E".
( J+ @+ r/ ~/ W% V* o- ^#24 Warning [ALG0016] Part Name "PASOT223P4_0_PASOT223P3_STD70NH02L" is renamed to "PASOT223P4_0_PASOT223P3_STD70NH".( J6 }# D- L2 q" k- W5 o3 p
#25 Warning [ALG0016] Part Name "PASOT223P4_0_PASOT223P3_STD17N03L" is renamed to "PASOT223P4_0_PASOT223P3_STD17N0".) l! C+ B9 O/ h0 ?4 H
#26 Warning [ALG0016] Part Name "PASOT223P4_0_PASOT223P3_STD1703LT4" is renamed to "PASOT223P4_0_PASOT223P3_STD1703".
  C. q7 g2 i+ e8 A2 r( t#27 Warning [ALG0016] Part Name "Q_FET_N_ENH#1_0_SOT23_1G1D1S_Q_FET_N_ENH" is renamed to "Q_FET_N_ENH#1_0_SOT23_1G1D1S_Q_".
7 X* H) [, R7 D. R) T; T#28 Warning [ALG0016] Part Name "IC LX8211 SOT23-5_SOT23P5_RT9179" is renamed to "IC LX8211 SOT23-5_SOT23P5_RT917".& `. Y: J- l0 g; h* \3 h# y
#29 Warning [ALG0016] Part Name "U_SHNTREG_TL431_0_SOT23_VR=1.240V_2%" is renamed to "U_SHNTREG_TL431_0_SOT23_VR=1.24".
  b% {) C0 _; o% z6 T. z#30 Warning [ALG0016] Part Name "U_SWREG_RT8805_0_QFN024Q_P050_I0179_TI108X108_VR=0.8V_1%" is renamed to "U_SWREG_RT8805_0_QFN024Q_P050_I".# Z) _, Z, `6 ^9 W8 }" i( y
#31 Warning [ALG0016] Part Name "U_SWREG_ISL6549_0_ASSO14_VR_SW=0.8V, VR_LD=0.8V_1%" is renamed to "U_SWREG_ISL6549_0_ASSO14_VR_SW=".* B0 @5 r1 M1 G* q+ [1 t
#32 Warning [ALG0016] Part Name "U_MEM_FL_SER_0_SO8_U_MEM_FL_SER_128KX8" is renamed to "U_MEM_FL_SER_0_SO8_U_MEM_FL_SER".$ c; _, M. j0 a  A* i
#33 Warning [ALG0016] Part Name "U_MEM_EE_CRYPT_0_SO8_U_MEM_EE_CRYPT_8X128" is renamed to "U_MEM_EE_CRYPT_0_SO8_U_MEM_EE_C".
# x. R& P" t# j. k6 l. S7 x#34 Warning [ALG0016] Part Name "N-CH MOSFET_4P_TO252_1_PASOT223P3_AZ78M05DTR" is renamed to "N-CH MOSFET_4P_TO252_1_PASOT223".
/ Z5 S, h' W: H& a; l. Z) b( I这个是刚导网表的记录,虽然都只是警告而已
; Y; I3 v8 B! U) S2 A6 W$ ]如果有二个网络名的前31个字符相同后几个字符恰巧是区别这两个网络的话那就出问题了,从上图可以看出系统自动重命名取前31个字符作为当前的网络名
" t4 _! ?4 q0 A7 j. S6 O7 ~6 l不知怎么讲了,反正网络命名是规范一点就保险.
发表于 2008-9-28 11:14 | 只看该作者
对于没有命名的网络名,软件自动命名。默认的为31个长。
 楼主| 发表于 2008-9-28 11:21 | 只看该作者
没有网络的怎么会有网络名呢???
GMT+8, 2025-11-5 21:07 , Processed in 0.156250 second(s), 24 queries , Gzip On.
