查看: 20056|回复: 90
Hotfix_SPB16.60.061 (1.7G)包括最新破解程序!好不容易得到的资源!分享给大家!
发表于 2015-12-3 09:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# ~% I# c* W2 ?
补丁包更新列表!# m2 G/ \0 e6 U% [3 x
9 _2 i1 Q. P, J
DATE: 11-20-2015   HOTFIX VERSION: 061
8 h( B4 l" G" f, R===================================================================================================================================! J. M. G0 h8 n1 K3 X, S
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE7 s8 O: ?: ~2 W- M
===================================================================================================================================; E& Q2 q4 _+ q" F3 f# S
1306441 APD            OTHER            The Minimum Shape Area option in Layer Compare uses an unspecified value
) K# M" x+ }6 g4 b3 c1342644 ADW            COMPONENT_BROWSE Need directive or method for Component Browser to load a search criteria file upon init& V. Y8 K0 k+ o5 m  d$ e3 I
1413248 concept_HDL    CORE             Import from another TDO project makes the block read-only1 V, t) l  r* x1 y' Q
1417429 allegro_EDITOR INTERACTIV       Pick box only accepts 1 set of values. You need to close the box and reopen it to draw a rectangle
1 u( d3 p" e4 e1417442 ALLEGRO_EDITOR INTERACTIV       Spin via stack and only part of the stack spins; h! ^9 H% f& U# P5 s" x5 C
1451977 CONCEPT_HDL    PDF              Origin of PDF mediabox not starting at (0,0) when PDF page_height and page_width are set
4 s" |8 {; ~# M$ S/ r4 W1453527 ALLEGRO_EDITOR EDIT_ETCH        Contour route hugs the outer edge of the route keepin3 U' C2 r3 h( V2 ?! i# M
1464948 PCB_LIBRARIAN  VERIFICATION     The errors/warnings do not match between the various tools9 i$ W- z2 |, T: w# f+ w1 x
1467826 CONCEPT_HDL    PDF              PublishPDF from Console Window creates a long PDF filename3 L& Q+ \/ _/ W- c  |9 U( _- r
1478639 CAPTURE        OTHER            Capture Browse Nets window does not display all nets9 d+ ^: K8 o! s' {) U
1479177 SIP_LAYOUT     OTHER            Pin pair constraints do not appear to be supported in Sip Layout XL
! e6 s0 n9 }- u& |, C$ f  Z1479227 CONCEPT_HDL    CHECKPLUS        Custom DE-HDL Rules Checker rule flagging invalid voltage in hierarchy
) ^% \1 Y7 c4 [1479454 CONCEPT_HDL    OTHER            DE-HDL issue: locked DIFF_PAIR property is editable% J( Y( W/ \$ D
1480293 CAPTURE        PROJECT_MANAGER  Capture hangs when searching for all nets4 n3 |5 x$ Z: @5 I. L# {
1483894 CONCEPT_HDL    CORE             Import Design hangs when pull-down arrow is clicked twice
3 e, Q7 \6 b4 B  T9 X1484781 CONCEPT_HDL    CORE             Three different Hierarchical Viewer issues: j8 T' M  v, Z5 O7 {$ S; X
1485059 PCB_LIBRARIAN  CORE             Part Developer pin attributes are randomly marked as read-only
* W( ?. P/ S9 [4 B1485960 CONCEPT_HDL    CHECKPLUS        Custom DE-HDL Rules Checker rule is crashing the project* b: n8 n6 p% V; `, c
1486086 ALLEGRO_EDITOR ARTWORK          Cannot generate artwork.; [# w& T. _$ F2 }2 t  R, r6 t! J1 v. X
1486834 CONSTRAINT_MGR OTHER            Restore the Status column in cmDiffUtility/ n7 n. R5 U3 p5 f( P$ Q# ]0 K
1487085 CONCEPT_HDL    CONSTRAINT_MGR   Import Physical with the Constraints only option reports problems1 k1 u3 S: \/ i9 M  o% L" K8 `/ P
1487197 ALLEGRO_EDITOR DRC_CONSTR       Drill to Via DRCs are not being reported
% i3 ?- M' J. x* k5 E2 @1487265 CONCEPT_HDL    CORE             Replace command in Windows mode shows incorrect behavior2 A* i6 q7 H3 Z5 v5 A+ h
1487733 CONSTRAINT_MGR OTHER            Running Export Physical - It takes over two hours to update the PCB Editor board
- f2 \9 j: A( b4 S1488758 CONCEPT_HDL    CONSTRAINT_MGR   CM_VALIDATION_ON_SAVE should be a hard stop on Constraint Manager5 Q! y8 `; V" ^
1490299 SCM            OTHER            ASA does not update revision properly
& A0 t1 F2 |0 R( T  ]4 Y1490744 ALLEGRO_EDITOR skill            axlChangeLine2Cline changes line to cline and places it on the TOP layer
. j, Z6 S# z2 [; @' J1490924 F2B            PACKAGERXL       Save Design/Export Physical is resetting Via constraints8 ^4 }6 |+ A% _+ z9 z7 a6 U
1491351 ALLEGRO_EDITOR OTHER            Create Detail for bond fingers on a custom layer not working
% z7 ~, N2 a' X* u/ k1492595 ALLEGRO_EDITOR MANUFACT         Dimension character substitution help is wrong
9 q& O( u% T% N& O1 k; n1492777 ORBITIO        ALLEGRO_SIP_IF   OrbitIO import of customer mcm results in crash
  Z# v* i) S6 T" _, b+ J! r1492901 CONCEPT_HDL    CORE             Cannot instantiate a multi-sections symbol (> 10 versions) in Design Entry HDL
# P) B6 h: h' W# g1495621 ALLEGRO_EDITOR INTERFACES       Oval pins are placed with wrong orientation in IPC2581( [! l/ z. U! X% |' {
1497597 ALLEGRO_EDITOR DATABASE         Show Element on pin shows wrong drill size5 `3 i9 O8 R0 \* u+ a0 ?
1497956 CONCEPT_HDL    CORE             ADW Library Flow test schematic generation crashes DE-HDL while saving the design when using customer adw_conf_root
1 Y6 r6 g8 V; K' e# x% y& S/ `1498234 ALLEGRO_EDITOR ARTWORK          PCB Editor fails to create artwork and no error is listed in the log file( Y7 ^1 n  _" `9 [' @* w! [' Y5 R$ d$ q
1499363 CONCEPT_HDL    CORE             Custom attributes under variant management stopped working in Hotfix60
1 |7 c2 U0 t+ g
1 u) m: _  Z. K  ?5 x8 K" i% O. @5 H1 p* G- f
) b! Q. H8 s! d$ h- N8 Q最新破解包列表!
, J6 [+ s& W3 E5 ]------------------------------------------------------------------------------
( v' b6 {/ p4 @7 v$ _) h" g6 H& wSPB 16.6   UPDATED KITS RELEASE: ISR 16.60.061    EST.DATE:  11-20-2015
5 F; g. K8 N5 V7 B; [------------------------------------------------------------------------------; X: d' P9 j) p6 g% ?) P* c! z
CompBrowser16.60-s037wint
; p, ]2 \# ^# p/ q2 |& W( w1 mDSCoreUtils16.60-s077wint
1 X) ~+ S- H" ~* E, }! vDSCore16.60-s055wint, p. s. H; ~& r: c% K8 Y9 C6 K
DSSchgen16.60-s030wint
4 F2 M% @" A3 O9 c5 O# zDSSetup16.60-s010wint0 \0 \4 A. p/ d' [8 i! N1 Q9 l
DSTableEditor16.60-s018wint0 {: p2 b2 I. @* X7 i
DSTextEditor16.60-s015wint
$ f+ U. U4 P+ Z; z: O% c' w2 z# KDSUICommonIndep16.60-s0193 g) n7 i3 S, n& ~: ^% K! n
DSUICommon16.60-s026wint
/ a; I3 M% D: W  o& JDSUIUtils16.60-s037wint5 P4 U' ]4 l- o8 H+ i" o3 J
SPBIX06116.60-p002wint
" d# w, x: Z$ ~0 D  wadpPDFLibs16.60-s033wint
# I0 p; G8 k$ K" L1 _advanPakgDsnr16.60-s129wint
  z+ ?9 Q# B  n& @adwLRM16.60-s033wint; t0 S; F' H. z3 l
adwSDM16.60-s044wint' ]5 o; u8 r; Q7 E+ A% k
algroAcad16.60-s122wint: T  o- X7 y; H. O' q2 F7 H# y) {' o
algroArtwork16.60-s122wint
: [% Z& ~. z' [8 ~4 UalgroAxl16.60-s048
  u7 a" M. \2 f: h% palgroBase16.60-s129wint
9 g' u) {% G; L2 _1 m+ t1 TalgroCxt16.60-s077& `6 m, [* e4 g( e- b9 ~0 i; |
algroDBTools16.60-s124wint
8 E$ B: s9 e& m3 c( e) |4 N1 nalgroDsign16.60-s122wint
4 a9 ]- v" y) yalgroF2B16.60-s122wint7 P# o6 z( r% ^2 d! ^$ W' |' ]
algroIDF16.60-s122wint. h2 Y" m, G6 q* @. W* T+ U+ L9 Z
algroIgin16.60-s122wint% \8 h; z3 g( J1 X" H) _  W( a
algroIgout16.60-s122wint
5 ?/ j  e8 |/ p) a1 B6 v4 y0 ZalgroIpc16.60-s122wint3 d( ^0 \& J: F* e* k6 n# ^) P
algroMfg16.60-s122wint
2 M: H( ~8 ]% \* PalgroNetin16.60-s122wint" b4 O. u- Z' u& f4 d
algroPlace16.60-s122wint4 x% k& f7 R4 N5 t7 V6 k- ^
algroSgnse16.60-s122wint
$ ]9 l8 N! b4 j& }$ E/ {& N* H5 EalgroSpif16.60-s122wint
$ V& M1 K' ~+ b5 D" JalgroStrm16.60-s122wint# T( A, j6 W- f* Z/ Y6 b6 ~
algroTextIndep16.60-s089
; C) a* b' ]% E8 S, l3 [algroTransltr16.60-s121wint7 ]/ r4 e( |, S& j+ [& e
algroUtlty16.60-s122wint, Y& B* S$ t! i8 [$ Q
bom16.60-s030wint
0 J. z3 J. O1 x' N  j0 Z$ fcapPSpLibMAB16.60-s018wint
& d$ H5 [' s4 e1 K$ d; W) t$ lcapProg16.60-s044wint
0 b9 w2 F" E* B, S$ @' Qcheckplus_exp16.60-s023wint: b% H; o6 f) X, M! r
conceptNT16.60-s106wint" G* U/ q" K. [! G- S  s; g/ j9 c- q
concptSetup16.60-s015wint
& ^6 t6 `7 t- v& \3 a3 C% U8 ~consMgr16.60-s104wint  s1 u- m) _* @; J' J8 ?+ X
desSync16.60-s019wint# h( n) O& h: B3 O5 g2 V, E# O
eCWCore16.60-s009wint
7 J; N: D( L% O$ S; KfetBase16.60-s034wint
' ~& t$ m& v0 r8 \icpCommon16.60-s122wint
! S: I0 t& U; r* G+ }: Niff2hdl16.60-s010wint1 H0 B- j; f' h- j5 F" d
lmancore16.60-s036wint
! i" H' s6 a7 M5 nlmanext16.60-s012wint
  A/ d8 `, I. ^* ^  ^, Zlman16.60-s023wint3 n5 ]( n" \: i
productServer16.60-s084wint) X/ e1 w$ t$ [" @4 O9 ^3 u" l
projMgr16.60-s015wint
2 b' v6 e9 ?' a: FpspProg16.60-s043wint
4 t% z* F  @0 Yrfpcbfe16.60-s026wint6 f& z  y1 j% m7 @! o8 w& q
rfsipPcellIndep16.60-s005
  p7 r. W% \% a" c3 B3 PsipDsnr16.60-s128wint
+ `5 r) @5 v; p8 U& R" mspbFPGAPlanner16.60-s065wint
$ @4 G8 r+ \1 N0 ?specctraQuest16.60-s122wint
. Y1 f2 U8 b: ospgSignal16.60-s123wint
7 ]5 B/ c* t5 P  c$ [6 pvedit16.60-s043wint& k7 p8 g6 G# D
4 n9 A7 v( X1 A: P4 B补丁包种子!
7 m3 h8 o- A, m1 ~4 B7 ~$ Q1 S cadence.spb.orcad.16.60.061.hotfix.rar (17.88 KB, 下载次数: 1069) & f, U$ a2 W; b6 G) u1 D* y3 ^" ~
; Y+ X+ ?7 |2 K! z9 _! e
. D9 I$ w7 w2 o- j( g, ?9 _) ^
, Z% O- L  ~5 G" W- B) D3 B
推荐
发表于 2015-12-3 15:25 | 只看该作者
XYX365 发表于 2015-12-3 13:04
: a9 @9 p4 G" b5 j4 S下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.
4 y( y7 @1 @* G  J/ u1 k8 H噢噢噢,发现了,Allegro_PCB_Productivity_TB 早就XX了,只是当时没有切换license的原因,没有用那个Performance L 模式,我说怎么回事。群众力量大哈! L- r/ D9 S! t6 h! Q
推荐
 楼主| 发表于 2015-12-3 15:31 | 只看该作者
7 Q$ W2 S9 t5 l下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.
! p- {. c" a" \3 ?' k/ r 我加入了你的代码?问什么还是没有出现TB这个选项?补丁已经是最新的61号!
1 y2 D4 ^; V" Q1 \2 o
你再執行LicenseServerConfiguration.exe程式後,指定license.lic試試看.  详情 回复 发表于 2015-12-3 16:34
推荐
发表于 2015-12-3 16:34 | 只看该作者
crskynet008 发表于 2015-12-3 15:31! w' O/ T& r* P2 T
" e& l6 b8 ?' W  ?( Z
你再執行LicenseServerConfiguration.exe程式後,指定license.lic試試看./ O! o) k. K0 i$ j( f
发表于 2015-12-3 09:51 | 只看该作者
大爱,感谢分享
发表于 2015-12-3 10:03 | 只看该作者
楼主威武啊
发表于 2015-12-3 10:13 | 只看该作者
好东西,谢谢分享
发表于 2015-12-3 10:18 | 只看该作者
能分享到百度网盘上吗,我用迅雷下载好慢啊
用迅雷会员下载很快!  详情 回复 发表于 2015-12-3 10:38
发表于 2015-12-3 10:23 | 只看该作者
什么叫最新破解程序?可以XX掉toolbox吗
下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.  详情 回复 发表于 2015-12-3 13:04
你试试就知道了!呵呵  详情 回复 发表于 2015-12-3 10:38
 楼主| 发表于 2015-12-3 10:38 | 只看该作者
mengshang 发表于 2015-12-3 10:18
3 v3 L  h; \0 |7 h: i9 u2 s能分享到百度网盘上吗,我用迅雷下载好慢啊
4 K% d( O, g7 ?) t& X2 z$ z3 X  ?用迅雷会员下载很快!
0 r+ ]. |% t0 W2 {7 R  L' s2 v
Soarphys 发表于 2015-12-3 10:23! Q% e& S3 c, }+ W% F
1 x4 @( v; {% ^  [9 A
你试试就知道了!呵呵
$ N& O6 r: a/ j, m% ^7 |( ]. |
发表于 2015-12-3 13:04 | 只看该作者
Soarphys 发表于 2015-12-3 10:231 _$ u2 o% w0 u' H2 N0 O- }$ G- i
  W; G# T; J2 g+ N下載的src.lic裡面沒有toolbox的license,必須加入我給的license,才可以使用.5 d& s: Y- k$ d3 T
LIC在哪里下载啊  详情 回复 发表于 2016-11-23 17:52
求分享完整地许可文件,感谢啊  详情 回复 发表于 2015-12-5 11:12
[attachimg]105564[/attachimg] 我加入了你的代码?问什么还是没有出现TB这个选项?补丁已经是最新的61号!  详情 回复 发表于 2015-12-3 15:31
噢噢噢,发现了,Allegro_PCB_Productivity_TB 早就XX了,只是当时没有切换license的原因,没有用那个Performance L 模式,我说怎么回事。群众力量大哈!  详情 回复 发表于 2015-12-3 15:25
GMT+8, 2025-11-5 17:16 , Processed in 0.203125 second(s), 29 queries , Gzip On.
